2 Replies Latest reply on Apr 23, 2006 8:18 PM by Newsgroup_User
    setInterval or setTimeout returning values
    DuhChamp
      Is it possible for setTimeout or setInterval to use functions that return values? If so, how would it look code-wise?
        • 1. Re: setInterval or setTimeout returning values
          Level 7
          No.. any return value is ignored.
          jeckyl
          • 2. Re: setInterval or setTimeout returning values
            Level 7
            If you mean "can I invoke a function that returns a value in a
            setInterval?" , the answer is yes and the syntax is the same as when you
            use a function that does not return a value.
            if you mean "can I use the return value of a function from inside the
            setInterval call?", answer is no, the return value will be discarded. To
            achieve that, you have to use a more sophisticated approach. For example,
            invoke setInterval with a wrapper function that calls your target function
            and does something with the return value.
            Tim.
