26 Replies Latest reply on Apr 28, 2016 10:17 AM by simonsaith
    My lightroom crashes after trying to open preferences
    jarmilaw37333836
      Hi all,
      I have a problem trying to open preferences which results in a crash and exit of lightroom.
      Changing the use autobahn setting to false in the preferences file as well as changing the number format setting in windows as proposed in another post is not helping or changing anything.
      Thank you all for your help.
        • 1. Re: My lightroom crashes after trying to open preferences
          Chetna Srivastava Adobe Employee
          Hi jarmilaw,
          Would suggest you to reset Lightroom Preferences and then, check : Resetting (or 'Trashing') the Lightroom Preferences file | Lightroom Forums
          If that does not help, could you please share the event viewer crash logs ? : Photoshop Elements Editor Help | How to Find Crash Logs on Windows
          Regards,
          Chetna
          • 2. Re: My lightroom crashes after trying to open preferences
            jarmilaw37333836 Level 1
            Hi Chetna,
            thanks for your answer:
            Yes I´ve checked with resetting the file, hitting ALT+SHIFT on restart. Lightroom starts correctly in initial mode (showing tips), preferences file is deleted from Lightroom Preferences folder but Lightroom again crashes.
            After crash preferences folder remains empty except the "Lightroom 6 Startup Preferences.agprefs" file.
            Please find below the error log:
            Protokollname: Application
            Quelle:        Application Error
            Datum:         17.03.2016 08:55:28
            Ereignis-ID:   1000
            Aufgabenkategorie:(100)
            Ebene:         Fehler
            Schlüsselwörter:Klassisch
            Benutzer:      Nicht zutreffend
            Computer:      WORKSTATION01
            Beschreibung:
            Name der fehlerhaften Anwendung: lightroom.exe, Version: 6.4.0.10, Zeitstempel: 0x56a2e8ef
            Name des fehlerhaften Moduls: KERNELBASE.dll, Version: 6.1.7601.19160, Zeitstempel: 0x56bcd73c
            Ausnahmecode: 0xe06d7363
            Fehleroffset: 0x000000000000965d
            ID des fehlerhaften Prozesses: 0x508
            Startzeit der fehlerhaften Anwendung: 0x01d180225632a20c
            Pfad der fehlerhaften Anwendung: C:\Program Files\Adobe\Adobe Lightroom\lightroom.exe
            Pfad des fehlerhaften Moduls: C:\Windows\system32\KERNELBASE.dll
            Berichtskennung: 9cd5d4fe-ec15-11e5-9d0e-74d02b982b4b
            Ereignis-XML:
            <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
              <System>
                <Provider Name="Application Error" />
                <EventID Qualifiers="0">1000</EventID>
                <Level>2</Level>
                <Task>100</Task>
                <Keywords>0x80000000000000</Keywords>
                <TimeCreated SystemTime="2016-03-17T07:55:28.000000000Z" />
                <EventRecordID>65848</EventRecordID>
                <Channel>Application</Channel>
                <Computer>WORKSTATION01</Computer>
                <Security />
              </System>
              <EventData>
                <Data>lightroom.exe</Data>
                <Data>6.4.0.10</Data>
                <Data>56a2e8ef</Data>
                <Data>KERNELBASE.dll</Data>
                <Data>6.1.7601.19160</Data>
                <Data>56bcd73c</Data>
                <Data>e06d7363</Data>
                <Data>000000000000965d</Data>
                <Data>508</Data>
                <Data>01d180225632a20c</Data>
                <Data>C:\Program Files\Adobe\Adobe Lightroom\lightroom.exe</Data>
                <Data>C:\Windows\system32\KERNELBASE.dll</Data>
                <Data>9cd5d4fe-ec15-11e5-9d0e-74d02b982b4b</Data>
              </EventData>
            </Event>
            Datum:         17.03.2016 08:54:02
            Ereignis-ID:   1000
            Ebene:         Fehler
            Beschreibung:
            ID des fehlerhaften Prozesses: 0x8ec
            Startzeit der fehlerhaften Anwendung: 0x01d180221767f3dd
