• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Dealing with parallel requests to cfc
New Here ,
Mar 04, 2016 Mar 04, 2016
I have a cfc that is exposed as a web service . However when a request from 2 different servers consume the webserice at the same time one request is dropped and the other processed. Im not sure why this happens and would really appreciate some insight
Thanks!
Views
914
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Mar 06, 2016 Mar 06, 2016
Some immediate suggestions
1) localtest is undefined; define it.
2) Var all your function-local variables:
<cfset var getArrD= arraynew(2)>
<cfset var size = 0>
<cfset var soapBodyd = "">
<cfset var soapResponsed = "">
<cfset var responseNodesd = "">
<cfset var FindTPIN = "">
<cfset var strXml = "">
<cfset var xmlRequest = "">
<cfset var XMLDOM = "">
<cfset var products = "">
<cfset var results = "">
<cfset var myqueryD = queryNew("")>
<cfset var temp = "">
<cfset var filteredData = queryNew("")>
3) Where you us
Votes
Translate
Translate
LEGEND ,
One possible solution that I can think of would be to use CFTHREAD for the requests.  That should eliminate any collisions, conflicts, or (a VERY small, miniscule, remote chance) identical IDs.
HTH,
^_^
UPDATE: I highly doubt that two servers could both have the same CFID/CFTOKEN combination, so never mind..
Votes
Translate
Translate
Report
Report
New Here ,
Hmm something like this ....
<cfset VARIABLES.Instance.LockID = CreateUUID() />
    <cffunction
        name="Add"
        access="public"
        returntype="any"
        output="false"
        <!--- Define arguments. --->
        <cfargument
            name="Message"
            type="string"
            required="true"
        <!--- Lock method call. --->
        <cflock
            name="#VARIABLES.Instance.LockID#-Message"
            type="exclusive"
            timeout="5">
            <cfreturn SUPER.Add(
                Message = ARGUMENTS.Message
        </cflock>
    </cffunction>
Votes
Translate
Translate
Report
Report
Advocate ,
Mar 05, 2016 Mar 05, 2016
This is the code you have at the moment?
The exclusive lock you have there will cause the behavior you have described. The lock wont let another request run the code until the previous request is done
Votes
Translate
Translate
Report
Report
Engaged ,
There is something in your code that is not thread safe.  Can you share the code from your service that you are having issues with?  I have written many services like you describe and have not ran into the issue you are having.  You shouldn't need to use cflock for this.
--Dave
Votes
Translate
Translate
Report
Report
New Here ,
this is the code that is giving the issue BKBK‌
<cffunction name="sendPaymentConfirmation" returntype="any" access="remote" >
  <cfargument name="tid" type="string" required="true"  />
  <cfargument name="cid" type="string" required="true"   />
  <cfargument name="declarantFlag" type="string" required="true" />
  <cfargument name="pflag" type="numeric" required="true" />
  <cfargument name="aNumber" type="string" required="true" />
   <cfargument name="aPaid" type="numeric" required="true" />
   <cfargument name="iAmt" type="numeric" required="true"  />
   <cfargument name="pAmt" type="numeric" required="true"  />
  <cfargument name="asYear" type="string" required="true"  />
  <cfargument name="pEntry" type="string" required="true"  />
  <cfargument name="rSerial" type="string" required="true" />
   <cfargument name="rNumber" type="string" required="true" />
  <cfargument name="rDate" type="string" required="false"/>
<cfargument name="pType" type="string" required="true"/>
  <cfargument name="source" type="string" required="true"  />
  <cfargument name="sourceID" type="string" required="true"   />
  <cfargument name="timestamp" type="string" required="true"/>
  <cfargument name="type" type="string" required="true"  />
  <cfargument name="country" type="string" required="true"  />
    <cfif #pflag# eq 2>
<cfset declarantCode=getDeclarant(#cid#,#pEntry#,#rNumber#,#rSerial#,#asYear#)>
     <cfif #iAmt# gt 0>
        <cfquery datasource="smartpay_log">
    INSERT INTO Log_table (taxPerIdentification, aNumber, aPaid, asYear, pEntry, rSerial, rNumber, rDate, source, sourceID, timestamp, type, country,asyResponse,log_time,item_type,declarant_code)
