5 Replies Latest reply on Apr 21, 2006 9:16 PM by TJ Bryan
    HotSpot Virtual Machine Error : 11
    TJ Bryan Level 1
      Has anyone had/resolved this issue? About every 12 hours I get this HotSpot Virtual Machine Error and have to stop/start my ColdFusion. It's a pain - and I can't sit here and babysit 24x7
      Server Product ColdFusion MX
      Version 7,0,1,116466
      Edition Enterprise
      Operating System UNIX
      OS Version 2.4.21-37.0.1.ELsmp
      JVM Details
      Java Version 1.4.2_05
      Java VM Specification Version 1.0
      Java VM Specification Vendor Sun Microsystems Inc.
      Java VM Specification Name Java Virtual Machine Specification
      Java VM Version 1.4.2_05-b04
      Java VM Vendor Sun Microsystems Inc.
      Java VM Name Java HotSpot(TM) Server VM
      Java Specification Version 1.4
      Java Specification Vendor Sun Microsystems Inc.
      Java Specification Name Java Platform API Specification
      Java Class Version 48.0
        • 1. Re: HotSpot Virtual Machine Error : 11
          swathi
          Hi Bryan,
          Whenever jvm crashes with hotspot errors, it will create a log file which starts with hs under Coldfusion-home/runtime/bin or JRun-Home/bin directory. Can you please check if you have any such logs? If you do, can you please post it here. Generally jvm crashes are caused because of native applications used with the application. Please check if you are using any Cor C++ components with your application.
          Swathi.
          • 2. Re: HotSpot Virtual Machine Error : 11
            TJ Bryan Level 1
            Don't believe we're using any c or c++ ... here is my log
            Local Time = Fri Apr 21 12:15:38 2006
            Elapsed Time = 38405
            # HotSpot Virtual Machine Error : 11
            # Error ID : 4F530E43505002EF
            # Please report this error at
            # http://java.sun.com/cgi-bin/bugreport.cgi
            # Java VM: Java HotSpot(TM) Server VM (1.4.2_05-b04 mixed mode)
            [root@iappst bin]# clear
            [root@iappst bin]# cat hs_err_pid8967.log
            Unexpected Signal : 11 occurred at PC=0x3FBC9700
            Function=(null)+0x3FBC9700
            Library=/opt/coldfusionmx7/runtime/jre//lib/i386/server/libjvm.so
            NOTE: We are unable to locate the function name symbol for the error
            just occurred. Please refer to release documentation for possible
            reason and solutions.
            Current Java thread:
            Dynamic libraries:
            08048000-08051000 r-xp 00000000 68:02 864493 /opt/coldfusionmx7/bin/cfmx7
            08051000-08052000 rwxp 00008000 68:02 864493 /opt/coldfusionmx7/bin/cfmx7
            3dbbf000-3e108000 r-xs 00000000 68:02 457324 /opt/coldfusionmx7/runtime/jre/lib/charsets.jar
            3e108000-3e119000 r-xs 00000000 68:02 457283 /opt/coldfusionmx7/runtime/jre/lib/jce.jar
            3e119000-3e1f2000 r-xs 00000000 68:02 457291 /opt/coldfusionmx7/runtime/jre/lib/jsse.jar
            3e1f2000-3e208000 r-xs 00000000 68:02 457282 /opt/coldfusionmx7/runtime/jre/lib/sunrsasign.jar
            3e252000-3f93b000 r-xs 00000000 68:02 457326 /opt/coldfusionmx7/runtime/jre/lib/rt.jar
            3f93b000-3f94f000 r-xp 00000000 68:02 457129 /opt/coldfusionmx7/runtime/jre/lib/i386/libzip.so
            3f94f000-3f952000 rwxp 00013000 68:02 457129 /opt/coldfusionmx7/runtime/jre/lib/i386/libzip.so
            3f952000-3f972000 r-xp 00000000 68:02 457127 /opt/coldfusionmx7/runtime/jre/lib/i386/libjava.so
