2 Replies Latest reply on Mar 4, 2016 2:50 PM by DebG_
    Where is my text going!
    DebG_
      I have a 200 page document using a template I have used many many times. When I go to create a TOC. it lists the first heading in the book, says it's done, and ALL THE OTHER TEXT DISAPPEARS FROM MY BOOK! Does anyone have any ideas. I have saved...closed...reopened...saved a backup....looked for oddball text blocks...
        • 1. Re: Where is my text going!
          Steve Werner Adobe Community Professional & MVP
          Open the Story editor when a text frame is selected (Edit > Edit in Story Editor). There may be a hidden character in the text which is keeping the text from flowing from that frame.
          • 2. Re: Where is my text going!
            DebG_ Level 1
            I want to thank you so much for your speedy answer. It turns out that, although I am keeping you input on file for future possible need, in continuing to research after I put this question up - I found that answer that worked for my problem. It turn out I had my TOC pages threaded with the main text - once I fixed this (through a series of cutting all text, removing TOC text, unthreading TOC pages, then recopying text so that it was no longer connected to the TOC pages - IT WORKED! I write this here in case it helps someone else looking into this - or perhaps everyone else knew this. I have created a lot of books over many many years - this is the first time I ran into this.
            But truly - thanks again for your feedback.
