5 Replies Latest reply on Mar 10, 2016 2:53 PM by Szalam
    Windows (composition & effects and presets) not refreshing
    PandaMotion
      Not much luck googling for this answer. I am not a strong tech, but I am a heavy ae user so this is urgent for me. The windows/tabs are not refreshing. First example is in the timeline/composition windows. If I scrub through the timeline with my mouse the composition updates. When I go frame by frame (page up/page down) the composition does not update. Second example is when I search for an effect in the "effects and presets" tab. The search results remain empty no matter what I put in the textfield. A workaround I discovered is if I go in the settings panel and toggle between the view settings (categories, finder folders, alphabetical).
      I have reset the ae preferences and keep the adaptive resolution off. I know the cuda/video card is an issue, but it wasn't causing a problem in a previous version of adobe cc ae that I had a month or two ago before updating. Please let me know how I can get this fixed.
      os.pngdoes not refresh 1.pngdoes not refresh 2A.pngdoes not refresh 2B.pngae.png
        • 1. Re: Windows (composition & effects and presets) not refreshing
          Have you tried restarting your machine?
          • 2. Re: Windows (composition & effects and presets) not refreshing
            PandaMotion Level 1
            I just tried restarting with no success. My computer runs fine, but ae has been buggy for quite a while. Whenever I close ae it crashes (command q). The issue above though is new, and I am not sure if it is related. I can post the error text if that would help. I am not sure if there is sensitive information in there though.
            • 3. Re: Windows (composition & effects and presets) not refreshing
              What do you mean by this part of your first post? You haven't installed the CUDA driver on that machine have you? Avoid installing NVIDIA CUDA drivers on computers with AMD GPUs
              It might.
              Your issues sound really strange. I wonder if it's something to do with your GPU or possibly your AE install. If we can't figure something else out, you might consider uninstalling AE and installing it again.
              • 4. Re: Windows (composition & effects and presets) not refreshing
                PandaMotion Level 1
                I have not installed any cuda drivers.
                If I can't figure this out I will try a fresh install next.
                Here is the error text that I get whenever I quit ae. "Whenever" means every time for the last year at least:
                Process:               After Effects [526]
                Path:                  /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/MacOS/After Effects
                Identifier:            com.adobe.AfterEffects
                Version:               13.7 (13.7)
                Code Type:             X86-64 (Native)
                Parent Process:        ??? [1]
                Responsible:           After Effects [526]
                User ID:               501
                Date/Time:             2016-03-10 14:21:26.019 -0800
                OS Version:            Mac OS X 10.10.5 (14F27)
                Report Version:        11
                Anonymous UUID:        FEF6FFD4-AE1F-8B94-D729-084117B4B246
                Time Awake Since Boot: 300 seconds
                Crashed Thread:        0  Dispatch queue: com.apple.main-thread
                Exception Type:        EXC_BAD_INSTRUCTION (SIGILL)
                Exception Codes:       0x0000000000000001, 0x0000000000000000
                Application Specific Information:
                objc[526]: autorelease pool page 0x7face9378000 corrupted
                  magic     0x0000045c 0x30000000 0x00007c10 0x00006180
                  should be 0xa1a1a1a1 0x4f545541 0x454c4552 0x21455341
                  pthread   0x0
                  should be 0x7fff740f5300
                Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
                0   libobjc.A.dylib               0x00007fff846f12ea _objc_trap() + 0
                1   libobjc.A.dylib               0x00007fff846f142a _objc_fatal + 195
                2   libobjc.A.dylib               0x00007fff8470104a (anonymous namespace)::AutoreleasePoolPage::busted(bool) + 138
                3   libobjc.A.dylib               0x00007fff846e6c9b (anonymous namespace)::AutoreleasePoolPage::pop(void*) + 75
                4   com.apple.CoreFoundation       0x00007fff931986f2 _CFAutoreleasePoolPop + 50
                5   com.apple.Foundation           0x00007fff858ee0e3 -[NSAutoreleasePool release] + 146
                6   libwx_osx_cocoa-2.9.1.0.0.dylib 0x0000000157e2aac1 wxApp::~wxApp() + 49
                7   com.adobe.VideoCopilot.OpticalFlares 0x00000001578f26bf FlaresDialogs::~FlaresDialogs() + 31
                8   libwx_osx_cocoa-2.9.1.0.0.dylib 0x0000000157cf9a2e wxEntryCleanup() + 78
                9   com.adobe.VideoCopilot.OpticalFlares 0x00000001578f8e22 GlobalShutdown(PF_InData*) + 466
                10  FLT.dylib                     0x0000000111f6a92f FLTp_TempParamTable::GetNumParams() const + 111
                11  FLT.dylib                     0x0000000111f68350 FLTp_DispatchFilter(short, FLT_FCSpec*, FLT_FCSeqSpec const*, int, PF_InData*, PF_OutData*, PF_ParamDef**, PF_LayerDef*, void*) + 1216
                12  FLT.dylib                     0x0000000111f67361 FLTp_DoGlobal(FLT_FCSpec*, int) + 321
                13  FLT.dylib                     0x0000000111f6a002 FLTp_DisposeFCSpec(FLT_FCSpec*) + 370
                14  FLT.dylib                     0x0000000111f204e6 FLT_FilterRegistry::~FLT_FilterRegistry() + 102
                15  FLT.dylib                     0x0000000111f2252c FLT_Death() + 140
                16  com.adobe.AfterEffectsLib.framework 0x00000001102443b7 CEggApp::Unbirth() + 519
                17  com.adobe.AfterEffectsLib.framework 0x0000000110243dd5 CEggApp::Dispose() + 1253
                18  com.adobe.AfterEffectsLib.framework 0x000000011021ddea CEggApp::~CEggApp() + 202
                19  com.adobe.AfterEffectsLib.framework 0x000000011021ecaf CEggApp::~CEggApp() + 15
                20  com.adobe.AfterEffectsLib.framework 0x0000000110262d5b MainMain(bool, bool, bool, bool, bool, bool, unsigned short const*, bool, void**, int, int, int) + 1243
                21  com.adobe.AfterEffectsLib.framework 0x000000011026284b EggMain(bool, bool, bool, bool, bool, bool, unsigned short const*, bool, int) + 59
                22  com.adobe.AfterEffects         0x000000010ff8ac00 main + 2368
                23  com.adobe.AfterEffects         0x000000010ff8a2b4 start + 52
                Thread 1:: Dispatch queue: com.apple.libdispatch-manager
                0   libsystem_kernel.dylib         0x00007fff918e7232 kevent64 + 10
                1   libdispatch.dylib             0x00007fff92beea6a _dispatch_mgr_thread + 52
                Thread 2:
                0   libsystem_kernel.dylib         0x00007fff918e694a __workq_kernreturn + 10
                1   libsystem_pthread.dylib       0x00007fff84b6c3dd start_wqthread + 13
                Thread 3:
                Thread 4:
                0   libsystem_kernel.dylib         0x00007fff918e6136 __psynch_cvwait + 10
                1   com.apple.CoreServices.CarbonCore 0x00007fff8dbe9a77 TSWaitOnCondition + 108
                2   com.apple.CoreServices.CarbonCore 0x00007fff8dbe9c76 TSWaitOnConditionTimedRelative + 171
                3   com.apple.CoreServices.CarbonCore 0x00007fff8dbbfd6b MPWaitOnQueue + 192
                4   com.adobe.dvacore.framework   0x0000000113c316c8 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr<dvacore::threads::Al locatedFunctionT<boost::function<void ()> > >&, int) + 152
                5   com.adobe.dvacore.framework   0x0000000113c2ea28 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 152
                6   com.adobe.dvacore.framework   0x0000000113c2b41a dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 202
                7   com.adobe.boost_threads.framework 0x0000000119635ee5 boost::(anonymous namespace)::thread_proxy(void*) + 133
                8   libsystem_pthread.dylib       0x00007fff84b6f05a _pthread_body + 131
                9   libsystem_pthread.dylib       0x00007fff84b6efd7 _pthread_start + 176
                10  libsystem_pthread.dylib       0x00007fff84b6c3ed thread_start + 13
                Thread 5:
                0   libsystem_kernel.dylib         0x00007fff918e721a kevent + 10
                1   com.adobe.dvatransport.framework 0x0000000119363b6c boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 284
                2   com.adobe.dvatransport.framework 0x00000001193636d8 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 568
                3   com.adobe.dvatransport.framework 0x00000001193521b2 SkyConnectionEnv::MainLoop() + 162
                4   com.adobe.dvatransport.framework 0x0000000119351b49 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
                5   com.adobe.boost_threads.framework 0x0000000119635ee5 boost::(anonymous namespace)::thread_proxy(void*) + 133
                6   libsystem_pthread.dylib       0x00007fff84b6f05a _pthread_body + 131
                7   libsystem_pthread.dylib       0x00007fff84b6efd7 _pthread_start + 176
                8   libsystem_pthread.dylib       0x00007fff84b6c3ed thread_start + 13
                Thread 6:
                1   com.adobe.dvatransport.framework 0x0000000119363c0b boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 443
                3   com.adobe.dvatransport.framework 0x000000011936347a boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_ io_service_runner>::run() + 42
                4   com.adobe.dvatransport.framework 0x00000001193646e3 boost_asio_detail_posix_thread_function + 19
                5   libsystem_pthread.dylib       0x00007fff84b6f05a _pthread_body + 131
                6   libsystem_pthread.dylib       0x00007fff84b6efd7 _pthread_start + 176
                7   libsystem_pthread.dylib       0x00007fff84b6c3ed thread_start + 13
                Thread 7:
                Thread 8:
                Thread 9:
                0   libsystem_kernel.dylib         0x00007fff918e14de mach_msg_trap + 10
                1   libsystem_kernel.dylib         0x00007fff918e064f mach_msg + 55
                2   com.apple.CoreFoundation       0x00007fff931d0eb4 __CFRunLoopServiceMachPort + 212
                3   com.apple.CoreFoundation       0x00007fff931d037b __CFRunLoopRun + 1371
                4   com.apple.CoreFoundation       0x00007fff931cfbd8 CFRunLoopRunSpecific + 296
                5   com.apple.AVCVideoServices     0x0000000142cafdb2 AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 162
                Thread 10:: com.apple.audio.IOThread.client
                2   com.apple.audio.CoreAudio     0x00007fff87b2b57e HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 98
                3   com.apple.audio.CoreAudio     0x00007fff87b2b50c HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
                4   com.apple.audio.CoreAudio     0x00007fff87b29aa9 HALC_ProxyIOContext::IOWorkLoop() + 965
                5   com.apple.audio.CoreAudio     0x00007fff87b29612 HALC_ProxyIOContext::IOThreadEntry(void*) + 88
                6   com.apple.audio.CoreAudio     0x00007fff87b294e3 HALB_IOThread::Entry(void*) + 157
                7   libsystem_pthread.dylib       0x00007fff84b6f05a _pthread_body + 131
                8   libsystem_pthread.dylib       0x00007fff84b6efd7 _pthread_start + 176
                9   libsystem_pthread.dylib       0x00007fff84b6c3ed thread_start + 13
                Thread 11:: cr_scratch
                1   com.adobe.CameraRaw           0x000000014515777b 0x1448c2000 + 9000827
                2   com.adobe.CameraRaw           0x00000001450e384b 0x1448c2000 + 8525899
                3   com.adobe.CameraRaw           0x0000000144e713f1 0x1448c2000 + 5960689
                4   libsystem_pthread.dylib       0x00007fff84b6f05a _pthread_body + 131
                5   libsystem_pthread.dylib       0x00007fff84b6efd7 _pthread_start + 176
                6   libsystem_pthread.dylib       0x00007fff84b6c3ed thread_start + 13
                Thread 12:
                Thread 13:
                1   com.adobe.headlights.LogSessionFramework 0x000000011224d1ac boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
                2   com.adobe.headlights.LogSessionFramework 0x000000011224ba6e boost::this_thread::hiden::sleep_until(timespec const&) + 78
                3   com.adobe.headlights.LogSessionFramework 0x00000001121f4523 RealTimeProcessor::Sleep(int) + 243
                4   com.adobe.headlights.LogSessionFramework 0x00000001121f2b32 RealTimeProcessor::WorkerThread() + 2660
                5   com.adobe.headlights.LogSessionFramework 0x000000011224aaca boost::(anonymous namespace)::thread_proxy(void*) + 138
                Thread 14:: com.apple.NSURLConnectionLoader
                5   com.apple.CFNetwork           0x00007fff85c0d420 +[NSURLConnection(Loader) _resourceLoadLoop:] + 434
                6   com.apple.Foundation           0x00007fff85910e92 __NSThread__main__ + 1345
                Thread 15:: com.apple.CFSocket.private
                0   libsystem_kernel.dylib         0x00007fff918e63fa __select + 10
                1   libsystem_pthread.dylib       0x00007fff84b6f05a _pthread_body + 131
                2   libsystem_pthread.dylib       0x00007fff84b6efd7 _pthread_start + 176
                3   libsystem_pthread.dylib       0x00007fff84b6c3ed thread_start + 13
                Thread 16:
                5   com.apple.AppKit               0x00007fff8705256b _NSEventThread + 137
                Thread 17:
                5   com.apple.Foundation           0x00007fff859f6c80 -[NSConnection run] + 152
                Thread 18:
                1   com.apple.Foundation           0x00007fff85910fd8 -[NSCondition wait] + 237
                2   com.apple.Foundation           0x00007fff85901e6e -[NSObject(NSThreadPerformAdditions) performSelector:onThread:withObject:waitUntilDone:modes:] + 823
                3   com.apple.Foundation           0x00007fff85901ab9 -[NSObject(NSThreadPerformAdditions) performSelectorOnMainThread:withObject:waitUntilDone:] + 131
                4   com.adobe.PlugPlug             0x0000000127f38d15 -[HtmlEngineMonitor monitorThreadProc] + 146
                5   com.apple.Foundation           0x00007fff85910e92 __NSThread__main__ + 1345
                Thread 19:
                0   libsystem_kernel.dylib         0x00007fff918e151a semaphore_wait_trap + 10
                1   libtbb.dylib                   0x000000011d2c7550 tbb::internal::rml::private_worker::thread_routine(void*) + 480
                2   libsystem_pthread.dylib       0x00007fff84b6f05a _pthread_body + 131
                3   libsystem_pthread.dylib       0x00007fff84b6efd7 _pthread_start + 176
                4   libsystem_pthread.dylib       0x00007fff84b6c3ed thread_start + 13
                Thread 20:
                Thread 21:
                Thread 22:
                Thread 23:
                Thread 24:
                Thread 25:
                Thread 26:
                Thread 27:
                Thread 28:
                Thread 29:
                Thread 30:
                Thread 0 crashed with X86 Thread State (64-bit):
                  rax: 0x0000000000000000  rbx: 0x00007face9378000  rcx: 0x0000000000000000  rdx: 0x00007fff740881e0
