9 Replies Latest reply on Mar 17, 2016 2:14 AM by karthiks94217840
    [JS] Write xml file.
    K159 Level 1
      Hi.
      I want to write xml file using only JavaScript. (Without the xml tag in the document.)
      I tried to below code, but get error.
      please advice for me.
      Thanks.
      main()
      function main()
          var myDocument = app.activeDocument;
          var myDocumentSize = myDocument.documentPreferences.pageSize;
          var myDocumentWidth = myDocument.documentPreferences.pageWidth;
          var myDocumentHeight = myDocument.documentPreferences.pageHeight;
          var tfCount = myDocument.textFrames.count();
          var tfContentsArr = new Array(tfCount);
          var tfGeometricArr= new Array(tfCount);
          for(var i=0; i<tfCount; i++)
              tfContentsArr[i] = myDocument.textFrames.item(i).contents;
              tfGeometricArr[i] = myDocument.textFrames.item(i).geometricBounds;
          var tagRoot = new XML("<Info>");
          tagRoot[0].DocInfo[0].DocSize[0] = myDocumentSize;
          tagRoot[0].DocInfo[0].DocWidth[0] = myDocumentWidth;
          tagRoot[0].DocInfo[0].DocHeight[0] = myDocumentHeight;
              tagRoot[0].ItemInfo[0].Story[i].contents[0] = tfContentsArr[i];    // error point.   If the <Story>tag two or more.
              tagRoot[0].ItemInfo[0].Story[i].GeometricBounds[0] = tfGeometricArr[i];
          alert(tagRoot.toXMLString());
          var settingsFile = File(Folder.desktop + "/CompleteDocumentXML.xml");
          settingsFile.open ("w");
          settingsFile.write ("<?xml version='1.0'?>\r" + tagRoot);
          settingsFile.close ();
      Output that I want :
      <Info>
        <DocInfo>
          <DocSize>Size</DocSize>
          <DocWidth>Width</DocWidth>
          <DocHeight>Height</DocHeight>
        </DocInfo>
        <ItemInfo>
          <Story>
            <contents>contents</contents>
            <GeometricBounds>GeometricBounds</GeometricBounds>
          </Story>
          <Story>
          </Story>
        </ItemInfo>
      </Info>
        • 1. Re: [JS] Write xml file.
          G. Singelmann Level 3
          Try this:
          main()  function main()  {      var myDocument = app.activeDocument;      var myDocumentSize = myDocument.documentPreferences.pageSize;      var myDocumentWidth = myDocument.documentPreferences.pageWidth;      var myDocumentHeight = myDocument.documentPreferences.pageHeight;            var tfCount = myDocument.textFrames.count();        var tfContentsArr = new Array(tfCount);      var tfGeometricArr= new Array(tfCount);        for(var i=0; itag two or more.          tagRoot.ItemInfo.Story[i].GeometricBounds[0] = tfGeometricArr[i];      }    //    alert(tagRoot.toXMLString());        var settingsFile = File(Folder.desktop + "/CompleteDocumentXML.xml");      settingsFile.open ("w");        settingsFile.write ("\r" + tagRoot);      settingsFile.close ();    }
          • 2. Re: [JS] Write xml file.
            K159 Level 1
            Hi.
            This line Change, is correct?
            I got the same error.
            • 3. Re: [JS] Write xml file.
              No, sorry, I fail today how to enter code in this forum.
              In line 26 you try to write to Story[i].contents before Story[i] even exists.
              If you create Story[i] first you should have no problem.
              i.e. precede line 26 with:
              tagRoot[0].ItemInfo[0].Story[i] = "aux";
              • 4. Re: [JS] Write xml file.
                K159 Level 1
                Thank you.
                I have finished successfully.
                • 5. Re: [JS] Write xml file.
                  karthiks94217840 Level 2
                  Hi friend K159,
                  I needed your one important help. Also, the same process going to our office. Please send your javascript coding (successed coding).
                  K159: This very help full of my life.
                  Advance Thanks,
                  • 6. Re: [JS] Write xml file.
                    K159 Level 1
                    Hi
                    main()
                    function main()
                        tagRoot.DocInfo.DocSize = myDocumentSize;
                        tagRoot.DocInfo.DocWidth = myDocumentWidth;
                        tagRoot.DocInfo.DocHeight = myDocumentHeight;
                            tagRoot.ItemInfo.Story[i] = "";
                            tagRoot.ItemInfo.Story[i].contents = tfContentsArr[i];
                            tagRoot.ItemInfo.Story[i].GeometricBounds = tfGeometricArr[i];
                        settingsFile.write ("<?xml version='1.0' encoding='UTF-8'?>\r" + tagRoot);
                    • 7. Re: [JS] Write xml file.
                      Dear K159,
                      Thanks you for given in your coding k159. Please suggest my doubt in the bellow:
                      1 step: I have run the your script, that showing one dialog box (attached screenshot for your reference)
                      2 Step: Creating xml file in my desktop "CompleteDocumentXML.xml" but this xml files is empty (attached screenshot for your reference) . Why was not creating the xml text? please suggest me.
                      • 8. Re: [JS] Write xml file.
                        K159 Level 1
                        try a short story.
                        And If the encoding does not match, not output.
                        • 9. Re: [JS] Write xml file.
                          Dear K159,
                          OK, i will try
                          Thanks, your valueble comment k159.
