31 Replies Latest reply on Jul 18, 2016 7:36 PM by DigitalSoju
    After effects won't open, big white screen except one panel
    DigitalSoju Level 1
      Frankly, ever since adobe went cloud, I've found premiere and after effects highly buggy. If it's not one problem, it's another. My latest example is this:
      -Out of the blue, After effects just crashes. I tried to re-open it and it fails several times.
      -I reboot, try it again, same thing.
      -I uninstall it, then reinstall it. Same problem.
      -I reboot, try it again same thing.
      It just sits there and I can't do anything. 2 completely white panels and one normal panel. Did I mention I have a project due tonight?
      I'm on the latest version of After Effects
      Windows 10 pro 64 bit
      32 gbs of ram
      Maximus VII motherboard / Intel 6700k process @ 4 ghz
      Geforce GTX 970
      Any ideas?
        • 1. Re: After effects won't open, big white screen except one panel
          What driver version are you using for your GPU?
          • 2. Re: After effects won't open, big white screen except one panel
            DigitalSoju Level 1
            My driver is the latest version (364.51)
            It wasn't even installed today, so I'm not sure why after effects broke. A temporary fix was to roll back to an earlier version of after effects, but after using it a few times, it had the same problem. So I tried to re-upgrade and the problem has remained.
            I'm wondering if the problem stems from my motherboard (Asus Maximus VIII). It doesn't play well with certain programs, but it's never had a problem with after effects until today (except for the occasional crash, but not sure what to blame that on). I'm less than a week off of a fresh install of everything too.
            • 3. Re: After effects won't open, big white screen except one panel
              Try using the 361.91 or 353.30 driver on the off chance that that helps.
              • 4. Re: After effects won't open, big white screen except one panel
                DigitalSoju Level 1
                It seems the only way I can fix it is to uninstall and downgrade to an older version of after effects. But then it doesn't give me the option to upgrade to the latest version, so I uninstall and then install it from the creative cloud app. Once I went back to the latest version, it went back to the white panels and not loading.
                I'll try downgrading the nvidia drivers as well to see if that helps.
                The problem mostly kept coming from when I had premiere and after effects open and I re-rendered something that was also in the project of premiere. This didn't give me any problems for the last week, then today, bam. Once it crashed, the program was unable to open again. It'd just freeze with those 2 white panels. Very strange.
                • 5. Re: After effects won't open, big white screen except one panel
                  DigitalSoju Level 1
                  Downgraded to 361.91 and it made no difference at all. Still stuck on the white screen. I wonder what's causing this state to be locked in, even after uninstalling.
                  • 6. Re: After effects won't open, big white screen except one panel
                    What older version of AE did you try to install? Have you tried installing CC 2014? How To Find And Install Previous Version Of Adobe Apps In CC 2015
                    • 7. Re: After effects won't open, big white screen except one panel
                      DigitalSoju Level 1
                      Version 13.5.0.347 is the one working for me now.
                      • 8. Re: After effects won't open, big white screen except one panel
                        If it works, great! If not, try CC 2014.
                        • 9. Re: After effects won't open, big white screen except one panel
                          DigitalSoju Level 1
                          Well the fact I have to use an older version isn't so great. I'm thinking the problem might be my motherboard. We'll see if more google searches eventually lead other people with an Asus Maximus VIII Hero in here as well.
                          • 10. Re: After effects won't open, big white screen except one panel
                            Well, in this case, needing to use an older version isn't necessarily a bad thing. AE CC 2015 is the first step in a major re-architecture, separating the renderer from the UI for the first time in AE's 20+ year history. This is a big job and it's clearly still in progress. It's a necessary step for improving After Effects performance, but it's taking a while (and multiple versions) for them to get through it. So, during this time of transition as they're introducing elements of the new architecture, sometimes it may be easier to use the older version to get a job done.
                            I don't mind a bit of a hiccup here and there if they're going to re-write AE and eventually deliver us a much more modern and faster application!
                            That being said, it may be a hardware issue in your case, but let's hope not.
                            • 11. Re: After effects won't open, big white screen except one panel
                              danl51353681 Level 1
                              I have the same motherboard, same processor, and a GTX 980Ti and I get this exact same error every time I try using AE on my desktop. Interestingly my laptop (although much less processing power) runs it fine, so I think it definitely has something to do with the hardware in our machines.
                              I don't want to use an older version, so for right now I'm just battling it out using my laptop for any AE needs. Hopefully this gets fixed soon.
                              • 12. Re: After effects won't open, big white screen except one panel
                                DigitalSoju Level 1
                                It makes me wonder if it's the motherboard, graphics card or a combination of both. @danl51353681 do you by chance use a USB mic? For some reason, my usb mic won't work anymore and I think it's this motherboard. It sucks because it's supposed to be one of the top motherboards for this processor.
                                • 13. Re: After effects won't open, big white screen except one panel
                                  Alexandre Parenteau Adobe Employee
                                  "Out of the blue".
                                  Does it mean it worked at some point, but now it's not?
                                  Have you installed a new plug-in, or updated the OS recently?
                                  (just pitching in the dark)
                                  • 14. Re: After effects won't open, big white screen except one panel
                                    DigitalSoju Level 1
                                    Yes it works at some point, but then within an hour it gets that annoying white screen and it can't be undone unless I reformat. The only solution was to roll back to an older version. After the older version started working, I tried to update and still got the white screen.
                                    Premiere pro has a similar white screen problem but I found a workaround for it on this board. Basically you set the workspace to Color correction, then save and exit. Afterwards Premiere pro will still not close properly, so you have to kill it from the task manager, then open it back up. Then the white screen goes away (but will eventually come back).
                                    For after effects I haven't found a solution.
                                    • 15. Re: After effects won't open, big white screen except one panel
                                      Could you please attach the log to this thread? (you can turn on the log from within the Help menu)
                                      • 16. Re: After effects won't open, big white screen except one panel
                                        I don't use a USB mic, however Premiere Pro luckily doesn't give me any problems - It's only that AE doesn't work on the current version.
                                        • 17. Re: After effects won't open, big white screen except one panel
                                          Okay, so I just updated to AE 2015.3, and I can load projects in, but then the Composition screen is still white (see pic). How should I attach the log file? This is soooo frustrating. Alexandre Parenteau
                                          • 18. Re: After effects won't open, big white screen except one panel
                                            Here is my log file:
                                            Log file created: 6/22/2016 10:33:22 AM
                                            Ticks = 0      <4972> <AppVers> <5> App Version = 13.8.0x144 release
                                            Ticks = 0      <4972> <AppDirs> <5> App Dir = C:\Program Files\Adobe\Adobe After Effects CC 2015.3\Support Files
                                            Ticks = 0      <4972> <AppDirs> <5> Executable Dir = C:\Program Files\Adobe\Adobe After Effects CC 2015.3\Support Files
                                            Ticks = 0      <4972> <AppDirs> <5> Resources Dir = C:\Program Files\Adobe\Adobe After Effects CC 2015.3\Support Files
                                            Ticks = 0      <4972> <AppDirs> <5> Package Dir = C:\Program Files\Adobe\Adobe After Effects CC 2015.3\Support Files
                                            Ticks = 109      <4972> <AppDirs> <5> Plugin Dir = C:\Program Files\Adobe\Adobe After Effects CC 2015.3\Support Files\Plug-ins
                                            Ticks = 109      <4972> <AppDirs> <5> Required Dir = C:\Program Files\Adobe\Adobe After Effects CC 2015.3\Support Files\Required
                                            Ticks = 109      <4972> <ALOG> <5> EGG STARTUP
                                            Ticks = 172      <4972> <ALOG> <5> U Birth U Birth
                                            Ticks = 172      <4972> <ALOG> <5> U CPU Data LogicalCores:8, PhysicalCores:4, MMX:1, SSE:1 SSE2:1, SSE3:1, SSSE(MNI):1, SSE4_1:0, SSE4_2:1
                                            Ticks = 172      <4972> <ALOG> <5> U Up_InitializeMemorySubsystem fudgebuffer=262144000, goDirect=1
                                            Ticks = 172      <4972> <ALOG> <5> U Birth U Hog Birth
                                            Ticks = 266      <4972> <ALOG> <5> EGG AMT AMT obtaining product license...
