0 Replies Latest reply on Mar 7, 2016 10:46 AM by juggernaut1967
    Why does the coded exercise file from a Lynda course work, and my recreation of that example does not?
    juggernaut1967
      I am taking a course on Lynda.com, called
      Creating a Slideshow with Edge Animate
      The author shows you step by step how to build a basic slideshow using the timeline.
      Then he shows you how to make that same slideshow, but pull the images in dynamically. {No animation, just bare bones.
      Then he shows you how to add animation to that one and that is where it all goes off the rails.
      I made the same modifications to the one I built from scratch. Double checked the code. Everything was Identical.
      It did not work. The example from the exercise files worked fine, but my did not.
      I deleted mine and started over. Same result.
      I copied and pasted the code from the example into mine. The example worked and the mine still does not, but does behave exactly as mine did before.
      How do I get mine to behave exactly as the example does?
