2 Replies Latest reply on Mar 18, 2016 7:42 AM by posmindset
    default folder location for disk cache
    posmindset
      what is the default folder location for AE CC disk cache?
      I changed it and things seemed to slow down so I want to set it back to the default and test it.
      thanks
        • 1. Re: default folder location for disk cache
          The default folder is inside your system's user folder. Not related to the cache at all. This is the same as in your other thread - you screwed your system by cloning it without regard to the specifics of the new SSD and in addition you are probably missing an essential driver for your SSD, so it's running in compatibility mode. You need to start from scratch and install your software correctly rather than pull it from a backup.
          Mylenium
          • 2. Re: default folder location for disk cache
            posmindset Level 1
            there are no drivers for that ssd 850 EVO on samsung's driver page.
            i started from scratch as you suggested, installed win10 with a clean install..............nothing has changed.
            thanks for your help
