5 Replies Latest reply on Mar 12, 2016 7:06 PM by OzSanta2
    Requesting assistance with printing document from mac
    OzSanta2
      G'day Javacripters
      Using Acrobat Pro DC for Mac.
      I've only use Java to add barcodes and text boxes to my Applescript Objective C application, but would like to see if it's possible to directly set print settings, and print every page of my documents using Java. I've searched, but cannot find an answer.
      Specifically, I want to set the following properties...
      Printer : largePagePrinter as variable
      Pages to Print : All
      Auto portrait/landscape : true
      Tile Scale :100%
      Overlap : 0.5"
      Cut Marks : true
      Tile only Large Pages : true
      Orientation : Portrait
      Auto-rotate pages within each sheet : true
      Page Setup dialog
      Format for : largePagePrinter as variable
      Paper Size : largePaperSize as variable
      Scale : 100%
      At the moment I'm using the GUI to set each property, and it's slow, particularly for the separate Page Setup dialog, and we're processing 200 plus pdf's a day.
      Is this possible? And if so, some guidance on coding would be appreciated.
      Regards
      Brian Christmas
        • 1. Re: Requesting assistance with printing document from mac
          I don't think it's possible to set all of these parameters with a script.
          You need to carefully study the PrintParams object to see what's possible.
          • 2. Re: Requesting assistance with printing document from mac
            OzSanta2 Level 1
            Thanks try67
            I managed to find some documentation, and think I can get away with setting just a few of the above parameters.
            I've copied and pasted, but the script fails.
            If anyone could tell me where and why, I'd be grateful.
            tell application "Adobe Acrobat"
              activate
              tell document 1
              say 1
              set javaScriptTwo to my Add_Printer_Parameters(CountOfPages)
              say 2
              do shell script ("sleep 1")
              do script javaScriptTwo
              say 3 # Does not say 3, but an error trap gives result at end
              end tell
              end tell
            on Add_Printer_Parameters(CountOfPages)
              set Params to ""
              set Params to Params & "var pp = this.getPrintParams();" & return
              set Params to Params & "pp.printerName = " & theLargePagePrinter & ";" & return
              set Params to Params & "pp.interactive = pp.constants.interactionLevel.automatic;" & return
              set Params to Params & "pp.tileMark = pp.constants.tileMarks.west; " & return
              set Params to Params & "pp.tileOverlap = pp.constants.36; " & return
              set Params to Params & "pp.tileScale = pp.constants.1; " & return
              set Params to Params & "pp.fontPolicy = pp.constants.fontPolicies.everyPage;" & return
              set Params to Params & "pp.useT1Conversion = pp.constants.usages.auto; " & return
              set Params to Params & "fv = pp.constants.flagValues;" & return
              set Params to Params & "// or pp.flags |= fv.setPageSize;;" & return
              set Params to Params & "pp.flags = pp.flags | fv.setPageSize; " & return
              set Params to Params & "this.print(pp);" & return
              set javaScript to Params
              return javaScript
              end Add_Printer_Parameters
            gives this error
            printAdobeAcrobat 2 Adobe Acrobat got an error: "var pp = this.getPrintParams();
            pp.printerName = Large Page Printer;
            this.print(pp);
            " doesn’t understand the “do script” message.
            error number -1708
            • 3. Re: Requesting assistance with printing document from mac
              OzSanta2 Level 1
              After entering my reply above, I realised I had not encased the Printer Name in quotes, however, this has not resulted in a working script. So, still asking for advice, probably regarding formatting of the 'fv' section.
              pp.printerName = \"Large Page Printer\";
              this.print(pp);
              error number -1708
              • 4. Re: Requesting assistance with printing document from mac
                I can't help you with the AS code, but in JS one you should remove the
                back-slashes before the quotes in the printer name.
                • 5. Re: Requesting assistance with printing document from mac
                  OzSanta2 Level 1
                  Thanks try67, but the back slashes are just Applescripts way of including a quotation mark.
                  The script I ended up with, that works, is...
                  on Add_Printer_Parameters()
                    set Params to ""
                    set Params to Params & "pp.printerName = \"" & theLargePagePrinter & "\";" & return
                    set Params to Params & "pp.tileOverlap = 36; " & return
                    set Params to Params & "pp.tileScale = 1; " & return
                    set Params to Params & "pp.flags =  fv.setPageSize; " & return
                    return javaScript
