8 Replies Latest reply on Mar 15, 2016 6:26 AM by JJMack
    How do you set Fill Screen as default view mode?
    Jim Mooney
      Does anyone have a way to set the Fill Screen view mode as the default view?
      This would work if there was a hotkey for it, or if it could be selected while recording an action.
      And then run it in the Script Events Manager with the "Open Document" option.
      When the zoom tool is selected and the option window is on, there are four options...
      Actual Pixels, Fit Screen, Fill Screen, Print Size
      But in the Menu options, Fill Screen is NOT an option (for some odd reason).
      My only guess is this has to be done with a script, but I cannot find anything online that addresses this problem
      and I'm not a script programmer.  Although I know how to use them (and modify them a little).
      By the way, I'm using Photoshop CS5
      Thanks for any help!
        • 1. Re: How do you set Fill Screen as default view mode?
          You can insert two menu item into an action in an Actions set. Then set  Script Manager a script even for an open document event to play that action.
          • 2. Re: How do you set Fill Screen as default view mode?
            Jim Mooney Level 1
            Thanks for the reply, but Fill screen is not in the menu so it cannot be used through actions as far as I know.  That's my problem.
            • 3. Re: How do you set Fill Screen as default view mode?
              There should be three screen mode in the menu and there is a Shortcut key F also.
              • 4. Re: How do you set Fill Screen as default view mode?
                Jim Mooney Level 1
                This is what I am trying to do.  Fill screen is right here. It is a zoom option.  It is not in the menu so you can't make an action out of it.
                And I don't know whether or not it can even be scripted, that is what I'm trying to find out.
                The "Full Screen Modes" almost work, but don't work very well with my workflow.
                Thanks for the help!!
                • 5. Re: How do you set Fill Screen as default view mode?
                  I use Windows.  On Windows in Photoshop,  I know Ctrl+0 Fit on Screen menu "View>Fit on screen" will zoom the current document to fit within Photoshop windows without scroll bars.  And that Photoshop menu "View>Screen Mode>Full Screen Mode"  will use the full display area as image display any display area not used because of image zoom size will be black. If Photoshop has a "Fill Screen" on Mac I have no idea it there is a menu item for Windows does not have a "Fill Screen" option.
                  • 6. Re: How do you set Fill Screen as default view mode?
                    Jim Mooney Level 1
                    OK, well thank you very much for trying to help
                    • 7. Re: How do you set Fill Screen as default view mode?
                      gionnyp9672044 Level 1
                      sorry if I go off topic
                      How do I get the scripts as JJMack JJMack
                      • 8. Re: How do you set Fill Screen as default view mode?
                        Photo Collage Toolkit
                        Photoshop scripting is powerful and I believe this package demonstrates this A video showing a 5 image collage PSD template  being populates with images:
                        The package includes four simple rules to follow when making Photo Collage Template PSD files so they will be compatible with my Photoshop scripts.
                        1. Size the photo collage templates for the print size you want - width, height and print DPI resolution.
                        2. Photo collage templates must have a Photoshop background layer. The contents of this layer can be anything.
                        3. Photo collage templates must have alpha channels named "Image 1", "Image 2", ... "Image n".
                        4. Photo collage templates layers above the background layers must provide transparent areas to let the images that will be placed below them show through.
                        There are fifteen scripts in this package they provide the following functions:
                        1. HelpPhotoCollageToolkit.jsx - Online Help
                        2. TestCollageTemplate.jsx - Used to test a Photo Collage Template while you are making it with Photoshop.
                        3. CollageTemplateBuilder.jsx - Can build Templates compatible with this toolkit's scripts.
                        4. LayerToAlphaChan.jsx - Used to convert a Prototype Image Layer stack into a template document.
                        5. InteractivePopulateCollage.jsx - Used to interactively populate Any Photo Collage template. Offers most user control inserting pictures and text.
                        6. ReplaceCollageImage.jsx - use to replace a populated collage image Smart Object layer with an other image correctly resized and positioned.
                        7. ChangeTextSize.jsx - This script can be used to change Image stamps text size when the size used by the populating did not work well.
                        8. PopulateCollageTemplate.jsx - Used to Automatically populate a Photo Collage template and leave the populated copy open in Photoshop.
                        9. BatchOneImageCollage.jsx - Used to Automatically Batch Populate Collage templates that only have one image inserted. The Collage or Image may be stamped with text.
                        10. BatchMultiImageCollage.jsx - Used to Automatically Batch Populate Any Photo Collage template with images in a source image folder. Easier to use than the interactive script. Saved collages can be tweaked.
                        11. PasteImageRoll.jsx - Paste Images into a document to be print on roll paper.
                        12. BatchPicturePackage.jsx - Used to Automatically Batch Populate Any Photo Collage template with an image in a source image folder.  Images Rotates for best fit.
                        13. BatchPicturePackageNoRotate.jsx - Used to Automatically Batch Populate Any Photo Collage template with an image in a source image folder.
                        14. PopulatePicturePackage.jsx - Used to Automatically populate a Photo Collage template Fill with the same single image and leave the populated copy open in Photoshop.
                        15. PCTpreferences.jsx - Edit This File to Customize Collage Populating scripts default setting and add your own Layer styles.
                        Documentation and Examples
