14 Replies Latest reply on Jul 28, 2016 5:54 AM by fernandezh34561706
    Android compilation with Crosswalk is currently broken
    UncatCrea
      It appears that Android compilation with Crosswalk is currently broken. I get the following error when having <plugin name="cordova-plugin-crosswalk-webview" source="npm" /> in my config.xml:
      COMPILE OUTPUT
      Build option --'' not recognized (ignoring).
      Running: /project/gradlew cdvBuildDebug -b /project/build.gradle -Dorg.gradle.daemon=true -PcdvBuildMultipleApks=false
      null
      embedded
      FAILURE: Build failed with an exception.
      * Where:
      Script '/project/cordova-plugin-crosswalk-webview/q_android-xwalk.gradle' line: 77
      * What went wrong:
      A problem occurred evaluating script.
      > Could not find property 'xwalkMultipleApk' on root project 'project'.
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      It's a blocker for me. Thank you in advance :-\
        • 1. Re: Android compilation with Crosswalk is currently broken
          martinb77004568 Level 2
          How about using
          <gap:plugin name='org.crosswalk.engine' version='1.3.0' source='pgb' />
          It is a pretty old version but should work (@PGB team: Many of us need crosswalk - why is there no official update?).
          • 2. Re: Android compilation with Crosswalk is currently broken
            UncatCrea Level 1
            Thank you. I've been able to compile with the spec attribute set to 1.5.0 (I use npm as source).
            • 3. Re: Android compilation with Crosswalk is currently broken
              UncatCrea Level 1
              Hi. I've done some tests and it appears that compilation with any CrossWalk version superior to 1.5.0 still won't work. Is there a plan to support latest CrossWalk versions on PGB? Thank you in advance
              • 4. Re: Android compilation with Crosswalk is currently broken
                What do you mean by "still won't work"? Are you getting the same error messages again or a different one?
                I have managed to use a later version of crosswalk using the following settings. Please note that I haven't tested this in a while but it worked 2 months ago :-) Maybe you will need to do some minor changes but I think we will get this working...
                <plugin name="cordova-plugin-crosswalk-webview" source="npm" version="1.7.0" />
                <preference name="xwalkMultipleApk" value="true" />
                <plugin name="cordova-build-architecture" spec="https://github.com/MBuchalik/cordova-build-architecture.git#v1.0.1" source="git" />
                <preference name="android-versionCode" value="1" />
                • 5. Re: Android compilation with Crosswalk is currently broken
                  UncatCrea Level 1
                  Thank you for your answer. I've done a test modifying my config.xml with the elements you gave. Unfortunatly, it has failed. It gave the following error:
                  * Where:
                  Script '/project/cordova-plugin-crosswalk-webview/q_plus_android-xwalk.gradle' line: 73
                  * What went wrong:
                  * Try:
                  BUILD FAILED
                  • 6. Re: Android compilation with Crosswalk is currently broken
                    I have tried it again and it works for me (have only tested it without signing).
                    Does this error still occur if you remove all unnecessary plugins and settings? Could you maybe post your new config.xml here (without personal data :-) ?
                    What version of PGB are you using? I have tried it with:
                    <preference name='phonegap-version' value='cli-6.0.0' />
                    <preference name="android-build-tool" value="gradle" />
                    • 7. Re: Android compilation with Crosswalk is currently broken
                      UncatCrea Level 1
                      Sure. Here's the config.xml file I use for my tests.
                      <?xml version="1.0" encoding="UTF-8" ?>
                      <widget xmlns       = "http://www.w3.org/ns/widgets"
                              xmlns:gap   = "http://phonegap.com/ns/1.0"
                              id          = "com.uncatcrea.q-plus-android"
                              version     = "1.0.0"
                              android-versionCode = "14" >
                        <name>Q+ Test App (Android)</name>
                        <description>Q+ Test App (Android) - Compiled by Benjamin</description>
                        <author href="http://uncatcrea.com" email="uncategorized.creations@gmail.com">Uncatcrea</author>
                        <gap:platform name="android" />
                        <preference name="permissions" value="none"/>
                        <preference name="disallowOverscroll" value="true" />
                        <preference name="webviewbounce" value="false" />
                        <!-- PhoneGap plugin declaration -->
                        <plugin name="cordova-plugin-inappbrowser" source="npm" />
                        <plugin name="cordova-plugin-network-information" source="npm" />
                        <plugin name="cordova-plugin-whitelist" source="npm" />
                        <plugin name="cordova-plugin-splashscreen" source="npm" />
                        <plugin name="cordova-plugin-device" source="npm" />
                        <plugin name="cordova-plugin-statusbar" source="npm" />
                        <plugin name="cordova-plugin-x-socialsharing" spec="5.0.12" source="npm" />
                        <!-- Whitelist policy  -->
                        <access origin="*" />
                        <allow-intent href="*" />
                        <allow-navigation href="*" />
                        <!-- SplashScreen configuration -->
                        <preference name="SplashScreen" value="splash" />
