2 Replies Latest reply on Mar 3, 2016 7:25 PM by Design Stream
    Custom print template with overlapping images
    Design Stream Level 1
      I am trying to create a print template for (2) 5 x 7 postcards (with logo/contact info at bottom edge) on a 8.5 x 11 page. I have imported a 5 x 7 white Photoshop background image with the contact info across the bottom. I now want to add 2 image boxes on top of the 5 x 7 artwork. The image boxes should be editable so that different images can be featured for different mailings. I would also like to be able to do this all in Lightroom. Can anyone offer advice on whether this is possible and if so, how?
        • 1. Re: Custom print template with overlapping images
          WobertC Adobe Community Professional
          All in the Lightroom Print module-
          Try starting with a Lightroom template  [Custom Square +2]  or design your own in the [Custom Package] Layout Style panel.
          The cells can be re-sized, re-positioned, overlapped, moved behind/infront, border stroked,  and with an edited Identity Plate Graphic.
          Once you have your design as you want it- save it as a print template, then you can drag and drop any images into the cells at any time in the future-  just select your images on the filmstrip, select your saved template, and drag images into the cells, print (or save as jpg for external printing!)
               My Print Template                          With 3 images & Identity Plate
          • 2. Re: Custom print template with overlapping images
            wobertc,
            Thanks very much for your answer and examples. I was able to create the templates with no problem.
            Lisa