            3f972000-3f974000 rwxp 0001f000 68:02 457127 /opt/coldfusionmx7/runtime/jre/lib/i386/libjava.so
            3f974000-3f984000 r-xp 00000000 68:02 457126 /opt/coldfusionmx7/runtime/jre/lib/i386/libverify.so
            3f984000-3f986000 rwxp 0000f000 68:02 457126 /opt/coldfusionmx7/runtime/jre/lib/i386/libverify.so
            3f986000-3f991000 r-xp 00000000 68:02 521446 /lib/libnss_files-2.3.2.so
            3f991000-3f992000 rwxp 0000a000 68:02 521446 /lib/libnss_files-2.3.2.so
            3f99a000-3f99e000 rwxs 00000000 68:02 602909 /tmp/hsperfdata_cfuser/8967
            3f99e000-3f9bf000 r-xp 00000000 68:02 521431 /lib/libm-2.3.2.so
            3f9bf000-3f9c0000 rwxp 00021000 68:02 521431 /lib/libm-2.3.2.so
            3f9c0000-3f9d2000 r-xp 00000000 68:02 521433 /lib/libnsl-2.3.2.so
            3f9d2000-3f9d3000 rwxp 00011000 68:02 521433 /lib/libnsl-2.3.2.so
            3f9d8000-3f9e0000 r-xp 00000000 68:02 457118 /opt/coldfusionmx7/runtime/jre/lib/i386/native_threads/libhpi.so
            3f9e0000-3f9e1000 rwxp 00007000 68:02 457118 /opt/coldfusionmx7/runtime/jre/lib/i386/native_threads/libhpi.so
            3f9e1000-3ff93000 r-xp 00000000 68:02 457120 /opt/coldfusionmx7/runtime/jre/lib/i386/server/libjvm.so
            3ff93000-3ffec000 rwxp 005b1000 68:02 457120 /opt/coldfusionmx7/runtime/jre/lib/i386/server/libjvm.so
            40000000-40015000 r-xp 00000000 68:02 521230 /lib/ld-2.3.2.so
            40015000-40016000 rwxp 00015000 68:02 521230 /lib/ld-2.3.2.so
            40023000-40033000 r-xp 00000000 68:02 521271 /lib/libpthread-0.10.so
            40033000-40036000 rwxp 0000f000 68:02 521271 /lib/libpthread-0.10.so
            40076000-40078000 r-xp 00000000 68:02 521429 /lib/libdl-2.3.2.so
            40078000-40079000 rwxp 00001000 68:02 521429 /lib/libdl-2.3.2.so
            40079000-401af000 r-xp 00000000 68:02 521237 /lib/libc-2.3.2.so
            401af000-401b2000 rwxp 00136000 68:02 521237 /lib/libc-2.3.2.so
            69854000-6990e000 r-xp 00000000 68:02 457140 /opt/coldfusionmx7/runtime/jre/lib/i386/libfontmanager.so
            6990e000-69929000 rwxp 000b9000 68:02 457140 /opt/coldfusionmx7/runtime/jre/lib/i386/libfontmanager.so
            6992a000-6993e000 r-xp 00000000 68:02 374693 /usr/X11R6/lib/libICE.so.6.3
            6993e000-6993f000 rwxp 00013000 68:02 374693 /usr/X11R6/lib/libICE.so.6.3
            69941000-69948000 r-xp 00000000 68:02 374733 /usr/X11R6/lib/libSM.so.6.0
            69948000-69949000 rwxp 00007000 68:02 374733 /usr/X11R6/lib/libSM.so.6.0
            69949000-69a25000 r-xp 00000000 68:02 374770 /usr/X11R6/lib/libX11.so.6.2
            69a25000-69a28000 rwxp 000db000 68:02 374770 /usr/X11R6/lib/libX11.so.6.2
            69a28000-69a2c000 r-xp 00000000 68:02 374941 /usr/X11R6/lib/libXtst.so.6.1
            69a2c000-69a2d000 rwxp 00004000 68:02 374941 /usr/X11R6/lib/libXtst.so.6.1
            69a2d000-69a3a000 r-xp 00000000 68:02 374729 /usr/X11R6/lib/libXext.so.6.4
            69a3a000-69a3b000 rwxp 0000c000 68:02 374729 /usr/X11R6/lib/libXext.so.6.4
            69a3b000-69a88000 r-xp 00000000 68:02 374751 /usr/X11R6/lib/libXt.so.6.0
            69a88000-69a8c000 rwxp 0004c000 68:02 374751 /usr/X11R6/lib/libXt.so.6.0
            69a8c000-69a93000 r-xp 00000000 68:02 374854 /usr/X11R6/lib/libXp.so.6.2
            • 3. Re: HotSpot Virtual Machine Error : 11
              TJ Bryan Level 1
              more of my log ....