VALUES (<cfqueryparam value="#cid#">,<cfqueryparam value="#rNumber#">,<cfqueryparam value="#iAmt#">,<cfqueryparam value="#asYear#">,<cfqueryparam value="#pEntry#">,<cfqueryparam value="#rSerial#">,<cfqueryparam value="#rNumber#">,<cfqueryparam value="#asYear#">,<cfqueryparam value="#source#">,<cfqueryparam value="#sourceID#">,<cfqueryparam value="#timestamp#">,<cfqueryparam value="#type#">,<cfqueryparam value="#country#">,<cfqueryparam value=" ">,<cfqueryparam value="#DateFormat(now(),"DD-MM-YYYY")# #TimeFormat(now(),"HH:mm:ss")#">,<cfqueryparam value="INTQ">,<cfqueryparam value="#declarantCode.declarantCode#">)
  </cfquery>
<cfset var xmlPacket_details_INT = "">
    <cfxml variable="xmlPacket_details_INT">
     <cfoutput><sendPaymentConfirmationResponse>
        <PaymentConfirmation>
          <pType>1</pType>
          <reasonCode>0</reasonCode>
          <reasonDescription>PAYMENTQUEUED</reasonDescription>
          <source>#source#</source>
          <sourceID>#sourceID#</sourceID>
          <timestamp>#DateFormat(now(),"YYYY-MM-DD")#T#TimeFormat(now(),"HH:mm:ss")#</timestamp>
          <type>#type#</type>
          <country>#country#</country>
        </PaymentConfirmation>
      </sendPaymentConfirmationResponse></cfoutput>
     </cfxml>
    </cfif>
  <cfif #pAmt# gt 0>
VALUES (<cfqueryparam value="#cid#">,<cfqueryparam value="#rNumber#">,<cfqueryparam value="#pAmt#">,<cfqueryparam value="#asYear#">,<cfqueryparam value="#pEntry#">,<cfqueryparam value="#rSerial#">,<cfqueryparam value="#rNumber#">,<cfqueryparam value="#asYear#">,<cfqueryparam value="#source#">,<cfqueryparam value="#sourceID#">,<cfqueryparam value="#timestamp#">,<cfqueryparam value="#type#">,<cfqueryparam value="#country#">,<cfqueryparam value=" ">,<cfqueryparam value="#DateFormat(now(),"DD-MM-YYYY")# #TimeFormat(now(),"HH:mm:ss")#">,<cfqueryparam value="PRNQ">,<cfqueryparam value="#declarantCode.declarantCode#">)
  </cfquery>
    </cfif>
    <cfif #iAmt# gt 0>
  </cfif>
  </cfif>
</cffunction>
Votes
Translate
Translate
Report
Report
Community Expert ,
I haven't looked into the content. But I do believe you can improve the code by doing something like
<cfset var declarantCode = "">
<cfif arguments.pflag eq 2>
    <cfset declarantCode=getDeclarant(arguments.cid,arguments.pEntry,arguments.rNumber,arguments.rSerial,arguments.asYear)>
    <cfif arguments.iAmt gt 0>
        VALUES (<cfqueryparam value="#arguments.cid#" cfsqltype="CF_SQL_VARCHAR">,
                <cfqueryparam value="#arguments.rNumber#" cfsqltype="CF_SQL_VARCHAR">,
                <cfqueryparam value="#arguments.iAmt#" cfsqltype="CF_SQL_NUMERIC">,
                <cfqueryparam value="#arguments.asYear#" cfsqltype="CF_SQL_VARCHAR">,
                <cfqueryparam value="#arguments.pEntry#" cfsqltype="CF_SQL_VARCHAR">,
                <cfqueryparam value="#arguments.rSerial#" cfsqltype="CF_SQL_VARCHAR">,
                <cfqueryparam value="#arguments.source#" cfsqltype="CF_SQL_VARCHAR">,
                <cfqueryparam value="#arguments.sourceID#" cfsqltype="CF_SQL_VARCHAR">,
                <cfqueryparam value="#arguments.timestamp#" cfsqltype="CF_SQL_VARCHAR">,
                <cfqueryparam value="#arguments.type#" cfsqltype="CF_SQL_VARCHAR">,
                <cfqueryparam value="#arguments.country#" cfsqltype="CF_SQL_VARCHAR">,
                <cfqueryparam value=" " cfsqltype="CF_SQL_VARCHAR">,
                <cfqueryparam value="#DateFormat(now(),'DD-MM-YYYY')# #TimeFormat(now(),'HH:mm:ss')#" cfsqltype="CF_SQL_DATE">,
                <cfqueryparam value="INTQ" cfsqltype="CF_SQL_VARCHAR">,
                <cfqueryparam value="#arguments.declarantCode.declarantCode#" cfsqltype="CF_SQL_VARCHAR">)
        </cfquery>
        <pType>1</pType>
        <source>#arguments.source#</source>
        <sourceID>#arguments.sourceID#</sourceID>
        <type>#arguments.type#</type>
        <country>#arguments.country#</country>
        </cfxml>
    </cfif>
    <cfif arguments.pAmt gt 0>
                <cfqueryparam value="#arguments.pAmt#" cfsqltype="CF_SQL_NUMERIC">,
                <cfqueryparam value="PRNQ" cfsqltype="CF_SQL_VARCHAR">,
                <cfqueryparam value="#declarantCode.declarantCode#" cfsqltype="CF_SQL_VARCHAR">)
        </cfquery>
    </cfif>
    </cfif>
</cfif>
<cfreturn someVar><!---Otherwise remove this line and set returntype = "void"--->
</cffunction>
Votes
Translate
Translate
Report
Report
New Here ,
OK ill try that just to make it more efficient .. Do you suppose this could solve the problem ? Im unfortunately not able to test it as i dont have a clustered environment on my local machine to consume the webservice concurrently
Votes
Translate
Translate
Report
Report
Community Expert ,
As I said, I haven't looked at the content. That might solve the problem, assuming that the database connection and declarantCode don't introduce any external influence.