                        <preference name="SplashScreenDelay" value="10000" />
                        <preference name="FadeSplashScreenDuration" value="300" />
                        <preference name="ShowSplashScreenSpinner" value="false" />
                        <!-- Icons and Splashscreens declaration -->
                        <icon src="icon.png" gap:platform="android" />
                        <icon src="icons/icon-wp-appkit-ldpi.png" gap:platform="android" gap:qualifier="ldpi" />
                        <icon src="icons/icon-wp-appkit-mdpi.png" gap:platform="android" gap:qualifier="mdpi" />
                        <icon src="icons/icon-wp-appkit-hdpi.png" gap:platform="android" gap:qualifier="hdpi" />
                        <icon src="icons/icon-wp-appkit-xhdpi.png" gap:platform="android" gap:qualifier="xhdpi" />
                        <icon src="icons/icon-wp-appkit-xxhdpi.png" gap:platform="android" gap:qualifier="xxhdpi" />
                        <icon src="icons/icon-wp-appkit-xxxhdpi.png" gap:platform="android" gap:qualifier="xxxhdpi" />
                        <gap:splash src="splash.9.png" gap:platform="android" />
                        <gap:splash src="splashscreens/splashscreen-wp-appkit-ldpi.9.png" gap:platform="android" gap:qualifier="ldpi" />
                        <gap:splash src="splashscreens/splashscreen-wp-appkit-mdpi.9.png" gap:platform="android" gap:qualifier="mdpi" />
                        <gap:splash src="splashscreens/splashscreen-wp-appkit-hdpi.9.png" gap:platform="android" gap:qualifier="hdpi" />
                        <gap:splash src="splashscreens/splashscreen-wp-appkit-xhdpi.9.png" gap:platform="android" gap:qualifier="xhdpi" />
                        <gap:splash src="splashscreens/splashscreen-wp-appkit-xxhdpi.9.png" gap:platform="android" gap:qualifier="xxhdpi" />
                        <gap:splash src="splashscreens/splashscreen-wp-appkit-xxxhdpi.9.png" gap:platform="android" gap:qualifier="xxxhdpi" />
                          <!-- Testing CrossWalk -->
                      </widget>
                      • 8. Re: Android compilation with Crosswalk is currently broken
                        VectorP Level 4
                        You can't have
                        as an attribute of the widget root.
                        In Phonegap Build, it's specified as a preference.
                        • 9. Re: Android compilation with Crosswalk is currently broken
                          UncatCrea Level 1
                          OK. I have deleted the android-versionCode attribute to android-versionCode preference and I got the same error.
                          • 10. Re: Android compilation with Crosswalk is currently broken
                            You can actually set the android versionCode attribute in the widget root. It's simply called "versionCode". But remember that, on PGB, the versionCode is slightly modified (I think an "8" is added to your number).
                            Please try to compile with sth like cli-6.0.0 like in my post above:
                            Does that help?
                            • 11. Re: Android compilation with Crosswalk is currently broken
                              UncatCrea Level 1
                              Unfortunatly no. I've added the following to my config.xml:
                              `<plugin name="cordova-plugin-crosswalk-webview" source="npm" version="1.7.0" />
                              <preference name='phonegap-version' value='cli-6.0.0' />`
                              Compilation still craches (below output).
                              I am going to retry your original answer later
                              null
                              Failed to notify ProjectEvaluationListener.afterEvaluate(), but primary configuration failure takes precedence.
                              java.lang.IllegalStateException: buildToolsVersion is not specified.
                                at com.google.common.base.Preconditions.checkState(Preconditions.java:176)
                                at com.android.build.gradle.BasePlugin.createAndroidTasks(BasePlugin.java:599)
                                at com.android.build.gradle.BasePlugin$10$1.call(BasePlugin.java:566)
                                at com.android.build.gradle.BasePlugin$10$1.call(BasePlugin.java:563)
                                at com.android.builder.profile.ThreadRecorder$1.record(ThreadRecorder.java:55)
                                at com.android.builder.profile.ThreadRecorder$1.record(ThreadRecorder.java:47)
                                at com.android.build.gradle.BasePlugin$10.execute(BasePlugin.java:562)
                                at com.android.build.gradle.BasePlugin$10.execute(BasePlugin.java:559)
                                at org.gradle.listener.BroadcastDispatch$ActionInvocationHandler.dispatch(BroadcastDispatch. java:109)
                                at org.gradle.listener.BroadcastDispatch$ActionInvocationHandler.dispatch(BroadcastDispatch. java:98)
                                at org.gradle.listener.BroadcastDispatch.dispatch(BroadcastDispatch.java:83)
                                at org.gradle.listener.BroadcastDispatch.dispatch(BroadcastDispatch.java:31)
                                at org.gradle.messaging.dispatch.ProxyDispatchAdapter$DispatchingInvocationHandler.invoke(Pr oxyDispatchAdapter.java:93)
                                at com.sun.proxy.$Proxy13.afterEvaluate(Unknown Source)
                                at org.gradle.configuration.project.LifecycleProjectEvaluator.notifyAfterEvaluate(LifecycleP rojectEvaluator.java:79)
                                at org.gradle.configuration.project.LifecycleProjectEvaluator.evaluate(LifecycleProjectEvalu ator.java:65)
                                at org.gradle.api.internal.project.AbstractProject.evaluate(AbstractProject.java:504)
