1 Reply Latest reply on Mar 16, 2016 5:13 AM by _Waylander_
    How to join lines.
    toymaker1 Level 1
      Could anyone show me how to join two lines created with the line tool in Animate CC so that there is a sharp point at the join. I am not sure to to do this.
      For example if I have two0 lines like this:
      I dont know how to join them so they look like this:
      Thanks for any tips on how to achieve this.
        • 1. Re: How to join lines.
          _Waylander_ Level 2
          Just make sure they are joined first, grab the point, and move it to insure that both lines move, if they do then they are actually attached. If not turn on Snap, from the View -> Snapping --> Snap to Objects. And drag one of the points to each other, you will feel it pull to the other point.
          All you need to do then is choose how they are joined from the Line Options panel.
          Change your Line ends to Sqaure, and the Join type to Mitre, and then adjust the miter to get the desired point you want.
