5 Replies Latest reply on Mar 16, 2016 5:52 AM by u561910
    Hello all, I am trying to upgrade flash player using the MSI but am getting error 2727. The directory entry Flash does not exist in the directory table. The applications previous install was done using SCCM with and MSI and MST. Now even a manual install
    u561910
      Hello all, I am trying to upgrade flash player using the MSI but am getting error 2727. The directory entry Flash does not exist in the directory table. The applications previous install was done using SCCM with and MSI and MST. Now even a manual install gives off the same error. The exe works though
        • 1. Re: Hello all, I am trying to upgrade flash player using the MSI but am getting error 2727. The directory entry Flash does not exist in the directory table. The applications previous install was done using SCCM with and MSI and MST. Now even a manual inst
          maria__ Adobe Employee
          Please upload a verbose MSI install log file from an impacted system to cloud.acrobat.com using the instructions at The specified item was not found. or some other file sharing service of your choice that doesn't require log-in access.  Post the link to the uploaded files in your reply.
          Is this an upgrade from a previous version to 21.0.0.182, or did you uninstall first and then attempt to install 21.0.0.182?
          Thank you.
          Maria
          • 2. Re: Hello all, I am trying to upgrade flash player using the MSI but am getting error 2727. The directory entry Flash does not exist in the directory table. The applications previous install was done using SCCM with and MSI and MST. Now even a manual inst
            u561910 Level 1
            unfortunately the cloud.acrobat.com site is down. But I do have a log file below.
            === Verbose logging started: 3/15/2016  7:37:33  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\WINDOWS\system32\msiexec.exe ===
            MSI (c) (34:90) [07:37:33:942]: Font created.  Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
            MSI (c) (34:CC) [07:37:33:951]: Resetting cached policy values
            MSI (c) (34:CC) [07:37:33:951]: Machine policy value 'Debug' is 0
            MSI (c) (34:CC) [07:37:33:951]: ******* RunEngine:
                       ******* Product: C:\Users\jryan\Desktop\Flash 21\activex\install_flash_player_21_active_x.msi
                       ******* Action:
                       ******* CommandLine: **********
            MSI (c) (34:CC) [07:37:33:955]: Machine policy value 'DisableUserInstalls' is 0
            MSI (c) (34:CC) [07:37:33:959]: User policy value 'SearchOrder' is 'nmu'
            MSI (c) (34:CC) [07:37:33:959]: User policy value 'DisableMedia' is 0
            MSI (c) (34:CC) [07:37:33:959]: Machine policy value 'AllowLockdownMedia' is 0
            MSI (c) (34:CC) [07:37:33:959]: SOURCEMGMT: Media enabled only if package is safe.
            MSI (c) (34:CC) [07:37:33:959]: SOURCEMGMT: Looking for sourcelist for product {92C34178-B679-4C83-AC33-7EFCE6D36E01}
            MSI (c) (34:CC) [07:37:33:959]: SOURCEMGMT: Adding {92C34178-B679-4C83-AC33-7EFCE6D36E01}; to potential sourcelist list (pcode;disk;relpath).
            MSI (c) (34:CC) [07:37:33:959]: SOURCEMGMT: Now checking product {92C34178-B679-4C83-AC33-7EFCE6D36E01}
            MSI (c) (34:CC) [07:37:33:959]: SOURCEMGMT: Media is enabled for product.
            MSI (c) (34:CC) [07:37:33:959]: SOURCEMGMT: Attempting to use LastUsedSource from source list.
            MSI (c) (34:CC) [07:37:33:959]: SOURCEMGMT: Trying source C:\WINDOWS\ccmcache\5b\.
            MSI (c) (34:CC) [07:37:34:036]: Cloaking enabled.
            MSI (c) (34:CC) [07:37:34:036]: Attempting to enable all disabled privileges before calling Install on Server
            MSI (c) (34:CC) [07:37:34:037]: Connected to service.
            MSI (c) (34:CC) [07:37:34:038]: SOURCEMGMT: Resolved source to: 'C:\WINDOWS\ccmcache\5b\'
            MSI (c) (34:CC) [07:37:34:039]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\jryan\Desktop\Flash 21\activex\install_flash_player_21_active_x.msi' against software restriction policy
            MSI (c) (34:CC) [07:37:34:039]: SOFTWARE RESTRICTION POLICY: C:\Users\jryan\Desktop\Flash 21\activex\install_flash_player_21_active_x.msi has a digital signature
            MSI (c) (34:CC) [07:37:34:149]: SOFTWARE RESTRICTION POLICY: C:\Users\jryan\Desktop\Flash 21\activex\install_flash_player_21_active_x.msi is permitted to run at the 'unrestricted' authorization level.
            MSI (c) (34:CC) [07:37:34:149]: Cloaking enabled.
            MSI (c) (34:CC) [07:37:34:149]: Attempting to enable all disabled privileges before calling Install on Server
            MSI (c) (34:CC) [07:37:34:149]: End dialog not enabled
            MSI (c) (34:CC) [07:37:34:149]: Original package ==> C:\WINDOWS\ccmcache\5b\install_flash_player_21_active_x.msi
            MSI (c) (34:CC) [07:37:34:149]: Package we're running from ==> C:\WINDOWS\ccmcache\5b\install_flash_player_21_active_x.msi
            MSI (c) (34:CC) [07:37:34:150]: APPCOMPAT: looking for appcompat database entry with ProductCode '{92C34178-B679-4C83-AC33-7EFCE6D36E01}'.