                  rdi: 0x0000000000000103  rsi: 0x0000010000000100  rbp: 0x00007fff4fc77760  rsp: 0x00007fff4fc77678
                   r8: 0x00007fff4fc77620   r9: 0x0000000000000000  r10: 0x00007fff918e1412  r11: 0xffffe1531388e810
                  r12: 0x0000000030000000  r13: 0x0000000000000000  r14: 0x0000000000000001  r15: 0x0000000000006180
                  rip: 0x00007fff846f12ea  rfl: 0x0000000000010206  cr2: 0x00007fff96db17ef
                Logical CPU:     2
                Error Code:      0x00000000
                Trap Number:     6
                Binary Images:
                       0x10ff87000 -        0x10ff8efff +com.adobe.AfterEffects (13.7 - 13.7) <F366C7F5-70A9-3287-8E26-915F19971369> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/MacOS/After Effects
                       0x10ff9e000 -        0x10ffacfff +com.adobe.boost_filesystem.framework (13.7.0 - 13.7.0.124) <0598F2EE-AF34-3C4F-80BE-D343FC4B80AE> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
                       0x10ffc0000 -        0x10ffccfff +com.adobe.boost_signals.framework (13.7.0 - 13.7.0.124) <EE1916F4-AF60-3E7F-BE31-38D53C205E98> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
                       0x10ffe4000 -        0x10ffe9ff7 +com.adobe.boost_system.framework (13.7.0 - 13.7.0.124) <B11874AA-1CF9-34D6-8DE0-C32CB56B2EBA> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                       0x10fff9000 -        0x110001ff7 +com.adobe.boost_date_time.framework (13.7.0 - 13.7.0.124) <1D1322A3-A45F-3930-B55B-0254784B95E2> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                       0x110019000 -        0x11001dff7 +ALOG.dylib (1) <3139AE7E-6055-3253-9A12-27FD2CFD4A1D> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/ALOG.dylib
                       0x110027000 -        0x110e26ff7 +com.adobe.AfterEffectsLib.framework (AfterFXLib 1.0 - 1.0) <5F2C4E64-2B7B-36BD-BEFA-27D35A48E9FC> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AfterFXLib.framework/Versions/A/AfterFXLib
                       0x11131d000 -        0x111a5bff7 +BEE.dylib (1) <716FDCD1-1662-388D-85DA-D784A63DDE5B> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/BEE.dylib
                       0x111d71000 -        0x111d83ff7 +BEZ.dylib (1) <9C0151AE-9D42-3E54-85D7-213E2416CF3D> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/BEZ.dylib
                       0x111d90000 -        0x111d99ff7 +BM.dylib (1) <0A0AE1C7-BBA3-3167-A31D-BD3935F8D83B> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/BM.dylib
                       0x111da3000 -        0x111e1fff7 +COR.dylib (1) <187461EC-AB02-3112-9DB2-D7CA921C30F3> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/COR.dylib
                       0x111e59000 -        0x111e89ff7 +FILE.dylib (1) <203B5762-A125-3140-A6A6-04AC2BE22E6D> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/FILE.dylib
                       0x111ea3000 -        0x111ea5ff7  com.apple.textencoding.unicode (2.8 - 2.8) <A2CAC6A6-82CE-3929-94F8-538375EC3DF9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                       0x111eaa000 -        0x111f07ff7 +FLO.dylib (1) <EFD10B56-C8B9-36FC-900A-4DE77125F576> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/FLO.dylib
                       0x111f1e000 -        0x111fb6fff +FLT.dylib (1) <9CE168C7-1217-316E-8CDD-A0CC715775B1> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/FLT.dylib
                       0x11202e000 -        0x11203aff7 +LIST.dylib (1) <6DA96B36-8C82-3B74-AF3A-4E4E5B6AB62B> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/LIST.dylib
                       0x112049000 -        0x112066ff7 +M.dylib (1) <F829E965-844D-30AA-9117-FD1D562C05BD> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/M.dylib
                       0x112077000 -        0x1120abff7 +MC.dylib (1) <B1400963-2F40-3CEA-A20E-8341E557AFC2> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/MC.dylib
                       0x1120c8000 -        0x11213fff7 +MSK.dylib (1) <ADEF27BD-BEC9-3606-9ED7-CD83108AC515> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/MSK.dylib
                       0x112167000 -        0x1122a6ff7 +com.adobe.headlights.LogSessionFramework (7.3.1.70) <408F19FE-B672-3E82-89B6-B782E000D2B0> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                       0x112361000 -        0x1123a5fff +OM.dylib (1) <035DBCC3-5012-3345-B8FD-F047775A659A> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/OM.dylib
                       0x1123bb000 -        0x1123e4ff7 +P.dylib (1) <8F63595A-A55F-3CA6-95D0-74F2A40372CA> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/P.dylib
                       0x1123f8000 -        0x1126ffff7 +PF.dylib (1) <8E721377-1418-3A38-9BFC-C65A60216B4A> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/PF.dylib
                       0x1127dc000 -        0x112a72ff7 +PIN.dylib (1) <E66C56DE-AADE-3A56-B551-D15630C6C96E> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/PIN.dylib
                       0x112b4e000 -        0x112b72fff +PLUG.dylib (1) <DED96883-B4D0-3DB1-88E0-EDBB7FBEB3D7> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/PLUG.dylib
                       0x112b87000 -        0x112b88fff  ATSHI.dylib (375.4) <55F6C886-CBBA-3065-9283-C6D73A7EFB1F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
                       0x112b8e000 -        0x112bb2fff +PR.dylib (1) <E1937F65-C713-3E99-9E7F-F0B0DD615766> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/PR.dylib
                       0x112bc8000 -        0x112be7ff7 +PREF.dylib (1) <8D308D69-5D35-3475-9194-D0DB096AE824> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/PREF.dylib
                       0x112bf8000 -        0x112c1afff +RG.dylib (1) <7B4D89EF-88B1-3F0F-B721-EA0C8582F50E> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/RG.dylib
                       0x112c33000 -        0x112c34ff7 +RND.dylib (1) <469A0009-0684-3FB4-9F61-08A60FDD0D9C> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/RND.dylib
                       0x112c42000 -        0x112cabfff +SLU.dylib (1) <2DE3563F-00BF-3BD6-9FAC-DA50195D3776> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/SLU.dylib
                       0x112ce8000 -        0x112d1bfff +SND.dylib (1) <7CC0F72C-2FC1-3C31-899A-4197B62A7FAC> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/SND.dylib
                       0x112d2d000 -        0x112d32ff7 +STR.dylib (1) <D755316B-C4CA-3D4B-9A9F-A65E0B182DD2> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/STR.dylib
                       0x112d40000 -        0x112d46fff +T.dylib (1) <6E98AC84-BB0E-3B1B-92DB-62F71B521598> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/T.dylib
                       0x112d4d000 -        0x112da1fff +TDB.dylib (1) <219B3759-D6AD-3F96-9146-D9D200D59835> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/TDB.dylib
                       0x112dcb000 -        0x1134affff +TXT.dylib (1) <85F2FB4D-2363-35A4-981A-1885B28490EA> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/TXT.dylib
                       0x1136f8000 -        0x11377aff7 +U.dylib (1) <1A0FC4D9-D9BD-38CE-93E0-738B59ED5650> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/U.dylib
                       0x1137b3000 -        0x1137b6fff +VAL.dylib (1) <F44B776D-1D04-334A-87E1-AC338A9E06FC> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/VAL.dylib
                       0x1137be000 -        0x11389cfff +com.adobe.exo.framework (13.7.0 - 13.7.0.124) <AAEE0DE1-188D-3CD2-97C3-A110A0A844AF> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/exo.framework/Versions/A/exo
                       0x113a25000 -        0x113a5afff +PREM.dylib (1) <4C8E3343-9B01-32B7-BFF1-B2B78355A3F6> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/PREM.dylib
                       0x113a7f000 -        0x113adffff +FRP.dylib (1) <80D89803-B0F7-3DC9-90FB-341B9ED4DAB4> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/FRP.dylib
                       0x113b06000 -        0x113dfefff +com.adobe.dvacore.framework (13.7.0 - 13.7.0.124) <58AEAC0A-E535-35CA-93EB-8E4D986ED9CA> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                       0x11407e000 -        0x114685ff7 +com.adobe.dvaui.framework (13.7.0 - 13.7.0.124) <20FE218A-0CD7-31C0-AE33-10015A09B916> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
                       0x114f2f000 -        0x1150b6fff +com.adobe.dvaworkspace.framework (13.7.0 - 13.7.0.124) <2E8B2E29-892C-35E1-80A2-79E7DFB99F1B> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
                       0x11532d000 -        0x115355fff +com.adobe.dvaunittesting.framework (13.7.0 - 13.7.0.124) <2CD808CC-7F01-3D46-B989-850336B6B9E9> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
                       0x11539b000 -        0x1153f5fff +com.adobe.dynamiclinkui.framework (13.7.0 - 13.7.0.124) <5D69E280-E0C4-3453-95A7-361CC5867833> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynamiclinkui
                       0x115485000 -        0x115486ff7  libCyrillicConverter.dylib (64) <91BE01AF-E364-3DF4-9968-05996B748FE0> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
                       0x11548a000 -        0x115701fff +com.adobe.dynamiclink.framework (13.7.0 - 13.7.0.124) <2D2C1544-C717-37AE-9BDB-A1AA75630C4F> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
                       0x115971000 -        0x1159c2fff +com.adobe.ASLFoundation.framework (13.7.0 - 13.7.0.124) <6231D3BE-1F90-3110-8A24-437CF9807102> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
                       0x115a32000 -        0x115a45fff +com.adobe.ASLMessaging.framework (13.7.0 - 13.7.0.124) <5B6B320E-EAB5-32CC-8821-B40DD7DFCC5E> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
                       0x115a64000 -        0x115a76ff7 +com.adobe.ASLUnitTesting.framework (13.7.0 - 13.7.0.124) <95AE3B0F-7556-398A-B10B-EDD6EA3445AA> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
                       0x115a99000 -        0x115addfff +com.adobe.AudioFilterHost.framework (13.7.0 - 13.7.0.124) <1F02FC1C-226F-35E6-B5EB-A182592B3C1B> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
                       0x115b47000 -        0x115b91ff7 +com.adobe.AudioFilters.framework (13.7.0 - 13.7.0.124) <67C59CA0-19AE-3F4D-8E84-346D05269F97> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
                       0x115c12000 -        0x115cbafff +com.adobe.AudioRenderer.framework (13.7.0 - 13.7.0.124) <0B2ED4EC-CB9B-31EE-8140-BF28F88B602D> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
                       0x115d8e000 -        0x115df4ff7 +com.adobe.AudioSupport.framework (13.7.0 - 13.7.0.124) <992F4818-7C43-315D-A3E8-0FF4D3734DB6> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
                       0x115e67000 -        0x116d53ff7 +com.adobe.Backend.framework (13.7.0 - 13.7.0.124) <DC2F61AA-9119-3387-88BF-38A60F87B14E> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
                       0x117a65000 -        0x117bc6fd7 +com.adobe.ImageRenderer.framework (13.7.0 - 13.7.0.124) <D9CEF08B-3740-3DE5-BBAE-7BBCB19A0208> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
                       0x117cd7000 -        0x117e8fff7 +com.adobe.ImporterHost.framework (13.7.0 - 13.7.0.124) <DABA7FE0-1C9E-37AC-98D1-0BD5B870E7A7> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
                       0x11803f000 -        0x1180e5fff +com.adobe.MediaFoundation.framework (13.7.0 - 13.7.0.124) <66B8DD2C-50EC-3171-9D2B-597E395FEFDE> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
                       0x1181ad000 -        0x1181b3ff7 +com.adobe.MediaUtils.framework (13.7.0 - 13.7.0.124) <2C1F6735-D26A-3A80-BAE6-9318220E2079> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
                       0x1181c3000 -        0x1181c8ff7 +com.adobe.Memory.framework (13.7.0 - 13.7.0.124) <D91F72FF-0F3A-3A2B-AB6D-51D103F1F36E> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
                       0x1181da000 -        0x118212ff7 +com.adobe.MLFoundation.framework (13.7.0 - 13.7.0.124) <3AC6B08D-2D65-3F5E-9A24-8CCA9E488BB3> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
                       0x118263000 -        0x1182a8fff +com.adobe.PluginSupport.framework (13.7.0 - 13.7.0.124) <688279D7-2B5D-3052-B0AD-6B37EFFA1BCC> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
                       0x1182f8000 -        0x1182fffff +com.adobe.PRM.framework (13.7.0 - 13.7.0.124) <42476E30-CD9D-3A97-87A5-5E7AECF37228> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
                       0x118316000 -        0x118346fff +com.adobe.SweetPeaSupport.framework (13.7.0 - 13.7.0.124) <BDEF6511-B4C8-311B-BD68-4849053A61F2> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
                       0x118395000 -        0x118417fff +com.adobe.VideoFrame.framework (13.7.0 - 13.7.0.124) <642AADB7-0B57-3BF1-AB07-36D339E71227> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
                       0x11848d000 -        0x1185d6ff7 +com.adobe.VideoRenderer.framework (13.7.0 - 13.7.0.124) <B769F170-7FEC-3A21-A56F-2247CB940311> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
                       0x11872f000 -        0x118821ff7 +com.adobe.dvaeve.framework (13.7.0 - 13.7.0.124) <F0B7D504-F368-3657-9206-794E8DAD9F60> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
                       0x11896b000 -        0x1189dcfff +com.adobe.PlayerHost.framework (13.7.0 - 13.7.0.124) <FB6114E8-44BE-309B-A10D-570D96AB2A80> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
                       0x118a71000 -        0x118b84ff7 +com.adobe.VideoFilterHost.framework (13.7.0 - 13.7.0.124) <460B1DF8-2182-3FC2-BC57-E5B6ADC2934E> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
                       0x118c89000 -        0x118d32ff7 +com.adobe.ICUConverter (4.0 - 3.61) <E20E390A-9BAF-3454-BA16-7B9CCD4CA8F0> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
                       0x118d5b000 -        0x118dc8fff +com.adobe.ICUData (4.0 - 3.61) <1770B361-1521-3A4F-A2D5-FE17EC641669> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
                       0x118dd0000 -        0x118eb0fff +com.adobe.dvametadata.framework (13.7.0 - 13.7.0.124) <E17E9401-EECB-39D3-B1FB-12E3C58E9B90> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
                       0x118f92000 -        0x1190bbfff +com.adobe.dvametadataUI.framework (13.7.0 - 13.7.0.124) <C3211730-6572-3600-9D15-BC16D3252201> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
                       0x119215000 -        0x11927eff7 +com.adobe.dvatemporalxmp.framework (13.7.0 - 13.7.0.124) <402DDFB8-6734-3A29-A4DE-FAC647E53527> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
                       0x1192c0000 -        0x1192feff7 +com.adobe.dvamediatypes.framework (13.7.0 - 13.7.0.124) <B2FD8604-D0D7-369E-B845-205DDD65E258> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
                       0x119338000 -        0x1193a4ff7 +com.adobe.dvatransport.framework (13.7.0 - 13.7.0.124) <50799C27-A07F-333B-9D70-F8DF247A512E> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
                       0x11943e000 -        0x11946bfff +com.adobe.dvamarshal.framework (13.7.0 - 13.7.0.124) <BEAFCD37-C983-3CB0-801E-303A50CA2F86> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
                       0x1194b2000 -        0x1194cdfff +com.adobe.ProjectSupport.framework (13.7.0 - 13.7.0.124) <2493872D-86E2-3D42-9E0D-A035888D82A2> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
