1 Reply Latest reply on Mar 14, 2016 1:20 AM by Nanaky
    Erase authorization?
    adam22!
      Trying to erase authorization but receiving error "unable to erase. Try again some time." Tried deleting program and reinstall but no luck. Also, looked for activation.dat file path but also can't find it to delete it. Any others in this boat.
        • 1. Re: Erase authorization?
          Nanaky Level 5
          Windows:
              Close all applications.
              Choose Start > Run.
              In the Open text box, type regedit and then press Enter. The Registry Editor opens.
              In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
              Select the Adept key.
              Choose File > Export.
              In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
              Right-click the Adept key and choose Delete.
              In the Confirm Key Delete dialog, click OK.
              Close the Registry Editor.
              Open Adobe Digital Editions and reauthorize.
          Macintosh:
              quit Adobe Digital Editions.
              Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
              If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