            MSI (c) (34:CC) [07:37:34:151]: APPCOMPAT: no matching ProductCode found in database.
            MSI (c) (34:CC) [07:37:34:158]: MSCOREE not loaded loading copy from system32
            MSI (c) (34:CC) [07:37:34:160]: Note: 1: 2205 2:  3: MsiFileHash
            MSI (c) (34:CC) [07:37:34:160]: Machine policy value 'DisablePatch' is 0
            MSI (c) (34:CC) [07:37:34:160]: Machine policy value 'AllowLockdownPatch' is 0
            MSI (c) (34:CC) [07:37:34:160]: Machine policy value 'DisableLUAPatching' is 0
            MSI (c) (34:CC) [07:37:34:160]: Machine policy value 'DisableFlyWeightPatching' is 0
            MSI (c) (34:CC) [07:37:34:160]: Looking for file transform: C:\WINDOWS\Installer\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\active.mst
            MSI (c) (34:CC) [07:37:34:160]: Original transform ==> C:\WINDOWS\Installer\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\active.mst
            MSI (c) (34:CC) [07:37:34:160]: Transform we're running from ==> C:\WINDOWS\Installer\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\active.mst
            MSI (c) (34:CC) [07:37:34:161]: SOFTWARE RESTRICTION POLICY: Verifying transform --> 'C:\WINDOWS\Installer\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\active.mst' against software restriction policy
            MSI (c) (34:CC) [07:37:34:161]: Note: 1: 2262 2:  DigitalSignature 3: -2147287038
            MSI (c) (34:CC) [07:37:34:161]: SOFTWARE RESTRICTION POLICY: C:\WINDOWS\Installer\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\active.mst is not digitally signed
            MSI (c) (34:CC) [07:37:34:162]: SOFTWARE RESTRICTION POLICY: C:\WINDOWS\Installer\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\active.mst is permitted to run at the 'unrestricted' authorization level.
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: Patch 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2205 2:  3: PatchPackage
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: _Tables 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: _Columns 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: TRANSFORM: 'PatchPackage' table is missing or empty.  No pre-transform fixup necessary.
            MSI (c) (34:CC) [07:37:34:162]: TRANSFORM: Applying regular transform to database.
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: ActionText 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: AdminExecuteSequence 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: AdminUISequence 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: AdvtExecuteSequence 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: AdvtUISequence 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: AppSearch 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: Feature 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: Binary 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: CheckBox 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: Icon 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: ComboBox 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: Directory 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: Control 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: Dialog 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: ControlCondition 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: ControlEvent 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: CreateFolder 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: Error 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: EventMapping 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: InstallExecuteSequence 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: InstallUISequence 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: LaunchCondition 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: ListBox 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: ListView 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: RadioButton 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: RegLocator 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: Signature 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: TextStyle 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: UIText 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: Upgrade 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: _Validation 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: ISComponentExtended 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: ISCustomActionReference 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: ISSetupFile 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: _MsiPatchTransformView 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: #_BaselineCost 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: #_BaselineFile 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: #_BaselineData 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: #_PatchCache 3: -2147287038
            MSI (c) (34:CC) [07:37:34:162]: APPCOMPAT: looking for appcompat database entry with ProductCode '{92C34178-B679-4C83-AC33-7EFCE6D36E01}'.
            MSI (c) (34:CC) [07:37:34:162]: APPCOMPAT: no matching ProductCode found in database.
            MSI (c) (34:CC) [07:37:34:162]: Transforms are not secure.
            MSI (c) (34:CC) [07:37:34:163]: Transforming table Property.
            MSI (c) (34:CC) [07:37:34:163]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\jryan\Desktop\Flash 21\activex\msi.txt'.
            MSI (c) (34:CC) [07:37:34:163]: Command Line: CURRENTDIRECTORY=C:\WINDOWS\system32 CLIENTUILEVEL=0 CLIENTPROCESSID=31796
            MSI (c) (34:CC) [07:37:34:163]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{68B30DE0-0B6D-4EB9-BFC0-D3DC88FF7A37}'.
            MSI (c) (34:CC) [07:37:34:163]: PROPERTY CHANGE: Adding TRANSFORMS property. Its value is 'C:\WINDOWS\Installer\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\active.mst'.
            MSI (c) (34:CC) [07:37:34:163]: Product Code passed to Engine.Initialize:           '{92C34178-B679-4C83-AC33-7EFCE6D36E01}'
            MSI (c) (34:CC) [07:37:34:163]: Product Code from property table before transforms: '{92C34178-B679-4C83-AC33-7EFCE6D36E01}'
            MSI (c) (34:CC) [07:37:34:163]: Product Code from property table after transforms:  '{92C34178-B679-4C83-AC33-7EFCE6D36E01}'
            MSI (c) (34:CC) [07:37:34:163]: Product not registered: beginning first-time install
            MSI (c) (34:CC) [07:37:34:163]: Determined that existing product (either this product or the product being upgraded with a patch) is installed per-machine.
            MSI (c) (34:CC) [07:37:34:163]: PROPERTY CHANGE: Adding ProductState property. Its value is '1'.
            MSI (c) (34:CC) [07:37:34:163]: Entering CMsiConfigurationManager::SetLastUsedSource.
            MSI (c) (34:CC) [07:37:34:163]: Specifed source is already in a list.