                       0x119501000 -        0x119566fff +com.adobe.DynamicLinkMedia.framework (13.7.0 - 13.7.0.124) <FC3F3C6F-CAA1-3D8B-98FE-18CE8C277D4E> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
                       0x119624000 -        0x119627fff +com.adobe.AdobeCrashReporter (7.2 - 7.2.3) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                       0x119634000 -        0x119643fff +com.adobe.boost_threads.framework (13.7.0 - 13.7.0.124) <C58DDD22-16FA-3C8D-B2E4-D7C864F7F032> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                       0x119661000 -        0x119e7bfff +libmkl_intel_lp64.dylib (0) <5788E2BB-1AE0-36E2-B511-016F9F045647> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libmkl_intel_lp64.dylib
                       0x119f48000 -        0x11adccfff +libmkl_intel_thread.dylib (0) <F1F7D1CC-9AB9-32F1-8A4C-49B32AE1C5C1> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libmkl_intel_thread.dylib
                       0x11b1dc000 -        0x11c536fe7 +libmkl_core.dylib (0) <DDDCB14C-5D3E-304F-8FFB-B2CF61331563> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libmkl_core.dylib
                       0x11c727000 -        0x11c7f9fcf +libiomp5.dylib (5) <0F6E6453-A6B5-378F-B6DE-3F73ECCE2437> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libiomp5.dylib
                       0x11c850000 -        0x11c8e4fff +libopencv_calib3d.2.4.8.dylib (0) <B2FB4E9B-507D-32DF-A021-E4A2A2D141FF> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libopencv_calib3d.2.4.8.dylib
                       0x11c901000 -        0x11cb12ff7 +libopencv_core.2.4.8.dylib (0) <CF98F320-D586-3F25-9F12-6ECFEADB4014> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libopencv_core.2.4.8.dylib
                       0x11cb71000 -        0x11cc05ff7 +libopencv_features2d.2.4.8.dylib (0) <6176DA7A-A9EC-3405-AD67-F3D683AAF652> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libopencv_features2d.2.4.8.dylib
                       0x11cc33000 -        0x11cc85fff +libopencv_flann.2.4.8.dylib (0) <F37D436E-D5B4-3230-B6E5-652888B52AA2> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libopencv_flann.2.4.8.dylib
                       0x11ccbd000 -        0x11ce8dfff +libopencv_highgui.2.4.8.dylib (0) <77F8A9EF-F112-3656-8BA4-AA4ADE799CAD> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libopencv_highgui.2.4.8.dylib
                       0x11ceff000 -        0x11d0c3ff7 +libopencv_imgproc.2.4.8.dylib (0) <0253A41D-5C67-3757-A733-80D14E3AB9CC> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libopencv_imgproc.2.4.8.dylib
                       0x11d1cf000 -        0x11d23cff7 +libopencv_objdetect.2.4.8.dylib (0) <2FB35359-29F0-3793-A876-ACBB73B4DFA7> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libopencv_objdetect.2.4.8.dylib
                       0x11d261000 -        0x11d2aafff +libopencv_video.2.4.8.dylib (0) <D624B586-618E-31B4-94A5-FE6BD2A864D0> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libopencv_video.2.4.8.dylib
                       0x11d2b9000 -        0x11d2e9fef +libtbb.dylib (0) <D41FA1F0-4921-308A-93DF-4D16F8913472> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libtbb.dylib
                       0x11d308000 -        0x11d32dfff +libtbbmalloc.dylib (0) <60EF4F46-298B-38B6-A6CD-9B168072EAB7> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libtbbmalloc.dylib
                       0x11d35e000 -        0x11d387fff +SegMatServices.dylib (1) <7AA548EA-B139-3AED-8BD2-13E6F32482F4> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/SegMatServices.dylib
                       0x11d3a7000 -        0x11d3b0ff7 +SAM.dylib (1) <AD98E15F-BDB3-30F7-8CF9-1273818432D0> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/SAM.dylib
                       0x11d3ba000 -        0x11d440fff +TDL.dylib (1) <9AEACC19-9F8B-3887-8AEE-06D6538FE26A> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/TDL.dylib
                       0x11d464000 -        0x11d4edff7 +MEE.dylib (1) <A6CE1A17-6819-39E5-8B72-202767A61FBD> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/MEE.dylib
                       0x11d511000 -        0x11d515fff  com.apple.agl (3.3.0 - AGL-3.3.0) <4E8F579B-A2E2-3A27-96D7-02A9465A78D8> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                       0x11d521000 -        0x11d612fff +com.adobe.adobe_caps (adobe_caps 9.0.0.28 - 9.0.0.28) <5FA2F01A-0E75-3655-8CC0-C09088813A57> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                       0x11d629000 -        0x11d72bfff +com.adobe.amtlib (9.0.0.89 - 9.0.0.89) <EBF9B7FD-5C40-31E1-976E-D5B5608080B9> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                       0x11d73e000 -        0x11dc49ff7 +com.adobe.EAClient.framework (13.7.0 - 13.7.0.124) <8D1AA1E7-196F-354E-B3D3-E0A166050337> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/EAClient.framework/Versions/A/EAClient
                       0x11e18e000 -        0x11e480ff7 +com.adobe.EAMedia.framework (13.7.0 - 13.7.0.124) <AD645976-3D07-3195-8972-06BE95B531A0> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/EAMedia.framework/Versions/A/EAMedia
                       0x11e75a000 -        0x11ec2cfff +com.adobe.EAProjectBridge.framework (13.7.0 - 13.7.0.124) <2C5D408D-7D40-37B2-925E-D079830F535D> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/EAProjectBridge.framework/Versions/A/EAProjectBridge
                       0x11f0f3000 -        0x11f11eff7 +com.adobe.eaurl.framework (13.7.0 - 13.7.0.124) <1AFDB8C4-C57A-35BC-84B8-51E9583FED4E> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/eaurl.framework/Versions/A/eaurl
                       0x11f15e000 -        0x11f1caff7 +com.adobe.aif_core.framework (13.7.0 - 13.7.0.124) <8D3AD8CA-7432-3C28-AB6C-A4718790D167> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
                       0x11f212000 -        0x11f2b3ff7 +com.adobe.aif_ogl.framework (13.7.0 - 13.7.0.124) <A1ADAFA2-F356-3337-A5C1-02B4330CEDA5> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
                       0x11f33f000 -        0x11f365fff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.35138 - 3.8.0.35138) <1D4C43D5-BD93-3479-9180-C53C57ED5365> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExp at
                       0x11f38c000 -        0x11f502fff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 111 - 79.158325) <0DF03DF6-1105-3715-846B-F110CD7ABF7F> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                       0x11f5ec000 -        0x11f74aff7 +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.6 -f 168 - 79.158325) <54620EAA-BE33-39D8-85E2-3B6233A81517> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
                       0x11f816000 -        0x11f816ff5 +cl_kernels (???) <EEA99D62-6BB0-4A23-92BC-8695781AD808> cl_kernels
                       0x11f81b000 -        0x11f85efff +com.adobe.boost_program_options.framework (13.7.0 - 13.7.0.124) <2B6BBAC2-549C-37F9-B384-64C245A08891> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/boost_program_options.framework/Versions/A/boost_program_opt ions
                       0x11f8b1000 -        0x11f8b1fef +cl_kernels (???) <FAC0ED12-E543-4E73-8AB8-D05F6240B1C9> cl_kernels
                       0x11f8b3000 -        0x11f969fff +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.1) <301A46EC-9FBF-3BA5-9A37-F4162060BF38> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                       0x11f9b4000 -        0x11fa76fff +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.1) <BA3DD538-DDFC-3F17-BD0C-ED236538B40F> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
                       0x11fac8000 -        0x11fb11ff7 +com.adobe.dvanet.framework (13.7.0 - 13.7.0.124) <C4E004BD-9247-32AB-AEAE-BC2B9342E9CE> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
                       0x11fb86000 -        0x11fcabff7 +com.adobe.dvanetsync.framework (13.7.0 - 13.7.0.124) <243549CC-FEA3-3F8D-AC17-373AA4C16344> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvanetsync.framework/Versions/A/dvanetsync
                       0x11fe11000 -        0x11fe32fff +com.adobe.BIB (AdobeBIB 1.2.03.35138 - 1.2.03.35138) <11EBACBD-C7F8-3E80-A2BF-E87543B5CE11> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                       0x11fe40000 -        0x11ff32fff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.35138 - 3.8.0.35138) <1B0545E8-1604-3226-93FC-5A1E0A33A055> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                       0x11ffd7000 -        0x11ffd8fff +com.adobe.AfterEffects.ExpressionControls (???) <C08DB74E-BB0B-3853-88E6-DEC54EA70A1D> /Applications/Adobe After Effects CC 2015/*/ExpressionControls.plugin/Contents/MacOS/ExpressionControls
                       0x11ffdd000 -        0x12033afff +com.adobe.CoolType (AdobeCoolType 5.15.00.35138 - 5.15.00.35138) <E750B0C0-428C-36F7-A6EF-07D8E8A95F06> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                       0x120389000 -        0x1206b3fff +com.adobe.AGM (AdobeAGM 4.30.60.35138 - 4.30.60.35138) <7B00FE6F-5B1E-31C0-9ED0-599F1EC1EC37> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                       0x120729000 -        0x120888ff7 +com.adobe.ACE (AdobeACE 2.20.02.35138 - 2.20.02.35138) <84F6B526-935A-3C14-8E1F-C9E0020C4C2D> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                       0x12089d000 -        0x1208c3ff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <6536192E-56D1-3EF0-97A9-04630B74CE0C> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                       0x1208cb000 -        0x120995ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.35138) <4205548A-573A-364B-93D0-F61996DD723A> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                       0x1209e0000 -        0x120a1cfff +com.adobe.ARE (AdobeARE 1.5.02.35138 - 1.5.02.35138) <54AA8EE4-A877-31A5-A089-835F4F144217> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
                       0x120a2a000 -        0x120defff7 +com.adobe.MPS (AdobeMPS 5.8.1.35138 - 5.8.1.35138) <809BAAB6-9F24-39D8-9101-B6D65FB1F7FC> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                       0x120e60000 -        0x120e86ff7 +com.adobe.AXE16SharedExpat (AdobeAXE16SharedExpat 3.8.0.35138 - 3.8.0.35138) <067412C8-422A-3FD9-AAA8-32D653C0F624> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedE xpat
                       0x120eb2000 -        0x1230def47 +com.adobe.psl (AdobePSL 15.1.0.34015 - 15.1.0.34015) <7B2AA133-FD2F-3DF4-9737-994B710AB33F> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
                       0x12356a000 -        0x123698fff +com.winsoft.wrservices (WRServices 7.0.0 - 7.0.0) <0853A41B-A14A-37B7-B27F-457F87865EAD> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                       0x1236fb000 -        0x123809ff7 +com.adobe.ExporterHost.framework (13.7.0 - 13.7.0.124) <EB8219BA-4BA3-3BBB-8997-C2D5D26E1EB6> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
                       0x123909000 -        0x123925fff +com.adobe.ahclientframework (2.0.0.1 - 2.0.0.1) <075BD455-9D2E-3B8A-8C83-8B40D3059A55> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                       0x123933000 -        0x12415afff +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 15.0.0.35138) <4BE53AB4-D541-37E6-9A79-2321A1F5E0C7> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
                       0x124216000 -        0x125617f2f +liboptix.1.dylib (3.0.1) <F73808E6-D80C-065F-00F6-FF446FB5CD29> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/liboptix.1.dylib
                       0x125d60000 -        0x125dcafef +libcudart.dylib (4.2) <6FD33B3C-5941-CE4A-41B5-F80250A591E1> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libcudart.dylib
                       0x125dd9000 -        0x125ddafff +libtlshook.dylib (4) <1D1C35CB-E17F-79E0-7DAE-988625AB57F9> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libtlshook.dylib
                       0x125de1000 -        0x125f29ff7 +com.adobe.AIDE (1.5.0 - 1.5.0.35138) <8640BC1A-99DC-3131-8EA2-58D4901D5693> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
                       0x125f8a000 -        0x126089ff7 +com.adobe.dvacaptioning.framework (13.7.0 - 13.7.0.124) <1766AAB8-5A0D-3FAC-8DF3-4DA1EAD6533E> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvacaptioning.framework/Versions/A/dvacaptioning
                       0x126160000 -        0x126177fff +com.adobe.ProjectConverterHost.framework (13.7.0 - 13.7.0.124) <35B40D67-F9E2-3507-A1AD-DE93F19B7B57> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A/ProjectConverterHo st
                       0x1261a3000 -        0x126369fff +com.adobe.EncoderHost.framework (13.7.0 - 13.7.0.124) <20EC6BD6-3FC8-318B-9A88-3409509F81F0> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
                       0x126507000 -        0x126724fff +com.adobe.SettingsUI.framework (13.7.0 - 13.7.0.124) <C663AC41-977F-3053-AE96-1279EF434FD9> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
                       0x126a0b000 -        0x126a72fff +com.adobe.QT32Client.framework (13.7.0 - 13.7.0.124) <3E452012-E546-340E-B404-073A559A6777> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Client
                       0x126b01000 -        0x126cf9fff +com.adobe.EACodec.framework (13.7.0 - 13.7.0.124) <BB57863D-A02F-3B42-A820-F87C1996898C> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/EACodec.framework/Versions/A/EACodec
                       0x126dd0000 -        0x126ec2ff7 +com.adobe.MBCProvider.framework (13.7.0 - 13.7.0.124) <83FC6B68-1832-35A5-959B-92549B3D782A> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/MBCProvider.framework/Versions/A/MBCProvider
                       0x126f97000 -        0x126feafff +com.adobe.TransmitHost.framework (13.7.0 - 13.7.0.124) <079F3F9F-2425-32E2-A990-202C523CE12C> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/TransmitHost.framework/Versions/A/TransmitHost
                       0x127043000 -        0x12708eff7 +com.adobe.DisplaySurface.framework (13.7.0 - 13.7.0.124) <8B16789F-C07D-3801-ADD7-E48940EC5A0A> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/DisplaySurface.framework/Versions/A/DisplaySurface
                       0x1270e7000 -        0x1275d3fef +com.adobe.GPUFoundation.framework (13.7.0 - 13.7.0.124) <3C925EA1-8291-3A20-9BA3-8851DDA2D71E> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/GPUFoundation.framework/Versions/A/GPUFoundation
                       0x127893000 -        0x127b6bfe6 +libxerces-c-3.0.dylib (0) <46020284-EEA8-7D7B-388C-BF23A318C997> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libxerces-c-3.0.dylib
                       0x127cef000 -        0x127d14fff +com.mainconcept.mc.enc.dv (9.11 - 9.11.14.4434) <1B92459E-24B1-C22D-57E6-CDF0DA4626C3> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/mc_enc_dv.framework/Versions/9/mc_enc_dv
                       0x127d30000 -        0x127de0ff7 +com.adobe.boost_regex.framework (13.7.0 - 13.7.0.124) <841E4724-E78A-3E5C-BA78-E1803B3E18D6> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
                       0x127e65000 -        0x127ebcfff +com.adobe.AdobeXMPCompareAndMerge (Adobe XMP Compare And Merge 1.0 -c 30 - 79.158325) <77ECCB53-F2C4-3C40-A36F-9FE9479704CA> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobeXMPCompareAndMerge.framework/Versions/A/AdobeXMPCompare AndMerge
                       0x127f35000 -        0x128250fdf +com.adobe.PlugPlug (6.1.0.158 - 6.1.0.158) <F26B79B6-22A4-38B4-8AB8-DFEEF9AE6824> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
