I am using Robohelp 6 to create CHM file. Running Windows XP,
SP3
I defined Glossary entries, enabled glossary in Default
window, made sure that HHActiveX.dll is registered.
Viewing CHM file does not show any entries in Glossary panel.
Both "Term" and "Definition for" sections are empty
NOTE: Viewing WebHelp as primary layout shows Glossary
entries.
Problem on all systems are tested. 2 XPs and 1 Vista
HHActiveX.DLL is registered. This is the first thing I
checked. If not registered Glossary Panel is very different.
You say the glossary panel is "very different" if the
hhactivex.dll is not registered. Can you elaborate for us as having
a blank glossary can't get more different!
Does the glossary display on your PC (presuming you have
RoboHelp installed)?
