1 Reply Latest reply on Mar 8, 2016 2:22 PM by Rick Gerard
    copy path to layer offset problems
    jmcadam2
      I'm experimenting with whiteboard animation in After Effects.
      I keep running into offset issues when copying a path to a different layer's position or anchor point properties.
      Doesn't always happen but it happens enough to be frustrating.
      Here is a 1:45 video walking you through the problem.
      The path I'm using was not imported from illustrator, but created in After effects. Any help would be appreciated.
      Feel free to send me a link if you know of any good resources that could help.
      Thanks so much
      Ryan
        • 1. Re: copy path to layer offset problems
          If the layer you are drawing pad on has been scheduled for rotated or repositioned the path will not lineup.
          The way I work is create a new white solid set the Blendwell to multiply and then draw my pathon that solid, Press alt/option plus I m to set a path keyframe and then copy it them set a position keyframe on the target layet and paste. It works every time.