              69a93000-69a94000 rwxp 00006000 68:02 374854 /usr/X11R6/lib/libXp.so.6.2
              69aa0000-69af3000 r-xp 00000000 68:02 457136 /opt/coldfusionmx7/runtime/jre/lib/i386/libmlib_image.so
              69af3000-69af4000 rwxp 00052000 68:02 457136 /opt/coldfusionmx7/runtime/jre/lib/i386/libmlib_image.so
              69af4000-69dc5000 r-xp 00000000 68:02 457137 /opt/coldfusionmx7/runtime/jre/lib/i386/libawt.so
              69dc5000-69ddb000 rwxp 002d0000 68:02 457137 /opt/coldfusionmx7/runtime/jre/lib/i386/libawt.so
              6b779000-6b77f000 r-xs 00000000 68:02 879896 /usr/lib/gconv/gconv-modules.cache
              6b863000-6b897000 r-xp 00000000 68:02 1206202 /usr/lib/libstdc++-2-libc6.1-1-2.9.0.so
              6b897000-6b8a3000 rwxp 00033000 68:02 1206202 /usr/lib/libstdc++-2-libc6.1-1-2.9.0.so
              6b8a5000-6b939000 r-xp 00000000 68:02 82720 /opt/coldfusionmx7/lib/libporting.so
              6b939000-6b95b000 rwxp 00093000 68:02 82720 /opt/coldfusionmx7/lib/libporting.so
              6b95c000-6b96b000 r-xp 00000000 68:02 521458 /lib/libresolv-2.3.2.so
              6b96b000-6b96c000 rwxp 0000f000 68:02 521458 /lib/libresolv-2.3.2.so
              6b96e000-6b972000 r-xp 00000000 68:02 521258 /lib/libnss_dns-2.3.2.so
              6b972000-6b973000 rwxp 00003000 68:02 521258 /lib/libnss_dns-2.3.2.so
              6ba6c000-6ba87000 r-xs 00000000 68:02 277660 /opt/coldfusionmx7/wwwroot/WEB-INF/cfform/jars/oscache.jar
              6ba87000-6bb05000 r-xs 00000000 68:02 277659 /opt/coldfusionmx7/wwwroot/WEB-INF/cfform/jars/jsse.jar
              6bb05000-6bb07000 r-xs 00000000 68:02 277658 /opt/coldfusionmx7/wwwroot/WEB-INF/cfform/jars/jnet.jar
              6bb07000-6bb0a000 r-xs 00000000 68:02 277657 /opt/coldfusionmx7/wwwroot/WEB-INF/cfform/jars/jcert.jar
              6bb0a000-6bb1a000 r-xs 00000000 68:02 277656 /opt/coldfusionmx7/wwwroot/WEB-INF/cfform/jars/jakarta-oro-2.0.7.jar
              6bb1a000-6bd0f000 r-xs 00000000 68:02 277655 /opt/coldfusionmx7/wwwroot/WEB-INF/cfform/jars/flex.jar
              6bd0f000-6bd3e000 r-xs 00000000 68:02 277072 /opt/coldfusionmx7/wwwroot/WEB-INF/cfform/jars/concurrent.jar
              6bd3e000-6bd48000 r-xs 00000000 68:02 276968 /opt/coldfusionmx7/wwwroot/WEB-INF/cfform/jars/commons-logging.jar
              6bd48000-6bd5a000 r-xs 00000000 68:02 276967 /opt/coldfusionmx7/wwwroot/WEB-INF/cfform/jars/commons-discovery.jar
              6bd5a000-6bd6e000 r-xs 00000000 68:02 276966 /opt/coldfusionmx7/wwwroot/WEB-INF/cfform/jars/batik-util.jar
