2 Replies Latest reply on Apr 20, 2006 12:53 PM by weanderson
    help with strings
    weanderson
      I'm trying to push data from a series of combo boxes into an array. I name each box a1, a2, a3, a4, a5 and so on. I have been tring to create a for loop to check which boxes were selected and push the label name to an array. I created a varable ("combo") to dynamically change the name of the combo box I am checking, which displays the correct name, but the .selected and .label return undefined. Not sure what I have done wrong. Any help would be appreciated. Here is the code I am using.
      var AdditionInfo:Array = new Array();
      additional_btn.onPress = function () {
      for (i=1; i<9;i++){
      combo = "a"+i;
      combo.toString();
      trace ("combo: " +combo);
      trace ("combo select: " + combo.selected);
      trace ("combo Label"+i+": "+ combo.label);
      if (combo.selected == true) {
      AdditionInfo.push (combo.label);
      trace ("combo Label:" +combo.label);
      //_root.play ();
      Thanks in advance.
      ..W
        • 1. Re: help with strings
          Level 7
          weanderson,
          Because of those quotes, there, it looks like "combo" is a String
          variable.
          I'm pretty sure you're trying to reference a ComboBox instance when what
          you're actually referencing is a String instance. And the String class
          doesn't define .selected or .label properties.
          So far, we have an Array instance.
          Now, we have a function assigned to the onPress event of a button (or
          maybe a movie clip acting lik a button).
          > for (i=1; i<9;i++){
          for() loop, counting from 1 to 8 ...
          > combo = "a"+i;
          Now we're declaring a variable -- yup, a String instance -- with the
          value a1 (and later, a2, a3, etc.).
          > combo.toString();
          This line doesn't really do anything at all. Object.toString() doesn't
          affect the object at all, but merely returns a String message of some
          kind -- it's String-based "snapshot" of the contents of the object. But
          since you aren't doing anything with the return value, such as
          trace(combo.toString());, the return value doesn't go anywhere. You could
          drop this line altogether.
          Okay, this will show you a1, a2, and so on. But remember, these are
          Strings.
          This will show you the String.selected property of your particular
          String instance, combo. But there is no String.selected property, so you'll
          see undefined.
          Same here.
          This won't work either, for the same reason.
          > //_root.play ();
          What you need to do is resolve the String into an actual object
          reference. You can do this with the array access operator, [], according to
          the article here ...
          http://www.quip.net/blog/2006/flash/actionscript-20/reference-objects-dynamically
          David
          stiller (at) quip (dot) net
          Dev essays: http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: help with strings
            weanderson Level 1
            Thanks for the help. Datatypes are no longer my downfall (at least for now).
