7 Replies Latest reply on Mar 20, 2018 12:32 AM by sl1330358
    why do stacked photos move to the end of the timeline in Lightroom
    jnix43124
      Hello,
      I am an advanced user, and I feel like this an elementary question that I have been struggling to find an answer to. I normally work on a large number of photos and need to take a few of those into photoshop for additional edits ... I set my sort at custom, but every time I take a photo from light room into photoshop for additional edits, light room moves the stack to to the very end of my sort. I am a wedding photographer and I am editing 1000+ images so having to move the edited photo back into place is extremely annoying and seems like a complete waste of time for two programs that are supposed to work seamlessly. I have searched the forums for what I thought would be an easy fix, but no luck. To me this this should be be one of those intuitive things things that make Adobe what it is. I hope there is a simple explanation for this. I simply want to arrange my photos and then edit them (w/ PS or not) in the order I want them.
        • 1. Re: why do stacked photos move to the end of the timeline in Lightroom
          dj_paige Level 10
          Set your sort order to By Capture Time or By File Name
          Once you are done with all of this editing, then you can set the custom sort order if you want.
          • 2. Re: why do stacked photos move to the end of the timeline in Lightroom
            Just Shoot Me Adobe Community Professional
            There is a setting for that. It is in the Export dialog window but whatever you chose will be globally applied. You have to first select an image, click Export, in the Export to area select Same folder as original photo, check Add to This Catalog then Add to Stack and then select either Below original or Above Original.
            It can also be changed for individual stacks by Right Clicking on the stacked image then hover over the Stacking entry and another list pops up where you can move up or down that image in the stack.
            I personally want all stacked images to be below the original. I don't want a stacked JPG, PSD or TIF to be above the original RAW files it was created from.
            Oh, Also.
            You have to actually Export that image to have the settings take hold. If you click Cancel all those changes you made will be forgotten.
            Another Also is if you are sending an image to PS or some other external editor check "Stack With Original" in the external editor tab of the preferences.
            • 3. Re: why do stacked photos move to the end of the timeline in Lightroom
              jnix43124 Level 1
              Thanks for your reply ... this is the most common answer I come across, but it does not address my issue. My problem is I am working with 1000s of files from multiple photographers and even though we are time synced, I still want to be able to reorganize the images in a more cohesive fashion  as I see it while I edit them ... for example, I would like certain sequences of the bride getting ready to be in order and and not interspersed with the photos the other photographer takes of the groom during the same timeframe and likewise ... I generally sort by capture time and then adjust manually as I move through the take. I want to use the custom order option, but am dismayed that any images exported to Photoshop and then saved are then moved to the back of the film strip. This, to me, defeats the entire purpose of a custom order.
              • 4. Re: why do stacked photos move to the end of the timeline in Lightroom
                I understand that isn't the answer that you are looking for. But I have found that sorting the images by filename is the best way to keep the images together and in place. I find that Lightroom on my computer always seems to change the sort order to capture time after I import new images. And I find the behavior the same as you are seeing. I'm using Lightroom CC 2015.
                • 5. Re: why do stacked photos move to the end of the timeline in Lightroom
                  Jane S 7 Level 1
                  I had the same problem. I think I figured it out, depending on how your photos are set to be arranged.
                  For whatever reason, all photos in my stack (one photo, and the edited photo from PS) were moved to the end of my sort. I had to select the EDITED image in the stack and move it to the end of the stack (by moving it down in the stack). This way, I think, the images would sort according to the image at the top of the stack (the original image with original file name needs to be at the top of the stack), and then all of them would magically get back into its original order.
                  I hope this solves your problem, like it solved mine!
                  • 6. Re: why do stacked photos move to the end of the timeline in Lightroom
                    williams30482568
                    This one has driven me nuts for a long time - just figured it out, I think... For me the issue was intermittent, sometimes I'd pop into PS make an edit and the image would be right where I left it, other times it would be at the end of the stack (image line). It turns out it's likely just me in a hurry.  If I use the import stack (last import) and make an edit, both images go to the end of the stack. If I navigate to the directory I placed the images in and do my edits, then everything stays together like I'd expect - no reindexing (why, no clue). There should be a setting... Hope this helps.
                    • 7. Re: why do stacked photos move to the end of the timeline in Lightroom
                      sl1330358
                      The solution that I found is the following:
                      1) go to the library module
                      2) select the grid view "G"
                      3) just above the photo film strip there is now an additional option, next to the spray paint can: Sort.
                      4) set the order to Capture time (usually LR sets this for you, or changes it even)
                      This has resolved the problem for me. Now LR does not move the edited file and the original to the very end of the photo strip.
                      Good luck with shooting weddings, all the best,
                      Steven