              6bd6e000-6bd7e000 r-xs 00000000 68:02 276965 /opt/coldfusionmx7/wwwroot/WEB-INF/cfform/jars/batik-transcoder.jar
              6bd7e000-6bd91000 r-xs 00000000 68:02 276964 /opt/coldfusionmx7/wwwroot/WEB-INF/cfform/jars/batik-ext.jar
              6bd91000-6bdca000 r-xs 00000000 68:02 276963 /opt/coldfusionmx7/wwwroot/WEB-INF/cfform/jars/batik-css.jar
              6bdca000-6be22000 r-xs 00000000 68:02 276962 /opt/coldfusionmx7/wwwroot/WEB-INF/cfform/jars/batik-awt-util.jar
              6be22000-6be27000 r-xs 00000000 68:02 1775932 /opt/coldfusionmx7/gateway/lib/examples.jar
              6be27000-6be3a000 r-xs 00000000 68:02 82514 /opt/coldfusionmx7/lib/commons-discovery-0.2.jar
              6be3a000-6be58000 r-xs 00000000 68:02 82513 /opt/coldfusionmx7/lib/wsdl4j-1.5.1.jar
              6be58000-6be5b000 r-xs 00000000 68:02 82501 /opt/coldfusionmx7/lib/ib61patch.jar
              6be5b000-6be7a000 r-xs 00000000 68:02 82717 /opt/coldfusionmx7/lib/xml-apis.jar
              6be7a000-6bf71000 r-xs 00000000 68:02 82716 /opt/coldfusionmx7/lib/xercesImpl.jar
              6bf71000-6c237000 r-xs 00000000 68:02 82715 /opt/coldfusionmx7/lib/xalan.jar
              6c237000-6c255000 r-xs 00000000 68:02 82714 /opt/coldfusionmx7/lib/wsdl4j.jar
              6c255000-6c256000 r-xs 00000000 68:02 82713 /opt/coldfusionmx7/lib/wsdl2java.jar
              6c256000-6c257000 r-xs 00000000 68:02 82712 /opt/coldfusionmx7/lib/webchartsJava2D.jar
              6c257000-6c43b000 r-xs 00000000 68:02 82502 /opt/coldfusionmx7/lib/wc50.jar
              6c43b000-6c4a1000 r-xs 00000000 68:02 82504 /opt/coldfusionmx7/lib/vsearch.jar
              6c4a1000-6c4ec000 r-xs 00000000 68:02 82518 /opt/coldfusionmx7/lib/vparametric.jar
              6c4ec000-6c53b000 r-xs 00000000 68:02 82503 /opt/coldfusionmx7/lib/verity.jar
              6c53b000-6c5a7000 r-xs 00000000 68:02 82517 /opt/coldfusionmx7/lib/vadmin.jar
              6c5a7000-6c5c9000 r-xs 00000000 68:02 82703 /opt/coldfusionmx7/lib/tt-bytecode.jar
              6c5c9000-6ca7c000 r-xs 00000000 68:02 82702 /opt/coldfusionmx7/lib/tools.jar
              6ca7c000-6cb36000 r-xs 00000000 68:02 82700 /opt/coldfusionmx7/lib/STComm.jar
              6cb36000-6cb6f000 r-xs 00000000 68:02 82519 /opt/coldfusionmx7/lib/smpp.jar
              6cb6f000-6cb97000 r-xs 00000000 68:02
              • 4. Re: HotSpot Virtual Machine Error : 11
                TJ Bryan Level 1
                even more!
