4 Replies Latest reply on Mar 9, 2009 6:30 AM by Newsgroup_User
    TCP IP Assocaition
    Level 7
      I'm trying to create a kind of web dicom tools in CF8, I found a dicom jar
      class (JDCM toolkit). I'm starting with a simple "echo" function, without
      success. I'm able to open a tcp socket, but not a DICOM association, does
      anyone have some experience?
        • 1. Re: TCP IP Assocaition
          Level 7
          > jar class (JDCM toolkit). I'm starting with a simple "echo" function,
          > without success. I'm able to open a tcp socket, but not a DICOM
          > association, does anyone have some experience?
          What is the error that you're getting ? Anything in the log files ?
          Mack
          • 2. Re: TCP IP Assocaition
            Level 7
            Hi Mack,
            simply all freezed, and after a while the browser show "no page found!".
            In the log file I can found:
            "Object Instantiation Exception.An exception occurred when instantiating a
            Java object. The class must not be an interface or an abstract class."
            What I suspect is that I wrong someting in a workflow. I'dont'have any
            docs that explane me the steps. So I did in this way:
            - Opening a socket with setting of called and calling host and port
            - creating an association using A_ASSOCIATE [JDCM -
            A_Associate(java.net.Socket socket, java.lang.String callingEntity,
            java.lang.String calledEntity, java.lang.String abstractSyntaxUID,
            java.lang.String transferSyntaxUID)]
            - init C_Echo class and writeRQ method.
            Do you have any experience with JDCM toolkit?
            Thanks and sorry for my bad english.
            kalder
            • 3. Re: TCP IP Assocaition
              Level 7
              aren't there any examples, java/jsp or getting started, etc. docs? while not
              100% easy its usually possible to get cf to talk to most java libs.
              • 4. Re: TCP IP Assocaition
                Level 7
                following the examples:
                ----Making the connection
                Make a TCP/IP connection with the peer DICOM entity making use of the
                standard java.net classes. In our example this is the server localhost at
                port number 104 (Default DICOM port).
                Socket socket = new Socket("localhost",104);
                ---Association sample 1
                In this example the application entity title of the DICOM application with
                which we want to connect is ANY-SCP and our own application entity title
                is JDCM. Propose a SOP Class with Implicit Little Endian syntax transfer.
                A_Associate associate;
                try {
                associate = new A_Associate(
                socket,"JDCM",
                "ANY-SCP",
                "1.2.840.10008.5.1.4.1.1.6.1", //affected SOPClass
                "1.2.840.10008.1.2"); //transfert Syntax
                } catch(IOException e) {...}
                kalder
                In data 05 marzo 2009 alle ore 15:08:58, PaulH **AdobeCommunityExpert**
                > not 100% easy its usually possible to get cf to talk to most java libs.
