I had to purge my computer and re-install everything. I've downloaded Digital Editions 4.5 but cannot transfer downloaded library books from my laptop to my Kobo e reader. I think it may be a problem with the authorization. How do I fix the authorization now? Can I just uninstall the software and reinstall it to start over again? I read that another member's similar problem was resolved by going back to version 3. Should I try that?
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
If not work say which error message you get when you try to transfer.
You say"Enter a name and location for the backup registry key". What name
and location should I use?
This is you own decision.
