• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
how to load video in Html5 Canvas?
Explorer ,
Mar 05, 2016 Mar 05, 2016
how to load video external in Animate CC canvas using createJs?
Views
11.6K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Mar 07, 2016 Mar 07, 2016
Create an HTML video tag in a DOM element positioned over the canvas.
Here are a couple of simple functions for managing DOM element creation in Canvas mode:
// Create a DIV layer above the canvas
// Accepts X, Y, width, height, HTML content, and CSS styling (optional)
// CSS styling is a string with format "prop:value; prop:value" etc.
// CSS properties must use JavaScript aliases
// Returns a reference to the DIV, required to remove it later
// DIV is added as a child to the CreateJS stage,
Votes
Translate
Translate
Adobe Employee ,
Votes
Translate
Translate
Report
Report
LEGEND ,
// DIV is added as a child to the CreateJS stage, allowing all
// applicable properties and methods to be used.
// http://www.createjs.com/docs/easeljs/classes/DOMElement.html
makeDiv = function(x, y, w, h, html, css) {
    // create and initialize DIV element
    var d = document.createElement("div");
    d.style.visibility = "hidden";
    d.style.position = "absolute";
    d.style.left = 0;
    d.style.top = 0;
    d.style.width = w + "px";
    d.style.height = h + "px";
    d.style.overflow = "auto";
    d.innerHTML = html;
    // apply styling
    if (css) {
        var cssPair;
        var cssStyles = css.split(";");
        var i = cssStyles.length;
        while ( i ) {
            cssPair = cssStyles[--i].split(":");
            if (cssPair.length == 2) {
                d.style[cssPair[0].trim()] = cssPair[1].trim();
    // attach element to CreateJS stage
    canvas.parentNode.appendChild(d);
    var dcjs = new createjs.DOMElement(d);
    dcjs.x = x;
    dcjs.y = y;
    return(stage.addChild(dcjs));
// Remove a DIV created by makeDiv
rmDiv = function(ref) {
    // sanity check
    if (!ref) {
        return;
    // remove the HTML element
    var elem = ref.htmlElement;
    if (elem.parentNode) {
        elem.parentNode.removeChild(elem);
    // remove the DOMElement proxy
    stage.removeChild(ref);
Example:
makeDiv(0, 0, 640, 480, "<video src='myvideo.mp4' autoplay controls></video>");
I really should post all this stuff on a blog or something.
Votes
Translate
Translate
Report
Report
Explorer ,
Mar 10, 2016 Mar 10, 2016
wow... its helped for me... video control is showing in video.
but what is function DOMElemet? i mean is for what the function of DOMElement?
and
can a canvas using form of the textfield?
thanks clay's.
Votes
Translate
Translate
Report
Report
LEGEND ,
Everything there is to know about DOMElement:
EaselJS v0.8.2 API Documentation : DOMElement
Short answer, it lets you use many of the CreateJS methods to manipulate user-created DOM elements as if they were native CreateJS canvas elements.
Votes
Translate
Translate
Report
Report
New Here ,
Jul 30, 2016 Jul 30, 2016
Thanks, its working for me.  There is some additional customization I'd like to do such as rotating the video 10 degrees and how can I remove the video once its done playing?
Votes
Translate
Translate
Report
Report
Explorer ,
Aug 05, 2016 Aug 05, 2016
Hi, I'm super new to coding and don't know very much. I'm trying to take this code and incorporate a video into my html5 canvas document. Where in this code would I put the file path to my video? Do I need to manipulate other things inside this code, like the width and height of the video, etc?
Votes
Translate
Translate
Report
Report
LEGEND ,
Don't use the version of makeDiv() in this thread. There's a better updated version here: Re: How can I add video
All it does is create arbitrary HTML content over the stage. If you want to know how to do a specific HTML thing, there are many, many detailed tutorials available online.
Votes
Translate
Translate
Report
Report
Explorer ,
Thank you, this helps a lot. Is there a way to make it so that the video only appears on one specific frame of my timeline? I added the call to it on frame three which is where I want it to show up, but I'd like it to only appear on that frame and I don't know how to make it disappear on the following frame.
Your help is much appreciated!
Votes
Translate
Translate
Report
Report
Explorer ,
Nevermind, I found that part of the code in your comments!
