6 Replies Latest reply on Mar 10, 2016 9:20 PM by birderpp
    How can I tile 2 photos side by side and send them by Email?
    birderpp Level 1
      For comparison purpose I would like to send two tiled photos by email. I use a Mac OS X 10.7 Lion computer. Can I do it using LR or Photoshop Elements 10?
      I can and have been able to export/send only one photo using LR's Export page, not two tiled photos.
        • 1. Re: How can I tile 2 photos side by side and send them by Email?
          dj_paige Level 9
          The only way to put photos side-by-side in Lightroom is to use the Print module and then print to JPG. Then you can e-mail the result.
          • 2. Re: How can I tile 2 photos side by side and send them by Email?
            birderpp Level 1
            I am looking at Scott Kelby's LR 3 book in the Print Module and still cannot follow it. How does one get the Template Browser? Can you walk  me through  the process to create side-by-side photos?
            • 3. Re: How can I tile 2 photos side by side and send them by Email?
              wobertc Adobe Community Professional
              Select two images in Grid or Collections view
              Goto the Print module,
              ***Totally IGNORE the Template Browser Panel. Close it down! (It only confuses many people! the Presets are rarely suitable)
              Click on [Page Setup]
              Choose you paper size and orientation (Portrait/Landscape) in the PRINTER dialog. Confirm OK, (Windows & Macs differ slightly)
              In the "Layout Style" Panel choose [Single Image/Contact Sheet]
              In the "Layout" Panel [Page Grid] choose 'Rows' or 'Columns' =2  (depending on orientation)
              Adjust Cell Size, Margins, Cell Spacing, for visual appeal.
              In the [Image Settings] Panel- Remove all the checks from "Zoom to Fill", "Rotate to Fit" and "Repeat one photo..."
              So by now you should be seeing what you want-
              If you have "Landscape" orientation and "2 x columns" for "Side by side"
              Set [Print Job / Print to : ]  JPEG file.
              Click on [Print to File] button.
              • 4. Re: How can I tile 2 photos side by side and send them by Email?
                birderpp Level 1
                I tried following your instructions, and got as far as the Layout Panel and was able to show two images side-by-side in Image Settings. But what next?
                I then tried exporting this in Library mode and it shows separate individual images in the Folder to which it was saved to my Mac hard drive.
                I also tried, Emailing the side-by-side images (which was achieved in the Image Settings panel) using LR5 and it opened up on my Mac Email showing not side-by-side images but two separate images one after the other. By the way, in my Printer Property I was given the option to send Portrait or landscape and image size and I selected Full image size. Could that be the problem maybe because it would not fit into Letter size format? I am confused.
                • 5. Re: How can I tile 2 photos side by side and send them by Email?
                  1. In the Print Job Panel-   Set the "Print to: " option to "JPEG File"
                  2. Click on the button in the lower right of screen- [Print to File...]
                  3. Select a folder location and save the new jpg file with a suitable filename.
                  4. If you are hoping to email using Lightrooms link to email- Note: the saved image will NOT appear in the Lightroom library (until you Import it, or do a folder synchronize).  Otherwise just open your email program and send the image as an 'attached' file.
                  Can you post a screen-clip of your 'tiled' image in the print module with the "Layout" panel expanded open.?
                  • 6. Re: How can I tile 2 photos side by side and send them by Email?
                    birderpp Level 1
                    Hallelujah, it worked!!! You made my day. Many thanks for your detailed and guided instructions.