                       0x12857a000 -        0x12857eff7 +com.adobe.ape.shim (3.4.0.29366 - 3.4.0.29366) <B9447EE8-6F91-9E85-C163-96600BF70764> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                       0x128585000 -        0x1285a5fff +VulcanControl.dylib (5.2.0.35 - 5.2.0.35 Copyright 2015, Adobe Systems Incorporated. All rights reserved.) <7DED4C28-2DC8-397F-9BCF-FB4777D99386> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/VulcanControl.dylib
                       0x1285d0000 -        0x128608ff7 +VulcanMessage5.dylib (5.2.0.35 - 5.2.0.35 Copyright 2015, Adobe Systems Incorporated. All rights reserved.) <4B0B878A-02F8-3EB1-89D5-4071034EDD0D> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/VulcanMessage5.dylib
                       0x12864d000 -        0x12865eff7 +com.adobe.RuntimeInstaller.framework (13.7.0 - 13.7.0.124) <B955A26F-6C4D-38C8-B228-9FF8BD427560> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/RuntimeInstaller.framework/Versions/A/RuntimeInstaller
                       0x12867e000 -        0x12876ffe7 +com.mainconcept.mc.mfimport (9.11 - 9.11.14.4434) <4DA5A813-7A9D-4496-AAF2-E778AC32C4EF> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/mc_mfimport.framework/Versions/9/mc_mfimport
                       0x128786000 -        0x128833fff +com.adobe.dvaaudiodevice.framework (13.7.0 - 13.7.0.124) <6E906B9B-C325-3D8F-AFB5-D1C7D3914929> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
                       0x128915000 -        0x128bd3fcf +com.adobe.dvaaudiodsp.framework (13.7.0 - 13.7.0.124) <B3F9F431-55CE-37DA-AF76-BB28B68CF1A2> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvaaudiodsp.framework/Versions/A/dvaaudiodsp
                       0x128c4f000 -        0x128d26fff +com.adobe.dvaaudiofilterhost.framework (13.7.0 - 13.7.0.124) <CEB3EAF0-6EC0-3D3D-9DD7-690AADAA4006> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvaaudiofilterhost.framework/Versions/A/dvaaudiofilterhost
                       0x128e11000 -        0x128e38ff7  com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <B355479D-7CBE-3142-80EA-4FD3CCCC56FE> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
                       0x128e59000 -        0x128e7efff +com.adobe.TimeCarving.framework (13.7.0 - 13.7.0.124) <F89C73CB-AAD8-322F-A23D-B0E4CC33E236> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/TimeCarving.framework/Versions/A/TimeCarving
                       0x128eb8000 -        0x128ee0fff +com.adobe.AMEAppFoundation.framework (13.7.0 - 13.7.0.124) <282B3F00-062B-3F4A-A42E-1D6E82DF1064> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
                       0x128f2a000 -        0x128f43fff +com.adobe.postprocess.framework (13.7.0 - 13.7.0.124) <054A3032-5167-3CA1-A136-DF96A2407DAD> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/postprocess.framework/Versions/A/postprocess
                       0x128f73000 -        0x12927eff7 +com.mainconcept.mc.enc.avc (9.11 - 9.11.14.4434) <0AFA960F-4161-F5C0-6BE6-E2CA8A54709D> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/mc_enc_avc.framework/Versions/9/mc_enc_avc
                       0x1292bf000 -        0x1294cefd7 +com.mainconcept.mc.dec.avc (9.11 - 9.11.14.4434) <FB5C96AC-281C-F84A-477C-309C2C6CBBF7> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/mc_dec_avc.framework/Versions/9/mc_dec_avc
                       0x1294d9000 -        0x1298e3fef +com.mainconcept.mc.mux.mp4 (9.11 - 9.11.14.4434) <690A03BA-1208-16E1-5F1E-1D5BB7141C9F> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/mc_mux_mp4.framework/Versions/9/mc_mux_mp4
                       0x12992b000 -        0x129b1efff +com.adobe.CodecSupport.framework (13.7.0 - 13.7.0.124) <3A02AF25-1A9F-3EA5-80BB-2CD6FC704056> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/CodecSupport.framework/Versions/A/CodecSupport
                       0x129c5a000 -        0x12a13bfc7 +libDNxHR.dylib (0) <16E89552-7DB0-3ABA-87A1-C9111E71CE84> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libDNxHR.dylib
                       0x12a224000 -        0x12a300fe7 +libmp4decMT.dylib (1.1.3) <A663DA9C-874F-742A-58B2-B5665D99CA03> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libmp4decMT.dylib
                       0x12a363000 -        0x12a46dfff +libCFHDDecoder.dylib (1) <0C9B6356-F555-39E0-9054-81E3FAC4DE55> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libCFHDDecoder.dylib
                       0x12a512000 -        0x12a614fff +libCFHDEncoder.dylib (1) <A3B4AE2B-D61C-339A-8DD1-B2E523640425> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/libCFHDEncoder.dylib
                       0x12a6c0000 -        0x12a856ff7 +com.mainconcept.mc.dec.mp2v (9.11 - 9.11.14.4434) <15B356B6-0883-1857-5689-F6CCD6A12922> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/mc_dec_mp2v.framework/Versions/9/mc_dec_mp2v
                       0x12a865000 -        0x12aaf7fcf +com.mainconcept.mc.bc.dec.avc (9.11 - 9.11.14.4434) <E93D751F-DD56-FF99-10ED-B2BE341ADE3B> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/mc_bc_dec_avc.framework/Versions/9/mc_bc_dec_avc
                       0x12ab0c000 -        0x12acddfef +com.mainconcept.mc.dec.mp4v (9.11 - 9.11.14.4434) <A25C82BE-D268-0F4E-EC28-438614052E04> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/mc_dec_mp4v.framework/Versions/9/mc_dec_mp4v
                       0x12acf2000 -        0x12ae58fff +com.adobe.dvametadataDB.framework (13.7.0 - 13.7.0.124) <1A7AD2D7-E4C4-34C5-94F5-BA2017F11689> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvametadataDB.framework/Versions/A/dvametadataDB
                       0x12aea8000 -        0x12af02fff +com.adobe.boost_serialization.framework (13.7.0 - 13.7.0.124) <2AA7FADE-683E-38D3-AD4E-B7B678330937> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/boost_serialization.framework/Versions/A/boost_serialization
                       0x130413000 -        0x130430fff  libJapaneseConverter.dylib (64) <12325659-06A4-37C9-8A9C-DA7A3F8DB8A2> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                       0x130435000 -        0x130457fff  libKoreanConverter.dylib (64) <E51FCBAE-3886-32B7-B4F8-51B3CBF683ED> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                       0x13045b000 -        0x13046afff  libSimplifiedChineseConverter.dylib (64) <468DE6E1-42B9-3751-ACA5-7D16C550FF84> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                       0x13046e000 -        0x130480fff  libTraditionalChineseConverter.dylib (64) <DCA11C00-8F36-39E5-BD2A-B15183931E8B> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                       0x130484000 -        0x130488ffb  libFontRegistryUI.dylib (134.1) <0E0D303E-2A48-340F-94A2-EEC3832E5895> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistryUI.dylib
                       0x1306ce000 -        0x130b08fff  com.apple.AMDRadeonX4000GLDriver (1.32.25 - 1.3.2) <362F6BAD-425D-32F0-8BFC-E9A32ABCA3E2> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLD river
                       0x132388000 -        0x13238cfff  com.apple.audio.AppleHDAHALPlugIn (272.18.1 - 272.18.1) <D6C9695C-4134-35D1-8FAC-8FB6179DFBFF> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                       0x1353fa000 -        0x135405ff7 +com.adobe.ExporterCoreAudio.framework (13.7.0 - 13.7.0.124) <F9647D7A-F25C-3551-A6FC-1F9390C4687E> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Plug-Ins/(MediaCore)/ExporterCoreAudio.bundle/Contents/MacOS/ExporterCo reAudio
                       0x135416000 -        0x135428fff +com.adobe.AudioConverter.framework (13.7.0 - 13.7.0.124) <063896CE-3174-3B39-90AF-883B377DB114> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AudioConverter.framework/Versions/A/AudioConverter
                       0x13601b000 -        0x136238ff3  com.apple.audio.units.Components (1.12 - 1.12) <AC14ADC7-587F-3E0F-92E7-9D8C07753C22> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
                       0x13631b000 -        0x1365d6fff  com.apple.audio.codecs.Components (5.0 - 5.0) <DB75033B-6B54-3F33-B078-23CB90450830> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
                       0x136676000 -        0x1366cafff +com.adobe.ExporterQuickTimeHost.framework (13.7.0 - 13.7.0.124) <3A816A67-129B-3C70-BDA3-F2EEB9D1FB49> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Plug-Ins/(MediaCore)/ExporterQuickTimeHost.bundle/Contents/MacOS/Export erQuickTimeHost
                       0x13670b000 -        0x13672afff +com.adobe.QTWriter.framework (13.7.0 - 13.7.0.124) <BCD94893-9BC9-34B6-99F9-E02ACDFFDD7E> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/QTWriter.framework/Versions/A/QTWriter
                       0x136759000 -        0x136792fff +com.adobe.QTParser.framework (13.7.0 - 13.7.0.124) <F436115F-8D82-3464-A7DC-2B91397E82E6> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
                       0x1367b6000 -        0x1367baff7 +ImporterIllustratorAE (???) <31BB5B22-E26D-3B0F-B838-CCB5F585B25A> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Plug-Ins/(MediaCore)/ImporterIllustratorAE.bundle/Contents/MacOS/Import erIllustratorAE
                       0x1367c5000 -        0x1367cefff +ImporterPhotoshopAE (???) <7CD6317A-F5C4-3789-9008-1B6AE76A0923> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Plug-Ins/(MediaCore)/ImporterPhotoshopAE.bundle/Contents/MacOS/Importer PhotoshopAE
                       0x1425b9000 -        0x14292ffe7 +com.adobe.ImporterQuickTime.framework (13.7.0 - 13.7.0.124) <819385A4-669C-3B35-A6C8-656356BB414C> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Plug-Ins/(MediaCore)/ImporterQuickTime.bundle/Contents/MacOS/ImporterQu ickTime
                       0x142b10000 -        0x142bc3fe7 +com.adobe.IPPMPEGDecoder.framework (13.7.0 - 13.7.0.124) <72680120-6AC4-33AC-8756-F30FCD3F13E5> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/IPPMPEGDecoder.framework/Versions/A/IPPMPEGDecoder
                       0x142c0a000 -        0x142c10ff7 +com.adobe.TransmitDesktopAudio.framework (13.7.0 - 13.7.0.124) <A8B12659-23F3-3776-BEAE-6865663A56B7> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Plug-Ins/(MediaCore)/TransmitDesktopAudio.bundle/Contents/MacOS/Transmi tDesktopAudio
                       0x142c6b000 -        0x142c81ff7 +com.adobe.TransmitDV.framework (13.7.0 - 13.7.0.124) <EF52EBE4-376D-3398-A6C7-2152B7FB12BD> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Plug-Ins/(MediaCore)/TransmitDV.bundle/Contents/MacOS/TransmitDV
                       0x142c9f000 -        0x142cd6ff7  com.apple.AVCVideoServices (1.0 - 42) <9EC79281-C689-3B68-B496-35B30763462F> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
                       0x142e78000 -        0x142e80ff7 +com.adobe.TransmitFullScreen.framework (13.7.0 - 13.7.0.124) <DE1BEBDD-0055-3C46-9178-E9F114AC5A33> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Plug-Ins/(MediaCore)/TransmitFullScreen.bundle/Contents/MacOS/TransmitF ullScreen
                       0x14489e000 -        0x1448b8ff7 +com.adobe.AfterEffects.MThread (???) <BCFDED47-F66D-319E-A2B6-C407FE619CAD> /Applications/Adobe After Effects CC 2015/*/Mthread.plugin/Contents/MacOS/MThread
                       0x1448c2000 -        0x1477c6fef +com.adobe.CameraRaw (9.4 [548] - 9.4f548) <431110CA-B806-3014-9EA5-681267AAC627> /Library/Application Support/Adobe/*/Camera Raw.plugin/Contents/MacOS/Camera Raw
                       0x148060000 -        0x148067ff7 +com.adobe.AfterEffects.EasyEase (???) <14C9BBB5-B3D7-3BE3-9C07-50BAD9A47DC6> /Applications/Adobe After Effects CC 2015/*/EasyEase.plugin/Contents/MacOS/EasyEase
                       0x148090000 -        0x148098ff7 +com.adobe.AfterEffects.ExpScale (???) <83D7C3A9-7A28-371E-AE91-C0906B5921A1> /Applications/Adobe After Effects CC 2015/*/ExpScale.plugin/Contents/MacOS/ExpScale
                       0x14809f000 -        0x1480a6fff +com.adobe.AfterEffects.TRKeys (???) <6423A100-F689-312A-8662-1FD3484C16E7> /Applications/Adobe After Effects CC 2015/*/TRKeys.plugin/Contents/MacOS/TRKeys
                       0x1480d0000 -        0x148181ff7 +com.adobe.AfterEffects.AEGPDriver (???) <9BEDC54A-0165-3E9A-9DD2-143B2754590F> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/AEGPDriver.plugin/Contents/MacOS/AEGPDriver
                       0x1481c6000 -        0x148214ff7 +com.adobe.AfterEffects.PS3Export (???) <1E43A5D4-007C-32A5-8BEE-2FD2C1D53D71> /Applications/Adobe After Effects CC 2015/*/PS Layer Export.plugin/Contents/MacOS/PS3Export
                       0x14823b000 -        0x148292fff +com.adobe.AfterEffects.PS3Import (???) <A63E954B-976E-3284-AA50-37954327E023> /Applications/Adobe After Effects CC 2015/*/PS Layer Import.plugin/Contents/MacOS/PS3Import
                       0x1482ba000 -        0x1482c7fff +com.adobe.AfterEffects.Sequence (???) <F2754AD8-172F-337A-BF17-3FA64AF808D0> /Applications/Adobe After Effects CC 2015/*/Sequence.plugin/Contents/MacOS/Sequence
                       0x1482d3000 -        0x148400ff7 +CinewareAELiveLink (0) <ABA4834E-EC88-3F69-B4B6-B57723ED9364> /Applications/Adobe After Effects CC 2015/*/Cineware_AE_LiveLink.plugin/Contents/MacOS/Cineware_AE_LiveLink
                       0x1484a9000 -        0x148514fff +com.adobe.AfterEffects.Escher (???) <EFA9B0CA-2EDD-3832-989A-6F466E489814> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/Advanced3D.plugin/Contents/MacOS/Escher
                       0x148535000 -        0x14863cfff +com.adobe.AfterEffects.AEDynamicLinkServer (???) <19983B07-8319-3F54-BB52-6E2EB9E1704F> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/AEDynamicLinkServer.plugin/Contents/MacOS/AEDynamicLinkServer
                       0x1486b7000 -        0x1486d9ff7 +com.adobe.AfterEffects.AudioPal (???) <960D5B13-8893-3180-B8DC-18FAFF0560FB> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/Audio Palette.plugin/Contents/MacOS/AudioPal
                       0x148704000 -        0x14873bfff +com.adobe.AfterEffects.BrushPal (???) <2152CDCA-D820-3CA7-963D-45696E1E9760> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/Brush Palette.plugin/Contents/MacOS/BrushPal
                       0x14876d000 -        0x1487b5fff +com.adobe.AfterEffects.CharPal (???) <A7836F84-6C7A-3D90-A0CD-181C65367056> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/Character Palette.plugin/Contents/MacOS/CharPal
                       0x1487f2000 -        0x148841ff7 +com.adobe.AfterEffects.InfoPal (???) <1DB4AA07-1A4F-3564-94C9-46361C9C37CA> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/Info Palette.plugin/Contents/MacOS/InfoPal
                       0x14886b000 -        0x14889cff7 +com.adobe.AfterEffects.PaintPal (???) <5BD3421E-76B3-345B-8542-291E4CC3F3C4> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/Paint Palette.plugin/Contents/MacOS/PaintPal
                       0x1488ce000 -        0x1488f5fff +com.adobe.AfterEffects.ParaPal (???) <7C1F1DCB-6DB9-3213-9A7B-2939147F957A> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/Paragraph Palette.plugin/Contents/MacOS/ParaPal
                       0x148921000 -        0x1489b5fff +com.adobe.AfterEffects.Picasso (???) <391DD97E-8047-374D-A5AC-35958F5CFB96> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/Picasso.plugin/Contents/MacOS/Picasso
                       0x1489dc000 -        0x1489f8ff7 +com.adobe.AfterEffects.ProgressPal (???) <3538FEE5-342A-3591-A2E6-CE535E1CDED3> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/Progress Palette.plugin/Contents/MacOS/ProgressPal