            MSI (c) (34:CC) [07:37:34:163]: User policy value 'SearchOrder' is 'nmu'
            MSI (c) (34:CC) [07:37:34:163]: Machine policy value 'DisableBrowse' is 0
            MSI (c) (34:CC) [07:37:34:163]: Machine policy value 'AllowLockdownBrowse' is 0
            MSI (c) (34:CC) [07:37:34:163]: Adding new sources is allowed.
            MSI (c) (34:CC) [07:37:34:163]: Package name retrieved from configuration data: 'install_flash_player_21_active_x.msi'
            MSI (c) (34:CC) [07:37:34:164]: Note: 1: 2262 2: AdminProperties 3: -2147287038
            MSI (c) (34:CC) [07:37:34:164]: Machine policy value 'DisableMsi' is 0
            MSI (c) (34:CC) [07:37:34:164]: Machine policy value 'AlwaysInstallElevated' is 0
            MSI (c) (34:CC) [07:37:34:164]: User policy value 'AlwaysInstallElevated' is 0
            MSI (c) (34:CC) [07:37:34:164]: Product {92C34178-B679-4C83-AC33-7EFCE6D36E01} is admin assigned: LocalSystem owns the publish key.
            MSI (c) (34:CC) [07:37:34:164]: Product {92C34178-B679-4C83-AC33-7EFCE6D36E01} is managed.
            MSI (c) (34:CC) [07:37:34:164]: Running product '{92C34178-B679-4C83-AC33-7EFCE6D36E01}' with elevated privileges: Product is assigned.
            MSI (c) (34:CC) [07:37:34:164]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\WINDOWS\system32'.
            MSI (c) (34:CC) [07:37:34:164]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
            MSI (c) (34:CC) [07:37:34:164]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '31796'.
            MSI (c) (34:CC) [07:37:34:164]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
            MSI (c) (34:CC) [07:37:34:164]: TRANSFORMS property is now: C:\WINDOWS\Installer\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\active.mst
            MSI (c) (34:CC) [07:37:34:164]: PROPERTY CHANGE: Adding PRODUCTLANGUAGE property. Its value is '1033'.
            MSI (c) (34:CC) [07:37:34:164]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '110'.
            MSI (c) (34:CC) [07:37:34:164]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\AppData\Roaming
            MSI (c) (34:CC) [07:37:34:164]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\Favorites
            MSI (c) (34:CC) [07:37:34:165]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts
            MSI (c) (34:CC) [07:37:34:165]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\Documents
            MSI (c) (34:CC) [07:37:34:165]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
            MSI (c) (34:CC) [07:37:34:165]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\Recent
            MSI (c) (34:CC) [07:37:34:165]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\SendTo
            MSI (c) (34:CC) [07:37:34:165]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\Templates
            MSI (c) (34:CC) [07:37:34:165]: SHELL32::SHGetFolderPath returned: C:\ProgramData
            MSI (c) (34:CC) [07:37:34:166]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\AppData\Local
            MSI (c) (34:CC) [07:37:34:166]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\Pictures
            MSI (c) (34:CC) [07:37:34:166]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
            MSI (c) (34:CC) [07:37:34:166]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
            MSI (c) (34:CC) [07:37:34:166]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
            MSI (c) (34:CC) [07:37:34:167]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
            MSI (c) (34:CC) [07:37:34:167]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
            MSI (c) (34:CC) [07:37:34:167]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\Desktop
            MSI (c) (34:CC) [07:37:34:168]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
            MSI (c) (34:CC) [07:37:34:168]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\Fonts
            MSI (c) (34:CC) [07:37:34:168]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
            MSI (c) (34:CC) [07:37:34:172]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
            MSI (c) (34:CC) [07:37:34:172]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
            MSI (c) (34:CC) [07:37:34:172]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
            MSI (c) (34:CC) [07:37:34:172]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
            MSI (c) (34:CC) [07:37:34:172]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
            MSI (c) (34:CC) [07:37:34:172]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Fortress Investment Group'.
            MSI (c) (34:CC) [07:37:34:172]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Fortress Investment Group'.
            MSI (c) (34:CC) [07:37:34:172]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\WINDOWS\ccmcache\5b\install_flash_player_21_active_x.msi'.
            MSI (c) (34:CC) [07:37:34:172]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\WINDOWS\ccmcache\5b\install_flash_player_21_active_x.msi'.
            MSI (c) (34:CC) [07:37:34:172]: Machine policy value 'MsiDisableEmbeddedUI' is 0
            MSI (c) (34:CC) [07:37:34:172]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\WINDOWS\ccmcache\5b\'.
            MSI (c) (34:CC) [07:37:34:172]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\WINDOWS\ccmcache\5b\'.
            MSI (c) (34:90) [07:37:34:172]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
            === Logging started: 3/15/2016  7:37:34 ===
            MSI (c) (34:CC) [07:37:34:176]: Note: 1: 2205 2:  3: PatchPackage
            MSI (c) (34:CC) [07:37:34:176]: Machine policy value 'DisableRollback' is 0
            MSI (c) (34:CC) [07:37:34:176]: User policy value 'DisableRollback' is 0
            MSI (c) (34:CC) [07:37:34:176]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
            MSI (c) (34:CC) [07:37:34:176]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
            MSI (c) (34:CC) [07:37:34:176]: Doing action: INSTALL
            Action 7:37:34: INSTALL.
            Action start 7:37:34: INSTALL.
            MSI (c) (34:CC) [07:37:34:176]: UI Sequence table 'InstallUISequence' is present and populated.
