2 Replies Latest reply on Jun 9, 2017 6:06 AM by mikeb41294032
    Script who can check for missing font
    runew73276507
      In this script for use in InDesign CS3:
      var doc = app.documents[0];
      var mExitFlag = false;
      var mTextFrames = doc.textFrames;
      for(var i = 0; i < mTextFrames.length; i++){
          if (mTextFrames[i].parentStory.overflows && checkIfOnPage(mTextFrames[i]) && mTextFrames[i].itemLayer.visible == true){
              alert('To much text' )
              mExitFlag = true;
      var mLinks = doc.links;
      for(var i = 0; i < mLinks.length; i++){
          if ((mLinks[i].status == LinkStatus.LINK_MISSING || mLinks[i].status == LinkStatus.LINK_OUT_OF_DATE) && checkIfOnPage(mLinks[i].parent.parent) && mLinks[i].parent.parent.itemLayer.visible == true ){
              alert('Missing or not updated link' );
              mExitFlag = true;
      if(mExitFlag){
          exit();
      function checkIfOnPage(mItem){
          var _OldZeroPoint = app.activeDocument.zeroPoint;
          app.activeDocument.zeroPoint = [0,0];
          var _Width =app.activeDocument.documentPreferences.pageWidth;
          var _Height=app.activeDocument.documentPreferences.pageHeight;
          var _Bounds = mItem.geometricBounds;
          if ((_Bounds[3] < 0)  || (_Bounds[1] > _Width) || (_Bounds[0] > _Height) || (_Bounds[2] < 0)){
              return false
          }else{
              return true
          app.activeDocument.zeroPoint =_OldZeroPoint;
      var doc = app.activeDocument;
      var _PDFExportPreset = app.pdfExportPresets.item('NewspaperAds_1v4_IND4');
      if (_PDFExportPreset == null){
         alert('Preset missing');
         exit();
      var _DocName = doc.name.replace(/\.indd/, "");
      var _EndNumber = parseInt(_DocName.match(/\d{3}$/),10); /* extract end number */
      /* test if is a number */
      if (isNaN(_EndNumber)){
          alert('End document name is not a number');
          exit();
      I also would like it to check for missing fonts - is that possible?