                       0x148a21000 -        0x148a24fff +com.adobe.AfterEffects.Durer (???) <C8988188-0677-3E74-BF95-9648B8D1038C> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/Standard3D.plugin/Contents/MacOS/Durer
                       0x148a84000 -        0x148d6cff7 +com.adobe.AfterEffects.SnapCut (???) <A423DF5D-D4E5-3FD7-9872-58F8AFDF59E1> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/Roto Brush.plugin/Contents/MacOS/SnapCut
                       0x148e2e000 -        0x148e63fff +com.adobe.AfterEffects.TimePal (???) <2995D5F6-F550-3087-B1CF-0A24871AF8E3> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/Time Palette.plugin/Contents/MacOS/TimePal
                       0x148e98000 -        0x148ef1fff +com.adobe.AfterEffects.ToolPal (???) <D18F518A-7EA1-3E56-90D8-996CE0798B4E> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/Tool Palette.plugin/Contents/MacOS/ToolPal
                       0x148f3c000 -        0x148f68fff +com.adobe.AfterEffects.TrackerPal (???) <4FE3B5F7-B26F-3C5D-8833-A04A36927B87> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/Tracker Palette.plugin/Contents/MacOS/TrackerPal
                       0x148f91000 -        0x148fb2fff +com.adobe.AfterEffects.WorkQueuePal (???) <14770327-AD39-3D5A-9A39-1E3A405248F3> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/WorkQueue Palette.plugin/Contents/MacOS/WorkQueuePal
                       0x148fdb000 -        0x14a418ff7 +com.imagineersystems.mochashapeconverter4ae (4.0.2 - 4.0.2f10148) <777F7A9B-78A7-3238-9D4E-474F191E7973> /Applications/Adobe After Effects CC 2015/*/mocha shape converter for AE.plugin/Contents/MacOS/mochashapeconverter4ae
                       0x14a62f000 -        0x14a709fff +com.adobe.AfterEffects.Anywhere2 (???) <ADB6382E-CC61-3A62-BF8C-A2616368658C> /Applications/Adobe After Effects CC 2015/*/Anywhere2.plugin/Contents/MacOS/Anywhere2
                       0x14a771000 -        0x14a825fff +com.adobe.AfterEffects.CEPManager (???) <6C0B504D-02C5-3E74-9457-0AE46D64BD49> /Applications/Adobe After Effects CC 2015/*/CEPManager.plugin/Contents/MacOS/CEPManager
                       0x14a904000 -        0x14a914fff +com.adobe.AfterEffects.LocalizePresets (???) <4D5158D9-05E3-3C55-A7DF-1FB4787F9CFE> /Applications/Adobe After Effects CC 2015/*/LocalizePresets.plugin/Contents/MacOS/LocalizePresets
                       0x14a922000 -        0x14a92bff7 +com.adobe.AfterEffects.RPFImport (???) <9A3C42B6-31BA-3C9A-9C7F-16C2ED9BD73D> /Applications/Adobe After Effects CC 2015/*/RPFImport.plugin/Contents/MacOS/RPFImport
                       0x14a952000 -        0x14a967fff +com.adobe.AfterEffects.MayaImport (???) <26AB3967-0439-3DE8-955F-936F18CAB30E> /Applications/Adobe After Effects CC 2015/*/MayaImport.plugin/Contents/MacOS/MayaImport
                       0x14a987000 -        0x14aac4fef +IMSLib.dylib (9.0.1.28 - 9.0.1.28) <5FC6C059-D74C-3F40-99C3-2B2C111878E6> /Library/Application Support/Adobe/*/IMSLib.dylib
                       0x14aae4000 -        0x14ab53ff7 +com.adobe.AfterEffects.Renoir (???) <F8CFDF08-E7CD-3290-88D7-B2E1B0ED5D64> /Applications/Adobe After Effects CC 2015/*/Renoir.plugin/Contents/MacOS/Renoir
                       0x14ab97000 -        0x14adb4fef +com.adobe.AfterEffects.OpenEXR (???) <415CEBC3-0C65-C2B9-DA34-EF176DF31828> /Applications/Adobe After Effects CC 2015/*/OpenEXR.plugin/Contents/MacOS/OpenEXR
                       0x14afa3000 -        0x14afe1ff7 +com.adobe.AfterEffects.PNGIO (???) <7087501F-7147-33C8-B832-DA00A52D7DAB> /Applications/Adobe After Effects CC 2015/*/PNGIO.plugin/Contents/MacOS/PNGIO
                       0x14aff3000 -        0x14b0c6fff +com.adobe.AfterEffects.PremiereProImport (???) <7CF3C1F5-0F29-3590-B954-5AE34F0B1DE8> /Applications/Adobe After Effects CC 2015/*/PremiereProImport.plugin/Contents/MacOS/PremiereProImport
                       0x14b109000 -        0x14b168ff7 +com.adobe.MediaCoreUI.framework (13.7.0 - 13.7.0.124) <8651486C-8F0A-3478-81E0-2F6CCEFCA5AA> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
                       0x14b1e0000 -        0x14b642fed +com.adobe.ProImportAE (Pro Import AE version 8.00 - 8.00) <AC4080BD-55B3-9433-7BE1-371B4F0A5629> /Applications/Adobe After Effects CC 2015/*/Pro Import AE.plugin/Contents/MacOS/Pro Import AE
                       0x14b7f2000 -        0x14b85afff +com.adobe.AfterEffects.TIFFIO (???) <3C06CC5D-C123-3635-B7A2-14CC1A545622> /Applications/Adobe After Effects CC 2015/*/TIFF.plugin/Contents/MacOS/TIFFIO
                       0x14b879000 -        0x14b89cff7 +com.adobe.AfterEffects.Align (???) <1F40DF6C-2F54-3747-BA47-C608F59A1CBD> /Applications/Adobe After Effects CC 2015/*/Align.plugin/Contents/MacOS/Align
                       0x14b8c2000 -        0x14b8d9ff7 +com.adobe.AfterEffects.Analyzer (???) <0300BD9E-244C-3F75-933B-E7667E9B9DEB> /Applications/Adobe After Effects CC 2015/*/Analyzer.plugin/Contents/MacOS/Analyzer
                       0x14b8f7000 -        0x14b919fff +com.adobe.AfterEffects.MediaBrowser (???) <42275785-548E-3F3C-BFEB-E9D12157ED1C> /Applications/Adobe After Effects CC 2015/*/MediaBrowser.plugin/Contents/MacOS/MediaBrowser
                       0x14b946000 -        0x14ba53fff +com.adobe.dvamediabrowser.framework (13.7.0 - 13.7.0.124) <9A6318B2-F44C-3E8C-8E72-661CB7067332> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvamediabrowser.framework/Versions/A/dvamediabrowser
                       0x14bbcf000 -        0x14bbeffff +com.adobe.dvamediaui.framework (13.7.0 - 13.7.0.124) <9D5A79F7-8219-3440-B27F-55208384B74F> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvamediaui.framework/Versions/A/dvamediaui
                       0x14bc3d000 -        0x14bc5bfff +com.adobe.AfterEffects.MetaPal (???) <59063706-6A49-3A75-B3A5-D56904D01E60> /Applications/Adobe After Effects CC 2015/*/MetaPal.plugin/Contents/MacOS/MetaPal
                       0x14bc87000 -        0x14bcbdfff +com.adobe.AfterEffects.Moka (???) <6876B315-D0F0-38B0-AD5E-CC3C930396E3> /Applications/Adobe After Effects CC 2015/*/Moka.plugin/Contents/MacOS/Moka
                       0x14bce6000 -        0x14bd00fff +com.adobe.AfterEffects.MotionSketch (???) <CA3481CD-F850-3E78-B3CB-DFC52820F5AE> /Applications/Adobe After Effects CC 2015/*/MotionSketch.plugin/Contents/MacOS/MotionSketch
                       0x14bd24000 -        0x14bd45fff +com.adobe.AfterEffects.RQMonitor (???) <DFF35F9B-7ACD-3CE5-BBF2-777A60B590B0> /Applications/Adobe After Effects CC 2015/*/RQMonitor.plugin/Contents/MacOS/RQMonitor
                       0x14bd54000 -        0x14c306ff7 +com.adobe.AfterEffects.Scripting (???) <6492B7D6-48F6-3311-AF05-9E78B94CEAEC> /Applications/Adobe After Effects CC 2015/*/Scripting.plugin/Contents/MacOS/Scripting
                       0x14c5ac000 -        0x14c70cff7 +com.adobe.dvascriptui.framework (13.7.0 - 13.7.0.124) <1DE1750F-BBAF-32D2-A40C-0A84696A90A6> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvascriptui.framework/Versions/A/dvascriptui
                       0x14c963000 -        0x14c98dfff +com.adobe.dvaflashview.framework (13.7.0 - 13.7.0.124) <D5482E64-46EB-3005-886C-3038568B5AD2> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
                       0x14cc6a000 -        0x14cc90ff7 +com.adobe.ape (3.4.0.29366 - 3.4.0.29366) <40A59819-7A57-0E9F-658D-1803B2A461AE> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
                       0x14cca2000 -        0x14ccbeff7 +com.adobe.AfterEffects.Smoother (???) <FA21AFA3-9F2A-3503-B081-11A8B3EAC037> /Applications/Adobe After Effects CC 2015/*/Smoother.plugin/Contents/MacOS/Smoother
                       0x14d25c000 -        0x14d27afff +com.adobe.AfterEffects.Wiggler (???) <2215EB4A-7115-31EC-B4BA-5E0A0E26BE58> /Applications/Adobe After Effects CC 2015/*/Wiggler.plugin/Contents/MacOS/Wiggler
                       0x14d29f000 -        0x14d3b4fff +CinewareAEExporter (0) <24C7030F-1ABB-339C-8A93-E6C3523DF7BE> /Applications/Adobe After Effects CC 2015/*/Cineware_AE_Exporter.plugin/Contents/MacOS/Cineware_AE_Exporter
                       0x14d454000 -        0x14d5b4fff +CinewareAESceneLayer (0) <F371014B-59A9-3853-8915-79C17FCE4DDC> /Applications/Adobe After Effects CC 2015/*/Cineware_AE_SceneLayer.plugin/Contents/MacOS/Cineware_AE_SceneLayer
                       0x14dff8000 -        0x14e013ff3  com.apple.security.csparser (3.0 - 57031.40.6) <806B54FA-CAA7-3060-A2FE-2B0F196FDBC7> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/cspa rser
                       0x154074000 -        0x154434ff7 +net.videocopilot.Element64 (1.6.3 - 1.6.3) <60F88BC2-800D-30F4-A715-F08BE846DC13> /Applications/Adobe After Effects CC 2015/*/Element.plugin/Contents/MacOS/Element64
                       0x154674000 -        0x1546c1fe7 +tmp.0.wcGaq7 (1) <2BE31C05-6F6C-3DFF-A45D-FAB55A867252> /var/tmp/tmp.0.wcGaq7
                       0x1546d6000 -        0x1546e0ff7 +com.adobe.AfterEffects.Fill (???) <512B4074-7DF6-3F54-979D-D31F302ABEB6> /Applications/Adobe After Effects CC 2015/*/Fill.plugin/Contents/MacOS/Fill
                       0x1546e7000 -        0x1546edfff +com.adobe.AfterEffects.Fast_Blur (???) <22D2A666-D405-3541-9BB9-F883EF4635A0> /Applications/Adobe After Effects CC 2015/*/Fast_Blur.plugin/Contents/MacOS/Fast_Blur
                       0x154811000 -        0x154817fff +com.adobe.AfterEffects.Tint (???) <F9C41200-C9DB-39EA-A1D1-AF39BE598D33> /Applications/Adobe After Effects CC 2015/*/Tint.plugin/Contents/MacOS/Tint
                       0x155f91000 -        0x155f95fff +com.adobe.AfterEffects.Paint (???) <D624B45B-3363-34AE-991C-A39E3A497C39> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/Paint.plugin/Contents/MacOS/Paint
                       0x155f9b000 -        0x155ff9fff +com.adobe.AfterEffects.FreePin (???) <1B6B5646-3BF2-3C4B-90C4-B99A36DFB401> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/Puppet.plugin/Contents/MacOS/FreePin
                       0x15600f000 -        0x1561c0fff +com.adobe.AfterEffects.RefineMatte (???) <5B28298D-4CE3-395C-9654-18AD8DB4092D> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/RefineMatte.plugin/Contents/MacOS/RefineMatte
                       0x156380000 -        0x1563bafff +com.adobe.pip (7.3.1.70) <62832BC3-E82F-3648-B0D2-67EFD1263C89> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
                       0x156da5000 -        0x15704dfff +com.adobe.AfterEffects.RefineMatte2 (???) <A4C59346-24BF-32BE-8E44-2FF8635DF5BF> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Required/RefineMatte2.plugin/Contents/MacOS/RefineMatte2
                       0x157100000 -        0x15726eff7 +CinewareAEEffect (0) <97D7F264-F697-3322-B869-55145AE2ED9F> /Applications/Adobe After Effects CC 2015/*/Cineware_AE_Effect.plugin/Contents/MacOS/Cineware_AE_Effect
                       0x157327000 -        0x157350fff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
                       0x15756e000 -        0x1575a4fff +com.adobe.ImporterMPEG.framework (13.7.0 - 13.7.0.124) <A466697B-E5F0-3ABD-92B5-AFE78BECFB75> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Plug-Ins/(MediaCore)/ImporterMPEG.bundle/Contents/MacOS/ImporterMPEG
                       0x1575d6000 -        0x1578a0fe7 +com.mainconcept.mc.demux.mp4 (9.11 - 9.11.14.4434) <32C65887-EEA9-E933-8822-6731A852B20D> /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/Frameworks/mc_demux_mp4.framework/Versions/9/mc_demux_mp4
                       0x1578d8000 -        0x157a4afff +com.adobe.VideoCopilot.OpticalFlares (???) <AAFE986C-72F8-C2F4-893D-A9E867B3BEB1> /Applications/Adobe After Effects CC 2015/*/OpticalFlares.plugin/Contents/MacOS/OpticalFlares
                       0x157c1c000 -        0x158742fff +libwx_osx_cocoa-2.9.1.0.0.dylib (1) <0940DD31-BD57-E431-74B8-B02E9EFCF6B3> /Applications/Adobe After Effects CC 2015/*/OpticalFlares.plugin/Contents/Frameworks/libwx_osx_cocoa-2.9.1.0.0.dylib
                       0x158c76000 -        0x158cf0ff7  com.apple.xquery (1.3.1 - 30) <9D868AE3-C5A0-34BD-8C33-EB5F8EDD7ACA> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
                       0x158d58000 -        0x158d7fff7 +com.adobe.AfterEffects.Levels2 (???) <42774E95-E857-302E-AB4C-CDCF3A7F5E2D> /Applications/Adobe After Effects CC 2015/*/Levels2.plugin/Contents/MacOS/Levels2
                       0x158d8f000 -        0x158da1ff7 +com.adobe.AfterEffects.Hue_Sat (???) <4F581E48-9A5F-31BB-80AD-AB69638E9511> /Applications/Adobe After Effects CC 2015/*/Hue_Sat.plugin/Contents/MacOS/Hue_Sat
                       0x15eb9f000 -        0x15ec05ff7 +com.adobe.AfterEffects.Timecode (???) <64F2993B-6847-316E-BB94-F8B0C56820F7> /Applications/Adobe After Effects CC 2015/*/Timecode.plugin/Contents/MacOS/Timecode
                       0x1615de000 -        0x1616c4fef  unorm8_bgra.dylib (2.4.5) <5F488C7E-2FB2-3C66-9764-28CF16B03E7A> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra .dylib
                    0x7fff6dfcd000 -     0x7fff6e003887  dyld (353.2.3) <B1B370A5-479F-3533-8AD7-97B687D4F989> /usr/lib/dyld
                    0x7fff8422c000 -     0x7fff84233ff7  libcompiler_rt.dylib (35) <BF8FC133-EE10-3DA6-9B90-92039E28678F> /usr/lib/system/libcompiler_rt.dylib
                    0x7fff8423a000 -     0x7fff8423bff7  com.apple.print.framework.Print (10.0 - 265) <3BC4FE7F-78A0-3E57-8F4C-520E7EFD36FA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                    0x7fff8423c000 -     0x7fff8468ffc7  com.apple.vImage (8.0 - 8.0) <33BE7B31-72DB-3364-B37E-C322A32748C5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                    0x7fff84690000 -     0x7fff84699ff7  libsystem_notify.dylib (133.1.1) <61147800-F320-3DAA-850C-BADF33855F29> /usr/lib/system/libsystem_notify.dylib
                    0x7fff846a2000 -     0x7fff846a4fff  libRadiance.dylib (1239) <648BCB0C-55B5-3197-8F5F-81D5994B4EE7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                    0x7fff846a5000 -     0x7fff846bcff7  libLinearAlgebra.dylib (1128) <E78CCBAA-A999-3B65-8EC9-06DB15E67C37> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
                    0x7fff846c6000 -     0x7fff846c8fff  libsystem_configuration.dylib (699.40.2) <56F94DCE-DBDE-3615-8F07-DE6270D9F8BE> /usr/lib/system/libsystem_configuration.dylib
                    0x7fff846df000 -     0x7fff848d946f  libobjc.A.dylib (647) <759E155D-BC42-3D4E-869B-6F57D477177C> /usr/lib/libobjc.A.dylib
                    0x7fff84944000 -     0x7fff849d5ff7  libCoreStorage.dylib (471.30.1) <9D95399F-1AC5-325F-8337-6E13AD99E44B> /usr/lib/libCoreStorage.dylib
                    0x7fff849d6000 -     0x7fff849d8fff  com.apple.SecCodeWrapper (4.0 - 238.20.2) <C6C126F0-6BF4-3E29-A9B7-7BAD8D17EE4F> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
                    0x7fff84a26000 -     0x7fff84a26fff  com.apple.audio.units.AudioUnit (1.12 - 1.12) <E5335492-7EFE-31EA-BE72-4A9CEE68D58E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                    0x7fff84a33000 -     0x7fff84ab1fff  com.apple.CoreServices.OSServices (640.4 - 640.4) <BE8DF749-84BA-3029-AE1D-32F3993A78A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                    0x7fff84ab2000 -     0x7fff84b23ffb  com.apple.ApplicationServices.ATS (360 - 375.4) <A1BEBCF8-8FC8-345D-B91D-1DA5773AF5A3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                    0x7fff84b24000 -     0x7fff84b6aff7  libFontRegistry.dylib (134.1) <CE41D8C2-BEED-345C-BC4F-3775CC06C672> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                    0x7fff84b6b000 -     0x7fff84b74fff  libsystem_pthread.dylib (105.40.1) <ACE90967-ECD0-3251-AEEB-461E3C6414F7> /usr/lib/system/libsystem_pthread.dylib