            MSI (c) (34:CC) [07:37:34:176]: Running UISequence
            MSI (c) (34:CC) [07:37:34:176]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
            MSI (c) (34:CC) [07:37:34:177]: Doing action: ISSetupFilesExtract
            Action 7:37:34: ISSetupFilesExtract.
            Action start 7:37:34: ISSetupFilesExtract.
            MSI (c) (34:CC) [07:37:34:177]: Transforming table CustomAction.
            MSI (c) (34:90) [07:37:34:179]: Invoking remote custom action. DLL: C:\Users\JRYAN-~1\AppData\Local\Temp\MSI3BAE.tmp, Entrypoint: SFStartupEx
            MSI (c) (34:80) [07:37:34:180]: Cloaking enabled.
            MSI (c) (34:80) [07:37:34:180]: Attempting to enable all disabled privileges before calling Install on Server
            MSI (c) (34:80) [07:37:34:180]: Connected to service for CA interface.
            1: Starting to extract setup files
            1: Getting SUPPORTDIR property :
            1: Extracting SetupFiles to:  C:\Users\JRYAN-~1\AppData\Local\Temp\{92C34178-B679-4C83-AC33-7EFCE6D36E01}
            1: Getting ISSetupFile table view
            1: Executing ISSetupFile table view
            1: Extracting Setup File:
            1: C:\Users\JRYAN-~1\AppData\Local\Temp\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\IsIllegalUpgr ade.vbs
            1: Setting SUPPORTDIR property to:  C:\Users\JRYAN-~1\AppData\Local\Temp\{92C34178-B679-4C83-AC33-7EFCE6D36E01}
            MSI (c) (34!90) [07:37:34:269]: PROPERTY CHANGE: Adding SUPPORTDIR property. Its value is 'C:\Users\JRYAN-~1\AppData\Local\Temp\{92C34178-B679-4C83-AC33-7EFCE6D36E01}'.
            MSI (c) (34!90) [07:37:34:269]: PROPERTY CHANGE: Adding ISSETUPFILESCOMPLETED property. Its value is 'Completed'.
            1: Setting ISSETUPFILESCOMPLETED property
            Action ended 7:37:34: ISSetupFilesExtract. Return value 1.
            MSI (c) (34:CC) [07:37:34:272]: Doing action: ISSetAllUsers
            Action 7:37:34: ISSetAllUsers.
            Action start 7:37:34: ISSetAllUsers.
            MSI (c) (34:CC) [07:37:34:272]: Transforming table CustomAction.
            MSI (c) (34:18) [07:37:34:276]: Invoking remote custom action. DLL: C:\Users\JRYAN-~1\AppData\Local\Temp\MSI3C0D.tmp, Entrypoint: SetAllUsers
            InstallShield 7:37:34: Begin SetAllUsers()
            InstallShield 7:37:34: Getting records from Upgrade table
            InstallShield 7:37:34: UpgradeCode: {42463807-970B-4257-BC95-5C348D61DF1C} MinVersion: 6.0.0.0 MaxVersion: 21.0.0.182 Language: Attributes: 769
            InstallShield 7:37:34: Checking related product {92C34178-B679-4C83-AC33-7EFCE6D36E01}
            InstallShield 7:37:34: Adobe Flash Player 21 ActiveX {92C34178-B679-4C83-AC33-7EFCE6D36E01} 1033 ***Related***
            MSI (c) (34!C0) [07:37:34:285]: PROPERTY CHANGE: Adding IS_MAJOR_UPGRADE property. Its value is 'Yes'.
            InstallShield 7:37:34: ALLUSERS of related product {92C34178-B679-4C83-AC33-7EFCE6D36E01} is = 1
            InstallShield 7:37:34: End SetAllUsers()
            Action ended 7:37:34: ISSetAllUsers. Return value 1.
            MSI (c) (34:CC) [07:37:34:288]: Doing action: AppSearch
            Action 7:37:34: AppSearch. Searching for installed applications
            Action start 7:37:34: AppSearch.
            AppSearch: Property: PREVIOUS_VERSION, Signature: NewSignature1
            MSI (c) (34:CC) [07:37:34:289]: Note: 1: 2262 2: Signature 3: -2147287038
            MSI (c) (34:CC) [07:37:34:289]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Macromedia\FlashPlayerActiveX 3: 2
            Action ended 7:37:34: AppSearch. Return value 1.
            MSI (c) (34:CC) [07:37:34:289]: Doing action: LaunchConditions
            Action 7:37:34: LaunchConditions. Evaluating launch conditions
            Action start 7:37:34: LaunchConditions.
            Action ended 7:37:34: LaunchConditions. Return value 1.
            MSI (c) (34:CC) [07:37:34:290]: Doing action: SetupInitialization
            Action 7:37:34: SetupInitialization.
            Action start 7:37:34: SetupInitialization.
            MSI (c) (34:CC) [07:37:34:290]: Transforming table CustomAction.
            Info 2898.For Tahoma8 textstyle, the system created a 'Tahoma' font, in 0 character set.
            Info 2898.For TahomaBold10 textstyle, the system created a 'Tahoma' font, in 0 character set.
            Action 7:37:34: SetupInitialization. Dialog created
            Action ended 7:37:34: SetupInitialization. Return value 1.
            MSI (c) (34:CC) [07:37:34:320]: Doing action: FindRelatedProducts
            Action 7:37:34: FindRelatedProducts. Searching for related applications
            Action start 7:37:34: FindRelatedProducts.
            Action ended 7:37:34: FindRelatedProducts. Return value 1.
