6 Replies Latest reply on Mar 27, 2016 4:32 AM by e.d.
    Getting duration out of pproTicksIn/pproTicksOut
    johnw74264726
      Hi there
      I’m trying to get the duration of a clip from an exported finalcut pro xml out of premiere pro cc. Somehow it seems my following calculation is wrong. TICKS_PER_SECOND is 254,016,000,000 (Source Post).
      TimeInSec = (pproTicksOut / TICKS_PER_SECOND) – (pproTicksIn / TICKS_PER_SECOND)
      With example data attached that results in TimeInSec = 37.32. Adobe Premiere shows duration for that clip of “00:00:36:20” (920 Frames).
      Is someone able to explain, how to calculate the same duration as premiere with the data given from an exported finalcut pro xml?
      Thanks a lot
      JW
      Example ClipItem Node from exported xml:
      <clipitem id="clipitem-13051" frameBlend="FALSE" premiereChannelType="stereo">
                      <masterclipid>masterclip-4999</masterclipid>
                      <name>Test_audio.wav</name>
                      <enabled>TRUE</enabled>
                      <duration>3750</duration>
                      <rate>
                                      <timebase>25</timebase>
                                      <ntsc>FALSE</ntsc>
                      </rate>
                      <start>82</start>
                      <end>-1</end>
                      <in>0</in>
                      <out>933</out>
                      <pproTicksIn>0</pproTicksIn>
                      <pproTicksOut>9479877120000</pproTicksOut>
                      <file id="file-4999"/>
                      <sourcetrack>
                                      <mediatype>audio</mediatype>
                                      <trackindex>1</trackindex>
                      </sourcetrack>
                                      <filter>
                                                      <effect>
        <name>Audio Levels</name>
        <effectid>audiolevels</effectid>
        <effectcategory>audiolevels</effectcategory>
        <effecttype>audiolevels</effecttype>
        <parameter authoringApp="PremierePro">
        <parameterid>level</parameterid>
        <name>Level</name>
        <valuemin>0</valuemin>
        <valuemax>3.98109</valuemax>
        <value>0.530654</value>
        </parameter>
                                                      </effect>
                                      </filter>
                      <link>
                                      <linkclipref>clipitem-13051</linkclipref>
                                      <trackindex>5</trackindex>
                                      <clipindex>1</clipindex>
                                      <groupindex>1</groupindex>
                      </link>
                      <link>
                                      <linkclipref>clipitem-13063</linkclipref>
                                      <trackindex>6</trackindex>
                      </link>
                      <logginginfo>
                                      <description></description>
                                      <scene></scene>
                                      <shottake></shottake>
                                      <lognote></lognote>
                      </logginginfo>
                      <labels>
                                      <label2>Caribbean</label2>
                      </labels>
      </clipitem>
      <transitionitem>
                      <start>990</start>
                      <end>1015</end>
                      <alignment>center</alignment>
                      <cutPointTicks>121927680000</cutPointTicks>
                      <rate>
                                      <ntsc>FALSE</ntsc>
                      </rate>
                      <effect>
                                      <name>Cross Fade (+3dB)</name>
                                      <effectid>KGAudioTransCrossFade3dB</effectid>
                                      <effecttype>transition</effecttype>
                                      <wipecode>0</wipecode>
                                      <wipeaccuracy>100</wipeaccuracy>
                                      <startratio>0</startratio>
                                      <endratio>1</endratio>
                                      <reverse>FALSE</reverse>
                      </effect>
      </transitionitem>
      <!-- Further clipitems -->
