1 Reply Latest reply on Mar 10, 2016 12:05 AM by Nanaky
    how to solve ade check activation issuse
    sandhyas77827668 Level 1
      i m annoying of this ADE 4.5 link.this is not supported me .i have download a book via ADE 4.5 this is not supported .this shows failed check ur activation&also i tried to erase computer autherisation but shows my password box blank and below writting in this words unable to erase authorisation pls try after some time this is really irretating me pls help how to solve this issue
        • 1. Re: how to solve ade check activation issuse
          Nanaky Level 5
          Windows:
              Close all applications.
              Choose Start > Run.
              In the Open text box, type regedit and then press Enter. The Registry Editor opens.
              In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
              Select the Adept key.
              Choose File > Export.
              In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
              Right-click the Adept key and choose Delete.
              In the Confirm Key Delete dialog, click OK.
              Close the Registry Editor.
              Open Adobe Digital Editions and reauthorize.
          Macintosh:
              quit Adobe Digital Editions.
              Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
              If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
