4 Replies Latest reply on Feb 27, 2009 8:23 AM by nikos101
    debugging help
    nikos101 Level 2
      In the debug view I have this for a variable:
      this.parameters = Object (@15ad7e99)
      debug = "true"
      localIP = "10.4.1."
      However after I do this code in flash:
      var ip:String = "";
      ip= this.parameters.localIP;
      var debug:String = this.parameters.debug;
      the ip variable still points to null.
      Any ideas?
        • 1. Re: debugging help
          Level 7
          "nikos101" <webforumsuser@macromedia.com> wrote in message
          news:go8ng5$enh$1@forums.macromedia.com...
          > debug = "true"
          > localIP = "10.4.1."
          > var ip:String = "";
          Is the flash movie embedded in Flex? How are you passing in the object?
          • 2. Re: debugging help
            nikos101 Level 2
            I'm passing these params via swf object:
            var flashvars = {};
            flashvars.localIP = "<cfoutput>#URL.localIP#</cfoutput>"
            var params = {};
            params.allowfullscreen = "true";
            params.wmode = "transparent";
            var attributes = {};
            attributes.id = "flexApp";
            swfobject.embedSWF("debug/Transfer.swf", "myAlternativeContent", "800", "750", "9.0.0", false, flashvars, params, attributes);
            </script>
            its just a swf builded from a flex project. I.m not embedding a flash movie
            • 3. Re: debugging help
              Level 7
              > debug = "true"
              > localIP = "10.4.1."
              > var ip:String = "";
              What happens if you do this
              var ip:String = "";
              trace(this.parameters.localIP);
              You may find that there's something additional going on in code you haven't
              shown that is affecting this.
              • 4. Re: debugging help
                nikos101 Level 2
                I found it, the debug url was linking directly to the swf file. Now it links to the cfm page and it works. Thanks Amy