            MSI (c) (34:CC) [07:37:34:322]: Skipping action: CCPSearch (condition is false)
            MSI (c) (34:CC) [07:37:34:322]: Skipping action: RMCCPSearch (condition is false)
            MSI (c) (34:CC) [07:37:34:322]: Doing action: ValidateProductID
            Action 7:37:34: ValidateProductID.
            Action start 7:37:34: ValidateProductID.
            Action ended 7:37:34: ValidateProductID. Return value 1.
            MSI (c) (34:CC) [07:37:34:323]: Doing action: CostInitialize
            Action 7:37:34: CostInitialize. Computing space requirements
            Action start 7:37:34: CostInitialize.
            MSI (c) (34:CC) [07:37:34:324]: Machine policy value 'MaxPatchCacheSize' is 10
            MSI (c) (34:CC) [07:37:34:325]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
            MSI (c) (34:CC) [07:37:34:325]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
            MSI (c) (34:CC) [07:37:34:325]: Transforming table FeatureComponents.
            Action ended 7:37:34: CostInitialize. Return value 1.
            MSI (c) (34:CC) [07:37:34:325]: Doing action: FileCost
            Action 7:37:34: FileCost. Computing space requirements
            Action start 7:37:34: FileCost.
            MSI (c) (34:CC) [07:37:34:326]: Note: 1: 2205 2:  3: MsiAssembly
            MSI (c) (34:CC) [07:37:34:326]: Note: 1: 2205 2:  3: Registry
            MSI (c) (34:CC) [07:37:34:326]: Note: 1: 2205 2:  3: Class
            MSI (c) (34:CC) [07:37:34:326]: Note: 1: 2205 2:  3: Extension
            MSI (c) (34:CC) [07:37:34:326]: Note: 1: 2205 2:  3: TypeLib
            Action ended 7:37:34: FileCost. Return value 1.
            MSI (c) (34:CC) [07:37:34:326]: Doing action: IsolateComponents
            Action 7:37:34: IsolateComponents.
            Action start 7:37:34: IsolateComponents.
            Action ended 7:37:34: IsolateComponents. Return value 0.
            MSI (c) (34:CC) [07:37:34:327]: Doing action: setUserProfileNT
            Action 7:37:34: setUserProfileNT.
            Action start 7:37:34: setUserProfileNT.
            MSI (c) (34:CC) [07:37:34:328]: Transforming table CustomAction.
            MSI (c) (34:CC) [07:37:34:328]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\jryan-admin'.
            Action ended 7:37:34: setUserProfileNT. Return value 1.
            MSI (c) (34:CC) [07:37:34:328]: Skipping action: SetAllUsersProfileNT (condition is false)
            MSI (c) (34:CC) [07:37:34:328]: Doing action: setAllUsersProfile2K
            Action 7:37:34: setAllUsersProfile2K.
            Action start 7:37:34: setAllUsersProfile2K.
            MSI (c) (34:CC) [07:37:34:328]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData'.
            Action ended 7:37:34: setAllUsersProfile2K. Return value 1.
            MSI (c) (34:CC) [07:37:34:329]: Doing action: ResolveSource
            Action 7:37:34: ResolveSource.
            Action start 7:37:34: ResolveSource.
            MSI (c) (34:CC) [07:37:34:329]: Resolving source.
            MSI (c) (34:CC) [07:37:34:329]: Resolving source to launched-from source.
            MSI (c) (34:CC) [07:37:34:329]: Setting launched-from source as last-used.
            MSI (c) (34:CC) [07:37:34:329]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{92C34178-B679-4C83-AC33-7EFCE6D36E01}'.
            MSI (c) (34:CC) [07:37:34:329]: SOURCEDIR ==> C:\WINDOWS\ccmcache\5b\
            MSI (c) (34:CC) [07:37:34:329]: SOURCEDIR product ==> {92C34178-B679-4C83-AC33-7EFCE6D36E01}
            MSI (c) (34:CC) [07:37:34:329]: Determining source type
            MSI (c) (34:CC) [07:37:34:330]: Source type from package 'install_flash_player_21_active_x.msi': 0
            MSI (c) (34:CC) [07:37:34:331]: Source path resolution complete. Dumping Directory table...
            MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: TARGETDIR , Object: C:\WINDOWS\ccmcache\5b\ , LongSubPath: , ShortSubPath:
            MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: USERPROFILE , Object: C:\WINDOWS\ccmcache\5b\UserProfile\ , LongSubPath: UserProfile\ , ShortSubPath: USERPR~1\
            MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: TempFolder , Object: C:\WINDOWS\ccmcache\5b\Temp\ , LongSubPath: Temp\ , ShortSubPath:
            MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: SystemFolder , Object: C:\WINDOWS\ccmcache\5b\System32\ , LongSubPath: System32\ , ShortSubPath:
            MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: MACROMED , Object: C:\WINDOWS\ccmcache\5b\System32\Macromed\ , LongSubPath: System32\Macromed\ , ShortSubPath:
            MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: FLASH , Object: C:\WINDOWS\ccmcache\5b\System32\Macromed\Flash\ , LongSubPath: System32\Macromed\Flash\ , ShortSubPath:
            MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: INSTALLDIR , Object: C:\WINDOWS\ccmcache\5b\System32\Macromed\Flash\ , LongSubPath: System32\Macromed\Flash\ , ShortSubPath:
            MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: CommonFilesFolder , Object: C:\WINDOWS\ccmcache\5b\Common\ , LongSubPath: Common\ , ShortSubPath:
            MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: ISCommonFilesFolder , Object: C:\WINDOWS\ccmcache\5b\Common\InstallShield\ , LongSubPath: Common\InstallShield\ , ShortSubPath: Common\Instal~1\
            MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: ISUpdateServiceFolder , Object: C:\WINDOWS\ccmcache\5b\Common\InstallShield\UpdateService\ , LongSubPath: Common\InstallShield\UpdateService\ , ShortSubPath: Common\Instal~1\UPDATE~1\
            MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: ALLUSERSPROFILE , Object: C:\WINDOWS\ccmcache\5b\All Users\ , LongSubPath: All Users\ , ShortSubPath: ALLUSE~1\
            Action ended 7:37:34: ResolveSource. Return value 1.