                                            Ticks = 281      <4972> <ALOG> <5> EGG AMT 0 - Licensing succeeded!
                                            Ticks = 297      <4972> <ALOG> <5> EGG AMT AMT Diagnostic Output
                                            Part of Suite:
                                            Tryout: false
                                            Activated: true
                                            Version: 1.0
                                            Serial: 909705270215148092442626
                                            ProBundle: true
                                            Ticks = 297      <4972> <ALOG> <5> EMUL Birth EMUL String Birth
                                            Ticks = 297      <4972> <ALOG> <5> EMUL SLOP UPDATE Mem Usage in MB: calc: 135.006697, measured: 76.929688, delta: -58.077009, delta pct: -75.493624, total slop: 17592186044357.924000
                                            Ticks = 297      <4972> <ALOG> <5> FILE Birth FILE Birth
                                            Ticks = 297      <4972> <ALOG> <5> M Birth M Birth
                                            Ticks = 297      <4972> <ALOG> <5> RND Birth RND Birth
                                            Ticks = 344      <4972> <ALOG> <5> PREF Birth PREF Birth
                                            Ticks = 375      <4972> <ALOG> <5> VAL Birth VAL Birth
                                            Ticks = 375      <4972> <ALOG> <5> MC Birth MC Birth
                                            Ticks = 375      <4972> <ALOG> <5> EGG IEggApp AXE8 v:3.8.0 Loaded
                                            Ticks = 406      <4972> <ALOG> <5> EGG IEggApp Splash screen shown
                                            Ticks = 406      <4972> <ALOG> <5> EGG BIRTH Beginning Verify Environment
                                            Ticks = 406      <4972> <ALOG> <5> BM Birth BM Birth
                                            Ticks = 406      <4972> <ALOG> <5> COR Birth COR Birth
                                            Ticks = 2734      <4972> <GPUManager> <2> Sniffer Result Code: 3
                                            Ticks = 3859      <4972> <ALOG> <5> Optix Initialization CUDA Version: 7.5
                                            Ticks = 3859      <4972> <ALOG> <5> Optix Initialization Optix Version: 3.6.2
                                            Ticks = 3859      <4972> <ALOG> <5> Optix Initialization Number of Available Devices = 2
                                            Ticks = 3859      <4972> <ALOG> <5> Optix Initialization Device 0: GeForce GTX 980 Ti (NOT PRESENT in the whitelist)
                                            Ticks = 3859      <4972> <ALOG> <5> Optix Initialization Device 1: CPU (NOT PRESENT in the whitelist)
                                            Ticks = 3859      <4972> <ALOG> <5> Optix Initialization Device Used For Rendering 0: GeForce GTX 980 Ti
                                            Ticks = 3937      <4972> <ALOG> <5> Optix Initialization     Device Available Memory 0: 5280179814 bytes
                                            Ticks = 3937      <4972> <ALOG> <5> Optix Initialization     Device Total Memory 0: 6442450944 bytes
                                            Ticks = 3937      <4972> <ALOG> <5> Optix Initialization CUDA Version: 7.5
                                            Ticks = 3937      <4972> <ALOG> <5> Optix Initialization Optix Version: 3.6.2
                                            Ticks = 3937      <4972> <ALOG> <5> Optix Initialization Number of Available Devices = 2
                                            Ticks = 3937      <4972> <ALOG> <5> Optix Initialization Device 0: GeForce GTX 980 Ti (NOT PRESENT in the whitelist)
                                            Ticks = 3937      <4972> <ALOG> <5> Optix Initialization Device 1: CPU (NOT PRESENT in the whitelist)
                                            Ticks = 3953      <4972> <ALOG> <5> Optix Initialization Device Used For Rendering 0: GeForce GTX 980 Ti
                                            Ticks = 4016      <4972> <ALOG> <5> Optix Initialization     Device Available Memory 0: 5280179814 bytes
                                            Ticks = 4016      <4972> <ALOG> <5> Optix Initialization     Device Total Memory 0: 6442450944 bytes
                                            Ticks = 4016      <4972> <ALOG> <5> COR Birth COR Birth Complete
                                            Ticks = 4031      <4972> <ALOG> <5> PLUG Birth PLUG Birth
                                            Ticks = 4031      <4972> <ALOG> <5> TDB Birth TDB Birth
                                            Ticks = 4031      <4972> <ALOG> <5> TDB Birth TDB StreamBase Birth
                                            Ticks = 4031      <4972> <ALOG> <5> PF Birth PF Birth
                                            Ticks = 4031      <4972> <ALOG> <5> P Birth P Birth
                                            Ticks = 4031      <4972> <ALOG> <5> EGG Splash Screen Initializing type engine...
                                            Ticks = 4031      <4972> <ALOG> <5> TXT Birth TXT Birth
                                            Ticks = 4094      <4972> <ALOG> <5> EGG Splash Screen Initializing MediaCore
                                            Ticks = 4094      <4972> <ALOG> <5> EGG IEggApp About to Init Media Core
                                            Ticks = 4094      <4972> <ALOG> <5> PREM MediaCoreData About to Init PRM
                                            Ticks = 4094      <4972> <ALOG> <5> PREM MediaCoreData About to Init BE
                                            Ticks = 4109      <4972> <ALOG> <5> PREM MediaCoreData About to Init ImporterHost
                                            Ticks = 4109      <4972> <DynamicLink> <5> Attempting to launch dynamiclinkmanager
                                            Ticks = 4109      <4972> <DynamicLink> <5> C:\Program Files\Adobe\Adobe After Effects CC 2015.3\Support Files\32\dynamiclinkmanager.exe
                                            Ticks = 4156      <4972> <ALOG> <5> PREM MediaCoreData About to Init ExporterHost
                                            Ticks = 4156      <4972> <ALOG> <5> PREM MediaCoreData About to Init VideoRenderer
                                            Ticks = 4156      <4972> <ALOG> <5> PREM MediaCoreData About to Init AudioFilterHost
                                            Ticks = 4156      <4972> <ALOG> <5> PREM MediaCoreData About to Init AudioSupport
                                            Ticks = 4156      <4972> <ALOG> <5> PREM MediaCoreData About to Init ProjectConverterHost
                                            Ticks = 4156      <4972> <ALOG> <5> PREM MediaCoreData About to Init VideoFilterHost
                                            Ticks = 4156      <4972> <ALOG> <5> PREM MediaCoreData About to Init Player Host
                                            Ticks = 4156      <4972> <ALOG> <5> PREM MediaCoreData About to Init AccleratedRendering
                                            Ticks = 4156      <4972> <ALOG> <5> PREM MediaCoreData About to Init DynamicLinkMedia
                                            Ticks = 4156      <4972> <ALOG> <5> PREM MediaCoreData About to Init TransmitHost
                                            Ticks = 4156      <4972> <ALOG> <5> PREM MediaCoreData About to Init DisplaySurface
                                            Ticks = 11703      <5036> <ALOG> <5> COR CORp_RegisterPSLThread initialized PSL
                                            Ticks = 11859      <4972> <ALOG> <5> PREM MediaCoreData About to Init DVAMediaBrowser
                                            Ticks = 11859      <4972> <ALOG> <5> EGG IEggApp Finished Initing Media Core
                                            Ticks = 11859      <4972> <ALOG> <5> EGG IEggApp Media Core initialized successfully
                                            Ticks = 11937      <4972> <ALOG> <5> PIN Birth PIN Birth
                                            Ticks = 11937      <4972> <ALOG> <5> PIN Birth PIN PS3 Birth
                                            Ticks = 11937      <4972> <ALOG> <5> PIN Birth PIN RLA Birth
                                            Ticks = 11937      <4972> <ALOG> <5> PIN Birth PIN CIN Birth
                                            Ticks = 11937      <4972> <ALOG> <5> PIN Birth PIN EI Birth
                                            Ticks = 11937      <4972> <ALOG> <5> PIN Birth PIN ZPIC Birth
                                            Ticks = 11937      <4972> <ALOG> <5> PIN Birth PIN YM Birth
                                            Ticks = 11937      <4972> <ALOG> <5> PIN Birth PIN PS Birth
                                            Ticks = 11937      <4972> <ALOG> <5> PIN Birth PIN PST Birth
                                            Ticks = 11937      <4972> <ALOG> <5> PIN Birth PIN D_MC Birth
                                            Ticks = 11937      <4972> <ALOG> <5> SND Birth SND Birth
                                            Ticks = 11953      <4972> <ALOG> <5> OM Birth OM Birth
                                            Ticks = 11953      <4972> <ALOG> <5> FLT Birth ALOG Birth
                                            Ticks = 11953      <4972> <ALOG> <5> PR Birth PR Birth
                                            Ticks = 11953      <4972> <ALOG> <5> BEE Birth BEE Birth
                                            Ticks = 11953      <4972> <BEE_WorkQueue> <5> BEE_Project::TimestampGetNext ZANZIBAR-3: cannot produce timestamp, frozen=0, open=0
                                            Ticks = 11953      <4972> <ALOG> <5> BEE Birth BEE Eval Birth
                                            Ticks = 11953      <4972> <ALOG> <5> BEE Birth BEE Stream Birth
                                            Ticks = 11953      <4972> <ALOG> <5> BEE Birth BEE TextAnimatorDispatch Birth
                                            Ticks = 11953      <4972> <ALOG> <5> BEE Birth BEE TextListener Birth
                                            Ticks = 11953      <4972> <ALOG> <5> BEE Birth BEE StyleListener Birth
                                            Ticks = 11953      <4972> <ALOG> <5> FRP Birth FRP PinListener Birth
                                            Ticks = 11953      <4972> <ALOG> <5> EGG Splash Screen AEGP Driver
                                            Ticks = 11969      <4972> <ALOG> <5> EGG Splash Screen Paint
                                            Ticks = 11969      <4972> <ALOG> <5> EGG Splash Screen Roto Brush & Refine Edge
                                            Ticks = 11969      <4972> <ALOG> <5> EGG Splash Screen Puppet
                                            Ticks = 11969      <4972> <ALOG> <5> EGG Splash Screen Refine Matte
                                            Ticks = 11969      <4972> <ALOG> <5> EGG Splash Screen Refine Hard Matte
                                            Ticks = 11969      <4972> <ALOG> <5> EGG Splash Screen Refine Soft Matte
                                            Ticks = 11969      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: PTX
                                            Ticks = 11969      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: XMPFiles
                                            Ticks = 11984      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: 32
                                            Ticks = 11984      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Adobe Color Themes
                                            Ticks = 11984      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: css
                                            Ticks = 11984      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: CSXS
                                            Ticks = 11984      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: icons
                                            Ticks = 11984      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: js
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: lib
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: locale
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: cs_CZ
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: da_DK
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: de_DE
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: en_US
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: es_ES
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: fi_FI
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: fr_FR
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: it_IT
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: ja_JP
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: ko_KR
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: nb_NO
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: nl_NL
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: pl_PL
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: pt_BR
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: ru_RU
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: sv_SE
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: tr_TR
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: zh_TW
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: META-INF
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: CEPHtmlEngine
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: locales
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: com.adobe.ccx.start
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: CSXS
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: fonts
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: images
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: empty-state
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: filetypes
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: indicators
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: products
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: thumbs
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: js
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: en_AE
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: en_GB
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: en_IL
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: es_MX
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: fr_CA
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: fr_MA
                                            Ticks = 12000      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: hu_HU
                                            Ticks = 12016      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: it_IT
                                            Ticks = 12016      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: ja_JP
                                            Ticks = 12016      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: ko_KR
                                            Ticks = 12016      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: nb_NO
                                            Ticks = 12016      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: nl_NL
                                            Ticks = 12016      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: pl_PL
                                            Ticks = 12016      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: pt_BR
                                            Ticks = 12016      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: ru_RU
                                            Ticks = 12016      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: sv_SE
                                            Ticks = 12016      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: tr_TR
                                            Ticks = 12016      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: uk_UA
                                            Ticks = 12016      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: zh_CN
                                            Ticks = 12016      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: zh_TW
                                            Ticks = 12016      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: META-INF
                                            Ticks = 12016      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: com.adobe.susi-dva.extension
                                            Ticks = 12016      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: CSXS
                                            Ticks = 12016      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: js
                                            Ticks = 12016      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: cursors
