1 Reply Latest reply on Apr 20, 2006 12:22 PM by Newsgroup_User
    Stop command
    swh0221
      I am new to flash and I am needing some help. I am creating a short frame that will have buttons across the bottom and when you click on them a quote will pop-up. How do I set it up so that it stops on frame 1 and doesn't go on until you select a button.
        • 1. Re: Stop command
          Level 7
          swh0221,
          Okay.
          Create a layer called "scripts" (or some other name that indicates to
          you, "This is where my ActionScript goes"). The new layer will
          automatically have a keyframe in frame 1. Click inside this keyframe and
          open the Actions panel (Window > Actions).
          Type ...
          stop();
          David
          stiller (at) quip (dot) net
          Dev essays: http://www.quip.net/blog/
          "Luck is the residue of good design."