            MSI (c) (34:CC) [07:37:34:331]: Doing action: CostFinalize
            Action 7:37:34: CostFinalize. Computing space requirements
            Action start 7:37:34: CostFinalize.
            MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
            MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
            MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
            MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
            MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
            MSI (c) (34:CC) [07:37:34:332]: Note: 1: 2262 2: Patch 3: -2147287038
            MSI (c) (34:CC) [07:37:34:332]: Note: 1: 2205 2:  3: Condition
            MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
            MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Modifying USERPROFILE property. Its current value is 'C:\Users\jryan-admin'. Its new value: 'C:\Users\jryan-admin\'.
            MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding MACROMED property. Its value is 'C:\WINDOWS\SysWOW64\Macromed\'.
            MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding FLASH property. Its value is 'C:\WINDOWS\SysWOW64\Macromed\Flash\'.
            MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\WINDOWS\SysWOW64\Macromed\Flash\'.
            MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
            MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
            MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Modifying ALLUSERSPROFILE property. Its current value is 'C:\ProgramData'. Its new value: 'C:\ProgramData\'.
            MSI (c) (34:CC) [07:37:34:332]: Target path resolution complete. Dumping Directory table...
            MSI (c) (34:CC) [07:37:34:332]: Note: target paths subject to change (via custom actions or browsing)
            MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: TARGETDIR , Object: C:\
            MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: USERPROFILE , Object: C:\Users\jryan-admin\
            MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: TempFolder , Object: C:\Users\JRYAN-~1\AppData\Local\Temp\
            MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: SystemFolder , Object: C:\WINDOWS\SysWOW64\
            MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: MACROMED , Object: C:\WINDOWS\SysWOW64\Macromed\
            MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: FLASH , Object: C:\WINDOWS\SysWOW64\Macromed\Flash\
            MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: INSTALLDIR , Object: C:\WINDOWS\SysWOW64\Macromed\Flash\
            MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files (x86)\Common Files\
            MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: ISCommonFilesFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\
            MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: ISUpdateServiceFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
            MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: ALLUSERSPROFILE , Object: C:\ProgramData\
            MSI (c) (34:CC) [07:37:34:332]: Note: 1: 2205 2:  3: MsiAssembly
            MSI (c) (34:CC) [07:37:34:332]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
            MSI (c) (34:CC) [07:37:34:332]: Note: 1: 2727 2: Flash
            Info 2835.The control ErrorIcon was not found on dialog SetupError.
            Error 2727.The directory entry 'Flash' does not exist in the Directory table.
            MSI (c) (34:CC) [07:37:39:113]: Product: Adobe Flash Player 21 ActiveX -- Error 2727.The directory entry 'Flash' does not exist in the Directory table.
            Action ended 7:37:39: CostFinalize. Return value 3.
            MSI (c) (34:CC) [07:37:39:114]: Doing action: SetupCompleteError
            Action 7:37:39: SetupCompleteError.
            Action start 7:37:39: SetupCompleteError.
            MSI (c) (34:CC) [07:37:39:115]: Transforming table CustomAction.
            Action 7:37:39: SetupCompleteError. Dialog created
            MSI (c) (34:B0) [07:37:39:127]: Note: 1: 2731 2: 0
            MSI (c) (34:90) [07:37:40:247]: Doing action: ISSetupFilesCleanup
            Action 7:37:40: ISSetupFilesCleanup.
            Action start 7:37:40: ISSetupFilesCleanup.
            MSI (c) (34:90) [07:37:40:247]: Transforming table CustomAction.
            MSI (c) (34:B8) [07:37:40:251]: Invoking remote custom action. DLL: C:\Users\JRYAN-~1\AppData\Local\Temp\MSI5365.tmp, Entrypoint: SFCleanupEx
            Action ended 7:37:40: ISSetupFilesCleanup. Return value 1.
            Action ended 7:37:40: SetupCompleteError. Return value 2.
            Action ended 7:37:40: INSTALL. Return value 3.
            MSI (c) (34:CC) [07:37:40:307]: Destroying RemoteAPI object.
            MSI (c) (34:80) [07:37:40:308]: Custom Action Manager thread ending.