                                            Ticks = 12031      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Dictionaries
                                            Ticks = 12031      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: EveScripts
                                            Ticks = 12031      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: FaceTracker
                                            Ticks = 12031      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: model
                                            Ticks = 12031      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Lumetri
                                            Ticks = 12031      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Base
                                            Ticks = 12031      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Blur and Sharpen
                                            Ticks = 12031      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Color Match
                                            Ticks = 12031      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Curves
                                            Ticks = 12031      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Film
                                            Ticks = 12031      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Looks
                                            Ticks = 12031      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Legacy
                                            Ticks = 12031      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: LUTs
                                            Ticks = 12031      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Creative
                                            Ticks = 12031      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Technical
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Misc
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Premiere Color
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Stylize
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Video
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: OBLRes
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: ar_AE
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: bg_BG
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: cs_CZ
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: da_DK
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: de_DE
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: el_GR
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: en_AE
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: en_GB
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: en_IL
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: en_MX
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: en_US
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: en_XM
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: es_ES
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: es_LA
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: es_MX
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: es_NA
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: et_EE
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: fi_FI
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: fr_CA
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: fr_FR
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: fr_MA
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: fr_MX
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: fr_XM
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: he_IL
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: hr_HR
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: hu_HU
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: it_IT
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: ja_JP
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: ko_KR
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: lt_LT
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: lv_LV
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: nb_NO
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: nl_NL
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: pl_PL
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: pt_BR
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: ro_RO
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: ru_RU
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: sk_SK
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: sl_SI
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: sv_SE
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: tr_TR
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: uk_UA
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: zh_CN
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: zh_TW
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: pdflsupport
                                            Ticks = 12047      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: CMaps
                                            Ticks = 12062      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Fonts
                                            Ticks = 12062      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: PFM
                                            Ticks = 12062      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Plug-ins
                                            Ticks = 12062      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Effects
                                            Ticks = 12062      <4972> <ALOG> <5> EGG Splash Screen 3D Camera Tracker
                                            Ticks = 12062      <4972> <ALOG> <5> EGG Splash Screen 3D Glasses (Obsolete)
                                            Ticks = 12062      <4972> <ALOG> <5> EGG Splash Screen Add Grain
                                            Ticks = 12062      <4972> <ALOG> <5> EGG Splash Screen Alpha Levels
                                            Ticks = 12062      <4972> <ALOG> <5> EGG Splash Screen Apply Color LUT
                                            Ticks = 12062      <4972> <ALOG> <5> EGG Splash Screen Arithmetic
                                            Ticks = 12062      <4972> <ALOG> <5> EGG Splash Screen Audio Spectrum
                                            Ticks = 12062      <4972> <ALOG> <5> EGG Splash Screen Audio Waveform
                                            Ticks = 12062      <4972> <ALOG> <5> EGG Splash Screen Bass & Treble
                                            Ticks = 12062      <4972> <ALOG> <5> EGG Splash Screen Delay
                                            Ticks = 12062      <4972> <ALOG> <5> EGG Splash Screen Flange & Chorus
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen High-Low Pass
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Stereo Mixer
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Modulator
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Parametric EQ
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Reverb
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Backwards
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Tone
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Auto Color
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Auto Contrast
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Auto Levels
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen 3D Channel Extract
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Brightness & Contrast
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Basic 3D
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Basic Text
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Beam
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Bevel Alpha
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Bevel Edges
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Bezier Warp
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Bilateral Blur
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Blend
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Block Dissolve
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Box Blur
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Broadcast Colors
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Brush Strokes
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Bulge
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Calculations
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Warp
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Card Dance
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Card Wipe
                                            Ticks = 12078      <4972> <ALOG> <5> EGG Splash Screen Video Abstraction
                                            Ticks = 12094      <4972> <ALOG> <5> EGG Splash Screen Cartoon
                                            Ticks = 12094      <4972> <ALOG> <5> EGG Splash Screen Caustics
                                            Ticks = 12094      <4972> <ALOG> <5> EGG Splash Screen Cell Pattern
                                            Ticks = 12094      <4972> <ALOG> <5> EGG Splash Screen Change to Color
                                            Ticks = 12094      <4972> <ALOG> <5> EGG Splash Screen Change Color
                                            Ticks = 12094      <4972> <ALOG> <5> EGG Splash Screen Channel Combiner
                                            Ticks = 12094      <4972> <ALOG> <5> EGG Splash Screen Channel Blur
                                            Ticks = 12094      <4972> <ALOG> <5> EGG Splash Screen Channel Mixer
                                            Ticks = 12094      <4972> <ALOG> <5> EGG Splash Screen Checkerboard
                                            Ticks = 12094      <4972> <ALOG> <5> EGG Splash Screen Cineon Converter
                                            Ticks = 12094      <4972> <ALOG> <5> EGG Splash Screen Circle
                                            Ticks = 12094      <4972> <ALOG> <5> EGG Splash Screen Colorama
                                            Ticks = 12094      <4972> <ALOG> <5> EGG Splash Screen Color Link
                                            Ticks = 12094      <4972> <ALOG> <5> EGG Splash Screen 4-Color Gradient
                                            Ticks = 12094      <4972> <ALOG> <5> EGG Splash Screen Color Balance
                                            Ticks = 12094      <4972> <ALOG> <5> EGG Splash Screen Color Difference Key
                                            Ticks = 12094      <4972> <ALOG> <5> EGG Splash Screen Color Emboss
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Color Balance (HLS)
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Color Key
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Color Range
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Compound Arithmetic
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Compound Blur
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Corner Pin
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Curves
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Color Stabilizer
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Depth of Field
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Depth Matte
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Difference Matte
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Time Difference
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Directional Blur
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Displacement Map
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Drop Shadow
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Dust & Scratches
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Echo
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Ellipse
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Emboss
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Equalize
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Exposure
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen HDR Compander
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Slider Control
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Angle Control
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Checkbox Control
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Color Control
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Point Control
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Layer Control
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen 3D Point Control
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Extract
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen EXtractoR
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Eyedropper Fill
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Fast Blur
                                            Ticks = 12109      <4972> <ALOG> <5> EGG Splash Screen Reduce Interlace Flicker
                                            Ticks = 12125      <4972> <ALOG> <5> EGG Splash Screen Fill
                                            Ticks = 12125      <4972> <ALOG> <5> EGG Splash Screen Find Edges
                                            Ticks = 12125      <4972> <ALOG> <5> EGG Splash Screen Foam
                                            Ticks = 12125      <4972> <ALOG> <5> EGG Splash Screen Fog 3D
                                            Ticks = 12125      <4972> <ALOG> <5> EGG Splash Screen Fractal
                                            Ticks = 12125      <4972> <ALOG> <5> EGG Splash Screen Fractal Noise
                                            Ticks = 12125      <4972> <ALOG> <5> EGG Splash Screen Gaussian Blur (Legacy)
                                            Ticks = 12125      <4972> <ALOG> <5> EGG Splash Screen Glow
                                            Ticks = 12125      <4972> <ALOG> <5> EGG Splash Screen Gamma/Pedestal/Gain
                                            Ticks = 12125      <4972> <ALOG> <5> EGG Splash Screen Gradient Wipe
                                            Ticks = 12125      <4972> <ALOG> <5> EGG Splash Screen Grid
                                            Ticks = 12125      <4972> <ALOG> <5> EGG Splash Screen Grow Bounds
                                            Ticks = 12125      <4972> <ALOG> <5> EGG Splash Screen Hue/Saturation
                                            Ticks = 12125      <4972> <ALOG> <5> EGG Splash Screen IDentifier
                                            Ticks = 12125      <4972> <ALOG> <5> EGG Splash Screen ID Matte
                                            Ticks = 12125      <4972> <ALOG> <5> EGG Splash Screen Inner/Outer Key
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Invert
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Iris Wipe
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Key Cleaner
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Leave Color
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Lens Blur
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Lens Flare
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Levels (Individual Controls)
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Lightning
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Advanced Lightning
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Linear Color Key
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Linear Wipe
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Liquify
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Luma Key
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Lumetri Color
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Magnify
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Match Grain
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Matte Choker
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Median
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Minimax
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Mirror
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Mosaic
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Mesh Warp
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Noise
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Noise Alpha
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Noise HLS
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Noise HLS Auto
                                            Ticks = 12141      <4972> <ALOG> <5> EGG Splash Screen Numbers
                                            Ticks = 12156      <4972> <ALOG> <5> EGG Splash Screen Offset
                                            Ticks = 12156      <4972> <ALOG> <5> EGG Splash Screen Optics Compensation
                                            Ticks = 12156      <4972> <ALOG> <5> EGG Splash Screen Paint Bucket
                                            Ticks = 12156      <4972> <ALOG> <5> EGG Splash Screen Particle Playground