                                at org.gradle.api.internal.project.AbstractProject.evaluate(AbstractProject.java:83)
                                at org.gradle.execution.TaskPathProjectEvaluator.configureHierarchy(TaskPathProjectEvaluator .java:42)
                                at org.gradle.configuration.DefaultBuildConfigurer.configure(DefaultBuildConfigurer.java:35)
                                at org.gradle.initialization.DefaultGradleLauncher.doBuildStages(DefaultGradleLauncher.java: 129)
                                at org.gradle.initialization.DefaultGradleLauncher.doBuild(DefaultGradleLauncher.java:106)
                                at org.gradle.initialization.DefaultGradleLauncher.run(DefaultGradleLauncher.java:86)
                                at org.gradle.launcher.exec.InProcessBuildActionExecuter$DefaultBuildController.run(InProces sBuildActionExecuter.java:80)
                                at org.gradle.launcher.cli.ExecuteBuildAction.run(ExecuteBuildAction.java:33)
                                at org.gradle.launcher.cli.ExecuteBuildAction.run(ExecuteBuildAction.java:24)
                                at org.gradle.launcher.exec.InProcessBuildActionExecuter.execute(InProcessBuildActionExecute r.java:36)
                                at org.gradle.launcher.exec.InProcessBuildActionExecuter.execute(InProcessBuildActionExecute r.java:26)
                                at org.gradle.launcher.daemon.server.exec.ExecuteBuild.doBuild(ExecuteBuild.java:47)
                                at org.gradle.launcher.daemon.server.exec.BuildCommandOnly.execute(BuildCommandOnly.java:34)
                                at org.gradle.launcher.daemon.server.exec.DaemonCommandExecution.proceed(DaemonCommandExecut ion.java:119)
                                at org.gradle.launcher.daemon.server.exec.WatchForDisconnection.execute(WatchForDisconnectio n.java:35)
                                at org.gradle.launcher.daemon.server.exec.ResetDeprecationLogger.execute(ResetDeprecationLog ger.java:24)
                                at org.gradle.launcher.daemon.server.exec.StartStopIfBuildAndStop.execute(StartStopIfBuildAn dStop.java:33)
                                at org.gradle.launcher.daemon.server.exec.ForwardClientInput$2.call(ForwardClientInput.java: 71)
                                at org.gradle.launcher.daemon.server.exec.ForwardClientInput$2.call(ForwardClientInput.java: 69)
                                at org.gradle.util.Swapper.swap(Swapper.java:38)
                                at org.gradle.launcher.daemon.server.exec.ForwardClientInput.execute(ForwardClientInput.java :69)
                                at org.gradle.launcher.daemon.server.exec.LogToClient.doBuild(LogToClient.java:60)
                                at org.gradle.launcher.daemon.server.exec.EstablishBuildEnvironment.doBuild(EstablishBuildEn vironment.java:70)
                                at org.gradle.launcher.daemon.server.exec.DaemonHygieneAction.execute(DaemonHygieneAction.ja va:39)
                                at org.gradle.launcher.daemon.server.exec.StartBuildOrRespondWithBusy$1.run(StartBuildOrResp ondWithBusy.java:46)
                                at org.gradle.launcher.daemon.server.DaemonStateCoordinator$1.run(DaemonStateCoordinator.jav a:246)
                                at org.gradle.internal.concurrent.DefaultExecutorFactory$StoppableExecutorImpl$1.run(Default ExecutorFactory.java:64)
                                at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
                                at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
                                at java.lang.Thread.run(Thread.java:745)
                              * Where:
                              * What went wrong:
                              * Try:
                              BUILD FAILED`
                              • 12. Re: Android compilation with Crosswalk is currently broken
                                You will need to add everything we discussed before.
                                So:
                                For some reason, you need to add android-versionCode. Otherwise, the app won't compile.
                                If you want to output the ARM version only, add
                                The first preferece tells crosswalk to output multiple APKs (one for ARM and one for x86). Since you can only download one single file on PGB, you need some way to specify what you want. By default, PGB outputs the ARM version if your app is not signed. If you sign it, it outputs the x86 version. Don't ask why - I have no idea.
                                That's the reason why I wrote the (experimental - it seems to work at the moment) plugin you find on GitHub. It allows you to force gradle to build the x86 or ARM version.
                                • 13. Re: Android compilation with Crosswalk is currently broken
                                  UncatCrea Level 1
                                  Beautiful! I've just did a successful compilation with Crosswalk 1.7.0 using phonegap-version and android-versionCode preferences. Thank you very much martinb77004568 :-)
                                  I am not sure to get it properly about ARM and x86 builds but I am going to search a little bit about that too.
                                  Again, thank you.
                                  • 14. Re: Android compilation with Crosswalk is currently broken
                                    fernandezh34561706 Level 1
                                    One of your plugins required the gradle android build tool to build.
                                    I have added the  <preference name="android-build-tool" value="gradle" /> and phonegap version in cli5.2.0
                                    Still unable to build the app
                                    Can some one please help.