                82697 /opt/coldfusionmx7/lib/smack.jar
                6cb97000-6cb9c000 r-xs 00000000 68:02 82515 /opt/coldfusionmx7/lib/saaj.jar
                6cb9c000-6cbbc000 r-xs 00000000 68:02 82498 /opt/coldfusionmx7/lib/ri_generic.jar
                6cbbc000-6cbca000 r-xs 00000000 68:02 82694 /opt/coldfusionmx7/lib/poi-contrib-2.5.1-final-20040804.jar
                6cbca000-6cc8e000 r-xs 00000000 68:02 82693 /opt/coldfusionmx7/lib/poi-2.5.1-final-20040804.jar
                6cc8e000-6cccf000 r-xs 00000000 68:02 82692 /opt/coldfusionmx7/lib/pbtools42RE.jar
                6cccf000-6cdf3000 r-xs 00000000 68:02 82691 /opt/coldfusionmx7/lib/pbserver42RE.jar
                6cdf3000-6cf0e000 r-xs 00000000 68:02 82690 /opt/coldfusionmx7/lib/pbembedded42RE.jar
                6cf0e000-6cf4a000 r-xs 00000000 68:02 82689 /opt/coldfusionmx7/lib/pbclient42RE.jar
                6cf4a000-6cf9a000 r-xs 00000000 68:02 82666 /opt/coldfusionmx7/lib/mail.jar
                6cf9a000-6cfa8000 r-xs 00000000 68:02 82656 /opt/coldfusionmx7/lib/ldapbp.jar
                6cfa8000-6cfc7000 r-xs 00000000 68:02 82655 /opt/coldfusionmx7/lib/ldap.jar
                6cfc7000-6d043000 r-xs 00000000 68:02 82654 /opt/coldfusionmx7/lib/jintegra.jar
                6d043000-6d049000 r-xs 00000000 68:02 82653 /opt/coldfusionmx7/lib/jeb.jar
                6d049000-6d06b000 r-xs 00000000 68:02 82652 /opt/coldfusionmx7/lib/jdom.jar
                6d06b000-6d073000 r-xs 00000000 68:02 82510 /opt/coldfusionmx7/lib/jaxrpc.jar
                6d073000-6d074000 r-xs 00000000 68:02 82649 /opt/coldfusionmx7/lib/java2wsdl.jar
                6d074000-6d084000 r-xs 00000000 68:02 82648 /opt/coldfusionmx7/lib/jakarta-oro-2.0.6.jar
                6d084000-6d0f3000 r-xs 00000000 68:02 82647 /opt/coldfusionmx7/lib/izmado.jar
                6d0f3000-6d144000 r-xs 00000000 68:02 82646 /opt/coldfusionmx7/lib/iTextAsian.jar
                6d144000-6d200000 r-xs 00000000 68:02 82497 /opt/coldfusionmx7/lib/iText.jar
                6d323000-6d3b9000 r-xs 00000000 68:02 82516 /opt/coldfusionmx7/lib/ib6core.jar
                6d3b9000-6d3bc000 r-xs 00000000 68:02 82640 /opt/coldfusionmx7/lib/ib6addonpatch.jar
                6d3bc000-6d425000 r-xs 00000000 68:02 82639 /opt/coldfusionmx7/lib/httpclient.jar
                6d425000-6d45f000 r-xs 00000000 68:02 82638 /opt/coldfusionmx7/lib/flashgateway.jar
                6d45f000-6d596000 r-xs 00000000 68:02 82636 /opt/coldfusionmx7/lib/crystal.jar
                6d596000-6d5bc000 r-xs 00000000 68:02 82635 /opt/coldfusionmx7/lib/commons-net-1.2.2.jar
                6d5bc000-6d5c1000 r-xs 00000000 68:02 82634 /opt/coldfusionmx7/lib/commons-logging-api-1.0.2.jar
                6d5c1000-6d5e8000 r-xs 00000000 68:02 82663 /opt/coldfusionmx7/lib/log4j.jar
                6d5e8000-6d5ef000 r-xs 00000000 68:02 82633 /opt/coldfusionmx7/lib/commons-logging-1.0.2.jar
                6d5ef000-6d602000 r-xs 00000000 68:02 82632 /opt/coldfusionmx7/lib/commons-discovery.jar
                6d602000-6d619000 r-xs 00000000 68:02 82631 /opt/coldfusionmx7/lib/commons-digester-1.3.jar