                                            Ticks = 12156      <4972> <ALOG> <5> EGG Splash Screen Path Text
                                            Ticks = 12156      <4972> <ALOG> <5> EGG Splash Screen Photo Filter
                                            Ticks = 12156      <4972> <ALOG> <5> EGG Splash Screen Polar Coordinates
                                            Ticks = 12156      <4972> <ALOG> <5> EGG Splash Screen Posterize
                                            Ticks = 12156      <4972> <ALOG> <5> EGG Splash Screen Posterize Time
                                            Ticks = 12156      <4972> <ALOG> <5> EGG Splash Screen Color Profile Converter
                                            Ticks = 12156      <4972> <ALOG> <5> EGG Splash Screen HDR Highlight Compression
                                            Ticks = 12156      <4972> <ALOG> <5> EGG Splash Screen Selective Color
                                            Ticks = 12156      <4972> <ALOG> <5> EGG Splash Screen Vibrance
                                            Ticks = 12156      <4972> <ALOG> <5> EGG Splash Screen Black & White
                                            Ticks = 12156      <4972> <ALOG> <5> EGG Splash Screen Brightness & Contrast
                                            Ticks = 12156      <4972> <ALOG> <5> EGG Splash Screen Photoshop Bevel And Emboss
                                            Ticks = 12156      <4972> <ALOG> <5> EGG Splash Screen Photoshop Drop Shadow
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Photoshop Inner Glow
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Photoshop Inner Shadow
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Photoshop Outer Glow
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Photoshop Solid Fill
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen PS Arbitrary Map
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Radial Shadow
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Radial Blur
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Radial Wipe
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Radio Waves
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Gradient Ramp
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Remove Grain
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Reshape
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Ripple
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Rolling Shutter Repair
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Timewarp
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Pixel Motion Blur
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Roughen Edges
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Scatter
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Scribble
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Set Channels
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Set Matte
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Shadow/Highlight
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Camera Lens Blur
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Sharpen
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Shatter
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Shift Channels
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Simple Choker
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Smart Blur
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Smear
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Solid Composite
                                            Ticks = 12172      <4972> <ALOG> <5> EGG Splash Screen Spherize
                                            Ticks = 12187      <4972> <ALOG> <5> EGG Splash Screen Spill Suppressor
                                            Ticks = 12187      <4972> <ALOG> <5> EGG Splash Screen Advanced Spill Suppressor
                                            Ticks = 12187      <4972> <ALOG> <5> EGG Splash Screen Warp Stabilizer VFX
                                            Ticks = 12187      <4972> <ALOG> <5> EGG Splash Screen Strobe Light
                                            Ticks = 12187      <4972> <ALOG> <5> EGG Splash Screen Stroke
                                            Ticks = 12187      <4972> <ALOG> <5> EGG Splash Screen Texturize
                                            Ticks = 12187      <4972> <ALOG> <5> EGG Splash Screen Three-Way Color Corrector
                                            Ticks = 12187      <4972> <ALOG> <5> EGG Splash Screen Threshold
                                            Ticks = 12187      <4972> <ALOG> <5> EGG Splash Screen Motion Tile
                                            Ticks = 12187      <4972> <ALOG> <5> EGG Splash Screen Timecode
                                            Ticks = 12187      <4972> <ALOG> <5> EGG Splash Screen Time Displacement
                                            Ticks = 12187      <4972> <ALOG> <5> EGG Splash Screen Tint
                                            Ticks = 12187      <4972> <ALOG> <5> EGG Splash Screen Transform
                                            Ticks = 12187      <4972> <ALOG> <5> EGG Splash Screen Tritone
                                            Ticks = 12187      <4972> <ALOG> <5> EGG Splash Screen Turbulent Displace
                                            Ticks = 12187      <4972> <ALOG> <5> EGG Splash Screen Turbulent Noise
                                            Ticks = 12187      <4972> <ALOG> <5> EGG Splash Screen Twirl
                                            Ticks = 12187      <4972> <ALOG> <5> EGG Splash Screen Remove Color Matting
                                            Ticks = 12187      <4972> <ALOG> <5> EGG Splash Screen Unsharp Mask
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen Detail-preserving Upscale
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen Vector Paint
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen Vegas
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen Venetian Blinds
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen Wave World
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen Wave Warp
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen Write-on
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: CycoreFXHD
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Ball Action
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Bender
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Bend It
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Blobbylize
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Block Load
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Bubbles
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Burn Film
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Color Neutralizer
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Color Offset
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Composite
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Cross Blur
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Cylinder
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Drizzle
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Environment
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Flo Motion
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Force Motion Blur
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Glass
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Glass Wipe
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Glue Gun
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Griddler
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Grid Wipe
                                            Ticks = 12203      <4972> <ALOG> <5> EGG Splash Screen CC Hair
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC HexTile
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Image Wipe
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Jaws
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Kaleida
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Kernel
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Lens
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Light Burst 2.5
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Light Rays
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Light Sweep
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Light Wipe
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Line Sweep
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Mr. Mercury
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Mr. Smoothie
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Overbrights
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Page Turn
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC PS Classic (obsolete)
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Particle Systems II
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC PS LE Classic (obsolete)
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Pixel Polly
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Plastic
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Power Pin
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Particle World
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Radial Blur
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Radial Fast Blur
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Radial ScaleWipe
                                            Ticks = 12219      <4972> <ALOG> <5> EGG Splash Screen CC Rain
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Rainfall
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC RepeTile
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Ripple Pulse
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Scale Wipe
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Scatterize
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Simple Wire Removal
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Slant
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Smear
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Snow
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Snowfall
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Sphere
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Split
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Split 2
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Spotlight
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Star Burst
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Threads
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Threshold
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Threshold RGB
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Tiler
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Time Blend
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Time Blend FX
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Toner
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Twister
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Vector Blur
                                            Ticks = 12234      <4972> <ALOG> <5> EGG Splash Screen CC Vignette
                                            Ticks = 12250      <4972> <ALOG> <5> EGG Splash Screen CC WarpoMatic
                                            Ticks = 12250      <4972> <ALOG> <5> EGG Splash Screen CC Wide Time
                                            Ticks = 12250      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Film Stocks
                                            Ticks = 12250      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Keylight
                                            Ticks = 12250      <4972> <ALOG> <5> EGG Splash Screen Keylight (1.2)
                                            Ticks = 12250      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: docs
                                            Ticks = 12250      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: mochaAE
                                            Ticks = 12250      <4972> <ALOG> <5> EGG Splash Screen mocha shape
                                            Ticks = 12250      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Synthetic Aperture
                                            Ticks = 12250      <4972> <ALOG> <5> EGG Splash Screen SA Color Finesse 3
                                            Ticks = 12250      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Extensions
                                            Ticks = 12250      <4972> <ALOG> <5> EGG Splash Screen Multiprocessing Support
                                            Ticks = 12250      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Format
                                            Ticks = 12250      <4972> <ALOG> <5> EGG Splash Screen IFF
                                            Ticks = 12250      <4972> <ALOG> <5> EGG Splash Screen JPEG
                                            Ticks = 12250      <4972> <ALOG> <5> EGG Splash Screen Photoshop Layered Export
                                            Ticks = 12250      <4972> <ALOG> <5> EGG Splash Screen Photoshop Layer Import
                                            Ticks = 12250      <4972> <ALOG> <5> EGG Splash Screen Radiance
                                            Ticks = 12250      <4972> <ALOG> <5> EGG Splash Screen SGI
                                            Ticks = 12266      <4972> <ALOG> <5> EGG Splash Screen BMP
                                            Ticks = 12266      <4972> <ALOG> <5> EGG Splash Screen Targa
                                            Ticks = 12266      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: PremiereProImport
                                            Ticks = 12266      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: ProImport
                                            Ticks = 12266      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Supporting Files
                                            Ticks = 12266      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: aafext
                                            Ticks = 12266      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: logs
                                            Ticks = 12266      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Keyframe
                                            Ticks = 12266      <4972> <ALOG> <5> EGG Splash Screen Easy Ease
                                            Ticks = 12266      <4972> <ALOG> <5> EGG Splash Screen Exponential Scale
                                            Ticks = 12281      <4972> <ALOG> <5> EGG Splash Screen Sequence
                                            Ticks = 12281      <4972> <ALOG> <5> EGG Splash Screen Time-Reverse Keyframes
                                            Ticks = 12281      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: MAXON CINEWARE AE
                                            Ticks = 12281      <4972> <ALOG> <5> EGG Splash Screen CINEWARE
                                            Ticks = 12281      <4972> <ALOG> <5> EGG Splash Screen CINEWARE LiveLink
                                            Ticks = 12281      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: PNG
                                            Ticks = 12297      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Presets
                                            Ticks = 12297      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Backgrounds
                                            Ticks = 12297      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Behaviors
                                            Ticks = 12297      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Image - Creative
                                            Ticks = 12312      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Image - Special Effects
                                            Ticks = 12312      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Image - Utilities
                                            Ticks = 12312      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Shapes
                                            Ticks = 12312      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Backgrounds
                                            Ticks = 12312      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Elements
                                            Ticks = 12312      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Sprites - Animated
                                            Ticks = 12312      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Sprites - Still
                                            Ticks = 12312      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Sound Effects
                                            Ticks = 12312      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Synthetics
                                            Ticks = 12312      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Text