            Berichtskennung: 6975d5aa-ec15-11e5-9d0e-74d02b982b4b
            Ereignis-XML:
              <System>
                <Level>2</Level>
                <Task>100</Task>
                <TimeCreated SystemTime="2016-03-17T07:54:02.000000000Z" />
                <EventRecordID>65846</EventRecordID>
                <Security />
              </System>
              <EventData>
                <Data>8ec</Data>
                <Data>01d180221767f3dd</Data>
                <Data>6975d5aa-ec15-11e5-9d0e-74d02b982b4b</Data>
              </EventData>
            </Event>
            • 3. Re: My lightroom crashes after trying to open preferences
              Please find below in addtion my system information:
              Version von Lightroom: 6.4 [ 1060496 ]
              Lizenz: Unbegrenzt
              Betriebssystem: Windows 7
              Version: 6.1
              Anwendungsarchitektur: x64
              Systemarchitektur: x64
              Anzahl logischer Prozessoren: 12
              Prozessorgeschwindigkeit: 4,1 GHz
              Integrierter Speicher: 65476,4 MB
              Für Lightroom verfügbarer phys. Speicher: 65476,4 MB
              Von Lightroom verwendeter phys. Speicher: 675,8 MB (1,0%)
              Von Lightroom verwendeter virtueller Speicher: 645,7 MB
              Cache-Speichergröße: 250,3 MB
              Maximale Anzahl Threads, die Camera Raw verwendet: 12
              Camera Raw SIMD-Optimierung: SSE2,AVX
              DPI-Einstellung des Systems: 96 DPI
              Desktop-Komposition aktiviert: Ja
              Monitore/Anzeigegeräte: 1) 1920x1200
              Eingabetypen: Multitouch: Nein, integrierte Toucheingabe: Nein, integrierter Stift: Nein, externe Toucheingabe: Nein, externer Stift: Nein, Tastatur: Nein
              Informationen zum Grafikprozessor:
              GeForce GTX 970/PCIe/SSE2
              Check OpenGL support: Passed
              Vendor: NVIDIA Corporation
              Version: 3.3.0 NVIDIA 361.91
              Renderer: GeForce GTX 970/PCIe/SSE2
              LanguageVersion: 3.30 NVIDIA via Cg compiler
              Anwendungsordner: C:\Program Files\Adobe\Adobe Lightroom
              Bibliothekspfad: D:\_LIGHTROOM_KATALOGE\Lightroom\Lightroom-2.lrcat
              Einstellungen-Ordner: C:\Users\ANDRE\AppData\Roaming\Adobe\Lightroom
              Installierte Zusatzmodule:
              1) Canon Tether-Zusatzmodul
              2) ColorChecker Passport
              3) Facebook
              4) Flickr
              5) HDR Efex Pro 2
              6) Leica Tether-Zusatzmodul
              7) Nikon Tether-Zusatzmodul
              Config.lua-Flags: None
              Adapter Nr. 1: Anbieter : 10de
                Gerät : 13c2
                Subsystem : 367a1458
                Version : a1
                Grafikspeicher : 4007
              AudioDeviceIOBlockSize: 1024
              AudioDeviceName: Lautsprecher (Realtek High Definition Audio)
              AudioDeviceNumberOfChannels: 2
              AudioDeviceSampleRate: 44100
              Build: LR5x102
              Direct2DEnabled: false
              GPUDevice: not available
              OGLEnabled: true
              • 4. Re: My lightroom crashes after trying to open preferences
                short update.
                Reinstallation of lightroom 6.0 worked as expected. preferences could be opened without issues.
                Upgrading to 6.4 and in a second test to 6.5 again produced crashes.
                Each time I have reset the preferences before performing my test.
                As grafic driver I was reinstalling an "old" version of the driver officially supported by the manifacturer and in a second set of tests the latest geforce nvidea driver 364.51 from 08.03.2016
                Everytime I receive the same error message produced in KERNELBASE.dll library.
                Looking forward to your help and feedback.
                Regards,
                André
                • 5. Re: My lightroom crashes after trying to open preferences
                  Thanks for the update.
