10 Replies Latest reply on Mar 5, 2016 6:41 AM by Captiv8r
    Put all text of pages into one file ?
    Krischu Level 1
      With a Robohelp  MS HTML Help project, would it be possible to dump all text contents into one big file?
      Christoph
        • 1. Re: Put all text of pages into one file ?
          Hi there
          One big Microsoft Word document?
          One single distributable file such as a CHM?
          A singe Zip file?
          An Adobe PDF document?
          One huge HTML file?
          Are you even using RoboHelp?
          Cheers... Rick
          • 2. Re: Put all text of pages into one file ?
            Jeff_Coatsworth Adobe Community Professional & MVP
            If you’re talking about creating CHMs, it’s already in one file; or are you talking about concatenating all the HTML pages into one long file (page?)
            • 3. Re: Put all text of pages into one file ?
              Krischu Level 1
              Rick. One Big Word Document would be desirable. I would like to apply a spelling checker for example. Or do some other text review.
              Jeff, if it's in the CHM (sure, it's gotta be   ), how could one extract it?
              Christoph
              • 4. Re: Put all text of pages into one file ?
                Hello again
                One may use the Printed Documentation feature of Adobe RoboHelp. Just open the Outputs(SSL) pod (RoboHelp 2015 Release) or the Single Source Layouts pod and double-click the Printed Documentation layout.
                Work through the wizard and you should end up with a single document once finished.
                Cheers... Rick
                • 5. Re: Put all text of pages into one file ?
                  Krischu Level 1
                  Rick,
                  the Printed Documentation feature is probably what I want. I tried it but I run into trouble with some VBA script stuff:
                  This appears in the output window. Also an alert box pops up from MS Word (2007) saying sth. about that VBA Macro.
                  Generierung der gedruckten Dokumentation wurde abgebrochen.
                  Die registrierte Version des Word-VBA-Makros ist falsch.
                  Installieren Sie 'Gedruckte Dokumentation' noch einmal.
                  Wartezeit, bis VBA-Makros für gedruckte Dokumentation registriert wurden...
                  Fehler beim Registrieren der VBA-Makros für gedruckte Dokumentation...
                  Christoph
                  • 6. Re: Put all text of pages into one file ?
                    Sorry but I'm nearly out the door for an appointment. Hopefully Peter or Jeff can pop in to advise.
                    Cheers... Rick
                    • 7. Re: Put all text of pages into one file ?
                      What version of RoboHelp are you using?
                      • 8. Re: Put all text of pages into one file ?
                        Krischu Level 1
                        I started a trial period with RH 2015 a couple of days ago but to stay compatible with our partner I also installed RH11 as a trial version. The former I will be going to license soon anyway (which will also entitle me to continue using RH 11 as I've learnt).
                        I got around this VBA thing by now by enabling Macro (insecurity) in Word 2007 and I'm tried start a PDF printed doc which seems to work now, but still got not through it. Gotto close my notebook yesterday night when I had to leave office while RH was still at 80%
                        of generating the printed doc. Takes long.
                        Well, I'd prefer to get it solved for Word 2007 nonetheless because it would be easier to do text correction.
                        RH doesn't provide a spelling checker built in, does it?
                        Christoph
                        • 9. Re: Put all text of pages into one file ?
                          Krischu Level 1
                          Meanwhile I managed to generate a printed documentation as a Word document. It's huge (1300 pages as was the PDF document).
                          I can also save the file as a .TXT document. THat's what I needed.
                          Thanks. Solved.
                          Christoph
                          • 10. Re: Put all text of pages into one file ?
                            Hello again
                            Indeed, RoboHelp does have a spelling checker built into it!
                            In RoboHelp (2015 Release) you launch the Spell Check by either pressing the F7 key (same key is used in Microsoft Products as well as in Adobe Captivate for spell check) or you click the Review tab followed by Spell Check.
                            Cheers... Rick