                                            Ticks = 12312      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: 3D Text
                                            Ticks = 12312      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Animate In
                                            Ticks = 12312      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Animate Out
                                            Ticks = 12312      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Blurs
                                            Ticks = 12328      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Curves and Spins
                                            Ticks = 12328      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Expressions
                                            Ticks = 12328      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Fill and Stroke
                                            Ticks = 12328      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Graphical
                                            Ticks = 12328      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Lights and Optical
                                            Ticks = 12328      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Mechanical
                                            Ticks = 12328      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Miscellaneous
                                            Ticks = 12344      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Multi-Line
                                            Ticks = 12344      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Organic
                                            Ticks = 12344      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Paths
                                            Ticks = 12344      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Rotation
                                            Ticks = 12344      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Scale
                                            Ticks = 12344      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Tracking
                                            Ticks = 12344      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Transform
                                            Ticks = 12344      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Transitions - Dissolves
                                            Ticks = 12344      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Transitions - Movement
                                            Ticks = 12359      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Transitions - Wipes
                                            Ticks = 12359      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: PTX
                                            Ticks = 12375      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: cubin20
                                            Ticks = 12375      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: cubin30
                                            Ticks = 12375      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: RuntimeInstallers
                                            Ticks = 12375      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: 1.0
                                            Ticks = 12375      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: sounds
                                            Ticks = 12375      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: typesupport
                                            Ticks = 12375      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: cmaps
                                            Ticks = 12391      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: unicode
                                            Ticks = 12391      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: icu
                                            Ticks = 12391      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: mappings
                                            Ticks = 12391      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: adobe
                                            Ticks = 12391      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: mac
                                            Ticks = 12391      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: win
                                            Ticks = 12391      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: File Formats
                                            Ticks = 12391      <4972> <ALOG> <5> EGG Splash Screen Camera Raw
                                            Ticks = 12453      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Generator
                                            Ticks = 12453      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: preview20155.generate
                                            Ticks = 12453      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: jsx
                                            Ticks = 12453      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: lib
                                            Ticks = 12453      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: asset-exporter
                                            Ticks = 12453      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: node-usbmux
                                            Ticks = 12453      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: node_modules
                                            Ticks = 12453      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: async
                                            Ticks = 12453      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: support
                                            Ticks = 12453      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: base64-js
                                            Ticks = 12453      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: bench
                                            Ticks = 12453      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: test
                                            Ticks = 12453      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: bluebird
                                            Ticks = 12453      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: browser
                                            Ticks = 12453      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: main
                                            Ticks = 12469      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: bufferpack
                                            Ticks = 12469      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: colors
                                            Ticks = 12469      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: examples
                                            Ticks = 12469      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: lib
                                            Ticks = 12469      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: custom
                                            Ticks = 12469      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: maps
                                            Ticks = 12469      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: system
                                            Ticks = 12469      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: screenshots
                                            Ticks = 12469      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: tests
                                            Ticks = 12469      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: themes
                                            Ticks = 12469      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: cycle
                                            Ticks = 12469      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: eyes
                                            Ticks = 12469      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: isstream
                                            Ticks = 12469      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: lodash
                                            Ticks = 12469      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: array
                                            Ticks = 12469      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: chain
                                            Ticks = 12469      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: collection
                                            Ticks = 12469      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: date
                                            Ticks = 12469      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: function
                                            Ticks = 12469      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: internal
                                            Ticks = 12484      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: lang
                                            Ticks = 12484      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: math
                                            Ticks = 12484      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: number
                                            Ticks = 12484      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: object
                                            Ticks = 12484      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: string
                                            Ticks = 12484      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: utility
                                            Ticks = 12484      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: pkginfo
                                            Ticks = 12484      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: docs
                                            Ticks = 12484      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: examples
                                            Ticks = 12484      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: subdir
                                            Ticks = 12484      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: lib
                                            Ticks = 12484      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: test
                                            Ticks = 12484      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: plist
                                            Ticks = 12484      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: dist
                                            Ticks = 12484      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: browser
                                            Ticks = 12484      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: stack-trace
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: lib
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: util-deprecate
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: winston
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: docs
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: examples
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: config
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: transports
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: test
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: fixtures
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: keys
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: logs
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: scripts
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: stress
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: xmlbuilder
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: xmldom
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: node_modules
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: after
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: arraybuffer.slice
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: backo2
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: balanced-match
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: base64-arraybuffer
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: benchmark
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: better-assert
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: blob
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: brace-expansion
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: callsite
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: component-bind
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: component-emitter
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: component-inherit
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: concat-map
                                            Ticks = 12500      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: core-util-is
                                            Ticks = 12516      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: lib
                                            Ticks = 12516      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: debug
                                            Ticks = 12516      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: engine.io-client
                                            Ticks = 12516      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: transports
                                            Ticks = 12516      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: support
                                            Ticks = 12516      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: test
                                            Ticks = 12516      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: arraybuffer
                                            Ticks = 12516      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: blob
                                            Ticks = 12516      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: public
                                            Ticks = 12516      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: engine.io-parser
                                            Ticks = 12516      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: fs-extra
                                            Ticks = 12516      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: generator-assets
                                            Ticks = 12516      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: etc
                                            Ticks = 12516      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: css
                                            Ticks = 12516      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: dom
                                            Ticks = 12516      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: resources
                                            Ticks = 12516      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: glob
                                            Ticks = 12516      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: global
                                            Ticks = 12516      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: graceful-fs
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: has-binary
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: fixtures
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: has-cors
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: indexof
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: inflight
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: inherits
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: isarray
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: build
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: json3
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: coverage
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: lcov-report
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: lib
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: jsonfile
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: later
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: benchmark
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: constraint
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: core
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: example
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: src
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: array
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: compat
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: date