                  Do you have any USB or any external device plugged in to your machine?
                  If yes, unplug it and then, relaunch Lightroom and check.
                  That should probably help.
                  • 6. Re: My lightroom crashes after trying to open preferences
                    Hi Chetna,
                    i have deplugged everything despite my mouse, restarted lightroom and still have the same issue.
                    Also after deleting/resetting the preferences.
                    • 7. Re: My lightroom crashes after trying to open preferences
                      simonsaith Adobe Employee
                      The issue is fixed in Lr 6.5.
                      A new behavior has been implemented in Lr 6.5. Whenever there is a GPU crash due to the GPU driver like this, Lr would just turn off the GPU acceleration preference automatically. Once you got a working GPU driver installed, you can try to manually turn GPU acceleration preference back on.
                      If you reset the user preferences without actually installing a working GPU driver, it will crash in the next launch (only once, not repeatedly as it used to until you reset the preference again). If possible, you need to take action to talk to your GPU vendors to get an updated driver that works with Lightroom.
                      • 8. Re: My lightroom crashes after trying to open preferences
                        Hi Simon,
                        your answer really does not help.
                        If you are following my answers I have tried using LR 6.5 with several different graphic driver versions. All caused a crash.
                        Everytime when testing I have reinstalled Lightroom 6 beginning with version 6.0. - The preferences showd up correctly with every version of the graphic driver.
                        Upgrading to 6.4 and 6.5 cuased the crashes while trying to open the preferences.
                        I am not using a very specialiced Graphics Card. It is a standard Gigabyte Geforce card which never caused any issues in former Lightroom versions, and as said ALL driver versions over the last months including the newest version work perfectly except LR 6.4 and LR 6.5.
                        Graphic Card manifacturer are not producing their drivers nort cards for specific programs. You should know that it is the other way round, meaning your tools, like LR are using libraries from graphic cards for calculations etc. I am sorry but your proposal to contact them to get a Lightroom working driver version seems for me like a joke. In addition if you think it is graphic card related then I really want to understand why deactivating the graphic card support in the settings is still causing crahses. Could you please be so kind and explain me this point?
                        One additional information: Adobe Photoshop is also running without any issues and with every driver version I have installed so far.
                        As already discused with Chetna via private chat I would really appreciate if my topic can be brought up as a support case with Adobe. I am really disappointed with the way my request is currently handled. I am from my business perspective dependant on a working version of Lightroom. Currently I have a version installed where I cannot change any preferences like export settings, etc.
                        Attached the system info if they might bring any value to this discussion.
                        Version: 3.3.0 NVIDIA 364.51
                        Regards,
                        André
                        • 9. Re: My lightroom crashes after trying to open preferences
                          squeezy
                          I have exactly the same problem as André and like him I am disappointed at Adobe's responses.
                          I have been running Lightroom since version 4 with no problems until 6.4 and now 6.5.  My graphics card is an AMD 7770 made by AMD and all my drivers etc are up to date.
                          David
                          • 10. Re: My lightroom crashes after trying to open preferences
                            Hi André,
                            Are you able to run Photoshop with the latest Adobe Camera Raw 9.5 by opening a raw file? If you go to the Adobe Camera Raw preferences dialog, is the GPU acceleration enabled there? What happens if you try to enable it?
                            On this issue, if you launch Lr 6.5 and then go to the develop module. Quit Lr without visiting the preferences menu.
                            Then relaunch Lr 6.5, then go to the preference menu, does Lr crash?
                            • 12. Re: My lightroom crashes after trying to open preferences
                              squeezy Level 1
                              My PC is running Windows 10 at the current supported level with all updates.
                              I have tried the suggested re start after closing in Develop mode but no change.
                              André is using Windows 7.1 with an Nvidia card and I am using Windows 10 with an AMD card.  We both have the same error so it must be Lightroom at fault, V6.4 and 6.5.
                              May be you could end the details required for the registry changes to allow us to make a MiniDump for you to study?
                              Regards,
                              Dave
                              • 13. Re: My lightroom crashes after trying to open preferences
                                Hi Simon, hi Dave
                                @Dave: Thanks for providing my PC details to Simon.
