1 Reply Latest reply on Feb 29, 2016 3:36 PM by Rick Gerard
    graph curves not showing after effects cs6
    zachachez
      hello there.
      I have two problems, i would appreciate any help.
      1st one => when making new keyframe  and select them and then turn graph editor on - then no curves shows at all in the graph section
      2nd one=> i cant copy and past any keyframes - when hitting ctr+c then ctr+v nothing happened i tried it million time copying and pasting keyframes not working i really don't know why!?
        • 1. Re: graph curves not showing after effects cs6
          Check the display options for graph editor. If you are unsure of the UI type graph editor in the Search Help field at the top right corner of AE and check out the community resources.
          If your AE is up to date and if you have had this working before and you are an experienced AE user then give us system, AE and OS details down to the last decimal point so we can help.