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: modifier
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: parse
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: test
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: lodash
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: chain
                                            Ticks = 12531      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: collection
                                            Ticks = 12547      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: date
                                            Ticks = 12547      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: function
                                            Ticks = 12547      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: internal
                                            Ticks = 12547      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: lang
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: math
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: number
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: object
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: string
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: utility
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: memory-stream
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: test
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: tests
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: minimatch
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: ms
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: object-component
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: once
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: options
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: lib
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: fixtures
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: os-tmpdir
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: parsejson
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: parseqs
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: parseuri
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: path-is-absolute
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: preview-common
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: q
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: readable-stream
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: rimraf
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: socket.io-client
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: socket.io-parser
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: bench
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: string_decoder
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: svgobjectmodelgenerator
                                            Ticks = 12562      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: jsx
                                            Ticks = 12578      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: tests
                                            Ticks = 12578      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: config
                                            Ticks = 12578      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: data
                                            Ticks = 12578      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: artboard-cropping
                                            Ticks = 12578      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: artboards-1
                                            Ticks = 12594      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: artboards-2
                                            Ticks = 12594      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: artboards-3
                                            Ticks = 12594      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: clipPath
                                            Ticks = 12594      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: cropping
                                            Ticks = 12594      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: custom
                                            Ticks = 12594      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: gradient
                                            Ticks = 12594      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: group-path
                                            Ticks = 12594      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: idGenerator
                                            Ticks = 12594      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: mask
                                            Ticks = 12594      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: paragraphTextAlign
                                            Ticks = 12594      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: pattern
                                            Ticks = 12594      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: pixelImage
                                            Ticks = 12594      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: radial-gradient-angle-global
                                            Ticks = 12594      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: responsive
                                            Ticks = 12594      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: shapes-with-external-fx
                                            Ticks = 12594      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: shapes-with-transform
                                            Ticks = 12594      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: stream
                                            Ticks = 12594      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: stroke-alignment
                                            Ticks = 12594      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: svgFill
                                            Ticks = 12594      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: svgGradientOverlay
                                            Ticks = 12609      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: text-on-path-2
                                            Ticks = 12609      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: text-with-transform
                                            Ticks = 12609      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: data-compare
                                            Ticks = 12609      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: paths
                                            Ticks = 12609      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: svgo
                                            Ticks = 12609      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: report
                                            Ticks = 12609      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: schema
                                            Ticks = 12609      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: visual
                                            Ticks = 12609      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: screenshots
                                            Ticks = 12609      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: tests
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: artboard-cropping
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: artboards-1
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: artboards-2
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: artboards-3
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: clipPath
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: group-path
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: idGenerator
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: mask
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: paragraphTextAlign
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: pattern
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: radial-gradient-angle-global
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: shapes-with-external-fx
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: shapes-with-transform
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: svgFill
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: svgGradientOverlay
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: text-on-path-2
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: text-with-transform
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: tmp
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: lib
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: test
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: symlinkme
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: to-array
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: utf8
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: coverage
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: utf8.js
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: tests
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: wrappy
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: ws
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: doc
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: fixtures
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: xmlhttprequest
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: example
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Digital Anarchy
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Flicker Free 1.1.3
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Flicker Free
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Instant HD
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Instant 4K
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Magic Bullet Denoiser
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Denoiser II
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Magic Bullet Frames
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Broadcast Spec
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Deartifacter
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Frames
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Frames Plus
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Letterboxer
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Opticals
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: Magic Bullet LUT Buddy
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen LUT Buddy
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: MB Mojo
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Mojo
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: MBCosmo
                                            Ticks = 12641      <4972> <ALOG> <5> EGG Splash Screen Cosmo
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: MBFilm
                                            Ticks = 12656      <4972> <FLT> <1> Potential oversize effect matchname found: Magic_Bullet_Suite_Magic_Bullet_Film, actual length: 40, matchname limit: 31
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Film
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Scanning Folder: MBLooks
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Looks
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up AEGP Driver
                                            Ticks = 12656      <4972> <ALOG> <5> AEGPDriver Birth AEGPDriver Birth
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Photoshop Layered Export
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Photoshop Layer Import
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Easy Ease
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Exponential Scale
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Sequence
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Time-Reverse Keyframes
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up CINEWARE LiveLink
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Advanced 3D
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up AEDynamicLinkServer
                                            Ticks = 12656      <4972> <ALOG> <5> DynamicLink Startup Main Entry Point, Creating Livelink Plugin
                                            Ticks = 12656      <4972> <ALOG> <5> DynamicLinkPlugin Startup Enter DynamicLink Plugin Constructor
                                            Ticks = 12656      <4972> <ALOG> <5> DynamicLinkPlugin Startup headless=0, dynamiclink=0, selflink=0, amelink=0
                                            Ticks = 12656      <4972> <ALOG> <5> DynamicLink Startup Registered Hooks
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Audio Palette
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Brush Tips Palette
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Character Palette
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Info Palette
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Paint Palette
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Paragraph Palette
                                            Ticks = 12656      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Ray-traced 3D
                                            Ticks = 12672      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Progress Palette
                                            Ticks = 12672      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up SnapCut
                                            Ticks = 12672      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Durer
                                            Ticks = 12672      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Time Palette
                                            Ticks = 12672      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Tool Palette
                                            Ticks = 12672      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Tracker Controls
                                            Ticks = 12672      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Work Queue Palette
                                            Ticks = 12672      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up MochaShapeConverter
                                            Ticks = 12672      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Anywhere
                                            Ticks = 12672      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up CEP Manager
                                            Ticks = 12781      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Localize Presets
                                            Ticks = 12781      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Renoir
                                            Ticks = 12781      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up OpenEXR
                                            Ticks = 12781      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up PNGIO Support
                                            Ticks = 12781      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up TIFFIO Support
                                            Ticks = 12781      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Premiere Pro Import
                                            Ticks = 12781      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Pro Import
                                            Ticks = 12797      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Align
                                            Ticks = 12797      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Audio Analyzer
                                            Ticks = 12797      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up MayaImport
                                            Ticks = 12797      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Media Browser
                                            Ticks = 12797      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Metadata Browser
                                            Ticks = 12797      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Motion Sketch
                                            Ticks = 12797      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up RPFImport
                                            Ticks = 12797      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up RQMonitor
                                            Ticks = 12797      <4972> <ALOG> <5> RQMonitorPlugin ctor created=41890fc0
                                            Ticks = 12797      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Scripting
                                            Ticks = 12812      <4972> <ALOG> <5> Scripting ScriptingPlugin::ScriptingPlugin APE initialization failed. Embedded flash panels in ExtendScript-generated UI will not work properly.