                                Regarding the proposal to go to develop > exit lightroom > restart > preferences: Lightroom again crashes on my PC.
                                Camera Raw (via Photoshop) is not giving me any error so far. I am using Photoshop CS6. I´ve tried running the 32bit as well as the 64bit version.
                                I am fully with Dave regarding his proposal to provide you with more details enabling you to maybe better understand what is going on on our systems.
                                Looking forward to your feedback.
                                Best regards,
                                André
                                • 14. Re: My lightroom crashes after trying to open preferences
                                  Thanks. Please follow this https://support.microsoft.com/en-us/kb/931673 Microsoft Windows instructions to create the mini dump file and share the file somewhere for me to investigate.
                                  • 15. Re: My lightroom crashes after trying to open preferences
                                    Also, can you follow the "Manually disable the graphics processor" steps in Adobe Lightroom GPU Troubleshooting and FAQ to see if it helps?
                                    • 16. Re: My lightroom crashes after trying to open preferences
                                      squeezy Level 1
                                      Hi Simon,
                                      we have both tried the disabling (autobahn) but to no avail.
                                      I have made a minidump but it may not tell the whole story as I had to start the dump then switch to lightroom/preferences before the dump had completed.   Have read loads about dumps/crashes etc so I ended up using AdPlus to create a full crash dump (900mb) Link to my Dropbox is: Dropbox - Adobe Lightroom Crash Dumps  lightroom.exe.14108.dmp is the mini dump and the other two folders contain the large dump (I think)
                                      Hope these help but if you need something else let me know.
                                      Kind regards,
                                      Dave
                                      • 17. Re: My lightroom crashes after trying to open preferences
                                        Ok. If the manual autobahn fix isn't doing it for you, then the crash is due to a separate reason that I am not aware of. Looking at the dump file now.
                                        • 18. Re: My lightroom crashes after trying to open preferences
                                          Thanks for the dump file that you uploaded. It gives me an idea on the nature of the issue. It might be related to one crash bug that we fixed on the Mac for the next update. That fix might also address this Windows issue as well. I am double-checking with my colleague.
                                          In the meantime, if you can follow the instructions at Lightroom -traceback debugging tip to provide with me the traceback logs. That will help me ascertain the the issue.
                                          • 19. Re: My lightroom crashes after trying to open preferences
                                            Hi Simon,
                                            please find my log report attached/below:
                                            00000001    0.00000000    [5828] L:
                                            00000002    0.00001489    [5828] [string "unarchived table s"]:1: unexpected symbol near 'Î'
                                            00000003    0.00001489    [5828]     0: global   loadstring                     - C
                                            00000004    0.00001489    [5828]     1:          [unnamed]                      - 214868927:1005+8
                                            00000005    0.00001489    [5828]     2: global   pcall                          - C
                                            00000006    0.00001489    [5828]     3: method   makeFileIntoItem               - 375650273:1214+42
                                            00000007    0.00001489    [5828]     4: upvalue  ?                              - 375650273:2704+123
                                            00000008    0.00001489    [5828]     5:          [unnamed]                      - 375650273:2888+98
                                            00000009    0.00001489    [5828]     6: method   scanTemplateDirectories        - 375650273:2534+128
                                            00000010    0.00001489    [5828]     7: upvalue  ?                              - 375650273:3381+68
                                            00000011    0.00001489    [5828]     8: field    makeFileDataModel              - 378055297:848+31
                                            00000012    0.00001489    [5828]     9: field    developPresetsData             - 2123590181:1133+155
                                            00000013    0.00001489    [5828]    10: field    makeDevelopPresetPopupMenuItems - 2123590181:2700+3
                                            00000014    0.00001489    [5828]    11:          [unnamed]                      - 921957638:3621+7
                                            00000015    0.00001489    [5828]    12:          [unnamed]                      - 921957638:0+1217
                                            00000016    0.00001489    [5828]    13: field    require                        - C
                                            00000017    0.00001489    [5828]    14: upvalue  ?                              - 1386750763:1490+27
                                            00000018    0.00001489    [5828]    15:          [unnamed]                      - 1386750763:1519+36
                                            00000019    0.00001489    [5828]    16: global   pcall                          - C