                6d619000-6d642000 r-xs 00000000 68:02 82630 /opt/coldfusionmx7/lib/commons-collections-2.1.jar
                6d642000-6d65e000 r-xs 00000000 68:02 82629 /opt/coldfusionmx7/lib/commons-beanutils-1.5.jar
                6d65e000-6d6ea000 r-xs 00000000 68:02 82626 /opt/coldfusionmx7/lib/cfmx-ssl.jar
                6d6ea000-6d6ee000 r-xs 00000000 68:02 82622 /opt/coldfusionmx7/lib/cf4was_ae.jar
                6d6ee000-6d6f3000 r-xs 00000000 68:02 82621 /opt/coldfusionmx7/lib/cf4was.jar
                6d6f3000-6d6f5000 r-xs 00000000 68:02 82620 /opt/coldfusionmx7/lib/cdohost.jar
                6d6f5000-6d718000 r-xs 00000000 68:02 82619 /opt/coldfusionmx7/lib/cdo.jar
                6d718000-6d791000 r-xs 00000000 68:02 82618 /opt/coldfusionmx7/lib/bcel.jar
                6d791000-6d919000 r-xs 00000000 68:02 82496 /opt/coldfusionmx7/lib/axis.jar
                6d919000-6da00000 r-xs 00000000 68:02 82616 /opt/coldfusionmx7/lib/ant.jar
                6db1b000-6db1d000 r-xs 00000000 68:02 82615 /opt/coldfusionmx7/lib/ant-launcher.jar
                6db1d000-6db23000 r-xs 00000000 68:02 50060 /opt/coldfusionmx7/wwwroot/WEB-INF/lib/cfmx_bootstrap.jar
                6db23000-6db25000 r-xs 00000000 68:02 50061 /opt/coldfusionmx7/wwwroot/WEB-INF/lib/cfx.jar
                6db25000-6db42000 r-xs 00000000 68:02 50062 /opt/coldfusionmx7/wwwroot/WEB-INF/lib/commons-beanutils.jar
                6db42000-6db8b000 r-xs 00000000 68:02 50063 /opt/coldfusionmx7/wwwroot/WEB-INF/lib/commons-collections.jar
                6db8b000-6dc00000 r-xs 00000000 68:02 50065 /opt/coldfusionmx7/wwwroot/WEB-INF/lib/js.jar
                6dd58000-6dd8c000 r-xs 00000000 68:02 82644 /opt/coldfusionmx7/lib/im.jar
                6dd8c000-6dda6000 r-xs 00000000 68:02 82512 /opt/coldfusionmx7/lib/ib6util.jar
                6dda6000-6ddb9000 r-xs 00000000 68:02 82508 /opt/coldfusionmx7/lib/ib6swing.jar
                6ddb9000-6ddbd000 r-xp 00000000 68:02 457275 /opt/coldfusionmx7/runtime/jre/lib/i386/libioser12.so
                6ddbd000-6ddbe000 rwxp 00003000 68:02 457275 /opt/coldfusionmx7/runtime/jre/lib/i386/libioser12.so
                6dde6000-6ddfb000 r-xp 00000000 68:02 82719 /opt/coldfusionmx7/lib/libCFXNeo.so
                6ddfb000-6de00000 rwxp 00014000 68:02 82719 /opt/coldfusionmx7/lib/libCFXNeo.so
                6e10d000-6e10e000 r-xs 00000000 68:02 1890358 /opt/coldfusionmx7/runtime/lib/xmlscript.jar
                6e10e000-6e10f000 r-xs 00000000 68:02 1890364 /opt/coldfusionmx7/runtime/lib/wsdl2java.jar
                6e10f000-6e35e000 r-xs 00000000 68:02 1890363 /opt/coldfusionmx7/runtime/lib/wsconfig.jar
                6e35e000-6e35f000 r-xs 00000000 68:02 1890356 /opt/coldfusionmx7/runtime/lib/sniffer.jar
                6e35f000-6e48f000 r-xs 00000000 68:02 1890353 /opt/coldfusionmx7/runtime/lib/oem-xdoclet.jar
                6e48f000-6e490000 r-xs 00000000 68:02 1890351 /opt/coldfusionmx7/runtime/lib/migrate.jar
                6e490000-6e491000 r-xs 00000000 68:02 1890350 /opt/coldfusionmx7/runtime/lib/jspc.jar