                                            Ticks = 12828      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up Smart Mask Interpolation
                                            Ticks = 12828      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up The Smoother
                                            Ticks = 12828      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up The Wiggler
                                            Ticks = 12828      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up CINEMA 4D
                                            Ticks = 12828      <4972> <ALOG> <5> EGG Splash Screen Cleaning Up CINEWARE SceneLayer
                                            Ticks = 12828      <4972> <ALOG> <5> AEGPDriver AEGPDp_CleanupHook Finished cleanup.
                                            Ticks = 12828      <4972> <ALOG> <5> EGG IEggApp Finished GP cleanup.
                                            Ticks = 12828      <4972> <ALOG> <5> EGG IEggApp Begin - Preset scan.
                                            Ticks = 12828      <4972> <ALOG> <5> EGG CFX Start Loading Presets
                                            Ticks = 13000      <4972> <ALOG> <5> EGG CFX Done Loading Presets
                                            Ticks = 13000      <4972> <ALOG> <5> EGG IEggApp End - Preset scan.
                                            Ticks = 13000      <4972> <ALOG> <5> EGG Splash Screen Initializing User Interface
                                            Ticks = 13000      <4972> <ALOG> <5> EGG IEggApp PreAllocate.
                                            Ticks = 13016      <4972> <ALOG> <5> BEE Command Do New Project
                                            Ticks = 13016      <4972> <ALOG> <5> BEE New Project Creating root folder
                                            Ticks = 13016      <10120> <ALOG> <5> BEE New Project Creating root folder
                                            Ticks = 13016      <4972> <ALOG> <5> EGG IEggApp SetupFilterMenu.
                                            Ticks = 13016      <4972> <ALOG> <5> EGG IEggApp SetupDynamicMenus
                                            Ticks = 13016      <4972> <ALOG> <5> EGG IEggApp Begin - PresetEffects.xml.
                                            Ticks = 13031      <4972> <ALOG> <5> EGG IEggApp End - PresetEffects.xml.
                                            Ticks = 13031      <4972> <ALOG> <5> EMUL SLOP UPDATE Mem Usage in MB: calc: 82.120921, measured: 563.625000, delta: 481.504079, delta pct: 85.429865, total slop: 423.427070
                                            Ticks = 13047      <4972> <ALOG> <5> EGG IEggApp Begin - CreateWindows.
                                            Ticks = 13047      <4972> <BEE_WorkQueue> <5> BEE_Project::TimestampGetNext ZANZIBAR-3: cannot produce timestamp, frozen=0, open=0
                                            Ticks = 13047      <4972> <ae.blitpipe> <2> HardwareBlitpipe Engaged
                                            Ticks = 13062      <4972> <BEE_WorkQueue> <5> BEE_Project::TimestampGetNext ZANZIBAR-3: cannot produce timestamp, frozen=0, open=0
                                            Ticks = 13062      <4972> <ae.blitpipe> <2> HardwareBlitpipe Engaged
                                            Ticks = 13109      <4972> <ae.blitpipe> <2> HardwareBlitpipe Engaged
                                            Ticks = 13109      <4972> <BEE_WorkQueue> <5> BEE_Project::TimestampGetNext ZANZIBAR-3: cannot produce timestamp, frozen=0, open=0
                                            Ticks = 13172      <4972> <BEE_WorkQueue> <5> BEE_Project::TimestampGetNext ZANZIBAR-3: cannot produce timestamp, frozen=0, open=0
                                            Ticks = 13187      <4972> <ALOG> <5> DynamicLinkPlugin ResumeApp
                                            Ticks = 13234      <4972> <ALOG> <5> EGG IEggApp End - CreateWindows.
                                            Ticks = 14781      <4972> <ALOG> <5> EGG IEggApp Done.
                                            Ticks = 15187      <4972> <ALOG> <5> BEE Command Close Project
                                            Ticks = 15187      <4972> <BEE_WorkQueue> <5> BEE_WorkQueue_PreCloseProject start
                                            Ticks = 15187      <4972> <BEE_WorkQueue> <5> BEE_WorkQueue_PreCloseProject end
                                            Ticks = 15187      <4972> <ALOG> <5> DynamicLinkPlugin ProjectClosed file=""
                                            Ticks = 15187      <4972> <ALOG> <5> BEE Command Do New Project
                                            Ticks = 15187      <4972> <ALOG> <5> BEE New Project Creating root folder
                                            Ticks = 15187      <10120> <ALOG> <5> BEE New Project Creating root folder
                                            Ticks = 15219      <4972> <ALOG> <5> BEE Command Do Load Project
                                            Ticks = 15219      <4972> <ALOG> <5> BEE Load Project Start H:\VIDEO\Projects\TV Commercials\Summer 2016 Bookend Concept.aep
                                            Ticks = 15219      <4972> <ALOG> <5> BEE New Project Creating root folder
                                            Ticks = 16062      <4972> <ALOG> <5> U U_Sev_WARNING After Effects warning: Grouped_Message_{This project contains references to missing effects. Please install the following effects to restore these references.|||This project contains a reference to a missing effect. Please install the following effect to restore this reference.###@0 missing effects.}“Optical Flares”
                                            Ticks = 16062      <4972> <ALOG> <5> U U_Sev_WARNING After Effects warning: Grouped_Message_{some layers have missing dependencies. Press Ctrl-C to copy this list.|||a layer has missing dependencies.###@0 dependencies are missing:}Text Layer: Font family: “Raleway”, Font style: “Regular”
                                            Ticks = 16062      <4972> <ALOG> <5> BEE Load Project End open untitled=FALSE
                                            Ticks = 16062      <10120> <ALOG> <5> BEE New Project Creating root folder
                                            Ticks = 16125      <10120> <DBSync> <5> BEE_ThreadedRenderUpdateQueue::Render_DeserializeFullProject ZANZIBAR-2: old=00000000-0000-0000-0000-000000000000, new=4e7db078-cb92-4e1a-b010-5ddb39fd4992, new-ts=22589
                                            Ticks = 16141      <4972> <BEE_WorkQueue> <5> BEE_Project::TimestampGetNext ZANZIBAR-3: cannot produce timestamp, frozen=0, open=0
                                            Ticks = 16203      <4972> <BEE_WorkQueue> <5> BEE_Project::TimestampGetNext ZANZIBAR-3: cannot produce timestamp, frozen=0, open=0
                                            Ticks = 16250      <4972> <BEE_WorkQueue> <5> BEE_Project::TimestampGetNext ZANZIBAR-3: cannot produce timestamp, frozen=0, open=0
                                            Ticks = 16484      <4972> <ALOG> <5> DynamicLinkPlugin ProjectOpened file="H:\VIDEO\Projects\TV Commercials\Summer 2016 Bookend Concept.aep"
                                            Ticks = 18031      <4972> <ALOG> <5> EMUL SLOP UPDATE Mem Usage in MB: calc: 593.410266, measured: 715.535156, delta: 122.124890, delta pct: 17.067630, total slop: 545.551960
                                            Ticks = 26703      <4972> <ALOG> <5> DynamicLinkPlugin SuspendApp
                                            Ticks = 45391      <4972> <ALOG> <5> DynamicLinkPlugin ResumeApp
                                            Ticks = 47578      <4972> <ALOG> <5> AudioRendererImpl Init starting up...
