4 Replies Latest reply on Apr 25, 2006 11:02 AM by ntsiii
    mx.controls.gridclasses.DataGridColumn is not assignable to Array
    fthj
      The error is mx.controls.gridclasses.DataGridColumn is not assignable to Array
      The flex version is Flex 1.5
      Mysql is 5.0
      This an example i have got from the net Flex ,PHP and Mysql, i have made some changes to the php but i have this error in the MXML section i can´t find a solution for it
      the database is called loja
      the table is users
      and the php variable is result
      and user
      the database is in mysql
      <mx ataGrid id="dgUserRequest" x="22" y="128" dataProvider="{userRequest.result.users.user}">
      <mx:columns>
      The error is in this line:
      2 Errors found.
      Error /flexandphp/index.mxml:22
      <mx ataGridColumn headerText="User ID" dataTipField="userid"/>
      Error /flexandphp/index.mxml:23
      Property may only contain one value
      <mx ataGridColumn headerText="User Name" dataTipField="username"/>
      </mx:columns>
      </mx ataGrid>
      <mx:Application xmlns:mx=" http://www.macromedia.com/2003/mxml" xmlns="*" creationComplete="userRequest.send()">
      <mx:HTTPService id="userRequest" url=" http://localhost/testes/request.php" useProxy="false" method="POST">
      <mx:request xmlns="">
      <username>{username.text}</username><emailaddress>{emailaddress.text}</emailaddress>
      </mx:request>
      </mx:HTTPService>
      <mx:Form x="22" y="10" width="493">
      <mx:HBox>
      <mx:Label text="Username"/>
      <mx:TextInput id="username"/>
      </mx:HBox>
      <mx:HBox>
      <mx:Label text="Email Address"/>
      <mx:TextInput id="emailaddress"/>
      </mx:HBox>
      <mx:Button label="Submit" click="userRequest.send()"/>
      </mx:Form>
      <mx:columns>
      </mx:columns>
      </mx ataGrid>
      <mx:TextInput x="22" y="292" id="selectedemailaddress" text="{dgUserRequest.selectedItem.emailaddress}"/>
      </mx:Application>
      The error mx.controls.gridclasses.DataGridColumn is not assignable to Array
      the table is users
      and user
      <mx:columns>
      </mx:columns>
      </mx ataGrid>
      php code file request.php
      <?php
      //connect to the database
      $link = mysql_connect('localhost','root','cacilda');
      if (!$link) {
      die('Could not connect: ' . mysql_error());
      echo 'Connected successfully';
      mysql_select_db('loja');
      // Quote variable to make safe
      function quote_smart($value)
      // Stripslashes
      if (get_magic_quotes_gpc()) {
      $value = stripslashes($value);
      // Quote if not integer
      if (!is_numeric($value)) {
      $value = "'" . mysql_real_escape_string($value) . "'";
      return $value;
      if( $_POST['emailaddress'] AND $_POST['username'])
      //add the user
      $Query = sprintf("INSERT INTO users VALUES ('', '%s', '%s')", quote_smart($_POST['username']), quote_smart($_POST['emailaddress']));
      $Result = mysql_query( $Query );
      //return a list of all the users
      $Query = "SELECT * from users";
      $Return = "<users>";
      while ( $User = mysql_fetch_object( $Result ) )
      $Return .= "<user><userid>".$User->userid."</userid><username>".$User->username."</username><emailad dress>".$User->emailaddress."</emailaddress></user>";
      $Return .= "</users>";
      mysql_free_result( $Result );
      print ($Return)
