0 Replies Latest reply on Dec 19, 2008 2:53 PM by Thanosb
    Connecting Flex object to View Object on ADF
    Thanosb
      I have a Flex object embedded on a JSF page and I want to connect this to a VO (View Objedct) that I have created, so that the Flex object updates when the VO updates.
      I searched on the web and I found the following
      http://biemond.blogspot.com/2008/03/flex-app-which-call-remote-java-object.html
      According to this I just build a java class on te server side and I connect the Flex object to this class.
      I tried doing that using both the embedded and the integrated server, but it does not work. When I get to the point where I build the Flex project and I try to validate the server directories, I get messages that the server is down, even if the server is running.
      I suspect that for some reason Flex cannot see the port where the server is running.
      Has anyone worked on something like that?
      Thank you in advance.