Votes
Translate
Translate
Report
Report
New Here ,
May 17, 2022 May 17, 2022
Hi, can i have the code for the updated version? Because the link is not available anymore
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Votes
Translate
Translate
Report
Report
Community Beginner ,
Nov 18, 2016 Nov 18, 2016
Thank you so much!! After tinkering around I bit I found out that if you replace the <video></video> tags with youtube's embed code, you can embed youtube videos as well using your code!
replace:
with:
makeDiv(0, 0, 640, 480, "<iframe width='600' height='338' src='youtubeurl' frameborder='0' allowfullscreen></iframe>");
to load youtube video in your html5 canvas
Votes
Translate
Translate
Report
Report
LEGEND ,
Nov 19, 2016 Nov 19, 2016
I'd certainly hope so. All it does is create an HTML DIV element. You can put literally any HTML content in it.
Votes
Translate
Translate
Report
Report
Haha, sorry. I'm so dumb when it comes to Flash/Animate/HTML5 and for the most part it's a completely foreign language to me. Anytime I figure out something in the program and it WORKS for me, I want to throw a party! So anyways, yeah I just wanted to point that out to anyone else who may be relatively new to animate and trying to figure things out.
THANK YOU for helping us beginners out.
Votes
Translate
Translate
Report
Report
New Here ,
May 27, 2016 May 27, 2016
can anyone tell me how to get this to scale responsively? I get the video to play on the stage, but when i scale the browser it does not scale with it.
Votes
Translate
Translate
Report
Report
LEGEND ,
May 31, 2016 May 31, 2016
It's complicated (also, Adobe's use of the terminology notwithstanding, just stretching things is *not* responsive design). In my own scaling application the Animate content is sandboxed in an iframe, with the navigation interface surrounding it being plain vanilla HTML. Using jQuery, I assign a resize listener to the top-level window and call this function when the page is resized:
function handleResize(e) {
    var w = $(this).width();
    var h = $(this).height();
    var scale = Math.min(w / _LSN_WIDTH, h / _LSN_HEIGHT);
    // scale UI
    $("#container").css({"-webkit-transform" : "scale(" + scale + ")"});
    $("#container").css({"-ms-transform" : "scale(" + scale + ")"});
    $("#container").css({"transform" : "scale(" + scale + ")"});
    $("#container").css({"left" : (w / 2 - (_LSN_WIDTH * scale) / 2) + "px"});
    // scale content
   _contentCanvas.width = _LSN_WIDTH * scale;
   _contentCanvas.height = _LSN_HEIGHT * scale;
   _contentCanvas.style.width = _LSN_WIDTH + "px";
   _contentCanvas.style.height = _LSN_HEIGHT + "px";
   _contentStage.scaleX = scale;
   _contentStage.scaleY = scale;
The content iframe is absolute-positioned and named "content". _LSN_WIDTH/HEIGHT are globals storing the content's native resolution. _contentCanvas is a pointer to the Animate canvas, and _contentStage is a pointer to the Animate stage (exposed within Animate as the globals "canvas" and "stage", respectively).
Votes
Translate
Translate
Report
Report
New Here ,
My Brother is a programmer, he figured it out for me. He said its a bit clunky but it works and that is all i care about. Just so you know this was the way he fixed it...
this.makeDiv = function (html) {
  var widthToHeight = stageWidth / stageHeight;
  var newWidth = window.innerWidth;
  var newHeight = window.innerHeight;
  var newWidthToHeight = newWidth / newHeight;
  var page_canvas = document.getElementById("canvas");
  if (newWidthToHeight > widthToHeight) {
  newWidth = newHeight * widthToHeight;
  page_canvas.style.height = newHeight + "px";
  page_canvas.style.width = newWidth + "px";
  } else {
  newHeight = newWidth / widthToHeight;
//I NEED TO TAKE SOME MEASUREMENTS TO SIZE AND POSITION THE VIDEO ON THE STAGE WHERE IN NEED IT//
  scale = newWidthToHeight / widthToHeight;
  var x = newWidth * 0.499 + ((window.innerWidth - newWidth) / 2); // left of viewport / browser_width
  var y = newHeight * 0.258 + ((window.innerHeight - newHeight) / 2); // top of viewport / browser_height
  var w = newWidth * 0.404;  // (right-left) / browser_width
  var h = newHeight * 0.412;  // (bottom-top) / browser_height
    d.setAttribute("id", "vidbox");
  d.style.cssText = "visibility:visible; position:absolute; left:" + x + "px; top:" + y + "px; width:" + w + "px; height:" + h + "px; overflow:hidden;";
  d.innerHTML = html;
Votes
Translate
Translate
Report
Report
New Here ,
Aug 22, 2020 Aug 22, 2020
can anyone tell me, how can I fade in/out the video, which is created with the code above?
Thanks for your help!
Votes
Translate
Translate
Report
Report
