6 Replies Latest reply on Mar 18, 2016 6:22 AM by Obi-wan Kenobi
    Choose one paragraph style and apply 1(2) above and 1(2) bellow new paragraph styles...finished script...
    kajzica Level 1
      If someone need to apply paragraph styles before and after main paragraph here is the script.
      1. Select text
      2. Run script
      3. Choose main paragraph around which you want to apply new styles
      Tnx to Goran G...
      // NextAndBeforeParagraphStyle
      // Goran Grčić 2016
      // Imput Dialog
      var imputPragraphDialog = function () {
              var docStyles=myDoc.paragraphStyles
              var myDialog = app.dialogs.add({name:"Dialog"});
              with (myDialog.dialogColumns.add()){
                  with(borderPanels.add()){
                      with(dialogColumns.add()){
                          staticTexts.add({staticLabel:"2. Paragraph above main:"});
                          staticTexts.add({staticLabel:"1. Paragraph above main:"});
                          staticTexts.add({staticLabel:"Main paragraph:"});
                          staticTexts.add({staticLabel:"1. Paragraph bellow main:"});
                          staticTexts.add({staticLabel:"2. Paragraph bellow main:"});
                          var para2Above = dropdowns.add({stringList:docStyles.everyItem().name});
                          var para1Above = dropdowns.add({stringList:docStyles.everyItem().name});
                          var paraTarget = dropdowns.add({stringList:docStyles.everyItem().name});
                          var para1Below = dropdowns.add({stringList:docStyles.everyItem().name});
                          var para2Below = dropdowns.add({stringList:docStyles.everyItem().name});
              // if OK
              if (myDialog.show() == true) {
                  // validate if Target Paragraph is selected
                  if (paraTarget.selectedIndex==-1) throw 'Please, choose main paragraph'
                  var myConfig = {
                          para2Above: para2Above.selectedIndex,
                          para1Above: para1Above.selectedIndex,
                          paraTarget: paraTarget.selectedIndex,
                          para1Below: para1Below.selectedIndex,
                          para2Below: para2Below.selectedIndex
                  myDialog.destroy();
                  return myConfig;
              // if Cancel
              else return   {
                          para2Above: -1,
                          para1Above: -1,
                          paraTarget: -1,
                          para1Below: -1,
                          para2Below: -1
      // validate if TextFrame or Text is selected
      var validateSelection= function () {
          if (myDoc.selection.length==0)  throw 'Select some text'
          if ((myDoc.selection[0].parent.constructor.name!='Story') || (myDoc.selection[0].constructor.name=='InsertionPoint'))  throw 'Select some text'
      // create progressbar
      var myCreateProgressPanel = function (myMaximumValue, myProgressBarWidth){
          progressPanel = new Window('window', 'Progress');
          progressPanel.add ('progressbar', [12, 12, myProgressBarWidth, 24], 0, myMaximumValue);
          return progressPanel
      // main functon for finding Target Paragraph i style Paragraphs
      var findAndStyleParagraphs = function (myConfig) {
          var checkParaStyle = function (count) {
              switch (myParagraphs[count].appliedParagraphStyle.name) {
                  case myDoc.paragraphStyles[myConfig.paraTarget].name:
                     return false
                     break;
                  default:
                     return true
           // ----------------------------  FUNCTION PROGRAM ----------------------------------//
           var lenPara=myParagraphs.length;
           //create and shoe progressbar
           var myProgressPanel=myCreateProgressPanel(lenPara-1, 300)
           myProgressPanel.show()
           for (var i=0; i<lenPara; i++) {
               myProgressPanel.children[0].value = i
              if (myParagraphs[i].appliedParagraphStyle.name==myDoc.paragraphStyles[myConfig.paraTarget].n ame) {
                  if ((myConfig.para2Above!=-1)&&(i>1)&&(checkParaStyle(i-2))) myParagraphs[i-2].appliedParagraphStyle=myDoc.paragraphStyles[myConfig.para2Above];
                  if ((myConfig.para1Above!=-1) && (i>0)&&(checkParaStyle(i-1))) myParagraphs[i-1].appliedParagraphStyle=myDoc.paragraphStyles[myConfig.para1Above];
                  if ((myConfig.para1Below!=-1) && (i<lenPara-2)&&(checkParaStyle(i+1))) myParagraphs[i+1].appliedParagraphStyle=myDoc.paragraphStyles[myConfig.para1Below];
                  if ((myConfig.para2Below!=-1) && (i<lenPara-2)&&(checkParaStyle(i+2))) myParagraphs[i+2].appliedParagraphStyle=myDoc.paragraphStyles[myConfig.para2Below];
      // ----------------------------   MAIN PROGRAM ----------------------//
      try {
          var myDoc=app.activeDocument;
          validateSelection();
          var myConfig=imputPragraphDialog();
           var myParagraphs=myDoc.selection[0].paragraphs;
           findAndStyleParagraphs (myConfig);
         } catch (err) {
            alert (err)