Votes
Translate
Translate
Report
Report
Engaged ,
Beyond what BKBK‌ suggested.  There might be an issue with the getDeclarant function code.  Also, the lack of var scoping in the code could also lead to issues. Based on this sample I am willing to bet that the code in that function is not thread safe either.
Votes
Translate
Translate
Report
Report
New Here ,
Thanks I'm looking thru the entire code. Any good articles on thread safety I can look at ?
Votes
Translate
Translate
Report
Report
Community Expert ,
Please read <cfqueryparam value="#declarantCode.declarantCode#" cfsqltype="CF_SQL_VARCHAR"> in place of <cfqueryparam value="#arguments.declarantCode.declarantCode#" cfsqltype="CF_SQL_VARCHAR">.
Adobe ColdFusion: Locking code with cflock
Could you show us the 'declarant' code?
Votes
Translate
Translate
Report
Report
New Here ,
Thank for the link. Below is the declarant code
<cffunction name="getDeclarant" returntype="any" access="private">
  <cfargument name="clienttpi" type="string" required="no" hint="This carries the TPIN"  >
  <cfargument name="poe" type="string" required="yes"   >
  <cfargument name="rnum" type="string" required="yes"  >
  <cfargument name="rser" type="string" required="yes"  >
  <cfargument name="registrationYear" type="string" required="yes"  >
  <cfset getArrD= arraynew(2)>
<cfsavecontent variable="soapBodyd">
      <cfoutput>
      <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:asy="http://www.asy.org">
        <soapenv:Header/>
        <soapenv:Body>
          <asy:getutp>
            <!--Optional:-->
            <asy:tinfo>
              <bankCode>SCB</bankCode>
              <!--Optional:-->
              <ctpi>#arguments.clienttpi#</ctpi>
            </asy:tinfo>
          </asy:getutp>
        </soapenv:Body>
      </soapenv:Envelope>
      </cfoutput>
      </cfsavecontent>
      <cfif localtest eq "YES">
      <cfhttp url="http://localhost" method="head"  result="httpResponse" >
</cfhttp>
      <cfelse>
         <cfhttp
url="https://127.0.0.1:8443/asy/WSZ"
method="post"
result="httpResponse" username="123" password="123">
      <cfhttpparam
type="header"
name="SOAPAction"
value="urn:getU"
      <cfhttpparam
type="header"
name="accept-encoding"
value="no-compression"
      <cfhttpparam
type="xml"
value="#trim( soapBodyd )#"
      </cfhttp>
      </cfif>
<cfset tranXML =getTransXML()>
</cfif>
      <cfif find( "200", httpResponse.statusCode )>
   <cfset soapResponsed = xmlParse( #tranXML# ) />
      <cfelse>
        <cfset soapResponsed = xmlParse( httpResponse.fileContent ) />
        </cfif>
        <cfset responseNodesd = xmlSearch(
soapResponsed,
"//*[ local-name() = 'unSR' ]"
        <cfset FindTPIN = xmlSearch(
soapResponsed,
"//*[ local-name() = 'TPIN' ]"
        <cfoutput>
        <cfsavecontent variable="strXml"> #soapResponsed# </cfsavecontent>
        <cfset strXml = strXml.ReplaceAll(
  "(</?)(\w+:)",
  "$1"
  "xmlns(:\w+)?=""[^""]*""",
        <cfset xmlRequest = XmlParse(
  strXml.Trim()
        <cfset XMLDOM = xmlParse(xmlRequest)>
        <cfset i=1>
        <cfset products =ArrayNew(2)>
        <cfloop   index="results" array="#xmlsearch(XMLDOM,'/Envelope/Body/getUTResponse/unSR/assmntPaid')#">
        <cfset results = xmlparse(results)>
        <cfset getArrD[1]=#results.asmTpd.declarantCode.xmltext#>
        <cfset getArrD[2]=#results.asmTpd.TPIN.xmltext#>
        <cfset getArrD[3]=#results.asmTpd.officeCode.XmlText#>
        <cfset getArrD[4]=#results.asmTpd.astp.XmlText#>
