1 Reply Latest reply on Oct 7, 2016 5:55 AM by tpk1982
    Please help! Need to adjust copy and paste table script.
    Preacher728
      Hi, I'm a novice to InDesign scripting and need some help to adjust this script so that it can help cut some manual labor time. This is the PopTabUnleashed script that I downloaded for free and used, but now I need to make some adjustments to it to fit a new need. This script currently copies the text from Table 2 and paste it into Table 1 without losing the formatting in Table 1, but it overwrites any existing text that's in Table 1. What I need it to do now is to be able to paste the text from Table 2 into Table 1 without overwriting the existing text, instead the text from Table 2 would flow right after the existing text in Table 1. Also I would like to add a " / " between each add. So the final result would look something similar to this for a table with 1 column, 3 rows:
      Table 1:
      English
      English
      English
      Table 2:
      French
      French
      French
      Final Result:
      English / French
      English / French
      English / French
      Would I be able to just tweak this script or would a brand new script be required? Any help would be great!
      Here's the existing script:
      (function() {
        if (app.documents.length > 0 &&
        app.selection.length > 0) {
        var clipPref = app.clipboardPreferences.preferStyledTextWhenPasting;
        app.clipboardPreferences.preferStyledTextWhenPasting = true;
        $.sleep(100); // needed to give the clipboard preference time to take !!!
        app.doScript(popTab, undefined, undefined, UndoModes.entireScript, "Populate Table");
        app.clipboardPreferences.preferStyledTextWhenPasting = clipPref;
        function popTab() {
        var selectedObj = validateSelection(app.selection[0]);
        if (selectedObj === null) return issueSelectMsg();
        // now we need to create a text frame to hold the contents of the clipboard
        // we could worry about the possibility of locked layers and the like, but really
        // but we should make sure it doesn't have a text wrap even though we're going to delete it
        var twPrefs = {textWrapMode : TextWrapModes.none};
        var tempFrame = app.documents[0].textFrames.add({textWrapPreferences : twPrefs});
        var tempStory = tempFrame.parentStory;
        app.select(tempStory.insertionPoints[0]);
        app.paste();
        if (tempStory.tables.length != 1) {
        tempFrame.remove();
        return issueClipMsg();
        // Grab data from table into an array (c) of arrays
        var table = tempStory.tables[0];
        var cArray = Array();
        var cLim = table.columnCount;
        var rLim = table.rows.length;
        for (var c = 0; cLim > c; c++) {
        cArray[c] = Array();
        for (var r = 0; rLim > r; r++) {
        var cell = table.cells.item(c + ":" +r);
        if (cell.name == (c + ":" + r)) {
        cArray[c][r] = cell.texts[0].contents;
        } else {
        // cell is merged with earlier cell
        cArray[c][r] = null;
        tempFrame.remove(); // don't need it any more
        if (selectedObj.hasOwnProperty("columns")) {
        // selection is a range of cells so check we have the right amount of data
        var colMismatch = "";
        var rowMismatch = "";
        if (cLim != selectedObj.columns) {
        var colMismatch =  (cLim > selectedObj.columns) ?
        "more columns on clipboard than selected" :
        "columns on clipboard won't fill selection";
        cLim = Math.min(cLim, selectedObj.columns);
        if (rLim != selectedObj.rows) {
        var rowMismatch = (rLim > selectedObj.rows) ?
        "more rows on clipboard than selected" :
        "rows on clipboard won't fill selection";
        rLim = Math.min(rLim, selectedObj.rows);
        if (colMismatch + rowMismatch != "") {
        if (!confirm("Data mismatch: " + colMismatch +
        (colMismatch == "" ? rowMismatch : " and " + rowMismatch) +
        ".  Continue?")) {
        return;
        // get base address of starting cell
        var cellNameParts = selectedObj.cell.name.split(":");
        var colBase = Number(cellNameParts[0]);
        var rowBase = Number(cellNameParts[1]);
        var table = selectedObj.table;
        // make sure we don't overflow bounds of table
        if (colBase + cLim > table.columnCount ||
        rowBase + rLim > table.rows.length) {
        if (!confirm("Data on clipboard overflows size of table; continue?")){
        return;
        } else {
        cLim = Math.min(cLim, table.columnCount - colBase);
        rLim = Math.min(rLim, table.rows.length - rowBase);
        var warning1 = new  Array(); // for overset cells with data
        var warning2 = new Array(); // for no data for cells not overset
        for (r = 0; rLim > r; r++) {
        var cell = table.cells.item((colBase + c) + ":" + (rowBase + r));
        var cellMerged = (cell.name != ((colBase + c) + ":" + (rowBase + r)));
        if (cArray[c][r] != null) {
        if (cellMerged != true) {
        cell.contents = cArray[c][r];
        } else {
        // we have content for a merged cell
        warning1.push(cell.name);
        } else {
        if (cellMerged == false) {
        warning2.push(cell.name);
        if (warning1.length > 0) {
        alert("Data provided for these cells merged with earler cells\n" + warning1.join("\n"));
        if (warning2.length > 0) {
        alert("Because of merged cells on clip, no data provided for these cells\n" + warning2.join("\n"));