                                            00000020    0.00001489    [5828]    17:          [unnamed]                      - 728037825:242+52
                                            00000021    0.00001489    [5828]    18:          [unnamed]                      - tail
                                            00000022    0.00001489    [5828]    19:          [unnamed]                      - 728037825:363+3
                                            00000023    0.00001489    [5828]    20:          [unnamed]                      - tail
                                            00000024    0.00001489    [5828]    21: upvalue  ?                              - 241623741:1195+3
                                            00000025    0.00001489    [5828]    22: upvalue  ?                              - 241623741:1242+67
                                            00000026    0.00001489    [5828]    23: upvalue  ?                              - 241623741:1537+102
                                            00000027    0.00001489    [5828]    24:          [unnamed]                      - 241623741:1958+3
                                            00000028    0.00001489    [5828] ---------------------------------
                                            00000029    0.00013132    [5828]
                                            00000030    1.45753896    [5828] AgMessageProcessor :: request DEBUG sending observable request( userdata: 0000000016442E08, "setProxyCredentials", "", "" )
                                            00000031    1.45755136    [5828]
                                            00000032    2.60079050    [5828] L:
                                            00000033    2.60080290    [5828] maybeAssignLayoutAttributeL had an unhandled key: margin_right
                                            00000034    2.60081339    [5828]
                                            00000035    23.09368324    [5828] WFHttpClientImp:: Error occured >
                                            00000036    23.09370041    [5828] Die Serververbindung konnte nicht hergestellt werden.
                                            00000037    23.09371376    [5828]
                                            00000038    25.09575653    [5828] L:
                                            00000039    25.09576988    [5828] bad argument #1 to 'stringByAppendingPathComponent' (string expected, got nil)
                                            00000040    25.09576988    [5828]     0: field    stringByAppendingPathComponent - C
                                            00000041    25.09576988    [5828]     1:          [unnamed]                      - 331058959:978+38
                                            00000042    25.09576988    [5828] ---------------------------------
                                            00000043    25.09578323    [5828]
                                            Best regards,
                                            André
                                            • 20. Re: My lightroom crashes after trying to open preferences
                                              Second run:
                                              00000001    0.00000000    [6168] L:
                                              00000002    0.00001539    [6168] [string "unarchived table s"]:1: unexpected symbol near 'Î'
                                              00000003    0.00001539    [6168]     0: global   loadstring                     - C
                                              00000004    0.00001539    [6168]     1:          [unnamed]                      - 214868927:1005+8
                                              00000005    0.00001539    [6168]     2: global   pcall                          - C
                                              00000006    0.00001539    [6168]     3: method   makeFileIntoItem               - 375650273:1214+42
                                              00000007    0.00001539    [6168]     4: upvalue  ?                              - 375650273:2704+123
                                              00000008    0.00001539    [6168]     5:          [unnamed]                      - 375650273:2888+98
                                              00000009    0.00001539    [6168]     6: method   scanTemplateDirectories        - 375650273:2534+128
                                              00000010    0.00001539    [6168]     7: upvalue  ?                              - 375650273:3381+68
                                              00000011    0.00001539    [6168]     8: field    makeFileDataModel              - 378055297:848+31
                                              00000012    0.00001539    [6168]     9: field    developPresetsData             - 2123590181:1133+155
                                              00000013    0.00001539    [6168]    10: field    makeDevelopPresetPopupMenuItems - 2123590181:2700+3
                                              00000014    0.00001539    [6168]    11:          [unnamed]                      - 921957638:3621+7
                                              00000015    0.00001539    [6168]    12:          [unnamed]                      - 921957638:0+1217
                                              00000016    0.00001539    [6168]    13: field    require                        - C
                                              00000017    0.00001539    [6168]    14: upvalue  ?                              - 1386750763:1490+27
                                              00000018    0.00001539    [6168]    15:          [unnamed]                      - 1386750763:1519+36
                                              00000019    0.00001539    [6168]    16: global   pcall                          - C
                                              00000020    0.00001539    [6168]    17:          [unnamed]                      - 728037825:242+52