                    0x7fff84b75000 -     0x7fff84b77ff7  libsystem_coreservices.dylib (9) <41B7C578-5A53-31C8-A96F-C73E030B0938> /usr/lib/system/libsystem_coreservices.dylib
                    0x7fff84ba9000 -     0x7fff84c03ff7  com.apple.LanguageModeling (1.0 - 1) <ACA93FE0-A0E3-333E-AE3C-8EB7DE5F362F> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
                    0x7fff84c04000 -     0x7fff84c0ffff  com.apple.AppSandbox (4.0 - 238.20.2) <BEFAB7F2-B189-391B-9B2D-FFF3EE2B77B6> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
                    0x7fff84c10000 -     0x7fff84c14fff  libCoreVMClient.dylib (79.1) <201EF6DF-5074-3CB7-A361-398CF957A264> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                    0x7fff84c15000 -     0x7fff84c34fff  com.apple.CoreDuet (1.0 - 1) <36AA9FD5-2685-314D-B364-3FA4688D86BD> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
                    0x7fff84c35000 -     0x7fff84c38ffb  libCGXType.A.dylib (788.3) <7CC6CD5B-AD6B-3B36-9165-BFB1E5274F69> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
                    0x7fff84c39000 -     0x7fff84c87ff7  com.apple.ImageCaptureCore (6.3 - 6.3) <75B5043C-9EF0-3CD2-875D-12813F0A73D3> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                    0x7fff84c88000 -     0x7fff84cc0fff  libsystem_network.dylib (412.20.3) <6105C134-6722-3C0A-A4CE-5E1261E2E1CC> /usr/lib/system/libsystem_network.dylib
                    0x7fff84d03000 -     0x7fff851f3fff  com.apple.MediaToolbox (1.0 - 1562.238) <BF6A868E-2F7D-371F-B14D-89C23EE4EF2B> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                    0x7fff851f4000 -     0x7fff8535bffb  com.apple.audio.toolbox.AudioToolbox (1.12 - 1.12) <5678FC94-456A-3F5F-BA9A-10EB6E462997> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                    0x7fff8535c000 -     0x7fff85367fff  libGL.dylib (11.1.2) <FD8B7B67-1532-32A1-B369-9D7A6C1EB3ED> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                    0x7fff853d5000 -     0x7fff853d7fff  libsystem_sandbox.dylib (358.20.5) <3F5E973F-C702-31AC-97BC-05F5C195683C> /usr/lib/system/libsystem_sandbox.dylib
                    0x7fff853d8000 -     0x7fff857e5ff7  libLAPACK.dylib (1128) <F9201AE7-B031-36DB-BCF8-971E994EF7C1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                    0x7fff857e6000 -     0x7fff85818ff3  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <C6DB0A07-F8E4-3837-BCA9-225F460EDA81> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
                    0x7fff8584b000 -     0x7fff858c4fe7  libcorecrypto.dylib (233.30.1) <5779FFA0-4D9A-3AD4-B7F2-618227621DC8> /usr/lib/system/libcorecrypto.dylib
                    0x7fff858c5000 -     0x7fff858cefff  com.apple.DisplayServicesFW (2.9 - 372.1) <30E61754-D83C-330A-AE60-533F27BEBFF5> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
                    0x7fff858d2000 -     0x7fff85c03fff  com.apple.Foundation (6.9 - 1154) <49EE64E1-9F53-35D1-A481-2EFE2789B254> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                    0x7fff85c04000 -     0x7fff85e14ff7  com.apple.CFNetwork (720.5.7 - 720.5.7) <A47D7DD2-5903-39D0-8D27-5A7E2D119D84> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                    0x7fff85eba000 -     0x7fff85ef5fff  com.apple.QD (301 - 301) <C4D2AD03-B839-350A-AAF0-B4A08F8BED77> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                    0x7fff86082000 -     0x7fff86094ff7  com.apple.ImageCapture (9.0 - 9.0) <7FB65DD4-56B5-35C4-862C-7A2DED991D1F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                    0x7fff86095000 -     0x7fff86188ff7  libJP2.dylib (1239) <D346D67E-78A2-309D-94BB-C7C5FEC28785> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                    0x7fff861d8000 -     0x7fff86457ffb  com.apple.RawCamera.bundle (6.06 - 819) <EDA3D142-24EC-3661-87EB-B35F8E858A9D> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                    0x7fff86458000 -     0x7fff8646dff7  com.apple.AppContainer (4.0 - 238.20.2) <2AA2EF49-9F38-31F6-8B08-8CC7C26F57F3> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
                    0x7fff86494000 -     0x7fff864fbff7  com.apple.framework.CoreWiFi (3.0 - 300.4) <19269C1D-EB29-384A-83F3-7DDDEB7D9DAD> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                    0x7fff86e89000 -     0x7fff86ef8fff  com.apple.SearchKit (1.4.0 - 1.4.0) <80883BD1-C9BA-3794-A20E-476F94DD89A9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                    0x7fff86ef9000 -     0x7fff87a7aff7  com.apple.AppKit (6.9 - 1348.17) <E485D56D-3E72-34B7-99BB-BFDEE2D07BF5> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                    0x7fff87a7b000 -     0x7fff87a81fff  com.apple.speech.recognition.framework (5.0.9 - 5.0.9) <BB2D573F-0A01-379F-A2BA-3C454EDCB111> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                    0x7fff87a8b000 -     0x7fff87aafff7  com.apple.quartzfilters (1.10.0 - 1.10.0) <1AE50F4A-0098-34E7-B24D-DF7CB94073CE> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
                    0x7fff87ab0000 -     0x7fff87affff7  libcurl.4.dylib (83.40.2) <AE97ED1E-A58F-3EF0-8E88-DDC6AD409BCE> /usr/lib/libcurl.4.dylib
                    0x7fff87b00000 -     0x7fff87b51fff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <450293F7-DAE7-3DD0-8F7C-71FC2FD72627> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                    0x7fff87b76000 -     0x7fff87b89ff7  com.apple.CoreBluetooth (1.0 - 1) <8D7BA9BA-EB36-307A-9119-0B3D9732C953> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
                    0x7fff87b8a000 -     0x7fff87bdbff7  com.apple.AppleVAFramework (5.0.31 - 5.0.31) <17C35538-7C2B-3735-A1B3-E8487EED0668> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                    0x7fff87beb000 -     0x7fff87e61ff7  com.apple.security (7.0 - 57031.40.6) <FCCCC4FD-043A-30CA-9997-4211CA0E9297> /System/Library/Frameworks/Security.framework/Versions/A/Security
                    0x7fff87e74000 -     0x7fff87ea7fff  com.apple.MediaKit (16 - 757.2) <2912E5C2-085F-3FE2-8531-23B6E894B0F0> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
                    0x7fff87ea8000 -     0x7fff87eaaff3  com.apple.SafariServices.framework (10601 - 10601.4.4) <82065DAF-DA17-3408-B809-11643DC9EC91> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
                    0x7fff87ed9000 -     0x7fff87edfff7  com.apple.XPCService (2.0 - 1) <AA4A5393-1F5D-3465-A417-0414B95DC052> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
                    0x7fff87ee0000 -     0x7fff88010fff  com.apple.UIFoundation (1.0 - 1) <466BDFA8-0B9F-3AB0-989D-F9779422926A> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
                    0x7fff88298000 -     0x7fff8829afff  com.apple.EFILogin (2.0 - 2) <3BA837D8-94F5-3240-9CF7-E40DC2808446> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
                    0x7fff8829b000 -     0x7fff882bfff7  com.apple.Sharing (328.17 - 328.17) <AD5E243A-B79F-3D7B-800B-A2C99A1CFEF1> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
                    0x7fff882c0000 -     0x7fff8862bfff  com.apple.VideoToolbox (1.0 - 1562.238) <510956DF-E324-3974-A83B-C0C74A6F812C> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                    0x7fff88639000 -     0x7fff88655fff  com.apple.GenerationalStorage (2.0 - 209.11) <9FF8DD11-25FB-3047-A5BF-9415339B3EEC> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                    0x7fff88656000 -     0x7fff88711ff7  com.apple.DiscRecording (9.0 - 9000.4.2) <4655B4B8-523D-3AE6-92A0-8486A2258B3B> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
                    0x7fff88712000 -     0x7fff8871fff7  com.apple.SpeechRecognitionCore (2.1.2 - 2.1.2) <551322E2-C1E4-3378-A218-F362985E3E3C> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
                    0x7fff88753000 -     0x7fff88756ff7  libdyld.dylib (353.2.3) <CFBBE540-D503-3AFC-B5D6-644F1E69949B> /usr/lib/system/libdyld.dylib
                    0x7fff88773000 -     0x7fff88775fff  libCVMSPluginSupport.dylib (11.1.2) <1C5C1757-67F1-3C23-90EF-643619A0E7DC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                    0x7fff8879a000 -     0x7fff8975dff3  com.apple.WebCore (10600 - 10600.8.9) <A5400B08-6067-370E-B224-14890DA39857> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
                    0x7fff8975e000 -     0x7fff89778ff7  com.apple.Kerberos (3.0 - 1) <7760E0C2-A222-3709-B2A6-B692D900CEB1> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                    0x7fff89779000 -     0x7fff89781ffb  libcopyfile.dylib (118.1.2) <0C68D3A6-ACDD-3EF3-991A-CC82C32AB836> /usr/lib/system/libcopyfile.dylib
                    0x7fff89782000 -     0x7fff89786fff  com.apple.TCC (1.0 - 1) <CCA42EE2-3400-3444-9486-BC454E60D944> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                    0x7fff89787000 -     0x7fff89937ff3  com.apple.QuartzCore (1.10 - 361.19) <F815B60E-75E3-3263-BE93-27A49882CF58> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                    0x7fff89938000 -     0x7fff8993fff7  libCGCMS.A.dylib (788.3) <1A47CDD9-99AE-3BD2-85F1-339FC169B16E> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
                    0x7fff89940000 -     0x7fff899ccfe7  libsystem_c.dylib (1044.40.1) <F0635E0F-FE4B-34DB-ACF9-A58C1E9070E9> /usr/lib/system/libsystem_c.dylib
                    0x7fff899cd000 -     0x7fff89a2cfff  com.apple.AE (681.5 - 681.7) <2BF39455-1CDD-392C-824A-9972C6B1FB57> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                    0x7fff89a2f000 -     0x7fff89aa1fff  com.apple.framework.IOKit (2.0.2 - 1050.20.2) <09C0518C-90DF-3FC3-96D6-34D35F72C8EF> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                    0x7fff89b62000 -     0x7fff89b64ff7  com.apple.securityhi (9.0 - 55006) <2B9C0BCB-7D82-39C2-A99F-7B9E1522CDD6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                    0x7fff89b8d000 -     0x7fff89ccafff  com.apple.ImageIO.framework (3.3.0 - 1239) <CC904E44-45C4-389B-8FD7-4DF03C41C9EC> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                    0x7fff89ccb000 -     0x7fff89cccfff  liblangid.dylib (117) <B54A4AA0-2E53-3671-90F5-AFF711C0EB9E> /usr/lib/liblangid.dylib
                    0x7fff89ccd000 -     0x7fff89cfafff  com.apple.CoreVideo (1.8 - 145.1) <18DB07E0-B927-3260-A234-636F298D1917> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                    0x7fff89cfe000 -     0x7fff8a003ff3  com.apple.HIToolbox (2.1.1 - 758.7) <E3129A67-BDF9-333D-9C9C-A95C8F0EF71C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                    0x7fff8a004000 -     0x7fff8a00dff3  com.apple.CommonAuth (4.0 - 2.0) <9A484EE6-0003-3AB1-AE4F-AA543BBBF53F> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                    0x7fff8a00e000 -     0x7fff8a19cfff  libBLAS.dylib (1128) <497912C1-A98E-3281-BED7-E9C751552F61> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                    0x7fff8a19d000 -     0x7fff8a41cff7  com.apple.CoreData (111 - 526.3) <5A27E0D8-5E5A-335B-B3F6-2601C7B976FA> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                    0x7fff8a41d000 -     0x7fff8a46cff7  com.apple.opencl (2.4.2 - 2.4.2) <EB365E68-9965-3596-A40A-D1E372F3A9B3> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                    0x7fff8a489000 -     0x7fff8a4d5ff7  libcups.2.dylib (408.2) <E8AD18F9-61E4-3791-B840-504468C25556> /usr/lib/libcups.2.dylib
                    0x7fff8a556000 -     0x7fff8a57cfff  com.apple.ChunkingLibrary (2.1 - 163.6) <29D4CB95-42EF-34C6-8182-BDB6F7BB1E79> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                    0x7fff8a57d000 -     0x7fff8a585ff7  com.apple.AppleSRP (5.0 - 1) <68F0C577-ED96-34F2-B701-CE3023367D4D> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
                    0x7fff8b014000 -     0x7fff8b071fff  com.apple.QuickLookFramework (5.0 - 675.43) <506D60B4-B188-3D0A-9187-0404A60A9B06> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                    0x7fff8b1a3000 -     0x7fff8b1ddffb  com.apple.DebugSymbols (115 - 115) <6F03761D-7C3A-3C80-8031-AA1C1AD7C706> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                    0x7fff8b279000 -     0x7fff8b2a5fff  libsandbox.1.dylib (358.20.5) <533B9C4A-6C92-3658-95B9-D30BC135796B> /usr/lib/libsandbox.1.dylib
                    0x7fff8b2a6000 -     0x7fff8b2c0ff3  com.apple.Ubiquity (1.3 - 313) <DF56A657-CC6E-3BE2-86A0-71F07127724C> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
                    0x7fff8b2c1000 -     0x7fff8b2c1fff  com.apple.ApplicationServices (48 - 48) <5BF7910B-C328-3BF8-BA4F-CE52B574CE01> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                    0x7fff8b2c2000 -     0x7fff8b2dbff3  com.apple.openscripting (1.6.4 - 162.2) <BF79207B-C762-346D-8FF0-3DDCECC9E9E2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                    0x7fff8b2dc000 -     0x7fff8b2dffff  com.apple.IOSurface (97.4 - 97.4) <AE11CFBC-4D46-30F3-BEEC-4C8131079391> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                    0x7fff8b310000 -     0x7fff8b35dff3  com.apple.CoreMediaIO (601.0 - 4760) <4D52EBBF-5DE1-3778-BDE5-DE8540E7DE5C> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                    0x7fff8b369000 -     0x7fff8b42cff7  libvMisc.dylib (516) <21497A28-8DCB-3EB8-BDAC-93C93382B0AA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                    0x7fff8b42d000 -     0x7fff8b43afff  libxar.1.dylib (255) <7CD69BB5-97BA-3858-8A8B-2F33F129E6E7> /usr/lib/libxar.1.dylib
                    0x7fff8b451000 -     0x7fff8b6bbff7  com.apple.imageKit (2.6.1 - 850) <612201FE-768E-386B-82E3-764038B40120> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
                    0x7fff8b6c4000 -     0x7fff8b75aff7  com.apple.cloudkit.CloudKit (283.67.4 - 283.67.4) <EA6E4B2C-A3AA-3636-B9C3-F61D3EFFB82B> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
                    0x7fff8b774000 -     0x7fff8b903fff  libGLProgrammability.dylib (11.1.2) <11882D43-25B4-331D-9428-C97F4A88DA21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                    0x7fff8b904000 -     0x7fff8ba65fff  com.apple.avfoundation (2.0 - 889.210) <E1F0F203-6EA6-3CFA-BC6C-F372F273D6C5> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                    0x7fff8bae1000 -     0x7fff8bb59ff7  com.apple.SystemConfiguration (1.14.4 - 1.14) <3DFFD7F7-BD23-3F4C-A209-C4A0D99F6573> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                    0x7fff8bb5a000 -     0x7fff8bc01fff  com.apple.PDFKit (3.1 - 3.1) <D410CE57-6227-31D8-9F39-92583E552EA8> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
                    0x7fff8bcdc000 -     0x7fff8be0eff7  com.apple.MediaControlSender (2.0 - 215.18) <88726256-A71E-33A8-A56C-ABA208951C92> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSen der
                    0x7fff8bf54000 -     0x7fff8bf60ff7  com.apple.OpenDirectory (10.10 - 187) <D993F138-DAD1-3640-94DE-8C9FEFBF158D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                    0x7fff8bf61000 -     0x7fff8bf6afff  libGFXShared.dylib (11.1.2) <7F9F6175-E993-3014-8C9B-1F08CE7C75A2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                    0x7fff8bf6b000 -     0x7fff8bf93fff  libxpc.dylib (559.40.1) <5C829202-962E-3744-8B50-00D38CC88E84> /usr/lib/system/libxpc.dylib
