1 Reply Latest reply on Mar 5, 2016 8:06 AM by JJMack
    Photoshop Script Change Blend Mode
    neila73906844
      Hi Guys
      I am a totally newbie when it comes to scripts but I have an existing script that works well to add an image onto a template and then you select the blend mode and away it goes.
      Problem is that I need to select another blend mode now. I thought it would be a case of changing the blend mode within the script but doesnt work.
      I would really appreciate any help on this, Im sure its a simple fix. Its the Multiply blend mode thats been added and causing the issue.
      I added copied and edited the code below (not sure what it mans at all)
      Win.btnPnl.rb4.onClick = function()
              {Win.close();
               Exe(4);
      as there was only 3 blend modes previously.
      Here is script
      app.displayDialogs = DialogModes.NO;
      var TemplateFile = File.openDialog ("Please select a template :", "*.psd");
      var DesignsFolder = Folder.selectDialog("Please select Designs folder :");
      preferences.typeUnits = TypeUnits.PIXELS;
      preferences.rulerUnits = Units.PIXELS;
      open(File(TemplateFile));
      var DocRef = activeDocument;
      var Rectangle = DocRef.activeLayer;
      var Rectangle = DocRef.channels.getByName("PASTE HERE");
      var Selection = DocRef.selection.load(Rectangle);
      var Bound = DocRef.selection.bounds ;
      PosX =  Bound[0];
      PosY =  Bound[1];
      DimX =  Bound[2] - Bound[0];
      DimY =  Bound[3] - Bound[1];
      var DesignsList = DesignsFolder.getFiles("*.psd"| "*.jpg"| "*.jpeg");
      var Win = new Window('dialog', 'BendMode :');
          Win.size = [150,150];
          Win.btnPnl = Win.add('panel', undefined, 'Build it');
          Win.btnPnl.rb1 = Win.btnPnl.add('radiobutton', undefined, 'Darken');
          Win.btnPnl.rb2 = Win.btnPnl.add('radiobutton', undefined, 'Normal');
          Win.btnPnl.rb3 = Win.btnPnl.add('radiobutton', undefined, 'Lighten');
          Win.btnPnl.rb4 = Win.btnPnl.add('radiobutton', undefined, 'Multiply');
             Win.btnPnl.rb1.onClick = function()
              {Win.close();
               Exe(1);
             Win.btnPnl.rb2.onClick = function()
              {Win.close();
               Exe(2);
             Win.btnPnl.rb3.onClick = function()
              {Win.close();
               Exe(3);
              {Win.close();
               Exe(4);
            Win.show();
      function Exe(Val){
          for(I=0; I < DesignsList.length ; I++ ){
              open(DesignsList[I]);
              var TempDocRef = activeDocument;
              var N = TempDocRef.name
              TempDocRef.resizeImage(DimX,DimY, undefined, undefined);
              TempDocRef.selection.selectAll();
              if(TempDocRef.activeLayer.isBackgroundLayer == true){
                  TempDocRef.selection.copy();
                  }else{
                      TempDocRef.selection.copy(true);
              TempDocRef.close(SaveOptions.DONOTSAVECHANGES);
              PasteANDSave(N);
          function PasteANDSave(N){
              DocRef.artLayers.add();
              DocRef.paste();
              if(Val == 1){
                  DocRef.activeLayer.blendMode  = BlendMode.DARKEN;
              }else if(Val == 2){
                  DocRef.activeLayer.blendMode  = BlendMode.NORMAL;
              }else if(Val == 3){
                  DocRef.activeLayer.blendMode  = BlendMode.LIGHTEN;
              }else if(Val == 4){
                  DocRef.activeLayer.blendMode  = BlendMode.MULTIPLY;
              DocRef.resizeImage("1000px", DocRef.height /(DocRef.width/1050) + "px",undefined, undefined);
              var JpegOptions = new JPEGSaveOptions();
              JpegOptions.quality = 12;
              DocRef.saveAs ( new File(DesignsFolder + "/result_" + N ), JpegOptions);
              DocRef.activeHistoryState = DocRef.historyStates[0] ;
        • 1. Re: Photoshop Script Change Blend Mode
          I see some problem area
          // The above looks odd the second set of Rectangle is not effected by the fist set
          // The alpha channel can have any shape  its bounds will be a rectangle
          PosX =  Bound[0];
          PosY =  Bound[1];
          //var DesignsList = DesignsFolder.getFiles("*.psd"| "*.jpg"| "*.jpeg");  // Does not do the job for me
          var DesignsList = DesignsFolder.getFiles(/\.(jpg|jpe|jpeg|psd)$/i);
                  {Win.close();
                   Exe(1);
                  {Win.close();
                   Exe(2);
                  {Win.close();
                   Exe(3);
                  {Win.close();
                   Exe(4);
                Win.show();
          function Exe(Val){
          alert("This resize will distort images that have a different aspect ratio then the alpha chanel")
                      }else{
                  PasteANDSave(N);
                  DocRef.artLayers.add();                         // not needed paste will add a layer
          //   there may be a problem  with paste if the clipboard image has a different  color profile
          //   than the tenplate document it depends of the users Photoshop Color settings.
                  DocRef.paste();
          // You could add the selection as a layer mask to shape the pasted layer to the alpha channel shape.
                  if(Val == 1){
                  }else if(Val == 2){
                  }else if(Val == 3){
                  }else if(Val == 4){
                  JpegOptions.quality = 12;                                                  // I would use quality 10 to reduce file size
                  DocRef.saveAs ( new File(DesignsFolder + "/result_" + N ), JpegOptions);   // would save files in a subfolder so addition templates could be populated
                  DocRef.activeHistoryState = DocRef.historyStates[0] ;                      //reset Template
          DocRef.close(SaveOptions.DONOTSAVECHANGES);                                        // do not save over the template
