1 Reply Latest reply on Mar 10, 2016 6:47 AM by John Mensinger
    Indesign issue! Help!
    jessicam82656326
      Help!
      I am wanting to set an TIFF image as a background of an A4 advert but its looks massive and unsure how to scale down without losing some of the image.
      Thank you
        • 1. Re: Indesign issue! Help!
          John Mensinger Adobe Community Professional & MVP
          jessicam82656326 wrote:
          ...without losing some of the image.
          Not sure what you mean by that. Your best bet would be to open the image in Photoshop and resize/crop it there to your A4 page (+bleed) at the desired resolution. Then Place in InDesign, and no resizing should be needed.
          OR, resize in InDesign using a corner handle while holding down Ctrl/Cmd+Shift. If the image is much larger than needed, this will push the effective resolution (see Info panel) up, and potentially cause a processing-bloat problem at output.