                    0x7fff8bfc4000 -     0x7fff8bfc8ff7  libGIF.dylib (1239) <292BB418-F5C2-3D7B-AC1D-99082A4B88F3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                    0x7fff8bfcb000 -     0x7fff8c016ff7  com.apple.CloudDocs (1.0 - 321.10) <A8221290-A2A5-3767-BB26-CC57AC18D4DC> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
                    0x7fff8c04b000 -     0x7fff8c070ff7  libJPEG.dylib (1239) <9AC25FD0-4190-3656-B8F5-6241D17105D0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                    0x7fff8c0af000 -     0x7fff8c0b4ff7  com.apple.MediaAccessibility (1.0 - 61) <00A3E0B6-79AC-387E-B282-AADFBD5722F6> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
                    0x7fff8c0b5000 -     0x7fff8c0bbff7  libsystem_networkextension.dylib (167.40.3) <BA58B30B-8377-3B0A-8AE3-4F84021D9D4E> /usr/lib/system/libsystem_networkextension.dylib
                    0x7fff8c0bc000 -     0x7fff8c1e4ff7  com.apple.coreui (2.1 - 308.6) <9E0E9C6A-68F5-34C1-A17C-96226D401D4D> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                    0x7fff8c1e5000 -     0x7fff8c1eafff  com.apple.DiskArbitration (2.6 - 2.6) <0DFF4D9B-2AC3-3B82-B5C5-30F4EFBD2DB9> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                    0x7fff8c1eb000 -     0x7fff8c26ffff  com.apple.PerformanceAnalysis (1.0 - 1) <4E934EE0-5CC6-3D54-8FA2-5B8AE669D775> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                    0x7fff8c270000 -     0x7fff8c2d7ffb  com.apple.datadetectorscore (6.0 - 396.1.2) <D04A8016-B2AD-33A2-8A8E-5793968A8370> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                    0x7fff8c2e5000 -     0x7fff8c384e27  com.apple.AppleJPEG (1.0 - 1) <6627DDD9-A8FE-3968-B23A-B6A29AA3919A> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
                    0x7fff8c385000 -     0x7fff8c385ff7  libunc.dylib (29) <5676F7EA-C1DF-329F-B006-D2C3022B7D70> /usr/lib/system/libunc.dylib
                    0x7fff8c4f5000 -     0x7fff8c505ff7  libbsm.0.dylib (34) <A3A2E56C-2B65-37C7-B43A-A1F926E1A0BB> /usr/lib/libbsm.0.dylib
                    0x7fff8c509000 -     0x7fff8c564ff7  libTIFF.dylib (1239) <B09E578A-D534-3A9B-9813-DAC9A0F230C7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                    0x7fff8c565000 -     0x7fff8c689ff7  com.apple.LaunchServices (644.56 - 644.56) <20AABB1C-9319-3E4D-A024-51B0DD5FCD3B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                    0x7fff8c68a000 -     0x7fff8c94dff7  com.apple.WebKit (10600 - 10600.8.9) <8EE5A9F9-DE98-3202-92C0-23F6E6E5E274> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
                    0x7fff8c94e000 -     0x7fff8c98ffff  libGLU.dylib (11.1.2) <2BA52A8D-ED35-3D86-B2D6-41479969C96D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                    0x7fff8c990000 -     0x7fff8c9a1ff7  libz.1.dylib (55) <88C7C7DE-04B8-316F-8B74-ACD9F3DE1AA1> /usr/lib/libz.1.dylib
                    0x7fff8c9a6000 -     0x7fff8cb8bff7  libicucore.A.dylib (531.48) <3CD34752-B1F9-31D2-865D-B5B0F0BE3111> /usr/lib/libicucore.A.dylib
                    0x7fff8cb8c000 -     0x7fff8cb8ffff  com.apple.xpc.ServiceManagement (1.0 - 1) <A95A15CD-3B21-3513-AFF8-1D7DE3DBFA12> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                    0x7fff8cb90000 -     0x7fff8cc84fff  libFontParser.dylib (134.7) <C49EDC56-A82A-39EF-9F20-C2342E4188ED> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                    0x7fff8cc85000 -     0x7fff8cc85fff  libOpenScriptingUtil.dylib (162.2) <D6A2216D-ADB2-3F24-AD30-F6D00829F545> /usr/lib/libOpenScriptingUtil.dylib
                    0x7fff8cf7e000 -     0x7fff8cf88ff7  com.apple.NetAuth (5.2 - 5.2) <2BBD749A-8E18-35B8-8E48-A90347C1CCA7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                    0x7fff8d2ca000 -     0x7fff8d6a1fe7  com.apple.CoreAUC (211.1.0 - 211.1.0) <12645629-E065-388E-A6B5-094A240578CE> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                    0x7fff8d6dc000 -     0x7fff8d70cff3  com.apple.GSS (4.0 - 2.0) <97F2A028-44CF-3188-B863-F4EEB39CBDBD> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                    0x7fff8d70d000 -     0x7fff8da40ff7  libmecabra.dylib (666.7) <0ED8AE5E-7A5B-34A6-A2EE-2B852E60E1E2> /usr/lib/libmecabra.dylib
                    0x7fff8da41000 -     0x7fff8da8dfff  com.apple.corelocation (1486.17 - 1615.24) <8825B3E2-E053-3E01-AE31-793443962D06> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
                    0x7fff8dae9000 -     0x7fff8db2fff7  libauto.dylib (186) <A260789B-D4D8-316A-9490-254767B8A5F1> /usr/lib/libauto.dylib
                    0x7fff8db32000 -     0x7fff8db3eff7  libGPUSupportMercury.dylib (11.1.2) <16B2CA57-479C-3F0F-BF87-03A2C6923D5A> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
                    0x7fff8db3f000 -     0x7fff8de26ffb  com.apple.CoreServices.CarbonCore (1108.6 - 1108.6) <8953580E-7857-33B2-AA64-98296830D3A8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                    0x7fff8de27000 -     0x7fff8de93fff  com.apple.framework.CoreWLAN (5.0 - 500.35.2) <03697149-1CDD-32FF-B564-1C1EF5E9E5C3> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                    0x7fff8de94000 -     0x7fff8deb4ff7  com.apple.MultitouchSupport.framework (264.6 - 264.6) <1539F1F6-6334-37F3-9C52-02EFFBF4835D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                    0x7fff8deb5000 -     0x7fff8df4cfff  com.apple.CoreMedia (1.0 - 1562.238) <B24BDB25-1203-380D-95B7-0A3FEB25521E> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                    0x7fff8df4d000 -     0x7fff8df5efff  libcmph.dylib (1) <46EC3997-DB5E-38AE-BBBB-A035A54AD3C0> /usr/lib/libcmph.dylib
                    0x7fff8df6c000 -     0x7fff8df77ff7  com.apple.CrashReporterSupport (10.10 - 631) <C44259AC-0A1C-3EC5-99AC-48CB520A709D> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                    0x7fff8df78000 -     0x7fff8dfa3fff  libc++abi.dylib (125) <88A22A0F-87C6-3002-BFBA-AC0F2808B8B9> /usr/lib/libc++abi.dylib
                    0x7fff8dfa5000 -     0x7fff8dfc0ff7  libCRFSuite.dylib (34) <D64842BE-7BD4-3D0C-9842-1D202F7C2A51> /usr/lib/libCRFSuite.dylib
                    0x7fff8dfc1000 -     0x7fff8e081ff7  com.apple.backup.framework (1.6.5 - 1.6.5) <86396038-33EA-3046-9F70-093A3D6407D4> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                    0x7fff8e082000 -     0x7fff8e0a3fff  com.apple.framework.Apple80211 (10.3 - 1030.71.6) <C0A17391-5C8B-34B1-BD46-8D644AB57DE0> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                    0x7fff8e0a4000 -     0x7fff8e0a4fff  com.apple.quartzframework (1.5 - 1.5) <26C982A3-2FC3-3F50-B5F4-3C545C3BAC10> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                    0x7fff8e0a5000 -     0x7fff8e0b3ff7  com.apple.opengl (11.1.2 - 11.1.2) <5F355713-4637-33CD-9CBA-4B4CA43FB0FE> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                    0x7fff8e0b4000 -     0x7fff8e19eff7  com.apple.QuickLookUIFramework (5.0 - 675.43) <011DEB49-0FB3-3E44-9D99-D89ADD59A3CC> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
                    0x7fff8e23d000 -     0x7fff8e34cff3  com.apple.desktopservices (1.9.3 - 1.9.3) <FEE11342-5BC4-37A7-8169-DA48BE17B9C9> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                    0x7fff8e34d000 -     0x7fff8e388fff  com.apple.Symbolication (1.4 - 56045) <D64571B1-4483-3FE2-BD67-A91360F79727> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                    0x7fff8e389000 -     0x7fff8e3b8ff7  com.apple.CoreServicesInternal (221.7.2 - 221.7.2) <B93D4775-149C-3698-B38C-9C50673D455C> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                    0x7fff8e3b9000 -     0x7fff8e3d3ff7  liblzma.5.dylib (7) <1D03E875-A7C0-3028-814C-3C27F7B7C079> /usr/lib/liblzma.5.dylib
                    0x7fff8e3d4000 -     0x7fff8e476fff  com.apple.Bluetooth (4.3.6 - 4.3.6f3) <E5DC1699-2727-329C-A843-C80CE9A6CD7B> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
                    0x7fff8e477000 -     0x7fff8e47cff7  libunwind.dylib (35.3) <BE7E51A0-B6EA-3A54-9CCA-9D88F683A6D6> /usr/lib/system/libunwind.dylib
                    0x7fff8e47d000 -     0x7fff8e488ff7  libcsfde.dylib (471.30.1) <A62AE3D8-E2A6-314A-BF45-804003BE0AC9> /usr/lib/libcsfde.dylib
                    0x7fff8e489000 -     0x7fff8e4f5ff3  com.apple.MMCS (1.3 - 327.5) <FC998246-ED60-334D-9E94-453F35EF9C78> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
                    0x7fff8e4f6000 -     0x7fff8e639fff  libsqlite3.dylib (168.2) <BCB1F77E-2484-3EC4-A1D5-1AE90A407A23> /usr/lib/libsqlite3.dylib
                    0x7fff8e63a000 -     0x7fff8e641fff  com.apple.network.statistics.framework (1.2 - 1) <61B311D1-7F15-35B3-80D4-99B8BE90ACD9> /System/Library/PrivateFrameworks/NetworkStatistics.framework/Versions/A/NetworkStatistic s
                    0x7fff8e642000 -     0x7fff8e6d0ff7  com.apple.CorePDF (4.0 - 4) <9CD7EC6D-3593-3D60-B04F-75F612CCB99A> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
                    0x7fff8e719000 -     0x7fff8e7fdfff  libcrypto.0.9.8.dylib (52.40.1) <D123FC57-E2EB-3E08-A51B-6C317EA83EB5> /usr/lib/libcrypto.0.9.8.dylib
                    0x7fff8e933000 -     0x7fff8e9a1ff3  com.apple.Heimdal (4.0 - 2.0) <8D1667CF-D454-3E07-A58E-E15591B5A95E> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                    0x7fff8e9a2000 -     0x7fff8e9bdfff  com.apple.AppleVPAFramework (1.4.5 - 1.4.5) <A6421B0B-6D4D-3E64-AC61-DDB04ED7CFF0> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
                    0x7fff8e9d1000 -     0x7fff8e9edff7  libsystem_malloc.dylib (53.30.1) <DDA8928B-CC0D-3255-BD8A-3FEA0982B890> /usr/lib/system/libsystem_malloc.dylib
                    0x7fff8e9ee000 -     0x7fff8e9f9fff  libcommonCrypto.dylib (60061.30.1) <E789748D-F9A7-3CFF-B317-90DF348B1E95> /usr/lib/system/libcommonCrypto.dylib
                    0x7fff8eafb000 -     0x7fff8eb00ff7  libmacho.dylib (862) <126CA2ED-DE91-308F-8881-B9DAEC3C63B6> /usr/lib/system/libmacho.dylib
                    0x7fff8f3ad000 -     0x7fff8f55cfff  GLEngine (11.1.2) <8A8153B1-94CE-3EC1-9840-441DA7217BA9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
                    0x7fff8f630000 -     0x7fff8fa60fff  com.apple.vision.FaceCore (3.1.6 - 3.1.6) <C3B823AA-C261-37D3-B4AC-C59CE91C8241> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
                    0x7fff8fa61000 -     0x7fff902c0ff7  com.apple.CoreGraphics (1.600.0 - 788.3) <875FBF24-D90E-36B1-9F7A-AF984E8943D9> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                    0x7fff9032d000 -     0x7fff90346ff7  com.apple.CFOpenDirectory (10.10 - 187) <3FCEE6F7-A8C6-3222-B22D-8AD290E477E2> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                    0x7fff90347000 -     0x7fff90372ff3  libarchive.2.dylib (30) <8CBB4416-EBE9-3574-8ADC-44655D245F39> /usr/lib/libarchive.2.dylib
                    0x7fff90373000 -     0x7fff90407fff  com.apple.ink.framework (10.9 - 213) <8E029630-1530-3734-A446-13353F0E7AC5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                    0x7fff9044e000 -     0x7fff90476fff  libsystem_info.dylib (459.40.1) <2E16C4B3-A327-3957-9C41-143911979A1E> /usr/lib/system/libsystem_info.dylib
                    0x7fff90511000 -     0x7fff90531fff  com.apple.IconServices (47.1 - 47.1) <E83DFE3B-6541-3736-96BB-26DC5D0100F1> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
                    0x7fff90532000 -     0x7fff90557ff7  libPng.dylib (1239) <BBB9FB25-3CA9-38AF-B88C-D6734693FEA1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                    0x7fff90558000 -     0x7fff90559fff  libDiagnosticMessagesClient.dylib (100) <2EE8E436-5CDC-34C5-9959-5BA218D507FB> /usr/lib/libDiagnosticMessagesClient.dylib
                    0x7fff90568000 -     0x7fff90570fff  libMatch.1.dylib (24) <C917279D-33C2-38A8-9BDD-18F3B24E6FBD> /usr/lib/libMatch.1.dylib
                    0x7fff9061e000 -     0x7fff90622fff  com.apple.CommonPanels (1.2.6 - 96) <F9ECC8AF-D9CA-3350-AFB4-5113A9B789A5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                    0x7fff90623000 -     0x7fff90625ff7  libutil.dylib (38) <471AD65E-B86E-3C4A-8ABD-B8665A2BCE3F> /usr/lib/libutil.dylib
                    0x7fff90629000 -     0x7fff9062dfff  libcache.dylib (69) <45E9A2E7-99C4-36B2-BEE3-0C4E11614AD1> /usr/lib/system/libcache.dylib
                    0x7fff90cef000 -     0x7fff90cfbfff  com.apple.speech.synthesis.framework (5.3.11 - 5.3.11) <DFC7FD85-F1B0-317C-8513-722570CB8FB9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                    0x7fff90cfc000 -     0x7fff90d2cff3  com.apple.CoreAVCHD (5.7.5 - 5750.4.1) <3E51287C-E97D-3886-BE88-8F6872400876> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
                    0x7fff90d52000 -     0x7fff90d7afff  libRIP.A.dylib (788.3) <6AB1CA86-38C8-33E3-AC07-3A065666E0F9> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
                    0x7fff90d7b000 -     0x7fff90e6dff3  libxml2.2.dylib (26.1) <3FBA890F-2850-3A45-87EA-DB6892BDEB60> /usr/lib/libxml2.2.dylib
                    0x7fff90e6e000 -     0x7fff90e75fff  com.apple.NetFS (6.0 - 4.0) <C263C8F8-F284-3101-AC82-A97A81716063> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                    0x7fff90ec7000 -     0x7fff90ec8fff  com.apple.TrustEvaluationAgent (2.0 - 25) <2D61A2C3-C83E-3A3F-8EC1-736DBEC250AB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                    0x7fff90edf000 -     0x7fff90ef5ff7  libsystem_asl.dylib (267) <F153AC5B-0542-356E-88C8-20A62CA704E2> /usr/lib/system/libsystem_asl.dylib
                    0x7fff90f08000 -     0x7fff90f0bff7  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <BCC15965-7869-34F4-9019-9D0A41DD6AFF> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
                    0x7fff90f0c000 -     0x7fff91025ffb  com.apple.CoreText (352.0 - 454.10) <3293BF91-B587-3B49-A159-A04D58533F14> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                    0x7fff91026000 -     0x7fff91050fff  GLRendererFloat (11.1.2) <50EC0CD3-5CAB-3183-9818-FC4A405B681F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
                    0x7fff910bc000 -     0x7fff911aeff7  libiconv.2.dylib (42) <2A06D02F-8B76-3864-8D96-64EF5B40BC6C> /usr/lib/libiconv.2.dylib
                    0x7fff911af000 -     0x7fff911b3fff  libpam.2.dylib (20) <E805398D-9A92-31F8-8005-8DC188BD8B6E> /usr/lib/libpam.2.dylib
                    0x7fff911b4000 -     0x7fff91249ff7  com.apple.ColorSync (4.9.0 - 4.9.0) <9150C2B7-2E6E-3509-96EA-7B3F959F049E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                    0x7fff9124a000 -     0x7fff912cbff7  com.apple.CoreUtils (1.1 - 110.1) <3808CBC5-1DF1-3821-8AAE-57C30D4F514B> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
                    0x7fff912cc000 -     0x7fff912ccff7  liblaunch.dylib (559.40.1) <4F81CA3A-D2CE-3030-A89D-42F3DAD7BA8F> /usr/lib/system/liblaunch.dylib
                    0x7fff912cd000 -     0x7fff91306fff  com.apple.AirPlaySupport (2.0 - 215.18) <A7730005-A538-30E8-815B-727957D74C89> /System/Library/PrivateFrameworks/AirPlaySupport.framework/Versions/A/AirPlaySupport
                    0x7fff91311000 -     0x7fff913affff  com.apple.Metadata (10.7.0 - 917.36) <00C4CB5D-E723-3612-84E0-439098392CDD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                    0x7fff913b0000 -     0x7fff914f4ff7  com.apple.QTKit (7.7.3 - 2890.7) <267DFB98-4959-3EDE-B76B-8B2F12F41A17> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                    0x7fff914f5000 -     0x7fff91500ff7  libkxld.dylib (2782.40.9) <2ADAE067-78A0-371E-A5A8-1E7C892D193C> /usr/lib/system/libkxld.dylib
