2 Replies Latest reply on Mar 2, 2016 10:30 AM by iane54858309
    How do I Populate a nested DataGrid dataProvider inside the cell of a dataGrid
    iane54858309
      <s:DataGrid id="aGrid"
                          textAlign="center"
                          width="100%"
                          dataProvider="{newArray}"
                          gridClick="handleClickEvent(event)">
           <s:columns>
                <s:ArrayList>
                          <s:GridColumn dataField="mN" headerText="MN" editable="false"/>
                          <s:GridColumn dataField="sN" headerText="SN" editable="false"/>
                          <s:GridColumn dataField="sC" headerText="OC" width="65" editable="false"/>
                          <s:GridColumn dataField="sN" headerText="NC" width="65" editable="false"/>
                          <s:GridColumn dataField="sInfo" headerText="Title goes here" width="300" editable="false">
                          <s:itemRenderer>
                                  <fx:Component>
                                      <s:GridItemRenderer>
                                          <s:DataGrid id="sGroup"
                                                      horizontalCenter="0"
                                                      width="100%"
                                                      dataProvider="{parentApplication.sGI}"
                                                      initialize="sGroup.columnHeaderGroup.height=0">
                                              <s:columns>
                                                  <s:ArrayList>
                                                      <s:GridColumn dataField="ssN" headerText="" width="150"/>
                                                      <s:GridColumn dataField="ssC"  headerText="" width="74"/>
                                                      <s:GridColumn dataField="ssNC" headerText="" width="74"/>
                                                  </s:ArrayList>
                                              </s:columns>
                                          </s:DataGrid>
                                          <fx:Script>
                                              <![CDATA[
                                                  import mx.rpc.http.HTTPService;
                                                  import mx.rpc.events.FaultEvent;
                                                  import mx.rpc.events.ResultEvent;
                                                  import flash.events.*;
                                                  import spark.events.*;
                                                  import mx.controls.*;
                                                  import mx.collections.*;
                                                  import mx.utils.ArrayUtil;
                                                  import mx.core.FlexGlobals;
                                                  import mx.managers.PopUpManager;
                                                  import mx.events.*;
                                                  import mx.utils.ObjectUtil;
                                                  public function handleClickEvent(event:GridEvent):void
                                                      var tempObj:Object = event.grid.dataGrid.dataProvider;
                                                      Alert.show(ObjectUtil.toString(tempObj));
                                                      event.grid.dataGrid.dataProvider = parentApplication.sGI;
                                                      Alert.show(ObjectUtil.toString(parentApplication.sGI));
                                                      Alert.show(ObjectUtil.toString(sdlGroup.dataProvider));
                                                      var tempObj2:Object = new Object();
                                                      tempObj2["ssC"]    = 1;
                                                      tempObj2["ssN"]   = "name";
                                                      tempObj2["ssNC"] = 2;
                                                      parentApplication.sGI.addItem(tempObj2);
                                          </fx:Script>
                                      </s:GridItemRenderer>
                                  </fx:Component>
                              </s:itemRenderer>
                          </s:GridColumn>
                          <s:GridColumn dataField="tx" headerText="TX" editable="false"/>
                          <s:GridColumn dataField="txc" headerText="TXC" width="65" editable="false"/>
                          <s:GridColumn dataField="txnc" headerText="TXNC" width="65" editable="true" itemRendererFunction="testFunction"/>
                      </s:ArrayList>
                  </s:columns>
              </s:DataGrid>
        • 1. Re: How do I Populate a nested DataGrid dataProvider inside the cell of a dataGrid
          iane54858309 Level 1
          Accidentally submitted the above question without a question!  Given the above mxml, containing a nested dataGrid, any ideas on how to populate the nested dataGrid's dataprovider? I have tried a few things inside the gridClick function just as a test. But the Alert shows the nested dataGrid dataProvider as null everytime. sGI is a public bindable array collection.
          • 2. Re: How do I Populate a nested DataGrid dataProvider inside the cell of a dataGrid
            I case anyone is interested; I forgot that the datagrid has the data variable available for use. Therefore in my actionscript I loop through data continously populating new instances fo an object, and store those objects in an arrayCollection.
            [Bindable]
            public var aTestArray:ArrayCollection = new ArrayCollection();
            obj:Object = new Object();
            obj["1"] = entry;
            obj["2"] = entry;
            obj["internalArray"] = returnAnArray();
            aTestArray.addItem(obj);
            where returnAnArray behaves much like the above code but the function returns an ArrayCollection.
            [Bindable]
            public var aTempArray:ArrayCollection = new ArrayCollection();
            obj["1"] = entry;
            obj["2"] = entry;
            aTempArray.addItem(obj);
            return aTempArray;
            For each row in the parent datagrid I can use data.internalArray as the dataProvider for the nested dataGrid.
            dataProvider="{parentApplication.sGI}" now appears as dataProvider="{data.internalArray}"
