0 Replies Latest reply on Mar 2, 2009 8:47 AM by Racerp51
    Publishing crash
    Level 1
      Is there a correlation between quiz question/answer size/limitation and the inability of Captivate 3 to publish correctly?
      I have had several instances where the module publishes correctly and the view output launches the file. Then after adding questions to the quiz manager and random questions the publish output fails. The publish procedure seems to run just fine, but when the preview output is selected it opens the C:\Program Files\Adobe\Adobe Captivate 3 folder in Explorer! If the selected publish output folder is viewed the only files found is the Pool1_CQP.swf file.
      Is Captivate trying to tell me there is a problem with this file?
      Interestingly the same module can be published stand alone with no problem. This only occurs on FlashFile outputs.
      Anyone have any ideas on this?
