1 Reply Latest reply on Mar 2, 2016 12:03 PM by rezun8
    action script coding issue - how to fix ClickTAG error?
    rdale1961 Level 1
      I'm using action script 2 to make banners with a ClickTAG, and generally no problem with different codes provided by publications. I have received code today that just creates an error message and is unfamiliar. Is this action script 3 code, and if so how do I modify my banner to use the code in AS3? Flash calls out the (<) as the issue.
      New problem code:  <param name=”flashvars” value=”clickTAG=” .urlencode($outUrl). “>
      Our default ClickTAG code works well:
      on (release) {
      if (clickTAG.substr(0,5) == "http:") {
      getURL(clickTAG, "_blank");
        • 1. Re: action script coding issue - how to fix ClickTAG error?
          rezun8 Level 4
          make a MC call it "_clickTag"
          place invisible button inside this MC
          make new layer and add the following
          //CLICK TAG
          function handleClick(mouseEvent:MouseEvent):void {
              var interactiveObject:InteractiveObject = mouseEvent.target as InteractiveObject;
              var li:LoaderInfo = LoaderInfo(interactiveObject.root.loaderInfo);
              var url:String = li.parameters.clickTag;
              if (url) {
                  if (ExternalInterface.available) {
                      var userAgent:String = ExternalInterface.call('function(){ return navigator.userAgent; }');
                      if (userAgent.indexOf("MSIE") >= 0) {
                          ExternalInterface.call('window.open', url, '_blank');
                      } else {
                          navigateToURL(new URLRequest(url), '_blank');
                  } else {
          clickTag_btn.addEventListener(MouseEvent.MOUSE_UP,handleClick);
          hope it helps you out.
