5 Replies Latest reply on Mar 1, 2016 9:28 PM by danielb27371135
    Master Page Guide Lines
    danielb27371135
      Hi, I'm having an issue with guide lines. I create single page horizontal guides on my master page, but when it is applied it applies itself to the entire spread in my document.
      My master pages are spreads also, but each guide line is applied by individual page.
      How can I stop this from happening?
        • 1. Re: Master Page Guide Lines
          Migintosh Level 4
          When you drag your guides from the ruler, they will appear on the page if you drag them to the page, like this:
          …and on both pages of the spread if you drag them to the pasteboard, like this:
          Does that help, or had you already been doing that?
          • 2. Re: Master Page Guide Lines
            danielb27371135 Level 1
            Yes that's correct, I've been pulling the guides onto each individual page within the master.
            However when the 'right' master page is applied, it also applies itself to the left page also.
            The image i've attached below highlights that my guides are applied to the Master page individually. Not a spread. I need this to work because each spread could have a different grid layout.
            • 3. Re: Master Page Guide Lines
              Migintosh Level 4
              I can't really tell, but may I assume that those are your document pages? Can you post a screen shot of the master pages also, so that I can see what you want it to look like? Also, have you created any guides directly on the document pages?
              Here's what my test document looks like. This is my A-Master pages:
              I have a high guide on the left, and a lower guide on the right. If I start with an 8-page document with None applied as my master, like this:
              …and apply my A-Master (with guides) to pages 2 and 5, I only get the guides on 2 and 5, like this:
              • 4. Re: Master Page Guide Lines
                That was my master page. My document pages are blank.
                In regards to your example, my problem is that it runs across the entire spread.
                • 5. Re: Master Page Guide Lines
                  So I had a friend look into it, and turns out you have to turn 'Smart Dimensions' OFF. Preferences > Guides & Pasteboard
                  That has solved the problem of guide lines going over spreads.
                  Thanks for your help Migintosh
