1 Reply Latest reply on Mar 4, 2009 8:33 PM by micweiss
    Is there a way to map a tag in flex to components in multiple directories?
    micweiss
      I've posted this question on other forums with no avail so I'll give this one a shot. Given a flex application or module, you can specify a custom xml namespace as follows:
      <mx:Module xmlns:mx=" http://www.adobe.com/2006/mxml" xmlns:custom="custom.namespace.*">
      We can then refer to mxml components in the directory custom/namespace/ using the custom tag. For example, if I have the components Custom1 and Custom2 in the custom/namespace directory, I can refer to them like so:
      <custom:Custom1/>
      <custom:Custom2/>
      Is there a way to map multiple directories onto the same tag? That is, if I have components in a subdirectory of custom/namespace, like custom/namespace/sub with component SubCustom1, is there a way to modify the flex document so the custom tag can refer to SubCustom1?
      Note that one workaround I found was to add a new tag for each directory (e.g. xmlns:custom.sub="custom.namespace.sub.*", and then:
      <custom.sub:SubCustom1>
      This solution seems like a kludge, though.