        <cfset getArrD[5]=#results.asmTpd.registrationYear.xmltext#>
        <cfset getArrD[6]=#results.asmTpd.rser.xmltext#>
        <cfset getArrD[7]=#results.asmTpd.rnum.xmltext#>
        <cfset getArrD[8]=#results.asmTpd.amtP.xmltext#>
        <cfset i=i+1>
        </cfloop>
        </cfoutput>
      </cfif>
      <cfset size = ArrayLen(getArrD)>
      <cfif size gte 1>
        <cfset myqueryD = QueryNew("trans_id,declarantCode,tpi,poe,astp,ayear,rser,rnum,amtP,reasonCode,reasonDescription,source,sourceID,timestamp,type,country","VarChar,VarChar,VarChar,VarChar,VarChar,VarChar,VarChar,VarChar,VarChar,VarChar,VarChar,VarChar,VarChar,VarChar,VarChar,VarChar") >
        <cfset temp = QueryAddRow(myqueryD,#size#)>
        <cfloop index="i" from = "1" to = #size#>
        <cfset temp = QuerySetCell(myqueryD, "trans_id", #i#, #i#)>
        <cfset temp = QuerySetCell(myqueryD, "declarantCode", #getArrD[1]#, #i#)>
        <cfset temp = QuerySetCell(myqueryD, "tpi", #getArrD[2]#, #i#)>
        <cfset temp = QuerySetCell(myqueryD, "poe", #getArrD[3]#, #i#)>
        <cfset temp = QuerySetCell(myqueryD, "astp", #getArrD[4]#, #i#)>
        <cfset temp = QuerySetCell(myqueryD, "ayear", #getArrD[5]#, #i#)>
        <cfset temp = QuerySetCell(myqueryD, "rser", #getArrD[6]#, #i#)>
        <cfset temp = QuerySetCell(myqueryD, "rnum", #getArrD[7]#, #i#)>
        <cfset temp = QuerySetCell(myqueryD, "amtP", #getArrD[8]#, #i#)>
        <cfset temp = QuerySetCell(myqueryD, "reasonCode", "0", #i#)>
        <cfset temp = QuerySetCell(myqueryD, "reasonDescription", "Sucessful", #i#)>
        <cfset temp = QuerySetCell(myqueryD, "source", "SP" ,#i#)>
        <cfset temp = QuerySetCell(myqueryD, "sourceID", "1234", #i#)>
        <cfset temp = QuerySetCell(myqueryD, "timestamp", "12:00", #i#)>
        <cfset temp = QuerySetCell(myqueryD, "type", "CHN", #i#)>
        <cfset temp = QuerySetCell(myqueryD, "country", "CHN", #i#)>
        </cfloop>
        <cfelse>
      </cfif>
      <cfquery name="filteredData" dbtype="query">
    select * from myqueryD where
    rnum=<cfqueryparam value="#arguments.rnum#"> and rser=<cfqueryparam value="#arguments.rser#"> and poe =<cfqueryparam value="#arguments.poe#">
    and ayear= <cfqueryparam value="#arguments.registrationYear#" cfsqltype="cf_sql_varchar">
    </cfquery>
  <cfreturn filteredData>
</cffunction>
Votes
Translate
Translate
Report
Report
Community Expert ,
3) Where you use arguments, prefix them with arguments.someVar
Votes
Translate
Translate
Report
Report
New Here ,
localtest is a global variable defined just after the cfcomponet declaration.
Votes
Translate
Translate
Report
Report
Community Expert ,
OK.
In any case, as a general rule, avoid using a global variable. If one user takes it into his room, others may have to wait outside wondering what he's doing with it and when he will be done. I mean of course thread issues.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 07, 2016 Mar 07, 2016
LATEST
Thank you all for pointing me in the right direction i can confirm it was as BKBK‌ said along with with everybody else. The service works exactly as i want it to
Votes
Translate
Translate
Report
Report
Community Expert ,
By default, requests to a web service run concurrently, each as a separate thread. If that is different in your service, then it means you have to redesign your service. Could you show us the CFC?
Votes
Translate
Translate
Report
Report
Resources
Documentation
