3 Replies Latest reply on Apr 21, 2006 5:42 AM by Newsgroup_User
    background music
    me000
      I'm trying to add some background music to a multimedia CV im making, but how can i get the music to keep playing when the user moves to a 'new page.' At the moment the music plays at the beginning then as soon as a button is pressed it stops.
      Thanks.
        • 1. Re: background music
          Level 7
          How are you activating the music? If you start it via Lingo, then it should
          continue to play regardless of whether you jump around the Score. So, in the frame
          where you want the music to start, you can write:
          on exitFrame
          puppetSound 1, "nameOfMusicMemeber"
          end
          The above will play 'nameOfMusicMemeber' in sound channel 1.
          If you've placed the sound in channel 1 or 2 in the Score, then simply stretch it
          over all the frames you want the sound to play. As long as there is no break in the
          sound sprite, it should not stop playing if you jump from one frame to another.
          If the above does not work, maybe it's something in he scripting of your button
          behavior. Let me know what the button behavior is specifying.
          I hope the above helps. Let me know if it solves your problem or if it persists.
          regards
          Dean
          Director Lecturer / Consultant
          http://www.fbe.unsw.edu.au/learning/director
          http://www.multimediacreative.com.au
          • 2. Re: background music
            me000 Level 1
            Thanks for the help. It plays for longer than before, but stops when i press some buttons. Is it maybe becuase i have sounds on those buttons?
            • 3. Re: background music
              Level 7
              It is most likely because of the button behavior that activates sound. What you should be doing is playing your background sound in one channel
              and the button sound in another. So, if you sound is in channel 1 of the Score, when you set the button behavior to play its sound, make sure it's
              in channel 2 or higher.
              I hope that is clear. Once again, let me know if it doesn't help you resolve the issue.
              regards
              Dean