                6e491000-6e494000 r-xs 00000000 68:02 1890345 /opt/coldfusionmx7/runtime/lib/jrun-ant-tasks.jar
                6e494000-6e58a000 r-xs 00000000 68:02 1890347 /opt/coldfusionmx7/runtime/lib/jrun-xdoclet.jar
                6e58a000-6e700000 r-xs 00000000 68:02 1889466 /opt/coldfusionmx7/runtime/lib/webservices.jar
                6e800000-6e801000 r-xp 00000000 68:02 457276 /opt/coldfusionmx7/runtime/jre/lib/i386/librmi.so
                6e801000-6e802000 rwxp 00000000 68:02 457276 /opt/coldfusionmx7/runtime/jre/lib/i386/librmi.so
                6e802000-6e812000 r-xp 00000000 68:02 457132 /opt/coldfusionmx7/runtime/jre/lib/i386/libnet.so
                6e812000-6e813000 rwxp 0000f000 68:02 457132 /opt/coldfusionmx7/runtime/jre/lib/i386/libnet.so
                6e841000-6f032000 r-xs 00000000 68:02 1890366 /opt/coldfusionmx7/runtime/lib/jrun.jar
                6f032000-6f033000 r-xs 00000000 68:02 1890344 /opt/coldfusionmx7/runtime/lib/java2wsdl.jar
                6f033000-6f042000 r-xs 00000000 68:02 1890343 /opt/coldfusionmx7/runtime/lib/instutil.jar
                6f042000-6f044000 r-xs 00000000 68:02 1890378 /opt/coldfusionmx7/runtime/lib/cfmx_mbean.jar
                6f044000-6f1d6000 r-xs 00000000 68:02 82665 /opt/coldfusionmx7/lib/macromedia_drivers.jar
                6f1d6000-6f1e1000 r-xs 00000000 68:02 1711456 /opt/coldfusionmx7/runtime/servers/lib/jrun-patch.jar
                6f1e1000-6f29c000 r-xs 00000000 68:02 1303840 /opt/coldfusionmx7/runtime/jre/lib/ext/localedata.jar
                6f29c000-6f2a9000 r-xs 00000000 68:02 1303839 /opt/coldfusionmx7/runtime/jre/lib/ext/ldapsec.jar
                6f2a9000-6f2ac000 r-xs 00000000 68:02 1303838 /opt/coldfusionmx7/runtime/jre/lib/ext/dnsns.jar
                6f2ac000-6f2c8000 r-xs 00000000 68:02 1303837 /opt/coldfusionmx7/runtime/jre/lib/ext/sunjce_provider.jar
                6f2ea000-6f752000 r-xs 00000000 68:02 82495 /opt/coldfusionmx7/lib/cfusion.jar
                6f752000-6f952000 r-xp 00000000 68:02 1776521 /usr/lib/locale/locale-archive
                Heap at VM Abort:
                Heap
                PSYoungGen total 4992K, used 1024K [0x6fe00000, 0x703d0000, 0x76fc0000)
                eden [0x6fe00000,0x6fe24150,0x70180000)
                from [0x70180000,0x7025c080,0x702e0000)
                to [0x702e0000,0x702e0000,0x703d0000)
                PSOldGen total 55168K, used 46517K [0x76fc0000, 0x7a5a0000, 0xafe00000)
                object [0x76fc0000,0x79d2d478,0x7a5a0000)
                PSPermGen total 29440K, used 29220K [0xafe00000, 0xb1ac0000, 0xb7e00000)
                object [0xafe00000,0xb1a890c0,0xb1ac0000)
                [root@iappst bin]#
                • 5. Re: HotSpot Virtual Machine Error : 11
                  TJ Bryan Level 1
                  I placed an Incident call with Adobe, they told me to change my client variables from registry (clientstorage="registry") to (clientstorage="datasource"). They think the server had too much load to use a file on the server to store the variables. Hopefully this will work. Cheers.