                                              00000021    0.00001539    [6168]    18:          [unnamed]                      - tail
                                              00000022    0.00001539    [6168]    19:          [unnamed]                      - 728037825:363+3
                                              00000023    0.00001539    [6168]    20:          [unnamed]                      - tail
                                              00000024    0.00001539    [6168]    21: upvalue  ?                              - 241623741:1195+3
                                              00000025    0.00001539    [6168]    22: upvalue  ?                              - 241623741:1242+67
                                              00000026    0.00001539    [6168]    23: upvalue  ?                              - 241623741:1537+102
                                              00000027    0.00001539    [6168]    24:          [unnamed]                      - 241623741:1958+3
                                              00000028    0.00001539    [6168] ---------------------------------
                                              00000029    0.00011916    [6168]
                                              00000030    0.90878177    [6168] AgMessageProcessor :: request DEBUG sending observable request( userdata: 00000000169E99F8, "setProxyCredentials", "", "" )
                                              00000031    0.90879416    [6168]
                                              00000032    1.88254619    [6168] L:
                                              00000033    1.88255799    [6168] maybeAssignLayoutAttributeL had an unhandled key: margin_right
                                              00000034    1.88256848    [6168]
                                              00000035    16.48221970    [6168] L:
                                              00000036    16.48223495    [6168] bad argument #1 to 'stringByAppendingPathComponent' (string expected, got nil)
                                              00000037    16.48223495    [6168]     0: field    stringByAppendingPathComponent - C
                                              00000038    16.48223495    [6168]     1:          [unnamed]                      - 331058959:978+38
                                              00000039    16.48223495    [6168] ---------------------------------
                                              00000040    16.48225212    [6168]
                                              • 21. Re: My lightroom crashes after trying to open preferences
                                                squeezy Level 1
                                                Hi Simon,
                                                I have added a DebugView folder with the report inside to Dropbox - Adobe Lightroom Crash Dumps
                                                Dave
                                                • 22. Re: My lightroom crashes after trying to open preferences
                                                  Thanks Guys. The trace back is very helpful.
                                                  In both @jarmilaw37333836 and @squeezy cases, Lightroom tries to retrieve the file system path to the "My Pictures" folder that is associated with your account on your local Windows machine and somehow it failed and could not retrieve the path.
                                                  Are there anything unique about your setup? After doing some googling, I found this Repair missing User folders in Windows 7 | Scottie's Tech.Info that might be helpful.
                                                  • 23. Re: My lightroom crashes after trying to open preferences
                                                    squeezy Level 1
                                                    !Hi Simon,
                                                    thanks for that, you have solved my problem.  It is to do with the "My Pictures" folder, although W10 does not use the MY part, but uses Libraries.
                                                    I use an SSD for my C drive so I moved the actual folders in he libraries folder to an HDD disk, but without thinking I have removed that drive and set up the folder on a new HDD, drive D and it seems that it was not working correctly.  The Pictures folder was pointing to the now non existant folder.  I changed the path to my D:\photos and after it ran through a setup process all now works.
                                                    This could be a problem for other software.
                                                    Cannot find the CORRECT button for your answer....
                                                    Many thanks,
                                                    Dave
                                                    • 24. Re: My lightroom crashes after trying to open preferences
                                                      Thanks Dave for the confirmation. We were able to able to simulate the crash internally by removing the "My Pictures"/"Pictures" folder and consequently we also made a fix in Lr not to crash when such condition happens. The fix will be in the next Lr update. Sorry for the inconvenience.
                                                      • 25. Re: My lightroom crashes after trying to open preferences
                                                        squeezy Level 1
                                                        Thanks Simon for the prompt help in solving this.
                                                        • 26. Re: My lightroom crashes after trying to open preferences
                                                          This should be fixed in the Lightroom CC 2015.5.1/6.5.1 update that was released today: http://blogs.adobe.com/lightroomjournal/2016/04/lightroom-cc-2015-5-1-now-available.html
