3 Replies Latest reply on Mar 1, 2016 2:56 PM by ShodanKid
    Shift-Drag to Snap Rotate a Path Not Working
    ShodanKid
      A path, it doesn't matter if it is a mask or a shape path. When you shift-drag to rotate, it snaps as expected to 45 degree increments. But once you release the mouse button it immediately reverts to scaling and no rotation is applied.
      I am only trying to rotate the path without affecting the transforms. This works as expected with older versions of After Effects.
      Upon research, the only answers to the question are to delete a 'frischluft feedup plugin' which I do not have. I've had this occur on other systems as well. I have also recently removed and reinstalled AE to fix some other issues that were occuring (C4D Lite problems) but the rotate problem persists.
      Ideas?
