1 Reply Latest reply on Mar 7, 2016 2:52 AM by Laubender
    How to use InDesign SDK on XCode 7.2, OS X 10.10.5 ?
    동후김83505835 Level 1
      I generate a dialog-based plug-in project using DollyXS.
      after build
      get error messages
      ld: warning: directory not found for option '-L../debug_cocoa64/packagefolder/contents/macos'
      ld: warning: directory not found for option '-L../debug_cocoa64/packagefolder/contents/macos/libs'
      ld: warning: directory not found for option '-L../debug_cocoa64/packagefolder/contents/Frameworks'
      ld: warning: directory not found for option '-L../../build/mac/debug/packagefolder/contents/macos/libs'
      ld: warning: directory not found for option '-F../debug_cocoa64/packagefolder/contents/Frameworks'
      ld: warning: directory not found for option '-F../debug_cocoa64/packagefolder/contents/macos'
      ld: warning: directory not found for option '-F../../build/mac/debug/packagefolder/contents/macos'
      ld: warning: directory not found for option '-F../../build/mac/debug/packagefolder/contents/Frameworks'
      so modify
      Build Settings - Search Paths - Framework Search Paths, LIbrary Search Paths
      after...
      get error messages
      ld: file not found: @executable_path/InDesignModel.framework/Versions/A/InDesignModel for architecture x86_64
      clang: error: linker command failed with exit code 1 (use -v to see invocation)
      All messages
      Regards.