            Property(C): DiskPrompt = [1]
            Property(C): UpgradeCode = {42463807-970B-4257-BC95-5C348D61DF1C}
            Property(C): ProductCode = {92C34178-B679-4C83-AC33-7EFCE6D36E01}
            Property(C): PrimaryVolumeSpaceRemaining = 0
            Property(C): PrimaryVolumeSpaceRequired = 0
            Property(C): PrimaryVolumeSpaceAvailable = 0
            Property(C): OutOfNoRbDiskSpace = 0
            Property(C): OutOfDiskSpace = 0
            Property(C): SourcedirProduct = {92C34178-B679-4C83-AC33-7EFCE6D36E01}
            Property(C): VersionNT = 601
            Property(C): TARGETDIR = C:\
            Property(C): ALLUSERSPROFILE = C:\ProgramData\
            Property(C): CommonFilesFolder = C:\Program Files (x86)\Common Files\
            Property(C): MACROMED = C:\WINDOWS\SysWOW64\Macromed\
            Property(C): FLASH = C:\WINDOWS\SysWOW64\Macromed\Flash\
            Property(C): INSTALLDIR = C:\WINDOWS\SysWOW64\Macromed\Flash\
            Property(C): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
            Property(C): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
            Property(C): CostingComplete = 0
            Property(C): SystemFolder = C:\WINDOWS\SysWOW64\
            Property(C): ROOTDRIVE = C:\
            Property(C): SourceDir = C:\WINDOWS\ccmcache\5b\
            Property(C): TempFolder = C:\Users\JRYAN-~1\AppData\Local\Temp\
            Property(C): USERPROFILE = C:\Users\jryan-admin\
            Property(C): IS_MAJOR_UPGRADE = Yes
            Property(C): ISSETUPFILESCOMPLETED = Completed
            Property(C): EXECUTEACTION = INSTALL
            Property(C): ACTION = INSTALL
            Property(C): UILevel = 5
            Property(C): VersionHandler = 5.00
            Property(C): SOURCEDIR = C:\WINDOWS\ccmcache\5b\
            Property(C): OriginalDatabase = C:\WINDOWS\ccmcache\5b\install_flash_player_21_active_x.msi
            Property(C): DATABASE = C:\WINDOWS\ccmcache\5b\install_flash_player_21_active_x.msi
            Property(C): Privileged = 1
            Property(C): MsiRunningElevated = 1
            Property(C): RedirectedDllSupport = 2
            Property(C): MsiWin32AssemblySupport = 6.1.7601.17514
            Property(C): MsiNetAssemblySupport = 4.0.30319.1
            Property(C): Date = 3/15/2016
            Property(C): Time = 7:37:40
            Property(C): TTCSupport = 1
            Property(C): ColorBits = 32
            Property(C): TextInternalLeading = 3
            Property(C): PREVIOUS_VERSION = 0
            Property(C): ISCHECKFORPRODUCTUPDATES = 0
            Property(C): ApplicationUsers = AllUsers
            Property(C): AgreeToLicense = Yes
            Property(C): _IsMaintenance = Change
            Property(C): RestartManagerOption = CloseRestart
            Property(C): IS_SQLSERVER_USERNAME = sa
            Property(C): IS_SQLSERVER_AUTHENTICATION = 0
            Property(C): SetupType = Typical
            Property(C): _IsSetupTypeMin = Typical
            Property(C): Display_IsBitmapDlg = 1
            Property(C): ProductName = Adobe Flash Player 21 ActiveX
            Property(C): ALLUSERS = 1
            Property(C): ARPHELPLINK = http://www.adobe.com/go/flashplayer_support/
            Property(C): ARPNOMODIFY = 1
            Property(C): ARPPRODUCTICON = ARPPRODUCTICON.exe
            Property(C): ARPURLINFOABOUT = http://www.adobe.com
            Property(C): TextHeight = 16
            Property(C): ARPURLUPDATEINFO = http://www.adobe.com/go/getflashplayer
            Property(C): DWUSINTERVAL = 30
            Property(C): DWUSLINK = CECCA75FE9CBA098D9ACE02FFEDB978FBEECA78F69BBE0B8CE8BA7CFE97CF0AFCEBCE08FD9AC
            Property(C): DefaultUIFont = Tahoma8
            Property(C): DialogCaption = InstallShield for Windows Installer
            Property(C): DisplayNameCustom = Custom
            Property(C): BorderSide = 1
            Property(C): DisplayNameMinimal = Minimal
            Property(C): DisplayNameTypical = Typical
            Property(C): ErrorDialog = SetupError
            Property(C): INSTALLLEVEL = 100
            Property(C): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine.  If available, please run ISScript.msi, or contact your support personnel for further assistance.
            Property(C): ISVROOT_PORT_NO = 0
            Property(C): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
            Property(C): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
            Property(C): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
            Property(C): IS_PROGMSG_TEXTFILECHANGS_REPLACE = Replacing %s with %s in %s...
            Property(C): IS_PROGMSG_XML_COSTING = Costing XML files...
            Property(C): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
            Property(C): IS_PROGMSG_XML_FILES = Performing XML file changes...
