2 Replies Latest reply on Mar 11, 2016 3:16 AM by gionnyp9672044
    recall script function
    gionnyp9672044 Level 1
      I created a dialog panel with buttons
      these buttons all use a function in this case proposed and multiply
      since I am very script how do I call this function?
      this a try
      win.crealayer.scurBtn.onClick = function () {
      var idMk = charIDToTypeID( "Mk  " );
          var desc514 = new ActionDescriptor();
          var idnull = charIDToTypeID( "null" );
              var ref261 = new ActionReference();
              var idAdjL = charIDToTypeID( "AdjL" );
              ref261.putClass( idAdjL );
          desc514.putReference( idnull, ref261 );
          var idUsng = charIDToTypeID( "Usng" );
              var desc515 = new ActionDescriptor();
              var idType = charIDToTypeID( "Type" );
                  var desc516 = new ActionDescriptor();
                  var idpresetKind = stringIDToTypeID( "presetKind" );
                  var idpresetKindType = stringIDToTypeID( "presetKindType" );
                  var idpresetKindDefault = stringIDToTypeID( "presetKindDefault" );
                  desc516.putEnumerated( idpresetKind, idpresetKindType, idpresetKindDefault );
              var idCrvs = charIDToTypeID( "Crvs" );
              desc515.putObject( idType, idCrvs, desc516 );
          desc514.putObject( idUsng, idAdjL, desc515 );
      executeAction( idMk, desc514, DialogModes.NO );
      app.doAction("FusionMultiply", "UserSteps");
      function FusionMultiply()
          var idLvls = charIDToTypeID( "Lvls" );
          var desc4 = new ActionDescriptor();
          desc4.putEnumerated( idpresetKind, idpresetKindType, idpresetKindDefault );
          var idAdjs = charIDToTypeID( "Adjs" );
              var list3 = new ActionList();
                  var desc5 = new ActionDescriptor();
                  var idChnl = charIDToTypeID( "Chnl" );
                      var ref2 = new ActionReference();
                      var idCmps = charIDToTypeID( "Cmps" );
                      ref2.putEnumerated( idChnl, idChnl, idCmps );
                  desc5.putReference( idChnl, ref2 );
                  var idAuCo = charIDToTypeID( "AuCo" );
                  desc5.putBoolean( idAuCo, true );
                  var idBlcC = charIDToTypeID( "BlcC" );
                  desc5.putDouble( idBlcC, 0.000000 );
                  var idWhtC = charIDToTypeID( "WhtC" );
                  desc5.putDouble( idWhtC, 0.000000 );
              var idLvlA = charIDToTypeID( "LvlA" );
              list3.putObject( idLvlA, desc5 );
          desc4.putList( idAdjs, list3 );
          executeAction( idLvls, desc4, DialogModes.NO );
        • 1. Re: recall script function
          Chuck Uebele Adobe Community Professional & MVP
          You have to put the onClick function within the code that defines your UI - just before the show() is good.
          The functions you have listed should be outside of the code that creates the UI. You refer to those functions within the onClick ui by just listed them:
          //code creating your UI
               FusionMultiply()
          win.show()
          //code here for that function
          That first big block of AM code should most likely be put in a separate function also and referred to as the example above.
          • 2. Re: recall script function
            Chuck Uebele
            you are great
            thank you
