5 Replies Latest reply on Dec 30, 2008 8:46 AM by chemFlasher
    relative target path
      I just switched to Flash CS3 on the Mac (used to work on Flash MX for PC). When I click on the "insert target path" in the actions window, and then click on the radio button for "relative", I get what looks like a reference that begins with "this." followed by a path that looks like from the root down to the current child mc.
      If I choose the "absolute" radio button, I get pretty much the same path, except that the "this" is replaced by "_root."
      Am I just not setting preferences correctly? Is there something I'm missing.
      Thanks in advance.
        • 1. Re: relative target path
          A relative path is based on where you are at the moment, so the term "this." is a target reference for where you currently are. An absolute path is referred from the base of the file, which is the _root level that conayins all of the content.
          In your case, it would appear that you are in the _root when you are targeting, so switching between the two will only change "this" to "_root"
          • 2. relative target path
            chemFlasher Level 1
            Hi NedWeb, I'm sorry I didn't clarify. The situation I described happens whether I'm at Scene 1 or inside an mc. It happens whether I'm referring to a child of a parent mc or a child of the current mc.
            Is this a glitch in my particular software? Or am I missing a setting?
            • 3. Re: relative target path
              You said you "get pretty much the same path", which could be a different path. It will be easier to reconcile if you provide some actual target info for both cases in the different scenarios you mention.
              • 4. relative target path
                chemFlasher Level 1
                freezePoint is a mc placed within a frame in Scene 1. freezePoint has a frame in which mc called "macroView" is embedded. macroView in turn has a frame which has an mc called "particulate" and another mc called "solvent". So the insert target window would look something like this:
                In freezePoint, the playhead goes to a frame which requires macroView to move its playhead to a frame labeled "pourOut".
                Normally, I would use a relative target path like this: _this.macroView.gotoAndPlay("pourOut");
                But if I press on "insert target path" and navigate the window to macroView and click on that (with the relative radio button chosen), the suggested syntax is: this.freezePoint.macroView. If I choose absolute pathing, it gives me: _root.freezePoint.macroView . . . which is correct, but I don't want the absolute path.
                On the other hand, if I want the "particulate" mc to move the freezPoint playhead by one frame, I would normally type: _this._parent._parent.nextFrame();
                what I get instead is: this.freezePoint (with relative path) and _root.freezePoint (with absolute path)
                Worse, if I want to move a playhead of "solvent" (another mc in the same frame in macroView) from "particulate", I would normally type: this._parent.solvent.
                what I get when I navigate in the insert target path window to "solvent" from a frame in "particulate" is: this.freezePoint.macroView.solvent
                Seems to me the only difference clicking on the relative path button is to replace "_root" with "this".
                Thanks for your time so far. I really hope you (or someone here) can help me.
                • 5. Re: relative target path
                  chemFlasher Level 1
                  . . . so, am I the only one who's experienced this? :(
