0 Replies Latest reply on Mar 1, 2016 5:29 AM by AndersBalari
    Error When Embedding A PDF File with Excel VBA (Win 7 SP1, Office 2010, Acrobat X Standard)
    AndersBalari
      Hello,
      when trying to embed PDF files via Excel VBA, I encounter a 1004 Runtime Error ("Can't insert object") caused by the OLEObjects.Add method on specific computers. I've searched the internet thoroughly but didn't find a workable solution for the problem. Embedding is no problem with the computer I used to develop the tool and with other computers with the same configuration (comparison: see below). On the problematic machines it is possible to manually embed PDF files.
      Delevopment System And Other Systems On Which Code Works
      Win 7 Enterprise SP1 32-Bit
      Excel 2010
      Acrobat Reader XI
      Problematic Systems
      Acrobat X Standard, rest the same
      Code Line That Causes The Error
          Set objAttachment = ThisWorkbook.Worksheets(strSheetSignOff).OLEObjects.Add _
      (Filename:=FileToEmbed, Link:=False, DisplayAsIcon:=True, IconFileName:=AppForIcon, IconIndex:=0, _
      IconLabel:=NameOfFileToEmbed, Left:=dblAttLeft, Top:=AttachmentOffsetTop)
      The variables are unproblematic, I tried to use fixed values without success.
      Do you have any idea what the problem might be? In one forum I found the solution to a similar problem to be the replacement of Acrobat Reader by a PDF reader from a different developer - well, this is no option in my case. I suppose that there's a specific problem with the different Acrobat version installed, but I've got no idea what is the root cause and how to solve this.
      Thanks a lot in advance.
      Cheers
      Günther
