• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How do I turn off the blue highlight that marks text not following paragraph styles?
New Here ,
Mar 15, 2016 Mar 15, 2016
I just updated InDesign CC and it is now highlighting text that doesn't follow an established paragraph style. How do I turn this feature off?
TOPICS
Performance
Views
32.7K
Translate
Translate
Report
Report
Community guidelines
community guidelines
correct answers 2 Correct answers
Community Expert , Mar 15, 2016 Mar 15, 2016
Beginning in 2015.3, you can now turn on a Style Override Highlighter button on the upper right corner of the Paragraph Styles and/or Character Styles panels. It appears in a bright aqua color. In the illustration below, italic formatting was added on top of a paragraph style.
Here's the rest of that article: http://indesignsecrets.com/indesign-cc-2015-3-update-brings-bug-fixes-small-improvements.php
Votes
Translate
Translate
I would recommend never to work with style overrides, as it causes always problems.
But you can turn it on/off in ther right upper corner with the [+]-symbol.
Votes
Translate
Translate
Community Expert ,
Votes
Translate
Translate
Report
Report
New Here ,
Oct 11, 2019 Oct 11, 2019
I have 5.5 and there is not plus sign to hit. How do I get rid of this annoyance?
Votes
Translate
Translate
Report
Report
New Here ,
Aug 02, 2021 Aug 02, 2021
I use CS 5.5 and needed to use a newer version of indesign to turn it off via the + sign.
My problem was using an existing layout that had the option turned on, then importing to CS5.5 where I couldn't turn it off.
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
New Here ,
Thanks so much. That worked. The reason I don't want the highlight on right now is because I'm designing a book cover and trying out a bunch of different looks. The blue highlight gets in the way of judging the design and the fonts. Once I've settled on a design, I'll set up the paragraph styles.
Votes
Translate
Translate
Report
Report
New Here ,
Aug 15, 2019 Aug 15, 2019
How to Remove Blue Highlighting in InDesign | 2019 - YouTube
I did a quick video on this because it was personally driving me nuts as well. I still don't know how I turned it on in the first place!
Votes
Translate
Translate
Report
Report
Community Expert ,
You can quickly turn the Style Overrides Highlighter (the swimming-pool green highlights) by clicking the + symbol in either the Paragraph or Character Styles panels.
It's a toggle, so turn it on and off whenever you need to.
|    Bevi Chagnon   |  Designer & Technologist for Accessible Documents
|    Classes & Books for Accessible InDesign, PDFs & MS Office |
Votes
Translate
Translate
Report
Report
Community Expert ,
Aug 16, 2019 Aug 16, 2019
This is typically such a mysterious indicator which users tend to just press and see if anything is happening. But with no stylistically overridden text (or at least in sight), you won't notice any of its function. And later on you suddenly see these blue stripes...
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
default3sl9140dtmn4 said:
"I use CS 5.5 and needed to use a newer version of indesign to turn it off via the + sign.
My problem was using an existing layout that had the option turned on, then importing to CS5.5 where I couldn't turn it off."
The story behind that story is:
Basically that feature with CC 2015.3 was already implemented before, but was never revealed to the user interface. Also with some differences in coloring. There is a script by Marc Autret for InDesign CS4 and above that exactly does this, it hides the style overrides when the feature is on and enables the visibility of the overrides when it is off: ShowHideLocalFormatting.jsx
Show Local Formatting in InDesign CS4/CS5
Marc Autret, May 10, 2010
https://www.indiscripts.com/post/2010/05/show-local-formatting-in-indesign-cs4
It's still working with the latest InDesign 2021 version 16.3.0. Just tested that.
Regards,
Uwe Laubender
( ACP )
Votes
Translate
Translate
Report
Report