                                            Ticks = 47578      <4972> <ALOG> <5> VideoRendererImpl Init starting up...
                                            Ticks = 47578      <4972> <ALOG> <5> DynamicLinkPlugin UpdateProjectList supresscounter=0
                                            Ticks = 47641      <4972> <ALOG> <5> EGG ParseClipboard Begin - ParseClipboard.
                                            Ticks = 47641      <4972> <ALOG> <5> BEE Command Set Scrap
                                            Ticks = 47641      <4972> <ALOG> <5> EGG ParseClipboard End - ParseClipboard.
                                            Ticks = 47641      <10120> <ALOG> <5> BEE Command Set Scrap
                                            Ticks = 49891      <4972> <ALOG> <5> BEE Command Do Set Layer Switch
                                            Ticks = 49891      <10120> <ALOG> <5> BEE Command Do Set Layer Switch
                                            Ticks = 51937      <10120> <ImporterMPEG> <5> MSDK Decoder failed to open file H:\VIDEO\BROLL\Week 2\MVI_5126.MOV with status -3
                                            Ticks = 53031      <4972> <ALOG> <5> EMUL SLOP UPDATE Mem Usage in MB: calc: 962.969439, measured: 1422.832031, delta: 459.862593, delta pct: 32.320231, total slop: 1020.764460
                                            Ticks = 56781      <4972> <DynamicLink> <0> Failed to find hyper drive app id. Do you really want to be calling this?
                                            Ticks = 56781      <4972> <ALOG> <5> DynamicLinkPlugin Plugin::UpdateMenuHook windowtype=2
                                            Ticks = 56781      <4972> <ALOG> <5> DynamicLinkPlugin Plugin::UpdateMenuHook GetActiveItem, enabled!
                                            Ticks = 57469      <1396> <SyncService> <4> CheckConnection: 2
                                            Ticks = 57953      <4972> <ALOG> <5> DynamicLinkPlugin Plugin::UpdateMenuHook windowtype=2
                                            Ticks = 57953      <4972> <ALOG> <5> DynamicLinkPlugin Plugin::UpdateMenuHook GetActiveItem, enabled!
                                            Ticks = 57953      <4972> <ALOG> <5> EGG Command HelpRevealLoggingFile
                                            Ticks = 57953      <4972> <ALOG> <5> Picasso PSO_PurgeGPUHook() Handled: false
                                            Ticks = 58281      <4972> <ALOG> <5> DynamicLinkPlugin SuspendApp
                                            Ticks = 62484      <10120> <ALOG> <5> EMUL SLOP UPDATE Mem Usage in MB: calc: 1781.729283, measured: 1389.378906, delta: -392.350377, delta pct: -28.239264, total slop: 628.279134
                                            • 19. Re: After effects won't open, big white screen except one panel
                                              It looks like you have a white solid at the top of your comp. What happens if you delete the Flare layer?
                                              • 20. Re: After effects won't open, big white screen except one panel
                                                danl51353681 Level 1
                                                The flare layer is just an adjustment layer with a transparent flare. That said, I deleted it and nothing happened.
                                                • 21. Re: After effects won't open, big white screen except one panel
                                                  What happens if you create a brand new project, brand new composition, and a brand new red solid?
                                                  • 22. Re: After effects won't open, big white screen except one panel
                                                    I can't speak to the red solid, but I did create a new project/composition earlier today and it was the same thing. I'm not by my desktop right now so I won't be able to see what that does until tomorrow, but I'd guess that it wouldn't do anything.
                                                    • 23. Re: After effects won't open, big white screen except one panel
                                                      Alexandre Parenteau Adobe Employee
                                                      I can see only this failure in the log :
                                                      Could it be a codec problem? Is it the movie inside the comp?
                                                      • 24. Re: After effects won't open, big white screen except one panel
                                                        DigitalSoju Level 1
                                                        Highly doubtful it's a codec problem,
                                                        it's the motherboard, graphics card or the combination of the motherboard and graphics card problem in my opinion. Is there anyone here who has either the Maximus VII motherboard or Geforce GTX 970 that doesn't have this problem?
                                                        I have a similar problem with premiere pro, except I know how to fix it. The video area becomes white (not the panel) and the program doesn't shut down properly (it looks closed, but you have to close it through task manager).
                                                        • 25. Re: After effects won't open, big white screen except one panel
                                                          I deleted the movies and that didn't do anything. I also created a new project, comp and red solid and it's still a white blank screen.
                                                          DigitalSoju I just realized I have the Maximus VIII (8) not VII (7). Either way they're most likely basically the same motherboard and upsetting that it's causing AE to not run.
                                                          • 26. Re: After effects won't open, big white screen except one panel
                                                            UPDATE: I just updated my Geforce graphics driver and now everything works! I hope you can figure yours out man. Good luck.
                                                            • 27. Re: After effects won't open, big white screen except one panel
                                                              DigitalSoju Level 1
                                                              First, I do have the Maximus VIII, just miswrote it.
                                                              Second, I've done several updates to my graphics card and it's still there with a big white panel. I tried updating to After Effects CC 2015.3 and the problem hasn't gone away. Really frustrating.Premiere 2015.3.png
                                                              • 28. Re: After effects won't open, big white screen except one panel
        Yeah, so when I updated my AE to CC 2015.3, my Premiere Pro started acting up and freezing after scrubbing through the timeline. I tried everything, but found a fix and now both AE and Premiere are working.
        Try downloading a pre-368 graphics driver from nvidia. Right now I'm running 365.19 and everything is working. Let me know if that works.
        • 29. Re: After effects won't open, big white screen except one panel
        DigitalSoju Level 1
        My premiere became really slow during playback and it was a pain to edit. The annoying thing is once you start editing in 2015.3, you can no longer open that file in a previous version which is just ridiculous and short sited by adobe.
        I've already had a pre 368 graphics driver on the previous update and there were already white panels. The odd thing too is now after effects doesn't shut down properly, I always have to kill it in task manager after closing the program (this used to only happen to premiere). Really frustrating experience because this mobo and graphics card should be getting really good performance, instead we're left with 2 barely functioning programs.
        • 30. Re: After effects won't open, big white screen except one panel
        DigitalSoju Level 1
        I have no idea how I did it, but somehow I got the white panel to not appear while opening the program. I'm not sure if this is what fixed it, but after reading several other threads about white screens, someone said they changed their scratch disk to not be C drive.
        No idea why this would fix it, but I changed my scratch disk location and exited After Effects 2015.3. I tried to open it again but it wouldn't, so had to kill it via the task manager. Then opened it again and to my surprise it was gone. I hope it stays gone.