            Property(C): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
            Property(C): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
            Property(C): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
            Property(C): InstallChoice = AR
            Property(C): Manufacturer = Adobe Systems Incorporated
            Property(C): MsiLogging = voicewarmupx
            Property(C): NewProperty2 = 0
            Property(C): NewProperty3 = 0
            Property(C): PIDTemplate = 12345<###-%%%%%%%>@@@@@
            Property(C): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
            Property(C): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
            Property(C): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
            Property(C): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
            Property(C): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
            Property(C): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
            Property(C): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
            Property(C): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
            Property(C): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
            Property(C): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
            Property(C): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
            Property(C): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
            Property(C): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
            Property(C): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
            Property(C): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
            Property(C): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
            Property(C): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
            Property(C): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
            Property(C): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
            Property(C): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
            Property(C): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
            Property(C): ProductID = none
            Property(C): ProductLanguage = 1033
            Property(C): ProductVersion = 21.0.0.182
            Property(C): ProgressType0 = install
            Property(C): ProgressType1 = Installing
            Property(C): ProgressType2 = installed
            Property(C): ProgressType3 = installs
            Property(C): RebootYesNo = No
            Property(C): ReinstallModeText = omus
            Property(C): SHOWLAUNCHPROGRAM = 0
            Property(C): SecureCustomProperties = INSTALLDIR;ISACTIONPROP1;ISACTIONPROP2;ISACTIONPROP3;PREVIOUS_VERSION;SUPPORTDIR
            Property(C): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_activeX.exe
            Property(C): SETUPEXENAME = setup.exe
            Property(C): SUPPORTDIR = C:\Users\JRYAN-~1\AppData\Local\Temp\{92C34178-B679-4C83-AC33-7EFCE6D36E01}
            Property(C): BorderTop = 1
            Property(C): CaptionHeight = 22
            Property(C): ScreenY = 1050
            Property(C): AdminUser = 1
            Property(C): ScreenX = 1680
            Property(C): SystemLanguageID = 1033
            Property(C): ComputerName = NYCWKSJRYAN2
            Property(C): UserLanguageID = 1033
            Property(C): UserSID = S-1-5-21-342624433-1998880279-1947940980-44069
            Property(C): LogonUser = jryan-admin
            Property(C): MsiTrueAdminUser = 1
            Property(C): VirtualMemory = 27181
            Property(C): PhysicalMemory = 16341
            Property(C): Intel = 6
            Property(C): Msix64 = 6
            Property(C): MsiAMD64 = 6
            Property(C): ShellAdvtSupport = 1
            Property(C): OLEAdvtSupport = 1
            Property(C): GPTSupport = 1
            Property(C): FontsFolder = C:\WINDOWS\Fonts\
            Property(C): DesktopFolder = C:\Users\Public\Desktop\
            Property(C): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
            Property(C): COMPANYNAME = Fortress Investment Group
            Property(C): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
            Property(C): USERNAME = Fortress Investment Group
            Property(C): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
            Property(C): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
            Property(C): MyPicturesFolder = C:\Users\jryan-admin\Pictures\
            Property(C): LocalAppDataFolder = C:\Users\jryan-admin\AppData\Local\
            Property(C): CommonAppDataFolder = C:\ProgramData\
            Property(C): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
            Property(C): SendToFolder = C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\SendTo\
            Property(C): RecentFolder = C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\Recent\
            Property(C): PrintHoodFolder = C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
            Property(C): PersonalFolder = C:\Users\jryan-admin\Documents\
            Property(C): NetHoodFolder = C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
            Property(C): FavoritesFolder = C:\Users\jryan-admin\Favorites\
            Property(C): AppDataFolder = C:\Users\jryan-admin\AppData\Roaming\
            Property(C): CommonFiles64Folder = C:\Program Files\Common Files\
            Property(C): ProgramFiles64Folder = C:\Program Files\
            Property(C): ProgramFilesFolder = C:\Program Files (x86)\
            Property(C): RemoteAdminTS = 1
            Property(C): System64Folder = C:\WINDOWS\system32\
            Property(C): WindowsVolume = C:\
            Property(C): WindowsFolder = C:\WINDOWS\
            Property(C): MsiNTProductType = 1
            Property(C): ServicePackLevelMinor = 0
            Property(C): ServicePackLevel = 1
            Property(C): WindowsBuild = 7601
            Property(C): VersionNT64 = 601
            Property(C): VersionMsi = 5.00
            Property(C): VersionDatabase = 110
            Property(C): PRODUCTLANGUAGE = 1033
            Property(C): MsiSystemRebootPending = 1
            Property(C): CLIENTUILEVEL = 0
            Property(C): CLIENTPROCESSID = 31796
            Property(C): ProductState = 1
            Property(C): TRANSFORMS = C:\WINDOWS\Installer\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\active.mst
            Property(C): PackageCode = {68B30DE0-0B6D-4EB9-BFC0-D3DC88FF7A37}
            Property(C): CURRENTDIRECTORY = C:\WINDOWS\system32
            Property(C): MsiLogFileLocation = C:\Users\jryan\Desktop\Flash 21\activex\msi.txt
            === Logging stopped: 3/15/2016  7:37:40 ===
            MSI (c) (34:CC) [07:37:40:323]: Grabbed execution mutex.
            MSI (c) (34:CC) [07:37:40:323]: Cleaning up uninstalled install packages, if any exist
            MSI (c) (34:CC) [07:37:40:325]: MainEngineThread is returning 1603
            === Verbose logging stopped: 3/15/2016  7:37:40 ===
            • 3. Re: Hello all, I am trying to upgrade flash player using the MSI but am getting error 2727. The directory entry Flash does not exist in the directory table. The applications previous install was done using SCCM with and MSI and MST. Now even a manual inst
              u561910 Level 1
              Hello, I realized the MST that was created with the MSI had a mistake in the component table, the row i had added had an incorrect Directory, changed from Flash to 1. I created a new MST, and any PC not touched by the previous MST works well. The only place it doesn't work is the PC that it was tested at, for that PC I ran the EXE but going forward hopefully I find out how that PC can be corrected.
              • 5. Re: Hello all, I am trying to upgrade flash player using the MSI but am getting error 2727. The directory entry Flash does not exist in the directory table. The applications previous install was done using SCCM with and MSI and MST. Now even a manual inst
                u561910 Level 1
                Yes, it would appear that way but the 2 PCs that i did push that MST to now cannot update using an msi so that "bad" mst somehow corrupted any future msi installs for Flash. The EXE worked ok.