                    0x7fff91501000 -     0x7fff91503fff  com.apple.loginsupport (1.0 - 1) <DAAD7013-A19D-3858-BFF7-DE1DAF664401> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
                    0x7fff91504000 -     0x7fff9150cfff  libsystem_platform.dylib (63) <64E34079-D712-3D66-9CE2-418624A5C040> /usr/lib/system/libsystem_platform.dylib
                    0x7fff9150d000 -     0x7fff9150ffff  libquarantine.dylib (76.20.1) <7AF90041-2768-378A-925A-D83161863642> /usr/lib/system/libquarantine.dylib
                    0x7fff91510000 -     0x7fff91518fff  libsystem_dnssd.dylib (576.30.4) <0CEB5910-843F-315C-A1DE-5D955A48A045> /usr/lib/system/libsystem_dnssd.dylib
                    0x7fff91519000 -     0x7fff91542ffb  libxslt.1.dylib (13) <AED1143F-B848-3E73-81ED-71356F25F084> /usr/lib/libxslt.1.dylib
                    0x7fff91543000 -     0x7fff91573fff  libsystem_m.dylib (3086.1) <1E12AB45-6D96-36D0-A226-F24D9FB0D9D6> /usr/lib/system/libsystem_m.dylib
                    0x7fff91574000 -     0x7fff9157cfe7  libcldcpuengine.dylib (2.4.5) <6CC680F9-0D13-333B-B151-F0D9C631A1E5> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
                    0x7fff9157d000 -     0x7fff9157dfff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <B92888D0-ED3F-3430-8F3A-6E56FD16C5F1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                    0x7fff916f6000 -     0x7fff916fbffb  libheimdal-asn1.dylib (398.40.1) <7D2BE3DE-60F7-3A6E-A92E-DA0EF9D3417E> /usr/lib/libheimdal-asn1.dylib
                    0x7fff91713000 -     0x7fff91753ff7  libGLImage.dylib (11.1.2) <9B05F3BF-D111-3B01-B7F8-C5EF7E02000B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                    0x7fff917d2000 -     0x7fff91826fff  libc++.1.dylib (120) <1B9530FD-989B-3174-BB1C-BDC159501710> /usr/lib/libc++.1.dylib
                    0x7fff91827000 -     0x7fff9182aff7  com.apple.Mangrove (1.0 - 1) <6326024D-5C8D-3F59-9468-ACA1E01BC70C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
                    0x7fff9182b000 -     0x7fff9182ffff  libspindump.dylib (182.4) <929670EB-4963-3496-AD24-8B50E388803C> /usr/lib/libspindump.dylib
                    0x7fff91844000 -     0x7fff91844fff  com.apple.Cocoa (6.8 - 21) <EAC0EA1E-3C62-3B28-A941-5D8B1E085FF8> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                    0x7fff91845000 -     0x7fff91845ff7  libkeymgr.dylib (28) <77845842-DE70-3CC5-BD01-C3D14227CED5> /usr/lib/system/libkeymgr.dylib
                    0x7fff9185c000 -     0x7fff91872ff7  com.apple.CoreMediaAuthoring (2.2 - 951) <C3E7D4C1-400D-34FA-9FE1-8C68C03CE969> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                    0x7fff918d0000 -     0x7fff918edfff  libsystem_kernel.dylib (2782.40.9) <16AD15EF-3DAE-3F63-9D26-26CCE1920762> /usr/lib/system/libsystem_kernel.dylib
                    0x7fff918ee000 -     0x7fff91a36ff7  com.apple.WebKitLegacy (10600 - 10600.8.9) <C01FF5CA-AB10-39D9-BD26-7A62332B708F> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/ Versions/A/WebKitLegacy
                    0x7fff91a37000 -     0x7fff91a48ff3  libsystem_coretls.dylib (35.40.1) <155DA0A9-2046-332E-BFA3-D7974A51F731> /usr/lib/system/libsystem_coretls.dylib
                    0x7fff91a49000 -     0x7fff91a63ff7  libextension.dylib (55.2) <3BB019CA-199A-36AC-AA22-14B562138545> /usr/lib/libextension.dylib
                    0x7fff91aca000 -     0x7fff91acdfff  com.apple.help (1.3.3 - 46) <CA4541F4-CEF5-355C-8F1F-EA65DC1B400F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                    0x7fff91ace000 -     0x7fff91b57ff7  com.apple.CoreSymbolication (3.1 - 57020.2) <FDAF88F6-7D11-37BC-B758-4B835FA657BA> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                    0x7fff91b58000 -     0x7fff91b59fff  libsystem_secinit.dylib (18) <581DAD0F-6B63-3A48-B63B-917AF799ABAA> /usr/lib/system/libsystem_secinit.dylib
                    0x7fff91b5a000 -     0x7fff91ba4fff  com.apple.HIServices (1.22 - 523) <E2F3C5FF-8C50-3E4F-BE63-77A700466663> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                    0x7fff91bf1000 -     0x7fff91c3eff7  com.apple.print.framework.PrintCore (10.3 - 451.1) <DE992474-0841-38A1-B4F6-46D653E454D5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                    0x7fff91c3f000 -     0x7fff91f0eff3  com.apple.CoreImage (10.3.4) <C1AE8252-A95D-3BF4-83B8-BE85E979F2CB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
                    0x7fff9202e000 -     0x7fff92040ff7  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <CE9FABB4-1C5D-3F9B-9BB8-5CC50C3E5E31> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDae monProtocol
                    0x7fff92041000 -     0x7fff92094ffb  libAVFAudio.dylib (118.6) <2441D4C1-D8FB-3DA9-9DD7-914E03413882> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
                    0x7fff92095000 -     0x7fff92099fff  com.apple.IOAccelerator (156.16 - 156.16) <12DE1474-4B2A-3D7D-ACF9-DDAF66A6936A> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
                    0x7fff9209a000 -     0x7fff920cbff7  com.apple.ProtectedCloudStorage (1.0 - 1) <9D76F2E0-C28A-3DBC-A91F-E87888D46BF0> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
                    0x7fff920cc000 -     0x7fff920ccfff  com.apple.CoreServices (62 - 62) <C69DA8A7-B536-34BF-A93F-1C170E2C6D58> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                    0x7fff920da000 -     0x7fff92111ffb  com.apple.LDAPFramework (2.4.28 - 194.5) <CAFB9695-000F-34EA-8DF5-09996929C26A> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                    0x7fff92112000 -     0x7fff92186ffb  com.apple.securityfoundation (6.0 - 55126) <AC8ED0BD-32F0-3EB8-B7B2-9AA14E07E8AB> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                    0x7fff921e4000 -     0x7fff922baff3  com.apple.DiskImagesFramework (10.10.5 - 398) <23E788A6-9A11-3232-A882-BA16D0C54880> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
                    0x7fff9232a000 -     0x7fff92347ffb  libresolv.9.dylib (57) <26B38E61-298A-3C3A-82C1-3B5E98AD5E29> /usr/lib/libresolv.9.dylib
                    0x7fff92348000 -     0x7fff9234afff  com.apple.CoreDuetDebugLogging (1.0 - 1) <9A6E5710-EA99-366E-BF40-9A65EC1B46A1> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebug Logging
                    0x7fff9234b000 -     0x7fff9234cff3  libSystem.B.dylib (1213) <1866C519-C5F3-3D09-8C17-A8F703664521> /usr/lib/libSystem.B.dylib
                    0x7fff9234d000 -     0x7fff9235fff7  libsasl2.2.dylib (194.1) <35371406-75EF-304A-A073-956C40373555> /usr/lib/libsasl2.2.dylib
                    0x7fff92360000 -     0x7fff92477fe7  libvDSP.dylib (516) <DFEDB210-49D1-3803-88A2-C61DB6A45C3D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                    0x7fff92478000 -     0x7fff924c7ff7  libstdc++.6.dylib (104.1) <803F6AC8-87DC-3E24-9E80-729B551F6FFF> /usr/lib/libstdc++.6.dylib
                    0x7fff92535000 -     0x7fff92837ffb  com.apple.GeoServices (1.0 - 1077.0.18) <2BBF8B44-DD46-3432-8C84-6D6AA004C233> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
                    0x7fff92838000 -     0x7fff92840ff3  com.apple.CoreServices.FSEvents (1210.20.1 - 1210.20.1) <84F79D3E-7B5E-3C93-8479-35794A3F125E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
                    0x7fff92841000 -     0x7fff92842ffb  libremovefile.dylib (35) <3485B5F4-6CE8-3C62-8DFD-8736ED6E8531> /usr/lib/system/libremovefile.dylib
                    0x7fff92bb1000 -     0x7fff92be9fff  com.apple.RemoteViewServices (2.0 - 99) <C9A62691-B0D9-34B7-B71C-A48B5F4DC553> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                    0x7fff92bea000 -     0x7fff92c14ff7  libdispatch.dylib (442.1.4) <502CF32B-669B-3709-8862-08188225E4F0> /usr/lib/system/libdispatch.dylib
                    0x7fff92c34000 -     0x7fff9315dff7  com.apple.QuartzComposer (5.1 - 332.1) <64399385-0768-3590-B4EF-1BD0F8A35CB3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
                    0x7fff9315e000 -     0x7fff934f6ff7  com.apple.CoreFoundation (6.9 - 1153.18) <5C0892B8-9691-341F-9279-CA3A74D59AA0> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                    0x7fff934f7000 -     0x7fff934f8ff7  libsystem_blocks.dylib (65) <9615D10A-FCA7-3BE4-AA1A-1B195DACE1A1> /usr/lib/system/libsystem_blocks.dylib
                    0x7fff934f9000 -     0x7fff93511ff7  libexpat.1.dylib (12) <C5FE8836-E277-3162-9D15-6735321CB2C6> /usr/lib/libexpat.1.dylib
                    0x7fff93512000 -     0x7fff93512fff  com.apple.Accelerate (1.10 - Accelerate 1.10) <F1B96A61-7E4B-31BD-A35B-BA7EF1F16EF4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                    0x7fff93513000 -     0x7fff93a28ffb  com.apple.JavaScriptCore (10600 - 10600.8.7) <480CDC12-5A1C-321C-B32F-673F0B3BA8F9> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                    0x7fff93a29000 -     0x7fff93a36ff3  com.apple.ProtocolBuffer (1 - 228.0.1) <3429EB06-9F0E-355F-B9AB-F72879177398> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
                    0x7fff93a37000 -     0x7fff93a3dfff  libsystem_trace.dylib (72.20.1) <840F5301-B55A-3078-90B9-FEFFD6CD741A> /usr/lib/system/libsystem_trace.dylib
                    0x7fff93a3e000 -     0x7fff93a4dfff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <D1E527E4-C561-352F-9457-E8C50232793C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                    0x7fff93a4e000 -     0x7fff93a56ff7  com.apple.icloud.FindMyDevice (1.0 - 1) <9CE67F85-2BA8-3093-97BA-07BF5C04A5D6> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
                    0x7fff93ac5000 -     0x7fff93ad2ff7  libbz2.1.0.dylib (36) <2DF83FBC-5C08-39E1-94F5-C28653791B5F> /usr/lib/libbz2.1.0.dylib
                    0x7fff93ad3000 -     0x7fff93afeff7  com.apple.DictionaryServices (1.2 - 229.1) <62EC3E1B-5A28-3252-90FF-C2E9999C2A2A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                    0x7fff93c1a000 -     0x7fff93c1afff  com.apple.Carbon (154 - 157) <9BF51672-1684-3FDE-A561-FC59A2864EF8> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                    0x7fff93c5d000 -     0x7fff93c62fff  libsystem_stats.dylib (163.30.2) <D0E96837-3CF6-323D-B711-6DF6F660E530> /usr/lib/system/libsystem_stats.dylib
                External Modification Summary:
                  Calls made by other processes targeting this process:
                    task_for_pid: 2
                    thread_create: 0
                    thread_set_state: 0
                  Calls made by this process:
                    task_for_pid: 0
                    thread_create: 0
                    thread_set_state: 0
                  Calls made by all processes on this machine:
                    task_for_pid: 242
                    thread_create: 0
                    thread_set_state: 0
                VM Region Summary:
                ReadOnly portion of Libraries: Total=817.2M resident=348.0M(43%) swapped_out_or_unallocated=469.2M(57%)
                Writable regions: Total=1.2G written=657.9M(55%) resident=741.1M(62%) swapped_out=0K(0%) unallocated=451.9M(38%)
                REGION TYPE                      VIRTUAL
                ATS (font support)                 32.3M
                ATS (font support) (reserved)         4K        reserved VM address space (unallocated)
                Activity Tracing                   2048K
                CG backing stores                  16.2M
                CG image                            212K
                CG raster data                     8360K
                CG shared images                    272K
                CoreAnimation                        48K
                CoreImage                             8K
                CoreUI image data                    96K
                Foundation                            4K
                IOKit                              4896K
                Image IO                           2068K
                Kernel Alloc Once                     8K
                MALLOC                            814.7M
                MALLOC (admin)                       32K
                Memory Tag 242                       12K
                Memory Tag 249                      156K
                Memory Tag 251                        8K
                OpenCL                               16K
                OpenGL GLSL                         512K
                STACK GUARD                        56.1M
                Stack                              54.8M
                VM_ALLOCATE                       242.0M
                VM_ALLOCATE (reserved)               36K        reserved VM address space (unallocated)
                __DATA                             61.2M
                __GLSLBUILTINS                     2588K
                __IMAGE                             528K
                __LINKEDIT                        204.3M
                __NV_CUDA                          5876K
                __TEXT                            612.9M
                __UNICODE                           552K
                mapped file                       155.5M
                shared memory                        68K
                TOTAL                               2.2G
                TOTAL, minus reserved VM space      2.2G
                Model: MacPro6,1, BootROM MP61.0116.B15, 4 processors, Quad-Core Intel Xeon E5, 3.7 GHz, 12 GB, SMC 2.20f18
                Graphics: AMD FirePro D300, AMD FirePro D300, PCIe, 2048 MB
                Memory Module: DIMM1, 4 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343531553741465238432D52442020
                Memory Module: DIMM2, 4 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343531553741465238432D52442020
                Memory Module: DIMM3, 4 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343531553741465238432D52442020
                AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x135), Broadcom BCM43xx 1.0 (7.15.166.24.3)
                Bluetooth: Version 4.3.6f3 16238, 3 services, 27 devices, 1 incoming serial ports
                Network Service: Ethernet 1, Ethernet, en0
                Network Service: Wi-Fi, AirPort, en2
                PCI Card: AMD FirePro D300, Display Controller, Slot-1
                PCI Card: AMD FirePro D300, Display Controller, Slot-2
                PCI Card: pci105a,8760, RAID Controller, Thunderbolt@158,0,0
                Serial ATA Device: APPLE SSD SM0256F, 251 GB
                USB Device: Hub
                USB Device: BRCM20702 Hub
                USB Device: Bluetooth USB Host Controller
                USB Device: DELL USB Laser Mouse
                USB Device: Hub in Apple Pro Keyboard
                USB Device: Apple Pro Keyboard
                USB Device: AK5370
                Thunderbolt Bus: Mac Pro, Apple Inc., 19.2
                Thunderbolt Device: Pegasus2-R, Promise Technology, Inc., 3, 19.2
                • 5. Re: Windows (composition & effects and presets) not refreshing
                  Hmmmm...if that's been happening for a year, it sounds like something is really wrong with your AE.
                  I'd suggest you contact Adobe support.
                  If you do have to do a clean install, make sure you've got a backup of all your Adobe stuff, uninstall it and run the CC Cleaner tool before you reinstall.
